KPOP w supla-device
[email protected]
Has thanked: 18 times
Been thanked: 26 times
2. Zaktualizowałem kod w zainicjalizowanym urządzeniu. Efekt ten sam. Log poniżej:
15:38:39.128 > Creating OneWire bus for pin: 4
15:38:39.128 > Initializing OneWire bus at pin 4
15:38:39.159 > OneWire(pin 4) Parasite power is OFF
15:38:39.159 > OneWire(pin 4) Found 1 devices:
15:38:39.174 > Index 0 - address {0x28, 0x52, 0x29, 0xB5, 0x63, 0x20, 0x01, 0x9B}
15:38:39.882 > Device address not provided. Using device from index 0
15:38:39.882 > Channel(2) value changed to -1.00
15:38:39.882 > Channel[3] initial caption set to 'Natężenie światła'
15:38:39.882 > GPM[3]: DefaultUnitAfterValue "lx"
15:38:39.898 > Channel(4) value changed to -1.00
15:38:39.898 > Channel(5) value changed to -1
15:38:39.898 > Channel[7] initial caption set to 'PM 0.5'
15:38:39.898 > GPM[7]: DefaultUnitAfterValue "μg/m³"
15:38:39.898 > GPM[7]: RefreshIntervalMs 60000 ms
15:38:39.913 > LittleFS: writing file 7_gpm_common
15:38:39.976 > GPM[7]: common config saved successfully
15:38:39.992 > GPM[8]: DefaultUnitAfterValue "μg/m³"
15:38:39.992 > Channel[8] initial caption set to 'PM 1.0'
15:38:39.992 > GPM[8]: RefreshIntervalMs 60000 ms
15:38:39.992 > LittleFS: writing file 8_gpm_common
15:38:40.070 > GPM[8]: common config saved successfully
15:38:40.070 > GPM[9]: DefaultUnitAfterValue "μg/m³"
15:38:40.070 > Channel[9] initial caption set to 'PM 2.5'
15:38:40.085 > GPM[9]: RefreshIntervalMs 60000 ms
15:38:40.085 > LittleFS: writing file 9_gpm_common
15:38:40.167 > GPM[9]: common config saved successfully
15:38:40.167 > GPM[10]: DefaultUnitAfterValue "μg/m³"
15:38:40.167 > Channel[10] initial caption set to 'PM 4.0'
15:38:40.167 > GPM[10]: RefreshIntervalMs 60000 ms
15:38:40.181 > LittleFS: writing file 10_gpm_common
15:38:40.251 > GPM[10]: common config saved successfully
15:38:40.267 > GPM[11]: DefaultUnitAfterValue "μg/m³"
15:38:40.267 > Channel[11] initial caption set to 'PM 10.0'
15:38:40.267 > GPM[11]: RefreshIntervalMs 60000 ms
15:38:40.267 > LittleFS: writing file 11_gpm_common
15:38:40.351 > GPM[11]: common config saved successfully
15:38:40.366 > [  1255][E][Wire.cpp:381] setClock(): could not acquire lock
15:38:40.366 > Main storage not configured
15:38:40.366 > LittleFsConfig: init called on non empty database. Aborting
15:38:40.381 > [Main] setting config.
15:38:40.383 > Supla - starting initialization
15:38:40.386 > Main storage not configured
15:38:40.388 > Security level: Supla CA
15:38:40.390 > RemoteDeviceConfig: Registering field 0x00000010
15:38:40.390 > Clock: automaticTimeSync: 1
15:38:40.398 > Channel[0] temperature correction 0.000000
15:38:40.402 > Channel[0] humidity correction 0.000000
15:38:40.406 > Channel[1] temperature correction 0.000000
15:38:40.406 > Channel[1] humidity correction 0.000000
15:38:40.468 > GPM[3]: config loaded successfully
15:38:40.485 > GPM[3]: RefreshIntervalMs 5000 ms
15:38:40.549 > GPM[7]: config loaded successfully
15:38:40.552 > GPM[7]: RefreshIntervalMs 60000 ms
15:38:40.552 > Channel[7] config changed offline flag is set
15:38:40.603 > GPM[8]: config loaded successfully
15:38:40.618 > GPM[8]: RefreshIntervalMs 60000 ms
15:38:40.618 > Channel[8] config changed offline flag is set
15:38:40.672 > GPM[9]: config loaded successfully
15:38:40.672 > GPM[9]: RefreshIntervalMs 60000 ms
15:38:40.684 > Channel[9] config changed offline flag is set
15:38:40.737 > GPM[10]: config loaded successfully
15:38:40.739 > GPM[10]: RefreshIntervalMs 60000 ms
15:38:40.739 > Channel[10] config changed offline flag is set
15:38:40.789 > GPM[11]: config loaded successfully
15:38:40.798 > GPM[11]: RefreshIntervalMs 60000 ms
15:38:40.801 > Channel[11] config changed offline flag is set
15:38:40.822 > Channel(0) value changed to 27.06
15:38:40.834 > Manufacturer ID=0x5449
15:38:40.839 > Device ID=0x1050
15:38:40.855 > Device Serial Number=209-4618-6900
15:38:40.900 > Channel(1) value changed to temp(24.422913), humi(68.627930)
15:38:40.906 > Channel(2) value changed to 0.00
15:38:40.919 > MS5611 init.
15:38:40.919 > MS5611 found.
15:38:40.919 > MS5611 getting pres.
15:38:40.932 > Channel(4) value changed to temp(1011.954834), humi(-1.000000)
15:38:45.920 > Channel(5) value changed to 0.00
15:38:45.936 > Turning ON SPS sensor
15:38:45.987 > measurements started
15:38:45.989 > Channel(7) value changed to 0.00
15:38:45.990 > Channel(8) value changed to 0.10
15:38:45.990 > Channel(9) value changed to 551100288.47
15:38:45.990 > Channel(11) value changed to 2147483647.47
15:38:45.990 > GUID: 5937A923697E90D3482A30C7A796AF46
15:38:46.006 > Device name: SUPLA-ESP32
15:38:46.009 > Device software version: SDK 24.06.01-dev
15:38:46.009 > Initializing network layer
15:38:46.009 > [Wi-Fi] Network AP/hostname: SUPLA-ESP32-AC67B236E4B8
15:38:46.020 > Using Supla protocol version 23
15:38:46.021 > Current status: [5] SuplaDevice initialized
15:38:46.025 > Enter normal mode
15:38:46.027 > addClock: DEPRECATED
15:38:46.060 > Channel(3) value changed to 461.00
15:38:46.060 > WiFi: establishing connection with SSID: "Dom44A"
15:38:49.123 > MS5611 getting pres.
