Automatyczny reset - da się?
Tu @elmaya
Ci podawał łącznie z adresem:
viewtopic.php?p=54769#p54769
elmaya
Yes, I know what module you use.
This module controls the relay through the serial port and there must be something strange.
install PuTTY and configure as in the image.
click on Open.
In the window that appears, see whats appears when the relay makes contact and sends a screenshot.
A jaki masz u siebie moduł.
ESP-01 czy ESP-01S
Może, tu jest problem.
Bo one się różnią od siebie.
https://nettigo.pl/products/modul-wifi- ... rzewodowej
kindziol
Witam ponownie.
Posiadam urządzenie ESP-01
Czyszcze tym blank_1MB.bin pod adresem 0x00000 Flash size 16 mbit
Programuje tym Kindziol2.bin pod adresem 0x00000 Flash size 4mbit
A wygląda to tak:
https://youtu.be/nuAwTcFcgXI
elmaya
no video....is as private
PuTTY ?????? :(
kindziol
elmaya wrote: Sun Dec 01, 2019 1:04 pm no video....is as private
PuTTY ?????? :(
poszło
elmaya
kindziol wrote: Sun Dec 01, 2019 1:15 pm
PuTTY ?????? :(
poszło
Very beautiful but totally useless.
I need to see the screenshots of PuTTY or we can't continue.
kindziol
elmaya wrote: Sun Dec 01, 2019 1:19 pm
PuTTY ?????? :(
poszło
Proszę
elmaya
please show me what's it goes on reset.
should be like this:
mounting FS...
mounted file system
reading config file
opened config file
40
{"host":"www.google.com","Reset_delay":"5"}
parsed json
reset delay: 300000
Connected
Adres IP:
192.168.1.114 / 255.255.255.0 / 192.168.1.1
(RSSI): -30 dBm
Pinging host www.google.com
Success!!
