Supla-Cloud-Server
fracz
Has thanked: 4 times
Been thanked: 6 times
Onlyzen wrote: Mon Nov 06, 2017 7:32 am To create a schema for airline-related tables and give the authorization ID anita access to all of the objects that use the schema, use the following syntax:
CREATE SCHEMA FLIGHTS AUTHORIZATION anita
To create a schema employee-related tables, use the following syntax:
CREATE SCHEMA EMP
To create a schema that uses the same name as the authorization ID takumi, use the following syntax:
CREATE SCHEMA AUTHORIZATION takumi
To create a table called availability in the EMP and FLIGHTS schemas, use the following syntax:
CREATE TABLE FLIGHTS.AVAILABILITY
(FLIGHT_ID CHAR(6) NOT NULL, SEGMENT_NUMBER INT NOT NULL,
FLIGHT_DATE DATE NOT NULL, ECONOMY_SEATS_TAKEN INT,
BUSINESS_SEATS_TAKEN INT, FIRSTCLASS_SEATS_TAKEN INT,
CONSTRAINT FLT_AVAIL_PK
PRIMARY KEY (FLIGHT_ID, SEGMENT_NUMBER, FLIGHT_DATE))
CREATE TABLE EMP.AVAILABILITY
(HOTEL_ID INT NOT NULL, BOOKING_DATE DATE NOT NULL, ROOMS_TAKEN INT,
CONSTRAINT HOTELAVAIL_PK PRIMARY KEY (HOTEL_ID, BOOKING_DATE))
Parent topic: CREATE statements
Related reference
CREATE FUNCTION statement
CREATE INDEX statement
CREATE PROCEDURE statement
CREATE ROLE statement
CREATE SYNONYM statement
CREATE TABLE statement
CREATE TRIGGER statement
CREATE VIEW statement
Are you sure it is the correct forum?
Return to “Help”