15:38:49.123 > Channel(4) value changed to 1012.13
15:38:54.128 > Speed: WiFi Station disconnected
15:38:59.133 > 0.00
15:38:59.134 > Channel(6) value changed to 18.60
15:38:59.134 > Wind direction: 18.60
15:38:59.156 > Channel(1) value changed to temp(24.443054), humi(68.627930)
15:38:59.163 > Channel(3) value changed to 454.00
15:38:59.166 > MS5611 getting pres.
15:39:04.150 > Speed: WiFi Station disconnected
15:39:07.015 > Connected BSSID: 32:DE:4B:9D:ED:DE
15:39:07.015 > local IP: 192.168.0.131
15:39:07.015 > subnetMask: 255.255.255.0
15:39:07.015 > gatewayIP: 192.168.0.1
15:39:07.015 > Signal strength (RSSI): -74 dBm
15:39:09.160 > 0.00
15:39:09.162 > Wind direction: 18.60
15:39:09.163 > Establishing encrypted connection with: svr85.supla.org (port: 2016)
15:39:10.499 > Connected via IP 192.168.0.131
15:39:10.502 > SSL error: 48, PADLOCK - Input data should be aligned
15:39:10.507 > LAST STATE ADDED: PADLOCK - Input data should be aligned (20)
15:39:10.512 > Connected to Supla Server
15:39:10.514 > Initializing SRPC (proto: 23)
15:39:10.517 > LAST STATE ADDED: Register in progress (20)
15:39:10.517 > Current status: [10] Register in progress
15:39:10.517 > Send: [53 55 50 4C 41 17 01 00 00 00 4B 00 00 00 EC 03 00 00 72 61 66 61 6C 65 6B 6B 61 6C 77 61 6B 40 77 70 2E 70 6C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F9 39 9D 7E 4E E6 6B 92 1E 18 BD 9A 39 B2 B2 0E 59 37 A9 23 69 7E 90 D3 48 2A 30 C7 A7 96 AF 46 53 55 50 4C 41 2D 45 53 50 33 32 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
15:39:10.614 > CH[0], type: 3034, FuncList: 0x0, function: 40, flags: 0x8010000, online, validityTimeSec: 0, icon: 0, value: [00 00 00 00 00 10 3b 40]
15:39:10.618 > Send: [00 DA 0B 00 00 00 00 00 00 28 00 00 00 00 00 01 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 3B 40 00 ]
15:39:10.634 > CH[1], type: 3038, FuncList: 0x0, function: 45, flags: 0x8010000, online, validityTimeSec: 0, icon: 0, value: [7b 5f 00 00 13 0c 01 00]
15:39:10.647 > Send: [01 DE 0B 00 00 00 00 00 00 2D 00 00 00 00 00 01 08 00 00 00 00 00 00 00 00 00 7B 5F 00 00 13 0C 01 00 00 ]
15:39:10.647 > CH[2], type: 3048, FuncList: 0x0, function: 270, flags: 0x10000, online, validityTimeSec: 0, icon: 0, value: [00 00 00 00 00 00 00 00]
15:39:10.666 > Send: [02 E8 0B 00 00 00 00 00 00 0E 01 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
15:39:10.679 > CH[3], type: 9000, FuncList: 0x0, function: 520, flags: 0x8010000, online, validityTimeSec: 0, icon: 0, value: [00 00 00 00 00 60 7c 40]
15:39:10.684 > Send: [03 28 23 00 00 00 00 00 00 08 02 00 00 00 00 01 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 7C 40 00 ]
15:39:10.700 > CH[4], type: 3044, FuncList: 0x0, function: 260, flags: 0x10000, online, validityTimeSec: 0, icon: 0, value: [00 00 00 c0 1a a1 8f 40]
15:39:10.714 > Send: [04 E4 0B 00 00 00 00 00 00 04 01 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 1A A1 8F 40 00 ]
15:39:10.718 > CH[5], type: 3042, FuncList: 0x0, function: 250, flags: 0x10000, online, validityTimeSec: 0, icon: 0, value: [00 00 00 00 00 00 00 00]
15:39:10.734 > Send: [05 E2 0B 00 00 00 00 00 00 FA 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
15:39:10.747 > CH[6], type: 3034, FuncList: 0x0, function: 40, flags: 0x10000, online, validityTimeSec: 0, icon: 0, value: [00 00 00 20 80 9a 32 40]
15:39:10.748 > Send: [06 DA 0B 00 00 00 00 00 00 28 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 20 80 9A 32 40 00 ]
15:39:10.767 > CH[7], type: 9000, FuncList: 0x0, function: 520, flags: 0x8010000, online, validityTimeSec: 0, icon: 0, value: [00 00 00 e0 81 35 6e 39]
15:39:10.780 > Send: [07 28 23 00 00 00 00 00 00 08 02 00 00 00 00 01 08 00 00 00 00 00 00 00 00 00 00 00 00 E0 81 35 6E 39 00 ]
15:39:10.784 > CH[8], type: 9000, FuncList: 0x0, function: 520, flags: 0x8010000, online, validityTimeSec: 0, icon: 0, value: [00 00 00 80 06 5e bb 3f]
15:39:10.800 > Send: [08 28 23 00 00 00 00 00 00 08 02 00 00 00 00 01 08 00 00 00 00 00 00 00 00 00 00 00 00 80 06 5E BB 3F 00 ]
15:39:10.813 > CH[9], type: 9000, FuncList: 0x0, function: 520, flags: 0x8010000, online, validityTimeSec: 0, icon: 0, value: [00 00 00 c0 8f 6c c0 41]
15:39:10.817 > Send: [09 28 23 00 00 00 00 00 00 08 02 00 00 00 00 01 08 00 00 00 00 00 00 00 00 00 00 00 00 C0 8F 6C C0 41 00 ]
15:39:10.835 > CH[10], type: 9000, FuncList: 0x0, function: 520, flags: 0x8010000, online, validityTimeSec: 0, icon: 0, value: [00 00 00 00 00 00 00 00]
15:39:10.847 > Send: [0A 28 23 00 00 00 00 00 00 08 02 00 00 00 00 01 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
15:39:10.847 > CH[11], type: 9000, FuncList: 0x0, function: 520, flags: 0x8010000, online, validityTimeSec: 0, icon: 0, value: [00 00 00 e0 6e 99 32 46]
15:39:10.867 > Send: [0B 28 23 00 00 00 00 00 00 08 02 00 00 00 00 01 08 00 00 00 00 00 00 00 00 00 00 00 00 E0 6E 99 32 46 00 ]
15:39:10.878 > Send: [53 55 50 4C 41 ]
15:39:10.897 > Channel(1) value changed to temp(24.453125), humi(68.627930)
15:39:10.902 > Channel(3) value changed to 413.00
15:39:10.902 > MS5611 getting pres.
