SOnOff TH10 not booting with Supla. Help!
MilanGajic
lesny8 wrote: Thu Nov 14, 2019 12:02 am Cool :D
Unfortunately SI7021 is not supported.
AM2301 is off. Click on him and select his function.
I'm not sure, but in this software only one measurement channel can be active.
dang, this was actually the whole point. ;)
I need to mesure humidity in the bathroom and automatically turn on ventilation , which is in another room. If i get a AM2301 sensor for the TH10/16 ... will Supla allow me to do this? by "one channel", you mean either humidity or temp ?
(https://nl.aliexpress.com/item/40000477 ... b201603_52)
MilanGajic
lesny8 wrote: Thu Nov 14, 2019 12:10 am You can compile soft and upload through the Arduino IDE, but you need a minimum of programming knowledge to do this. If you feel up to it, give it a try ;)
I've only just wetted my toes in ESP waters. I do play with arduinos, and I was planning on trying some homebrew ESP software (possibly on the sonoff) ... but this will probably take some time to get around to ... :|
Been thanked: 9 times
MilanGajic wrote: Thu Nov 14, 2019 12:33 am ...
You can do this, but using Supla Scripts from @fracz. I have done so, but using other hardware.
MilanGajic wrote: Thu Nov 14, 2019 12:33 am ... by "one channel", you mean either humidity or temp ?
I mean one of them DS18B20 or AM2301. You are not able to physically connect two sensors, so in the Cloud you activate only the channel you connect.
SOP 2023 :heavy_check_mark:
SOP 2024 :heavy_check_mark:
🧩: 🔑cz->b ⛴️+ila
Return to “Help”
