elmaya wrote: Sun Dec 01, 2019 2:19 pm please show me what's it goes on reset.
should be like this:
mounting FS... mounted file system reading config file opened config file 40 {"host":"www.google.com","Reset_delay":"5"} parsed json reset delay: 300000 ................ Connected Adres IP: 192.168.1.114 / 255.255.255.0 / 192.168.1.1 (RSSI): -30 dBm Pinging host www.google.com Success!!
Automatyczny reset - da się?
kindziol
elmaya
when you have it connected, connect for a moment RST to GND so that it resets and can see the start.
elmaya
Load this, it will show me the time.
Remember to delete before loading.
I will be out for a couple of hours.
elmaya
I don't know what you have in the flash but it's definitely NOT one of the last 10 that I've sent !!!!!
Check what and how you upload it !!!!!
if you access wifi config you should see this
kindziol
po wgraniu i resetelmaya wrote: Sun Dec 01, 2019 3:06 pmI don't know what you have in the flash but it's definitely NOT one of the last 10 that I've sent !!!!!
elmaya
It seems we have some problem with SPIFFS(FS).
Please try the following:
enter into wificonfig
click on Info.
click on Erase WiFi Config.
The module restarts.
Enter Wificonfig
Complete with your data.
Check if the data changes on the serial terminal (PuTTY).
click on Info.
Enter Wificonfig
elmaya
finally find the bug!
If in wificonfig you do not set the correct data (SSID, Pass) or at the time of the configuration the Ap is not operational will do exactly what you describe.
conclusion.
When configuring WiFiConfig, the Ap must be operational and the data must be correct otherwise it does not save the data and the resulting effect is that of continuous restarts.
updated
correction to always save wifi config data.
viewtopic.php?p=54829#p54829
conclusion.
updated
kindziol
Zrobiłem wszystko co napisałeś ale niestety jest tak samo. Chyba muszę zrezygnować z tego urządzenia.elmaya wrote: Sun Dec 01, 2019 6:16 pm finally find the bug!
conclusion.
updated
elmaya
You have not downloaded the file!
How have you tried it without downloading?