15:39:10.902 > Channel(4) value changed to 1012.03
15:39:15.903 > Speed: 0.00
15:39:20.904 > Wind direction: 18.60
15:39:20.912 > Recv: [53 55 50 4C 41 17 01 00 00 00 46 00 00 00 07 00 00 00 03 00 00 00 78 18 01 53 55 50 4C 41 ]
15:39:20.921 > Device registered (activity timeout 120 s, server version: 24, server min version: 1)
15:39:20.928 > LAST STATE ADDED: Registered and ready (31)
15:39:20.932 > Current status: [17] Registered and ready
15:39:20.937 > Changing activity timeout to 30 s
15:39:20.939 > Send: [53 55 50 4C 41 17 02 00 00 00 D2 00 00 00 01 00 00 00 1E ]
15:39:20.944 > Send: [53 55 50 4C 41 ]
15:39:20.944 > Send: [53 55 50 4C 41 17 03 00 00 00 80 02 00 00 1E 00 00 00 03 00 00 00 16 00 00 00 4E 61 74 C4 99 C5 BC 65 6E 69 65 20 C5 9B 77 69 61 74 C5 82 61 00 ]
15:39:20.960 > Send: [53 55 50 4C 41 ]
15:39:20.962 > Send: [53 55 50 4C 41 17 04 00 00 00 80 02 00 00 0F 00 00 00 07 00 00 00 07 00 00 00 50 4D 20 30 2E 35 00 ]
15:39:20.973 > Send: [53 55 50 4C 41 ]
15:39:20.975 > Send: [53 55 50 4C 41 17 05 00 00 00 80 02 00 00 0F 00 00 00 08 00 00 00 07 00 00 00 50 4D 20 31 2E 30 00 ]
15:39:20.978 > Send: [53 55 50 4C 41 ]
15:39:20.978 > Send: [53 55 50 4C 41 17 06 00 00 00 80 02 00 00 0F 00 00 00 09 00 00 00 07 00 00 00 50 4D 20 32 2E 35 00 ]
15:39:20.995 > Send: [53 55 50 4C 41 ]
15:39:20.995 > Send: [53 55 50 4C 41 17 07 00 00 00 80 02 00 00 0F 00 00 00 0A 00 00 00 07 00 00 00 50 4D 20 34 2E 30 00 ]
15:39:21.007 > Send: [53 55 50 4C 41 ]
15:39:21.009 > Send: [53 55 50 4C 41 17 08 00 00 00 80 02 00 00 10 00 00 00 0B 00 00 00 08 00 00 00 50 4D 20 31 30 2E 30 00 ]
15:39:21.010 > Send: [53 55 50 4C 41 ]
15:39:21.022 > Send: [53 55 50 4C 41 17 09 00 00 00 E0 01 00 00 00 00 00 00 ]
15:39:21.027 > Send: [53 55 50 4C 41 ]
15:39:21.044 > Channel(3) value changed to 420.00
15:39:21.055 > MS5611 getting pres.
15:39:26.055 > Speed: 0.00
15:39:31.049 > Wind direction: 18.60
15:39:31.049 > Recv: [53 55 50 4C 41 17 02 00 00 00 AD 02 00 00 1C 00 00 00 01 00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00 01 00 01 53 55 50 4C 41 ]
15:39:31.071 > Received new device config
15:39:31.071 > Processing AutomaticTimeSync config
15:39:31.071 > Sending device config result OK (1)
15:39:31.071 > Send: [53 55 50 4C 41 17 0A 00 00 00 B7 02 00 00 0A 00 00 00 01 00 00 00 00 00 00 00 00 00 ]
15:39:31.088 > Send: [53 55 50 4C 41 ]
15:39:31.088 > Send: [53 55 50 4C 41 17 0B 00 00 00 67 00 00 00 0E 00 00 00 01 00 00 00 00 00 85 5F 00 00 13 0C 01 00 ]
15:39:31.100 > Send: [53 55 50 4C 41 ]
15:39:31.119 > Channel(3) value changed to 388.00
15:39:31.119 > MS5611 getting pres.
15:39:36.120 > Speed: 0.00
15:39:41.125 > Wind direction: 18.60
15:39:41.125 > Channel(7) value changed to 13.14
15:39:41.125 > Channel(8) value changed to 2.29
15:39:41.125 > Channel(9) value changed to 0.05
15:39:41.125 > Channel(10) value changed to 0.00
15:39:41.125 > Channel(11) value changed to 0.00
15:39:41.142 > Recv: [53 55 50 4C 41 17 03 00 00 00 AA 02 00 00 28 00 00 00 00 28 00 00 00 00 20 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 53 55 50 4C 41 ]
15:39:41.158 > Received SetChannelConfig for channel 0, function 40, config type 0, config size 32
15:39:41.166 > Channel[0]: handleChannelConfig, func 40, configtype 0, configsize 32
15:39:41.166 > Channel[0] temperature correction 0.000000
15:39:41.176 > Channel[0] humidity correction 0.000000
15:39:41.179 > Sending channel config result OK (1)
15:39:41.181 > Send: [53 55 50 4C 41 17 0C 00 00 00 B4 02 00 00 03 00 00 00 01 00 00 ]
15:39:41.181 > Send: [53 55 50 4C 41 ]
15:39:41.192 > Send: [53 55 50 4C 41 17 0D 00 00 00 67 00 00 00 0E 00 00 00 03 00 00 00 00 00 00 00 00 00 00 40 78 40 ]
15:39:41.199 > Send: [53 55 50 4C 41 ]
15:39:41.214 > Channel(1) value changed to temp(24.473267), humi(68.627930)
15:39:41.226 > Channel(3) value changed to 406.00
15:39:41.230 > MS5611 getting pres.
