8 blinds 16 buttons
Lesik
Hello. I have a question, is it possible to use monostable buttons ?? The first press the blind is opened, the second press stops, the third blind is closed, etc.
elmaya
only works with monostable buttons:
button up = up, stop, up, stop, ETC ..
button close = close, stop, close, stop, ETC ..
always with 2 monostable buttons per blind.
Lesik
Hello. At the beginning I would like to apologize for my English :). At the weekend I submitted a project with my friend Elmaya to 4 blinds. At the beginning, after pressing the button, the system lived its life. But we gave a pullup, i.e. a resistor connected to each button and given to the power supply (+ 3.3V). Everything started working great. Big applause for the project. Today we decided to use the project for 8 blinds. We also soldered resistors with power connection (+ 3.3V). And when connected, everything works great. But after a few operations on the blinds (closing and opening) with both Supla and buttons, the system stops responding. In supli, everything is active but nothing works. Similarly with buttons. I would ask for help.
19:41:58.733 ->
19:41:58.733 -> CONNECTED
19:41:58.733 -> local IP: 192.168.1.33
19:41:58.733 -> subnetMask: 255.255.255.0
19:41:58.733 -> gatewayIP: 192.168.1.1
19:41:58.733 -> Signal Strength (RSSI): -13 dBm
19:41:59.683 -> status: 10
19:41:59.750 -> status: 17
19:42:35.672 -> Mcp 2A input 223
19:42:35.740 -> 5 Shut
19:43:53.817 -> write position 3:100
19:44:04.919 -> write position 3:1926
19:44:33.949 -> write position 5:3999
19:44:49.086 -> write position 5:100
19:45:30.423 -> Mcp 2B input 247
19:45:30.490 -> 3 Reveal
19:45:35.934 -> write position 3:100
19:47:12.179 -> write position 4:100
19:47:19.288 -> write position 4:1286
19:47:19.592 -> write position 2:10100
19:47:20.578 -> write position 2:10100
19:47:21.292 -> write position 4:1675
19:47:21.599 -> write position 1:10100
19:47:21.599 -> write position 2:10100
19:47:22.341 -> write position 4:1861
19:47:22.894 -> write position 0:10100
19:47:23.617 -> write position 5:823
19:47:24.363 -> write position 4:2252
19:47:25.042 -> write position 3:1293
19:47:26.067 -> write position 3:1505
19:47:26.370 -> write position 4:2651
19:47:27.086 -> write position 3:1708
19:47:27.397 -> write position 4:2829
19:47:28.085 -> write position 3:1889
19:47:28.733 -> write position 5:1595
19:47:29.106 -> write position 3:2090
19:47:29.413 -> write position 4:3246
19:47:30.160 -> write position 3:2293
19:47:30.429 -> write position 4:3447
19:47:30.765 -> write position 5:1923
19:47:31.177 -> write position 3:2522
19:47:31.449 -> write position 4:3676
19:47:32.167 -> write position 3:2721
19:47:32.471 -> write position 4:3897
19:47:32.785 -> write position 5:2272
19:47:33.201 -> write position 3:2934
19:47:33.503 -> write position 4:4107
19:47:34.216 -> write position 3:3155
19:47:34.519 -> write position 4:4304
19:47:34.753 -> write position 5:2619
19:47:35.231 -> write position 3:3346
19:47:35.534 -> write position 4:4515
19:47:36.282 -> write position 3:3547
19:47:36.548 -> write position 4:4712
19:47:36.785 -> write position 5:2968
19:47:37.264 -> write position 3:3779
19:47:37.575 -> write position 4:4923
19:47:38.293 -> write position 3:3979
19:47:38.599 -> write position 4:5140
19:47:38.803 -> write position 5:3292
19:47:39.347 -> write position 3:4192
19:47:40.332 -> write position 3:4405
19:47:40.605 -> write position 4:5556
19:47:40.840 -> write position 5:3631
19:47:41.351 -> write position 3:4621
19:47:41.621 -> write position 4:5767
19:47:42.366 -> write position 3:4845
19:47:42.677 -> write position 4:5966
19:47:43.401 -> write position 3:5045
19:47:43.672 -> write position 4:6184
19:47:44.687 -> write position 4:6393
19:47:44.892 -> write position 5:4324
19:47:45.432 -> write position 3:5481
19:47:45.705 -> write position 4:6599
19:47:46.420 -> write position 3:5678
19:47:46.757 -> write position 4:6815
19:47:47.480 -> write position 3:5886
