firmware BME/BMP280
Yepestis
Has thanked: 19 times
Been thanked: 3 times
qba93 wrote: Thu Jun 20, 2019 8:15 pm ets Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 1384, room 16
tail 8
chksum 0x2d
csum 0x2d
v8b899c12
~ld
PS zamówiłem NodeMCU poczekam az przyjdzie zobaczymy co bedzie jak kicha to se dam spokój :D
Odpal terminal na prędkości 115 200
Powinieneś zobaczyć coś takiego:
|                                             HEX                                                     |                STRING                |
|   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00   |                                      |
|   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 31 00   |                                 1    |
|   00 00 00 00 00 00 00 00 31 32 38 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00   |           128                        |
|   00 00 00 00 00 00 00 00 00 00 00 00 73 76 72 37 2E 73 75 70 6C 61 2E 6F 72 67 00 00 00 00 00 00   |               svr7.supla.org         |
|   30 2E 30 2E 30 2E 30 00 00 00 00 00 00 00 00 30 2E 30 2E 30 2E 30 00 00 00 00 00 00 00 00 30 2E   |   0.0.0.0        0.0.0.0        0.   |
|   30 2E 30 2E 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00   |   0.0.0                              |
Adresacja IP zostanie pobrana z serwera DHCP po nawiązaniu połczenia WiFi
WiFi init
SSID: mojeWiFi PASSWORD: ********
Adres IP:        192.168.254.101
Maska podsieci:  255.255.255.0
Brama domyślna:  192.168.254.254
BME Ciśnienie: 1003.96
ESP RSSI : -60.00
BME Temperatura: 54.40   Wilgotność : 54.40
Uruchamianie serwera aktualizacji...
REGISTER IN PROGRESS
BME Ciśnienie: 1003.95
Value changed
ESP RSSI : -62.00
Value changed
BME Temperatura: 28.55   Wilgotność : 54.40
Value changed
REGISTERED AND READY
Value changed
ESP RSSI : -62.00
BME Temperatura: 28.57   Wilgotność : 54.30
Value changed
BME Ciśnienie: 1003.94
Value changed
ESP RSSI : -61.00
Value changed
BME Temperatura: 28.59   Wilgotność : 53.94
Value changed
BME Ciśnienie: 1003.92
Value changed
ESP RSSI : -62.00
BME Temperatura: 28.88   Wilgotność : 53.05
Value changed
qba93
Na necie gdzieś przypadkiem zobaczyłem, że jakieś piny trzeba ze sobą zlutować, które muszę tu ze zobą zlutować?
qba93 wrote: Fri Jun 21, 2019 9:21 pm Na necie gdzieś przypadkiem zobaczyłem, że jakieś piny trzeba ze sobą zlutować, które muszę tu ze zobą zlutować?
Bzdura!!
qba93
Hmm na supli mi nie działa ale jak biorę BME-i2c test to działa.. Wina płytki, że wemos mini a nie NodeMCU hmm w poniedziałek mi przyjśc ma, zobaczymy :D
Been thanked: 9 times
Jeżeli wgrywasz skompilowaną już binarkę, to musisz pamiętać o tym, by ustawić parametry wgrywania zgodnie z tymi jakie były ustawione podczas kompilowania. Druga sprawa w tym przypadku to poprawne podłączenie czujnika, pod właściwe piny.
Z tego loga wynika, że czujnik widać i nawet ciśnienie jest mierzone, czyli jdnak BME ;)
W tym sofcie, jeśli dobrze pamiętam, podczas uruchamiania inicjowane jest połączenie z BME, jak go nie ma to nie przechodzi dalej, do rejestracji, dlatego kolega @Yepestis pisał o restarcie modułu.
SOP 2023 :heavy_check_mark:
SOP 2024 :heavy_check_mark:
🧩: 🔑cz->b ⛴️+ila
qba93
Jak go zresetowac?tym przyciskiem na module?
shimano73
Te piny są prawdopodobnie do zmiany adresu i2c
qba93 wrote: Sat Jun 22, 2019 5:18 am Jak go zresetowac?tym przyciskiem na module?
Tak, możesz też odłączyć kabel zasilający lub zewrzeć RST z GND. Najprościej jest oczywiście wcisnać mikrostyk.
🧩: 🔑cz->b ⛴️+ila
I teraz @gba93 spać nie może. 😁🤣
Podłącz sobie jeszcze równolegle oled pod d1 i d2 bo kod to obsługuje :P
qba93
Na wstępie chciałbym podziękować QLQ, który mi bardzo duzo pomógł, a w zasadzie to za mnie zrobił ten czujnik ale dział i zadowolony jestem.
Nie ja je " pochowane" mam zeby nie bylo widac tylko z telfonow i tabletow sterowanie/podglad