15:39:46.214 > Speed: 0.00
15:39:51.221 > Wind direction: 18.60
15:39:51.235 > Recv: [53 55 50 4C 41 17 04 00 00 00 AB 02 00 00 01 00 00 00 00 53 55 50 4C 41 ]
15:39:51.244 > Received ChannelConfigFinished for channel [0]
15:39:51.248 > Send: [53 55 50 4C 41 17 0E 00 00 00 67 00 00 00 0E 00 00 00 04 00 00 00 00 00 00 00 00 00 44 A0 8F 40 ]
15:39:51.254 > Send: [53 55 50 4C 41 ]
15:39:51.323 > Channel(1) value changed to temp(24.473267), humi(68.530273)
15:39:51.329 > Channel(3) value changed to 421.00
15:39:51.331 > MS5611 getting pres.
15:39:51.333 > Channel(4) value changed to 1012.07
15:39:56.328 > Speed: 0.00
15:40:01.329 > Wind direction: 18.60
15:40:01.330 > Recv: [53 55 50 4C 41 17 05 00 00 00 AA 02 00 00 08 00 00 00 01 2D 00 00 00 00 00 00 53 55 50 4C 41 ]
15:40:01.340 > Received SetChannelConfig for channel 1, function 45, config type 0, config size 0
15:40:01.347 > Channel[1]: handleChannelConfig, func 45, configtype 0, configsize 0
15:40:01.352 > Channel[1] no config on server
15:40:01.352 > Sending channel config result OK (1)
15:40:01.352 > Send: [53 55 50 4C 41 17 0F 00 00 00 B4 02 00 00 03 00 00 00 01 00 01 ]
15:40:01.366 > Send: [53 55 50 4C 41 ]
15:40:01.369 > Send: [53 55 50 4C 41 17 10 00 00 00 67 00 00 00 0E 00 00 00 07 00 00 00 00 00 00 00 00 E0 E0 48 2A 40 ]
15:40:01.379 > Send: [53 55 50 4C 41 ]
15:40:01.380 > Channel(3) value changed to 465.00
15:40:01.397 > MS5611 getting pres.
15:40:06.398 > Speed: 0.00
15:40:11.399 > Wind direction: 18.60
15:40:11.401 > Recv: [53 55 50 4C 41 17 06 00 00 00 AB 02 00 00 01 00 00 00 01 53 55 50 4C 41 ]
15:40:11.407 > Received ChannelConfigFinished for channel [1]
15:40:11.412 > Send: [53 55 50 4C 41 17 11 00 00 00 67 00 00 00 0E 00 00 00 08 00 00 00 00 00 00 00 00 00 5F 52 02 40 ]
15:40:11.416 > Send: [53 55 50 4C 41 ]
15:40:11.436 > Channel(1) value changed to temp(24.493408), humi(68.530273)
15:40:11.440 > Channel(3) value changed to 481.00
15:40:11.440 > MS5611 getting pres.
15:40:11.440 > Channel(4) value changed to 1012.11
15:40:16.431 > Speed: 0.00
15:40:21.432 > Wind direction: 18.60
15:40:21.448 > Recv: [53 55 50 4C 41 17 07 00 00 00 AA 02 00 00 08 00 00 00 03 08 02 00 00 00 00 00 53 55 50 4C 41 ]
15:40:21.448 > Received SetChannelConfig for channel 3, function 520, config type 0, config size 0
15:40:21.467 > Channel[3]: handleChannelConfig, func 520, configtype 0, configsize 0
15:40:21.473 > Channel[3] no config on server
15:40:21.477 > Sending channel config result OK (1)
15:40:21.479 > Send: [53 55 50 4C 41 17 12 00 00 00 B4 02 00 00 03 00 00 00 01 00 03 ]
15:40:21.486 > Send: [53 55 50 4C 41 ]
15:40:21.489 > Send: [53 55 50 4C 41 17 13 00 00 00 67 00 00 00 0E 00 00 00 09 00 00 00 00 00 00 00 00 00 C0 08 AD 3F ]
15:40:21.498 > Send: [53 55 50 4C 41 ]
15:40:21.514 > Channel(1) value changed to temp(24.503479), humi(68.530273)
15:40:21.514 > Channel(3) value changed to 480.00
15:40:21.514 > MS5611 getting pres.
15:40:26.519 > Speed: 0.00
15:40:31.509 > Wind direction: 18.60
15:40:31.509 > Recv: [53 55 50 4C 41 17 08 00 00 00 AB 02 00 00 01 00 00 00 03 53 55 50 4C 41 ]
15:40:31.525 > Received ChannelConfigFinished for channel [3]
15:40:31.525 > Send: [53 55 50 4C 41 17 14 00 00 00 67 00 00 00 0E 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 1C 69 3F ]
15:40:31.543 > Send: [53 55 50 4C 41 ]
15:40:31.560 > Channel(3) value changed to 474.00
15:40:31.560 > MS5611 getting pres.
15:40:31.560 > Channel(4) value changed to 1011.97
15:40:36.564 > Speed: 0.00
15:40:41.555 > Wind direction: 18.60
15:40:41.555 > Channel(7) value changed to 11.36
15:40:41.570 > Channel(8) value changed to 1.98
15:40:41.572 > Channel(9) value changed to 0.04
15:40:41.575 > Channel(10) value changed to 0.00
15:40:41.578 > Channel(11) value changed to 0.00
15:40:41.582 > Recv: [53 55 50 4C 41 17 09 00 00 00 AA 02 00 00 08 00 00 00 07 08 02 00 00 00 00 00 53 55 50 4C 41 ]
15:40:41.591 > Received SetChannelConfig for channel 7, function 520, config type 0, config size 0
15:40:41.599 > Channel[7]: handleChannelConfig, func 520, configtype 0, configsize 0
15:40:41.604 > Channel[7]: Ignoring config (local config changed offline)
15:40:41.609 > Sending channel config result OK (1)
15:40:41.613 > Send: [53 55 50 4C 41 17 15 00 00 00 B4 02 00 00 03 00 00 00 01 00 07 ]
15:40:41.620 > Send: [53 55 50 4C 41 ]
15:40:41.621 > Send: [53 55 50 4C 41 17 16 00 00 00 67 00 00 00 0E 00 00 00 0B 00 00 00 00 00 00 00 00 00 00 DC 60 3F ]
15:40:41.630 > Send: [53 55 50 4C 41 ]
15:40:41.650 > Channel(3) value changed to 476.00
15:40:41.654 > MS5611 getting pres.
