Automatyczny reset - da się?
No właśnie.
Masz zaznaczone 16Mbit, a powinno być 4Mbit.
kindziol
elmaya wrote: Thu Nov 28, 2019 9:18 pm @kindziol I'm sure you understand the difference between 4 and 16.
why do you put 16Mbit in Flashtool?
Jutro to sprawdzę. Mój błąd.
I'll check it tomorrow. My mistake.
Nie znam angielskiego
I do not know English
pozdrawiam
greetings
elmaya
don't strain in polish it's ok
Just try to give all the details and the screenshots helps.
talking about screenshots in the Firmware attachment there is one with the flashtool configuration, haven't you seen it?
Dawid84
elmaya wrote: Thu Nov 28, 2019 9:15 pm
Dawid84 wrote: Thu Nov 28, 2019 8:52 pm
elmaya wrote: Thu Nov 28, 2019 2:14 pm @kindziol Please try to be more specific when you have a request for something!
Until now I could not understand that there was a problem with the duration of the relay activation time.
I don't have that module and I can't test physically, I have solved the problem with the serial buffer.
router reset for: esp 01 relay board
LED behavior changed.
Ledflashing 0.5 seconds: wifiConfig
Led on: alarm (no connection)
Led wink every 30 seconds: normal operation
to access wifi config connect Gpio0 to ground for at least 3 seconds
added reset delay (time that has to pass without connection before the Reset is triggered) selection in wificonfig (5.10 or 15 minutes)
reset_router_v3_stc15f_delaySelect_DOUT_4Mbit.rar
Czy to oprogramowanie bedzie pasowalo do mnie wemos d1 mini?
no
soon there will be an updated version for wemos
Do you have a new relay?
Tomorrow I will have a new one
Dawid
elmaya
router reset for: wemos relay board
The Wemos will connect to Wi-Fi and ping google.com (editable in wificonfig) every 30 seconds,
if any Ping fails the LED will light up,
if the situation persists during the time set in wificonfig it activates the relay for 5 seconds.
Led flash every 30 seconds: normal operation
to access wifi config connect Gpio0 (D3) to ground for at least 3 seconds
reset delay selection in wificonfig (5.10 or 15 minutes)
Always erase flash with flashtool before programming.
See screenshot for programming parameters.
correction to always save wifi config data.
reset_router_v3_delaySelect_DOUT_16Mbit.rar
kindziol
elmaya wrote: Thu Nov 28, 2019 9:31 pm don't strain in polish it's ok
Witaj @elmaya !!!!
Mój błąd, zrobiłem złe ustawienia programu. Soft się wgrał i pracuje dobrze tylko ustawiłem czas 5 min a on robi reset po zaniku wifi co 5 sek. A jak zamykałem program to pokazały się takie informacje:
elmaya
you should update flash download tools
https://www.espressif.com/sites/default ... .6.7_1.zip
kindziol
elmaya wrote: Fri Nov 29, 2019 11:52 am you should update flash download tools
Dzięki. pobieram
kindziol
kindziol wrote: Fri Nov 29, 2019 11:55 am
Dzięki. pobieram
Jest coś źle w programie. Po zaniku wifi robi restarty bardzo szybko , co jakieś 10s więc nie pozwoli aby router się załączył.
Po załadowaniu nowego programu pokazuje takie błędy:
elmaya
You may have it stored in a folder with Polish letters, I think he doesn't like that.
try changing the name of the folder and file so that it only contains standard characters.
