v22.07
fracz
Has thanked: 4 times
Been thanked: 6 times
PuteR wrote: Sun Jul 31, 2022 3:58 pm fracz da radę coś z tym zrobić w niedługim czasie bo nie wiem czy czekać czy raczej już przywracać kopię zapasową.
Pokaż logi tylko z clouda.
docker-compose logs supla-cloud
Zrestartuj?
./supla.sh restart
Jesteś teraz online?
PuteR
fracz wrote: Sun Jul 31, 2022 8:18 pm
Zrestartuj?
./supla.sh restart
log z clouda
pi@RPI-4:~/supla-docker$ docker-compose logs supla-cloud
Attaching to supla-cloud
supla-cloud     | Database connection has been established.
supla-cloud     |
supla-cloud     |                     Application Migrations
supla-cloud     |
supla-cloud     |
supla-cloud     | Migrating up to 20220719210858 from 20220208164512
supla-cloud     |
supla-cloud     |   ++ migrating 20220222110707
supla-cloud     |
supla-cloud     |      -> DROP PROCEDURE IF EXISTS `supla_update_channel_flags`
supla-cloud     |      -> DROP PROCEDURE IF EXISTS `supla_update_iodevice`
supla-cloud     |      -> CREATE PROCEDURE `supla_update_channel_flags`(IN `_channel_id` INT, IN `_user_id` INT, IN `_flags` INT)
supla-cloud     |     NO SQL
supla-cloud     | UPDATE supla_dev_channel SET flags = IFNULL(flags, 0) | IFNULL(_flags, 0) WHERE id = _channel_id AND user_id = _user_id
supla-cloud     |      -> CREATE PROCEDURE `supla_update_iodevice`(IN `_name` VARCHAR(100) CHARSET utf8mb4, IN `_last_ipv4` INT(10) UNSIGNED,
supla-cloud     |   IN `_software_version` VARCHAR(20) CHARSET utf8, IN `_protocol_version` INT(11), IN `_original_location_id` INT(11),
supla-cloud     |   IN `_auth_key` VARCHAR(64) CHARSET utf8, IN `_id` INT(11), IN `_flags` INT(11))
supla-cloud     | BEGIN
supla-cloud     | UPDATE `supla_iodevice`
supla-cloud     | SET
supla-cloud     | `name` = _name,
supla-cloud     | `last_connected` = UTC_TIMESTAMP(),
supla-cloud     | `last_ipv4` = _last_ipv4,
supla-cloud     | `software_version` = _software_version,
supla-cloud     | `protocol_version` = _protocol_version,
supla-cloud     | original_location_id = _original_location_id,
supla-cloud     | `flags` = IFNULL(`flags`, 0) | IFNULL(_flags, 0) WHERE `id` = _id;
supla-cloud     | IF _auth_key IS NOT NULL THEN
supla-cloud     |   SET `auth_key` = _auth_key WHERE `id` = _id AND `auth_key` IS NULL;
supla-cloud     | END IF;
supla-cloud     | END
supla-cloud     |
supla-cloud     |   ++ migrated (took 0ms, used 16M memory)
supla-cloud     |
supla-cloud     |   ++ migrating 20220309061811
supla-cloud     |
supla-cloud     |      -> ALTER TABLE supla_accessid ADD active_from DATETIME DEFAULT NULL COMMENT '(DC2Type:utcdatetime)', ADD active_to DATETIME DEFAULT NULL COMMENT '(DC2Type:utcdatetime)', ADD active_hours VARCHAR(768) DEFAULT NULL
supla-cloud     |
supla-cloud     |
supla-cloud     |   ++ migrating 20220309061812
supla-cloud     |
supla-cloud     |      -> DROP FUNCTION IF EXISTS supla_current_weekday_hour
supla-cloud     |      ->         CREATE FUNCTION supla_current_weekday_hour(`user_timezone` VARCHAR(50))
supla-cloud     |         RETURNS VARCHAR(3)
supla-cloud     |         BEGIN
supla-cloud     |             DECLARE current_weekday INT;