15:40:41.654 > Channel(4) value changed to 1012.15
15:40:46.654 > Speed: 0.00
15:40:51.655 > Wind direction: 18.60
15:40:51.663 > Recv: [53 55 50 4C 41 17 0A 00 00 00 AB 02 00 00 01 00 00 00 07 53 55 50 4C 41 ]
15:40:51.672 > Received ChannelConfigFinished for channel [7]
15:40:51.676 > Send: [53 55 50 4C 41 17 17 00 00 00 E0 01 00 00 00 00 00 00 ]
15:40:51.681 > Send: [53 55 50 4C 41 ]
15:40:51.701 > Channel(3) value changed to 479.00
15:40:51.705 > MS5611 getting pres.
15:40:51.707 > Channel(4) value changed to 1012.00
15:40:56.705 > Speed: 0.00
15:41:01.696 > Wind direction: 18.60
15:41:01.696 > Recv: [53 55 50 4C 41 17 0B 00 00 00 AA 02 00 00 08 00 00 00 08 08 02 00 00 00 00 00 53 55 50 4C 41 ]
15:41:01.711 > Received SetChannelConfig for channel 8, function 520, config type 0, config size 0
15:41:01.711 > Channel[8]: handleChannelConfig, func 520, configtype 0, configsize 0
15:41:01.727 > Channel[8]: Ignoring config (local config changed offline)
15:41:01.727 > Sending channel config result OK (1)
15:41:01.727 > Send: [53 55 50 4C 41 17 18 00 00 00 B4 02 00 00 03 00 00 00 01 00 08 ]
15:41:01.742 > Send: [53 55 50 4C 41 ]
15:41:01.742 > Send: [53 55 50 4C 41 17 19 00 00 00 67 00 00 00 0E 00 00 00 01 00 00 00 00 00 B7 5F 00 00 B2 0B 01 00 ]
15:41:01.775 > Channel(3) value changed to 484.00
15:41:01.775 > MS5611 getting pres.
15:41:01.775 > Channel(4) value changed to 1012.04
15:41:06.780 > Speed: 0.00
15:41:11.786 > Wind direction: 18.60
15:41:11.787 > Recv: [53 55 50 4C 41 17 0C 00 00 00 AB 02 00 00 01 00 00 00 08 53 55 50 4C 41 ]
15:41:11.795 > Received ChannelConfigFinished for channel [8]
15:41:11.800 > Send: [53 55 50 4C 41 17 1A 00 00 00 67 00 00 00 0E 00 00 00 03 00 00 00 00 00 00 00 00 00 00 40 7E 40 ]
15:41:11.809 > Send: [53 55 50 4C 41 ]
15:41:11.825 > Channel(1) value changed to temp(24.523621), humi(68.530273)
15:41:11.831 > Channel(3) value changed to 487.00
15:41:11.835 > MS5611 getting pres.
15:41:16.831 > Speed: 0.00
15:41:21.831 > Wind direction: 18.60
15:41:21.840 > Recv: [53 55 50 4C 41 17 0D 00 00 00 AA 02 00 00 08 00 00 00 09 08 02 00 00 00 00 00 53 55 50 4C 41 ]
15:41:21.849 > Received SetChannelConfig for channel 9, function 520, config type 0, config size 0
15:41:21.857 > Channel[9]: handleChannelConfig, func 520, configtype 0, configsize 0
15:41:21.863 > Channel[9]: Ignoring config (local config changed offline)
15:41:21.867 > Sending channel config result OK (1)
15:41:21.872 > Send: [53 55 50 4C 41 17 1B 00 00 00 B4 02 00 00 03 00 00 00 01 00 09 ]
15:41:21.877 > Send: [53 55 50 4C 41 ]
15:41:21.879 > Send: [53 55 50 4C 41 17 1C 00 00 00 67 00 00 00 0E 00 00 00 04 00 00 00 00 00 00 00 00 60 62 A0 8F 40 ]
15:41:21.888 > Send: [53 55 50 4C 41 ]
15:41:21.911 > Channel(1) value changed to temp(24.543762), humi(68.530273)
15:41:21.917 > Channel(3) value changed to 485.00
15:41:21.920 > MS5611 getting pres.
15:41:26.916 > Speed: 0.00
15:41:31.917 > Wind direction: 18.60
15:41:31.920 > Recv: [53 55 50 4C 41 17 0E 00 00 00 AB 02 00 00 01 00 00 00 09 53 55 50 4C 41 ]
15:41:31.922 > Received ChannelConfigFinished for channel [9]
15:41:31.922 > Send: [53 55 50 4C 41 17 1D 00 00 00 67 00 00 00 0E 00 00 00 07 00 00 00 00 00 00 00 00 00 B6 BB 26 40 ]
15:41:31.939 > Send: [53 55 50 4C 41 ]
15:41:31.954 > Channel(3) value changed to 483.00
15:41:31.958 > MS5611 getting pres.
