https://pl.aliexpress.com/item/10050053 ... pt=glo2pol
============ After Setup End =============
[ 29275][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 29277][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 29817][I][ZigbeeCore.cpp:299] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x2aac)
[ 29817][V][ZigbeeCore.cpp:303] esp_zb_app_signal_handler(): Device capabilities: 0x80
[ 29927][D][ZigbeeGateway.cpp:128] find_Cb(): Sensor found: short address(0x2aac), endpoint(1)
[ 30020][I][ZigbeeGateway.cpp:271] printJoinedDevices(): joined devices:
[ 30020][I][ZigbeeGateway.cpp:274] printJoinedDevices(): Device on endpoint 1, short address: 0x2aac
[ 30137][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 30137][V][ZigbeeHandlers.cpp:94] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x2aac) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 30138][V][ZigbeeHandlers.cpp:103] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(16)
[ 30139][I][ZigbeeEP.cpp:223] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_yj6k7vfo"
[ 30021][I][Z2S_Device_Scanner.ino:88] loop(): manufacturer _TZ3000_yj6k7vfo
[ 30258][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 30258][V][ZigbeeHandlers.cpp:94] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x2aac) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 30259][V][ZigbeeHandlers.cpp:103] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(6)
[ 30259][I][ZigbeeEP.cpp:232] zbReadBasicCluster(): Peer Model is "TS0041"
[ 30140][I][Z2S_Device_Scanner.ino:89] loop(): model TS0041
[ 30261][I][ZigbeeGateway.cpp:207] zbPrintDeviceDiscovery(): short_addr_req 10924
[ 30315][I][ZigbeeGateway.cpp:141] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 10924, endpoints count 4
[ 30316][I][ZigbeeGateway.cpp:144] Z2S_active_ep_req_cb(): Endpont # 1, id 1
[ 30316][I][ZigbeeGateway.cpp:144] Z2S_active_ep_req_cb(): Endpont # 2, id 2
[ 30317][I][ZigbeeGateway.cpp:144] Z2S_active_ep_req_cb(): Endpont # 3, id 3
[ 30317][I][ZigbeeGateway.cpp:144] Z2S_active_ep_req_cb(): Endpont # 4, id 4
[ 30442][I][ZigbeeGateway.cpp:160] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 10924, endpoint # 1
[ 30442][I][ZigbeeGateway.cpp:161] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 4, out clusters # 2
[ 30443][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 1, id 1
[ 30443][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 2, id 6
[ 30444][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 3, id 57344
[ 30444][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 4, id 0
[ 30445][I][ZigbeeGateway.cpp:180] Z2S_simple_desc_req_cb(): Out cluster # 1, id 25
[ 30445][I][ZigbeeGateway.cpp:180] Z2S_simple_desc_req_cb(): Out cluster # 2, id 10
[ 30461][I][ZigbeeGateway.cpp:160] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 10924, endpoint # 2
[ 30462][I][ZigbeeGateway.cpp:161] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 3, out clusters # 0
[ 30462][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 1, id 6
[ 30463][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 2, id 1
[ 30463][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 3, id 6
[ 30478][I][ZigbeeGateway.cpp:160] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 10924, endpoint # 3
[ 30479][I][ZigbeeGateway.cpp:161] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 3, out clusters # 0
[ 30479][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 1, id 6
[ 30480][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 2, id 1
[ 30480][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 3, id 6
[ 30495][I][ZigbeeGateway.cpp:160] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 10924, endpoint # 4
[ 30496][I][ZigbeeGateway.cpp:161] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 3, out clusters # 0
[ 30497][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 1, id 6
[ 30497][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 2, id 1
[ 30498][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 3, id 6
[ 30523][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 30523][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0x1), attribute id (0x0), data type (0x21)
[ 30524][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0x1), attribute id (0x20), data type (0x20)
[ 30525][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0x1), attribute id (0x21), data type (0x20)
[ 30526][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0x1), attribute id (0xfffd), data type (0x21)
[ 30540][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 30540][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0x6), attribute id (0x0), data type (0x10)
[ 30554][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 30555][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0xe000), attribute id (0x0), data type (0x10)
[ 30556][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0xe000), attribute id (0x1), data type (0x10)
[ 30572][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 30572][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0x0), attribute id (0x0), data type (0x20)
[ 30573][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0x0), attribute id (0x1), data type (0x20)
[ 30574][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0x0), attribute id (0x2), data type (0x20)
[ 30574][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0x0), attribute id (0x3), data type (0x20)
[ 30575][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0x0), attribute id (0x4), data type (0x42)
[ 30576][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0x0), attribute id (0x5), data type (0x42)
[ 30577][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0x0), attribute id (0x6), data type (0x42)
[ 30578][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0x0), attribute id (0x7), data type (0x30)
[ 30578][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0x0), attribute id (0xffde), data type (0x20)
