Automatyczny reset - da się?
elmaya
PioKar wrote: Thu Nov 21, 2019 12:13 pm Nie idzie.
To co wpisać zamiast www.google by połączyć się lokalnie z raspberry/supla/scripts?
Pi jest lokalnie na 195.168.1xx
Enter the IP address for local network.
if you have trouble connecting via port 443.
HTTP version (port 80)
#include <FS.h>       // ---- esp board manager 2.4.2 --- iwip Variant V2 higher Bandwidth
#include <ESP8266Ping.h>
#include <WiFiClientSecure.h>
#include <ESP8266WiFi.h>
#include <DNSServer.h>
#include <WiFiManager.h>     //--------- https://github.com/tzapu/WiFiManager/tree/0.14 -------------
#include <ArduinoJson.h>     //--------- https://github.com/bblanchon/ArduinoJson/tree/v5.13.2 ------
#include <Ticker.h>
Ticker ticker;
WiFiManager wifiManager;
#define alarm_led   5  //D1     // High if no net connection (Dodatkowa dioda LED(czerwona) przez rezystor 330 ohm do masy.) GIPO5
#define Relay       4  //D2     // High for 5 seconds on reset ( Przekaźnik ) GIPO 4
#define TRIGGER_PIN 0  //D3     // wifi config ( Do masy ) GIPO0
#define onboard_led 2  //D4     // Status Led  (Dioda wemosa d1 mini.) GIPO2
char host[40] = "www.google.com";
const int httpPort = 80;
const char* fingerprint = "CF 05 98 89 CA FF 8E D8 5E 5C E0 C2 E4 F7 E6 C3 C7 50 DD 5C";
bool shouldSaveConfig = false;
bool initialConfig = false;
bool net_ok = false;
unsigned long reset_delay = 300000;   // 300000 --- Reset Delay in miliseconds --- ( Czas 5 min - do resetu. )
unsigned long time_last = 30000;
unsigned long time_last_chek;
unsigned long Chek_delay = 60000;       //  Ping co 60 sek. --- Ping Delay ---
int timeout = 120;     // Wifi manager timeout
int C_W_state = HIGH;
int last_C_W_state = HIGH;
unsigned long time_last_C_W_change = 0;
long C_W_delay = 3000;               // config delay 3 seconds  ------------ opóźnienie konfiguracji 3 sekund
void tick()
  int state = digitalRead(onboard_led);
  digitalWrite(onboard_led, !state);
void saveConfigCallback () {
  Serial.println("Should save config");
  shouldSaveConfig = true;
void ondemandwifiCallback () {
  ticker.attach(0.2, tick);
  WiFiManagerParameter custom_host("host", "host", host, 40);
  wifiManager.setBreakAfterConfig(true);
  wifiManager.setSaveConfigCallback(saveConfigCallback);
  wifiManager.addParameter(&custom_host);
  wifiManager.setMinimumSignalQuality();
    wifiManager.setConfigPortalTimeout(timeout);
    if (!wifiManager.startConfigPortal("AutoReset")) {
      Serial.println("failed to connect and hit timeout");
      delay(3000);
      ESP.restart();
      delay(5000);
    Serial.println("connected...yeey :)");
    strcpy(host, custom_host.getValue());
void check_host (){
  Serial.print("connecting host ");
  Serial.println(host);
  WiFiClient client;
  if (!client.connect(host, httpPort)) {
    Serial.println("connection failed");
    digitalWrite(alarm_led, HIGH);
    Serial.println("Error :(");
    net_ok = false;
    return;
  }else{
    Serial.println("Success!!");
    digitalWrite(onboard_led, LOW);
    delay(100);
    digitalWrite(onboard_led, HIGH);
    digitalWrite(alarm_led, LOW);
    time_last = millis();
    net_ok = true;
void setup() {
  Serial.begin(115200);
   pinMode(TRIGGER_PIN, INPUT_PULLUP);
   pinMode(onboard_led, OUTPUT);
   pinMode(Relay, OUTPUT);
   pinMode(alarm_led, OUTPUT);
  ticker.attach(0.8, tick);
    if (WiFi.SSID()==""){
    initialConfig = true;
  //read configuration from FS json
  Serial.println("mounting FS...");
  if (SPIFFS.begin()) {
    Serial.println("mounted file system");
    if (SPIFFS.exists("/config.json")) {
      Serial.println("reading config file");
      File configFile = SPIFFS.open("/config.json", "r");
      if (configFile) {
        Serial.println("opened config file");
        size_t size = configFile.size();
        // Allocate a buffer to store contents of the file.