15:41:31.960 > Channel(4) value changed to 1012.08
15:41:36.958 > Speed: 0.00
15:41:41.960 > Wind direction: 18.60
15:41:41.962 > Channel(7) value changed to 11.69
15:41:41.965 > Channel(8) value changed to 2.03
15:41:41.968 > Channel(9) value changed to 0.05
15:41:41.971 > Channel(10) value changed to 0.00
15:41:41.973 > Channel(11) value changed to 0.00
15:41:41.977 > Recv: [53 55 50 4C 41 17 0F 00 00 00 AA 02 00 00 08 00 00 00 0A 08 02 00 00 00 00 00 53 55 50 4C 41 ]
15:41:41.985 > Received SetChannelConfig for channel 10, function 520, config type 0, config size 0
15:41:41.993 > Channel[10]: handleChannelConfig, func 520, configtype 0, configsize 0
15:41:41.999 > Channel[10]: Ignoring config (local config changed offline)
15:41:42.004 > Sending channel config result OK (1)
15:41:42.004 > Send: [53 55 50 4C 41 17 1E 00 00 00 B4 02 00 00 03 00 00 00 01 00 0A ]
15:41:42.014 > Send: [53 55 50 4C 41 ]
15:41:42.016 > Send: [53 55 50 4C 41 17 1F 00 00 00 67 00 00 00 0E 00 00 00 08 00 00 00 00 00 00 00 00 00 E1 4E 00 40 ]
15:41:42.023 > Send: [53 55 50 4C 41 ]
15:41:42.046 > Channel(3) value changed to 485.00
15:41:42.049 > MS5611 getting pres.
15:41:42.051 > Channel(4) value changed to 1011.95
15:41:47.049 > Speed: 0.00
15:41:52.050 > Wind direction: 18.60
15:41:52.058 > Recv: [53 55 50 4C 41 17 10 00 00 00 AB 02 00 00 01 00 00 00 0A 53 55 50 4C 41 ]
15:41:52.066 > Received ChannelConfigFinished for channel [10]
15:41:52.070 > Send: [53 55 50 4C 41 17 20 00 00 00 67 00 00 00 0E 00 00 00 09 00 00 00 00 00 00 00 00 00 E0 D7 A9 3F ]
15:41:52.079 > Send: [53 55 50 4C 41 ]
15:41:52.095 > Channel(3) value changed to 487.00
15:41:52.100 > MS5611 getting pres.
15:41:52.101 > Channel(4) value changed to 1012.12
15:41:57.098 > Speed: 0.00
15:42:02.100 > Wind direction: 18.60
15:42:02.103 > Recv: [53 55 50 4C 41 17 11 00 00 00 AA 02 00 00 08 00 00 00 0B 08 02 00 00 00 00 00 53 55 50 4C 41 ]
15:42:02.112 > Received SetChannelConfig for channel 11, function 520, config type 0, config size 0
15:42:02.118 > Channel[11]: handleChannelConfig, func 520, configtype 0, configsize 0
15:42:02.124 > Channel[11]: Ignoring config (local config changed offline)
15:42:02.130 > Sending channel config result OK (1)
15:42:02.133 > Send: [53 55 50 4C 41 17 21 00 00 00 B4 02 00 00 03 00 00 00 01 00 0B ]
15:42:02.139 > Send: [53 55 50 4C 41 ]
15:42:02.142 > Send: [53 55 50 4C 41 17 22 00 00 00 67 00 00 00 0E 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 58 66 3F ]
15:42:02.151 > Send: [53 55 50 4C 41 ]
15:42:02.173 > Channel(1) value changed to temp(24.563904), humi(68.432617)
15:42:02.179 > Channel(3) value changed to 492.00
15:42:02.182 > MS5611 getting pres.
15:42:02.184 > Channel(4) value changed to 1011.99
15:42:07.178 > Speed: 0.00
15:42:12.176 > Wind direction: 18.60
15:42:12.182 > Recv: [53 55 50 4C 41 17 12 00 00 00 AB 02 00 00 01 00 00 00 0B 53 55 50 4C 41 ]
15:42:12.182 > Received ChannelConfigFinished for channel [11]
15:42:12.193 > Send: [53 55 50 4C 41 17 23 00 00 00 67 00 00 00 0E 00 00 00 0B 00 00 00 00 00 00 00 00 00 00 5A 61 3F ]
15:42:12.202 > Send: [53 55 50 4C 41 ]
15:42:12.216 > MS5611 getting pres.
15:42:17.223 > Speed: 0.00
15:42:22.222 > Wind direction: 18.60
15:42:22.232 > Recv: [53 55 50 4C 41 17 13 00 00 00 DC 00 00 00 03 00 00 00 1E 0A F0 53 55 50 4C 41 ]
15:42:22.241 > Activity timeout set to 30 s
15:42:22.254 > Channel(1) value changed to temp(24.573975), humi(68.432617)
15:42:22.260 > Channel(3) value changed to 496.00
15:42:22.263 > MS5611 getting pres.
15:42:22.263 > Channel(4) value changed to 1012.03
15:42:27.259 > Speed: 0.00
15:42:32.261 > Wind direction: 18.60
15:42:32.265 > Recv: [53 55 50 4C 41 17 14 00 00 00 8A 02 00 00 1F 00 00 00 03 00 00 00 1A 16 00 00 00 4E 61 74 C4 99 C5 BC 65 6E 69 65 20 C5 9B 77 69 61 74 C5 82 61 00 53 55 50 4C 41 ]
15:42:32.280 > Receieved setChannelCaptionResult for channel [3]
15:42:32.285 > Send: [53 55 50 4C 41 17 24 00 00 00 67 00 00 00 0E 00 00 00 01 00 00 00 00 00 FD 5F 00 00 50 0B 01 00 ]
15:42:32.294 > Send: [53 55 50 4C 41 ]
15:42:32.312 > Channel(3) value changed to 497.00
15:42:32.315 > MS5611 getting pres.
15:42:37.315 > Speed: 0.00
15:42:42.316 > Wind direction: 18.60
15:42:42.319 > Channel(7) value changed to 13.66
15:42:42.322 > Channel(8) value changed to 2.38
15:42:42.324 > Channel(9) value changed to 0.05
15:42:42.324 > Channel(10) value changed to 0.00
15:42:42.324 > Channel(11) value changed to 0.00
15:42:42.332 > Recv: [53 55 50 4C 41 17 15 00 00 00 8A 02 00 00 10 00 00 00 07 00 00 00 1A 07 00 00 00 50 4D 20 30 2E 35 00 53 55 50 4C 41 ]
15:42:42.344 > Receieved setChannelCaptionResult for channel [7]
15:42:42.344 > Send: [53 55 50 4C 41 17 25 00 00 00 67 00 00 00 0E 00 00 00 03 00 00 00 00 00 00 00 00 00 00 10 7F 40 ]
15:42:42.358 > Send: [53 55 50 4C 41 ]
15:42:42.376 > Channel(1) value changed to temp(24.594116), humi(68.432617)
15:42:42.382 > Channel(3) value changed to 494.00
15:42:42.382 > MS5611 getting pres.