[ 30579][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0x0), attribute id (0xfffd), data type (0x21)
[ 30580][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0x0), attribute id (0xfffe), data type (0x30)
[ 30581][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0x0), attribute id (0xffe2), data type (0x20)
[ 30582][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0x0), attribute id (0xffe3), data type (0x48)
[ 30597][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 30598][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0x19), attribute id (0x0), data type (0xf0)
[ 30599][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0x19), attribute id (0x1), data type (0x23)
[ 30599][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0x19), attribute id (0x2), data type (0x23)
[ 30600][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0x19), attribute id (0x3), data type (0x21)
[ 30601][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0x19), attribute id (0x4), data type (0x23)
[ 30602][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0x19), attribute id (0x5), data type (0x21)
[ 30603][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0x19), attribute id (0x6), data type (0x30)
[ 30604][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0x19), attribute id (0x7), data type (0x21)
[ 30605][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0x19), attribute id (0x8), data type (0x21)
[ 30605][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0x19), attribute id (0x9), data type (0x21)
[ 30606][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0x19), attribute id (0xfffd), data type (0x21)
[ 30620][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 30621][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x1), source cluster (0xa), attribute id (0xfffd), data type (0x21)
[ 30645][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 30645][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x2), source cluster (0x6), attribute id (0x0), data type (0x10)
[ 30660][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 30660][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x2), source cluster (0x1), attribute id (0x0), data type (0x21)
[ 30661][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x2), source cluster (0x1), attribute id (0x20), data type (0x20)
[ 30662][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x2), source cluster (0x1), attribute id (0x21), data type (0x20)
[ 30663][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x2), source cluster (0x1), attribute id (0xfffd), data type (0x21)
[ 30676][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 30677][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x2), source cluster (0x6), attribute id (0x0), data type (0x10)
[ 30700][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 30701][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x3), source cluster (0x6), attribute id (0x0), data type (0x10)
[ 30715][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 30716][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x3), source cluster (0x1), attribute id (0x0), data type (0x21)
[ 30717][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x3), source cluster (0x1), attribute id (0x20), data type (0x20)
[ 30718][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x3), source cluster (0x1), attribute id (0x21), data type (0x20)
[ 30718][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x3), source cluster (0x1), attribute id (0xfffd), data type (0x21)
[ 30732][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 30733][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x3), source cluster (0x6), attribute id (0x0), data type (0x10)
[ 30757][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 30757][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x4), source cluster (0x6), attribute id (0x0), data type (0x10)
[ 30772][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 30772][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x4), source cluster (0x1), attribute id (0x0), data type (0x21)
[ 30773][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x4), source cluster (0x1), attribute id (0x20), data type (0x20)
[ 30774][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x4), source cluster (0x1), attribute id (0x21), data type (0x20)
[ 30775][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x4), source cluster (0x1), attribute id (0xfffd), data type (0x21)
[ 30778][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
[ 30779][I][ZigbeeGateway.cpp:357] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0x2aac), source endpoint (0x4), source cluster (0x6), attribute id (0x0), data type (0x10)
[ 31244][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[ 31316][I][ZigbeeCore.cpp:330] esp_zb_app_signal_handler(): Network(0x3882) is open for 180 seconds
[183356][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
[207132][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
[210145][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
[211316][I][ZigbeeCore.cpp:332] esp_zb_app_signal_handler(): Network(0x3882) closed, devices joining not allowed.
[213209][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
[216222][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
[219234][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
[222246][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
[225259][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
[228273][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
[231285][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
[234297][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
[237309][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
[247831][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
[250992][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
[274363][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