        std::unique_ptr<char[]> buf(new char[size]);
        configFile.readBytes(buf.get(), size);
        DynamicJsonBuffer jsonBuffer;
        JsonObject& json = jsonBuffer.parseObject(buf.get());
        Serial.println(jsonBuffer.size());
        json.printTo(Serial);
        if (json.success()) {
          Serial.println("\nparsed json");
          strcpy(host, json["host"]);
        } else {
          Serial.println("failed to load json config");
  } else {
    Serial.println("failed to mount FS");
  WiFi.mode(WIFI_STA);
void loop() {
  if (initialConfig){    //   ----------enter WiFi configuration if there is no data in memory---------------
    ondemandwifiCallback () ;
  checkButton();           //   ------------------------------------ NEW Settings delay 3" --------------------------------------
  if (shouldSaveConfig) {
    Serial.println("saving config");
    JsonObject& json = jsonBuffer.createObject();
    json["host"] = host;
    File configFile = SPIFFS.open("/config.json", "w");
    if (!configFile) {
      Serial.println("failed to open config file for writing");
    json.prettyPrintTo(Serial);
    json.printTo(configFile);
    configFile.close();
    Serial.println("config saved");
    ticker.detach();
    ESP.restart();
    delay(5000);
  if (WiFi.status() != WL_CONNECTED)
    WiFi_up();
  if ((millis() - time_last_chek) > Chek_delay) {
      check_host();
      time_last_chek = millis();
  if  (net_ok == false){
   if ((millis() - time_last) > reset_delay) {
     Serial.println("Reset");
     digitalWrite(Relay, HIGH);
     delay(5000);                             // Czas włączenia przekaźnika
     digitalWrite(Relay, LOW);
    yield();
void checkButton(){
  // check for button press
  int C_W_read = digitalRead(TRIGGER_PIN);{
   if (C_W_read != last_C_W_state) {
     time_last_C_W_change = millis();
   if ((millis() - time_last_C_W_change) > C_W_delay) {
     if (C_W_read != C_W_state) {
       C_W_state = C_W_read;
       if (C_W_state == LOW) {
        Serial.println("Triger config");
   last_C_W_state = C_W_read;
void WiFi_up()
  WiFi.begin();
  for (int x = 20; x > 0; x--)
    yield();
    if (WiFi.status() == WL_CONNECTED)
      break;
    else
      Serial.print(".");
      delay(200);
  //  ticker.attach(5.0, tick);  // 5.0 sek dioda ON i 5.0 sek dioda OFF podczas połączenia z WiFi
    ticker.detach();                                // Dioda wyłączona podczas połączenia z wifi ( źeby mrugneła podczas pingowania ).
      if (digitalRead(onboard_led == LOW)) {        //                          - II -
          digitalWrite(onboard_led, HIGH);          //                          - II -
          }                                         //                          - II -
    Serial.println("");
    Serial.println("Connected");
    Serial.println("Adres IP: ");
    Serial.print(WiFi.localIP());
    Serial.print(" / ");
    Serial.print(WiFi.subnetMask());
    long rssi = WiFi.RSSI();
    Serial.print("(RSSI): ");
    Serial.print(rssi);
    Serial.println(" dBm");
  else
    Serial.println("");
    net_ok = false;                                // new
PioKar
Uff. Teraz tak. Jest OK.
Sprawdziłem ping co 60 sek. Led w wemos miga.
Wyłączyłem Pi i po 60 sek zapaliła się led alarm.
Po 5 minutach włączył się przekażnik.
Włączyłem Pi i po chwili led alarm zgasła.
Mam to o co prosiłem.
Dziękuję.
ps: podłączam zasilanie pi do przekażnika.
elmaya
PioKar wrote: Thu Nov 21, 2019 2:35 pm Uff. Teraz tak. Jest OK.
Dziękuję.
port 443 or 80?
PioKar
80 ip local 192.168.1.xx
elmaya
PioKar wrote: Thu Nov 21, 2019 2:52 pm 80 ip local 192.168.1.xx
ok useful information if someone else needs it ;)
Dawid84
Czy da sie zmienic czas oczekiwania na reset?
Dawid
elmaya
Dawid84 wrote: Sat Nov 23, 2019 9:14 pm Czy da sie zmienic czas oczekiwania na reset?
unsigned long reset_delay = 300000; // 300000 --- Reset Delay in miliseconds --- ( Czas 5 min - do resetu. ) ;)
Dawid84
Ok mam prośbę czy dasz radę zrobic zeby czas oczekiwania na reset byl 5min i skompilowac do binarki .bin
Dawid
elmaya
Dawid84 wrote: Sat Nov 23, 2019 9:38 pm Ok mam prośbę czy dasz radę zrobic zeby czas oczekiwania na reset byl 5min i skompilowac do binarki .bin
I guess you mean the first version " Ping" . ;)
for the router you would be worth any of the last two (https and http) but here you also have it with ping 5 minutes to reset.
reset_router_5mi_DOUT_16Mbit.rar
Dawid84
Niewiem co robie źle wgrałem program podłączone wg. schematu ustwaienia wifi też zrobione po restercie załącza się przekaźnik i cały czas jest załączony dioda zgaszona kiedy wyłącze router dioda zapala się że niema internetu przekaźnik cały czas włączony po uplywie 5min powinien nastąpić reset czyli przekaźnik zostaje na chwilę wyłączony po czym załącza się ponownie. A umnie tak się nie dzieje czekałem 5min nawet 15min i nic cały czas jest załączony nie robi resetu.
Dawid