15:42:42.382 > Channel(4) value changed to 1012.06
15:42:47.377 > Speed: 0.00
15:42:52.383 > Wind direction: 18.60
15:42:52.392 > Recv: [53 55 50 4C 41 17 16 00 00 00 8A 02 00 00 10 00 00 00 08 00 00 00 1A 07 00 00 00 50 4D 20 31 2E 30 00 53 55 50 4C 41 ]
15:42:52.403 > Receieved setChannelCaptionResult for channel [8]
15:42:52.407 > Send: [53 55 50 4C 41 17 26 00 00 00 67 00 00 00 0E 00 00 00 04 00 00 00 00 00 00 00 00 C0 7E A0 8F 40 ]
15:42:52.417 > Send: [53 55 50 4C 41 ]
15:42:52.439 > Channel(3) value changed to 484.00
15:42:52.442 > MS5611 getting pres.
15:42:52.442 > Channel(4) value changed to 1012.10
15:42:57.443 > Speed: 0.00
15:43:02.445 > Wind direction: 18.60
15:43:02.447 > Recv: [53 55 50 4C 41 17 17 00 00 00 8A 02 00 00 10 00 00 00 09 00 00 00 1A 07 00 00 00 50 4D 20 32 2E 35 00 53 55 50 4C 41 ]
15:43:02.458 > Receieved setChannelCaptionResult for channel [9]
15:43:02.462 > Send: [53 55 50 4C 41 17 27 00 00 00 67 00 00 00 0E 00 00 00 07 00 00 00 00 00 00 00 00 20 CD 52 2B 40 ]
15:43:02.472 > Send: [53 55 50 4C 41 ]
15:43:02.494 > Channel(1) value changed to temp(24.614258), humi(68.432617)
15:43:02.500 > Channel(3) value changed to 481.00
15:43:02.502 > MS5611 getting pres.
15:43:07.498 > Speed: 0.00
15:43:12.501 > Wind direction: 18.60
15:43:12.503 > Recv: [53 55 50 4C 41 17 18 00 00 00 8A 02 00 00 10 00 00 00 0A 00 00 00 1A 07 00 00 00 50 4D 20 34 2E 30 00 53 55 50 4C 41 ]
15:43:12.514 > Receieved setChannelCaptionResult for channel [10]
15:43:12.518 > Send: [53 55 50 4C 41 17 28 00 00 00 67 00 00 00 0E 00 00 00 08 00 00 00 00 00 00 00 00 80 BB 0B 03 40 ]
15:43:12.524 > Send: [53 55 50 4C 41 ]
15:43:12.543 > Channel(1) value changed to temp(24.604187), humi(68.328857)
15:43:12.556 > Channel(3) value changed to 477.00
15:43:12.559 > MS5611 getting pres.
15:43:12.559 > Channel(4) value changed to 1011.82
15:43:17.555 > Speed: 0.00
15:43:22.555 > Wind direction: 18.60
15:43:22.562 > Recv: [53 55 50 4C 41 17 19 00 00 00 8A 02 00 00 11 00 00 00 0B 00 00 00 1A 08 00 00 00 50 4D 20 31 30 2E 30 00 53 55 50 4C 41 ]
15:43:22.572 > Receieved setChannelCaptionResult for channel [11]
15:43:22.581 > Send: [53 55 50 4C 41 17 29 00 00 00 67 00 00 00 0E 00 00 00 09 00 00 00 00 00 00 00 00 00 80 2E AE 3F ]
15:43:22.585 > Send: [53 55 50 4C 41 ]
15:43:22.612 > Channel(1) value changed to temp(24.614258), humi(68.328857)
15:43:22.618 > Channel(3) value changed to 470.00
15:43:22.621 > MS5611 getting pres.
15:43:22.622 > Channel(4) value changed to 1012.14
15:43:27.613 > Speed: 0.00
15:43:32.617 > Wind direction: 18.60
15:43:32.620 > Recv: [53 55 50 4C 41 17 1A 00 00 00 EA 01 00 00 1A 00 00 00 E8 07 06 10 01 0F 27 14 0E 00 00 00 45 75 72 6F 70 65 2F 57 61 72 73 61 77 00 53 55 50 4C 41 ]
15:43:32.632 > Current local time: 1970-1-1 0:4:53
15:43:32.637 > Clock: time diff (system-new): -1718552067 s
15:43:32.641 > Clock: new local time: 2024-6-16 15:39:20
15:43:32.645 > Send: [53 55 50 4C 41 17 2A 00 00 00 67 00 00 00 0E 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 1C 6A 3F ]
15:43:32.652 > Send: [53 55 50 4C 41 ]
15:43:32.678 > Channel(1) value changed to temp(24.634399), humi(68.328857)
15:43:32.682 > Channel(3) value changed to 468.00
15:43:32.682 > MS5611 getting pres.
15:43:37.683 > Speed: 0.00
15:43:42.684 > Wind direction: 18.60
15:43:42.687 > Channel(7) value changed to 13.74
15:43:42.690 > Channel(8) value changed to 2.39
15:43:42.693 > Channel(9) value changed to 0.05
15:43:42.696 > Channel(10) value changed to 0.00
15:43:42.699 > Channel(11) value changed to 0.00
15:43:42.701 > Recv: [53 55 50 4C 41 17 1B 00 00 00 EA 01 00 00 1A 00 00 00 E8 07 06 10 01 0F 28 32 0E 00 00 00 45 75 72 6F 70 65 2F 57 61 72 73 61 77 00 53 55 50 4C 41 ]
15:43:42.715 > Current local time: 2024-6-16 15:39:30
15:43:42.719 > Clock: time diff (system-new): -80 s
15:43:42.721 > Clock: new local time: 2024-6-16 15:40:50
15:43:42.726 > Send: [53 55 50 4C 41 17 2B 00 00 00 67 00 00 00 0E 00 00 00 0B 00 00 00 00 00 00 00 00 00 00 64 64 3F ]
15:43:42.735 > Send: [53 55 50 4C 41 ]
15:43:42.757 > MS5611 getting pres.
15:43:42.759 > Channel(4) value changed to 1012.18
15:43:47.760 > Speed: 0.00
15:43:52.759 > Wind direction: 18.60
15:43:52.789 > Channel(3) value changed to 466.00
15:43:52.794 > MS5611 getting pres.
