Sterowanie suplą przez esp32 z dotykowym LCD 4” + FlightRadar
Has thanked: 289 times
SOYER wrote: Tue Dec 24, 2024 1:38 pm Cześć, na razie przez linki bezpośrednie, po świętach spróbuję na MQTT:
4” Touch LCD, open gate
https://youtube.com/shorts/CPGHRZQSJ48?feature=share
Brawo!
SOYER
Dziękuje, strasznie oporna materia to była, ale daliśmy radę;)
https://forbot.pl/forum/topic/24775-mon ... /#comments
https://kryry01.aqi.eco/pl
https://github.com/Soyer79
SOYER
MQTT ogarnięte.
Dziękuję wszystkim za pomoc. Jest tego trochę na forum, ale jakby ktoś potrzebował w prostej formie to proszę:
#include <WiFi.h>
#include <WiFiClientSecure.h>
#include <PubSubClient.h>
#include "HWCDC.h"
HWCDC USBSerial;
// Update these with values suitable for your network.
const char* ssid = "xx";
const char* password = "xx";
const char* mqtt_server = "xx";
const char* mqtt_user = "xx";
const char* mqtt_pass = "xx";
WiFiClientSecure client1;
PubSubClient client(client1);
unsigned long lastMsg = 0;
#define MSG_BUFFER_SIZE  (50)
char msg[MSG_BUFFER_SIZE];
int value = 0;
void setup_wifi() {
  delay(10);
  // We start by connecting to a WiFi network
  USBSerial.println();
  USBSerial.print("Connecting to ");
  USBSerial.println(ssid);
  WiFi.mode(WIFI_STA);
  WiFi.begin("xx", "xx");
    delay(500);
    USBSerial.print(".");
  randomSeed(micros());
String tempGrunt;
String top1="supla/xx/devices/xxxx/channels/xxxx/state/temperature";//TemGrunt
void callback(char* topic, byte* payload, unsigned int length) {
  USBSerial.print("Message arrived [");
  USBSerial.print(topic);
  USBSerial.print("] ");
  for (int i = 0; i < length; i++) {
    USBSerial.print((char)payload[i]);
if (strcmp(topic,top1.c_str())==0){
    payload[length] = '\0';
    tempGrunt=String((char*)payload);
USBSerial.print("tempGrunt.......................:");
USBSerial.println(tempGrunt);
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    USBSerial.print("Attempting MQTT connection...");
    // Create a random client ID
    String clientId = "ESP32Client-";
    clientId += String(random(0xffff), HEX);
    // Attempt to connect
    if (client.connect(clientId.c_str(), mqtt_user, mqtt_pass)) {
      USBSerial.println("connected");
      client.subscribe(top1.c_str());
    } else {
      USBSerial.print("failed, rc=");
      USBSerial.print(client.state());
      USBSerial.println(" try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(5000);
void setup() {
  pinMode(BUILTIN_LED, OUTPUT);     // Initialize the BUILTIN_LED pin as an output
USBSerial.begin(9600);
  setup_wifi();
  client1.setInsecure();
  client.setServer(mqtt_server, 8883);
  client.setCallback(callback);
void loop() {
  if (!client.connected()) {
    reconnect();
  client.loop();
///sterowanie przekaźnikiem
client.publish("supla/xxx/devices/xxx/channels/xxx/execute_action", "TOGGLE");
SOYER
Trochę dzisiaj popracowałem, mam już po mqtt odbieranie danych z krańcówek, sterowanie bramami i wyświetlanie danych z czujników.
Esp32 Touch 4”, Supla MQTT
https://youtube.com/shorts/ShKYXEBxfiM?feature=share
SOYER
Aktualne postępy prac:
ESP32-S3, 4” touch panel, Supla MQTT
https://youtube.com/shorts/8zBX69HGKW0
Dodałem obsługę odczytu jakości powietrza, pobieram dane z czujnika(serwera supli w sumie), przeliczam w.g. indeksu i wyświetlam odpowiednie info. Kolor tła banerów na stronie głównej również zmienia się zależnie od odczytów, temperatury, jakości powietrza i siły wiatru.
Generalnie co chciałem zrobić zrobiłem. Teraz muszę to gdzieś zamontować zamiast zwykłego włącznika.
SOYER
SOYER
Witam w Nowym Roku.
Mam pytanie co do OTA.
Teraz mam esp32 z LCD które łaczy się z serwerem supli i uzywając MQTT odbiera/wysyła dane.
Chciałbym dodać do tej płytki aktualizacje poprzez OTA, jednak z możliwością przejścia w tryb konfiguracyjny z poziomu clouda.
Tej metody już z powodzeniem używam w innym esp32:
#include <HTTPUpdateServer.h>
HTTPUpdateServer httpUpdater;
httpUpdater.setup(suplaServer.getServerPtr(), "/update");
Teraz pytanie jak zrobić by w najprostszy możliwy sposób mieć możliwość zdalnego przejścia w tryb konfiguracyjny i móc zaktualizować soft.
Chyba, że jest na to(OTA) inny sposób.
Podpowie ktoś coś?
SOYER
Wydaje mi się, że jeśli dodam to esp32 normalnie do supli jako device i odpalę SuplaDevice.iterate(); to mi się to bedzie gryźć z mqtt, ale nie jestem pewien.
Wymyśliłem, żeby na innym device dodać kanał wirtualnego przekaźnika, a na moim esp z mqtt dam subskrybcję tego VR.
Wtedy kiedy włączę ten VR to na esp odbieram to info przez mqtt i ustawiam esp w tryb update.
Tylko jak zrobić to ostatnie? Czyli jak zareagować na ten topic z mqtt i odpalić web z możliwością update używając tego:
@lukfud?
Has thanked: 37 times
Been thanked: 27 times
Jeśli dobrze Cię rozumiem, to chcesz mieć możliwość aktualizacji przez OTA swojego urządzenia MQTT/ESP32, które to urządzenie nie jest widoczne w Supla Cloud. Więc soft musisz wystawić na jakimś zasobie w swojej sieci lokalnej lub na www w sieci Internet.
To może zrobić dodatkowy przycisk na panelu ESP32 do sprawdzania i aktualizowania softu?
SOYER
Dobrze rozumiesz, ale nie ma możliwości dodatkowego przycisku fizycznego.
Więc wymyśliłem włączanie trybu konfiguracji w reakcji na topic z mqtt z konkretnego kanału sterowanego z innego esp. Nie wiem jak to zrobić. Czy podobnie jak przy przycisku fizycznym? Czyli libsy do supli, webinterface itd i reagujemy na topic a nie na przycisk. Tylko czy to będzie działać bez supladevice.iterate?