19:47:47.760 -> write position 4:7041
19:47:47.861 -> write position 2:10100
19:47:48.476 -> write position 3:6072
19:47:48.881 -> write position 2:10100
19:47:48.915 -> write position 1:10100
19:47:49.187 -> write position 0:10100
19:47:49.492 -> write position 3:6270
19:47:49.794 -> write position 4:7406
19:47:49.897 -> write position 2:10100
19:47:49.931 -> write position 1:10096
19:47:50.001 -> write position 5:5125
19:47:50.205 -> write position 0:10100
19:47:50.541 -> write position 3:6492
19:47:50.812 -> write position 4:7589
19:47:50.880 -> write position 2:10100
19:47:50.915 -> write position 1:10100
19:47:51.222 -> write position 0:10096
19:47:51.828 -> write position 4:7798
19:47:51.897 -> write position 2:10100
19:47:51.964 -> write position 1:10100
19:47:51.999 -> write position 5:5450
19:47:52.241 -> write position 0:10100
19:47:52.549 -> write position 3:6939
19:47:52.861 -> write position 4:8039
19:47:52.931 -> write position 2:10100
19:47:52.966 -> write position 1:10100
19:47:53.279 -> write position 0:10100
19:47:53.549 -> write position 3:7161
19:47:53.888 -> write position 4:8256
19:47:53.955 -> write position 2:10100
19:47:53.990 -> write position 1:10100
19:47:54.263 -> write position 0:10100
19:47:54.604 -> write position 3:7388
19:47:54.909 -> write position 4:8475
19:47:55.012 -> write position 1:10100
19:47:55.282 -> write position 0:10100
19:47:55.924 -> write position 4:8663
19:47:56.061 -> write position 5:6183
19:47:56.602 -> write position 3:7806
19:47:56.939 -> write position 4:8893
19:47:57.632 -> write position 3:8035
19:47:57.975 -> write position 4:9095
19:47:58.317 -> write position 0:10100
19:47:58.625 -> write position 3:8214
19:47:58.965 -> write position 4:9269
19:47:59.103 -> write position 5:6653
19:47:59.645 -> write position 3:8375
19:47:59.987 -> write position 4:9432
19:48:00.125 -> write position 5:6784
19:48:00.669 -> write position 3:8586
19:48:01.144 -> write position 5:6943
19:48:01.681 -> write position 3:8790
19:48:02.025 -> write position 4:9858
19:48:02.742 -> write position 3:9010
19:48:03.054 -> write position 4:10079
19:48:03.156 -> write position 5:7296
19:48:03.728 -> write position 3:9225
19:48:04.066 -> write position 4:10100
19:48:04.740 -> write position 3:9426
elmaya
Lesik wrote: Thu Jun 04, 2020 5:59 pm Hello. At the beginning I would like to apologize for my English :). At the weekend I submitted a project with my friend Elmaya to 4 blinds. At the beginning, after pressing the button, the system lived its life. But we gave a pullup, i.e. a resistor connected to each button and given to the power supply (+ 3.3V). Everything started working great. Big applause for the project. Today we decided to use the project for 8 blinds. We also soldered resistors with power connection (+ 3.3V). And when connected, everything works great. But after a few operations on the blinds (closing and opening) with both Supla and buttons, the system stops responding. In supli, everything is active but nothing works. Similarly with buttons. I would ask for help.
19:41:58.733 ->
I have seen the serial log and it seems that the Mcp23017 that controls the relays is not connected or does not work.
please check your connections.
piotrekk
scan i2c and see if it detects you?
Lesik
Hello. I checked with an i2c scanner and detects two modules. I corrected one connection and everything works ok. The buttons work and the system correctly saves the position of the blind. However, when I connect the relays, everything returns to normal. The system just hangs. The relays are controlled high. I still have relays but controlled low. Could someone embed a compiled project to control low state relays?
elmaya
software is incompatible with relays active in low state, precisely because of what happens to you.
!! It will only work with high level active relays !!
there will be no other version.
piotrekk
use bc547c or uln2008
radzik_r
Return to “Ideas and concepts”