15:43:52.794 > Channel(4) value changed to 1012.04
15:43:57.793 > Speed: 0.00
15:44:02.794 > Wind direction: 18.60
15:44:02.794 > Send: [53 55 50 4C 41 17 2C 00 00 00 67 00 00 00 0E 00 00 00 01 00 00 00 00 00 3A 60 00 00 E8 0A 01 00 ]
15:44:02.805 > Send: [53 55 50 4C 41 ]
15:44:02.822 > Channel(1) value changed to temp(24.674683), humi(68.298340)
15:44:02.827 > Channel(3) value changed to 464.00
15:44:02.830 > MS5611 getting pres.
15:44:02.832 > Channel(4) value changed to 1012.08
15:44:07.824 > Speed: 0.00
15:44:12.837 > Wind direction: 18.60
15:44:12.837 > Send: [53 55 50 4C 41 17 2D 00 00 00 28 00 00 00 10 00 00 00 A0 07 6F 66 00 00 00 00 44 DC 01 00 00 00 00 00 ]
15:44:12.837 > Send: [53 55 50 4C 41 ]
15:44:12.849 > Send: [53 55 50 4C 41 17 2E 00 00 00 67 00 00 00 0E 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00 7D 40 ]
15:44:12.854 > Send: [53 55 50 4C 41 ]
15:44:12.866 > Channel(1) value changed to temp(24.674683), humi(68.200684)
15:44:12.874 > MS5611 getting pres.
15:44:12.879 > Channel(4) value changed to 1011.98
Wg mnie coś jest dziwnie zrobione jeśli chodzi o wymianę configa. Spodziewał bym się, że cokolwiek wyślę do Cloud, zapisuje się też lokalnie i Cloud podaje swój config w odpowiedzi zwrotnej, ale jak się nie różnią to jest to ignorowane, w przeciwnym wypadku zapisuje się lokalnie ?
Cloud krzyczy: "Konfiguracja jeszcze nie jest dostępna. Poczekaj, aż urządzenie się podłączy." co jest półprawdą, bo urządzenie już działa i podaje wartość ale najwidoczniej nie dostało configa z Cloud - co swoją drogą strasznie długo trwa.
@klew Rzucisz okiem? Kanały 4, 7,8,9,10,11 to są KPOP.
Has thanked: 135 times
[email protected] wrote: Sun Jun 16, 2024 1:50 pm 2. Zaktualizowałem kod w zainicjalizowanym urządzeniu. Efekt ten sam. Log poniżej:
15:38:59.133 > 0.00
15:39:09.160 > 0.00
Nie czytałem dokładnie, ale config w domyślnym rozmiarze raczej takiej konfiguracji nie ogarnie.
Trzeba stworzyć instancję i dać tam więcej pamięci. Robisz to na esp32?
[email protected]
klew wrote: Sun Jun 16, 2024 1:52 pm ...
Tak, na ESP32, rozumiem , że mam przestawić wartość : SUPLA_LITTLEFS_CONFIG_BUF_SIZE ? :D
Has thanked: 290 times
[email protected] wrote: Sun Jun 16, 2024 2:03 pm Tak, na ESP32, rozumiem , że mam przestawić wartość : SUPLA_LITTLEFS_CONFIG_BUF_SIZE ? :D
Lepiej w konstruktorze klasy:
Supla::LittleFsConfig                     configSupla(3000);
vajera wrote: Mon Jun 17, 2024 8:19 am
Teraz przejrzałem logi, które wysłałeś i tam problem jest chyba inny.
Ogólnie coś strasznie zamula i komunikacja z serwerem odbywa się co 10-20 s.
Od wiadomości rejestrującej, minęło około 4 min, zanim wszystkie pozostałe komunikaty się wymieniły.
Ponieważ ten interwał 10s jest zbyt równy, to obstawiam, że do "loop" wstawiłeś coś co blokuje wykonanie SuplaDevice.iterate() na 10 s.
Ogólnie w loop nie powinno być niczego co blokuje wykonanie pozostałych rzeczy z loop na dłużej niż 100-200 ms.
[email protected]
klew wrote: Mon Jun 17, 2024 8:35 am
Skoro tak mówisz, to nic nie mam jawnie (link do githuba wyżej), aczkolwiek może odczyt wszystkich czujników się sumuje.
Ok, zrobię test: wykastruje ten program z odczytów z faktycznych czujników na rzecz randomowej liczby i zobaczymy ile potrwa.
A drugi test to jeśli zadziała, to ile można dodać KPOPów bez zmian w wielkości configa.
[email protected] wrote: Mon Jun 17, 2024 9:00 am Skoro tak mówisz, to nic nie mam jawnie (link do githuba wyżej), aczkolwiek może odczyt wszystkich czujników się sumuje.
Tutaj chyba się robi to opóźnienie:
Za każdym razem te 3 logi są w takich odstępach czasu.
Dokładnie kodu nie przeglądałem, ale widzę, że używasz też tego typu zapisu:
if (lastSendTime + 10000 < millis())
Zmień to na:
if (millis() - lastSendTime > 10000) {
Tylko znak > < dostosuj do potrzeb. Ogólnie to jest arytmetyka na zmiennych typu "unsigned int" i ona dobrze działa, gdy robi się to tak jak podałem - wtedy nawet przy przekręceniu się inta, nadal różnica czasu będzie policzona dobrze.
[email protected]
@klew pozamieniałem te porównania ale to nic nie zmieniło.
Zostawiłem tylko 6 x KPOP i efekt jest taki, że one się dodają ale w Cloud, pierwszy ma wszystko a dla kolejnych nie widać im jednostek ale nie ma tego komunikatu o niedostępnej konfiguracji, za to w Apce na Androida wszystko się zgadza.
Wczoraj jak sprawdzałem skupiłem się tylko na Cloud, a w apce też było wszystko zgodnie z konfiguracją z urządzenia.
Co więcej teraz w Cloud jak kliknę przywróć domyślną konfigurację to ustawiają się wartości podane z urządzenia. Także coś jest nie tak :P
Czas 10 sek to jest domyślna pętla no nie? bo ja tam nic innego nie robiłem dla tych czujników.
Return to “supla-dev”