supla-cloud     |             DECLARE current_hour INT;
supla-cloud     |             DECLARE current_time_in_user_timezone DATETIME;
supla-cloud     |             SELECT COALESCE(CONVERT_TZ(CURRENT_TIMESTAMP, 'UTC', `user_timezone`), UTC_TIMESTAMP) INTO current_time_in_user_timezone;
supla-cloud     |             SELECT (WEEKDAY(current_time_in_user_timezone) + 1) INTO current_weekday;
supla-cloud     |             SELECT HOUR(current_time_in_user_timezone) INTO current_hour;
supla-cloud     |             RETURN CONCAT(current_weekday, current_hour);
supla-cloud     |         END
supla-cloud     |      -> DROP FUNCTION IF EXISTS supla_is_access_id_now_active
supla-cloud     |      ->         CREATE FUNCTION supla_is_access_id_now_active(`active_from` DATETIME, `active_to` DATETIME, `active_hours` VARCHAR(768), `user_timezone` VARCHAR(50))
supla-cloud     |         RETURNS int(11)
supla-cloud     |         BEGIN
supla-cloud     |             DECLARE res INT DEFAULT 1;
supla-cloud     |
supla-cloud     |             IF `active_from` IS NOT NULL THEN
supla-cloud     |               SELECT (active_from <= UTC_TIMESTAMP) INTO res;
supla-cloud     |
supla-cloud     |             IF res = 1 AND `active_to` IS NOT NULL THEN
supla-cloud     |               SELECT (active_to >= UTC_TIMESTAMP) INTO res;
supla-cloud     |
supla-cloud     |             IF res = 1 AND `active_hours` IS NOT NULL THEN
supla-cloud     |               SELECT (`active_hours` LIKE CONCAT('%,', supla_current_weekday_hour(`user_timezone`) ,',%') COLLATE utf8mb4_unicode_ci) INTO res;
supla-cloud     |
supla-cloud     |             RETURN res;
supla-cloud     |         END
supla-cloud     |      ->         CREATE OR REPLACE VIEW supla_v_accessid_active AS
supla-cloud     |         SELECT sa.*, supla_is_access_id_now_active(active_from, active_to, active_hours, timezone) is_now_active
supla-cloud     |         FROM supla_accessid sa
supla-cloud     |         INNER JOIN supla_user su ON su.id = sa.user_id;
supla-cloud     |
supla-cloud     |
supla-cloud     |   ++ migrating 20220404100406
supla-cloud     |
supla-cloud     |      ->             UPDATE supla_dev_channel c
supla-cloud     |             SET caption = CONCAT(
supla-cloud     |                 (SELECT COALESCE(caption, '') FROM (SELECT * FROM supla_dev_channel) AS t WHERE id=c.param1),
supla-cloud     |                 ' AT'
supla-cloud     |             )
supla-cloud     |             WHERE func = 700 AND param1 > 0 AND (caption IS NULL OR caption = '');
supla-cloud     |
supla-cloud     |   ++ migrated (took 0ms, used 18M memory)
supla-cloud     |
supla-cloud     |   ++ migrating 20220718203129
supla-cloud     |
supla-cloud     |      -> ALTER TABLE supla_user ADD limit_operations_per_scene INT DEFAULT 20 NOT NULL
supla-cloud     |
supla-cloud     |
supla-cloud     |   ++ migrating 20220719210858
supla-cloud     |
supla-cloud     |      -> ALTER TABLE supla_scene ADD alt_icon TINYINT UNSIGNED DEFAULT 0 NOT NULL COMMENT '(DC2Type:tinyint)'
supla-cloud     |
supla-cloud     |
supla-cloud     |   ------------------------
supla-cloud     |
supla-cloud     |   ++ finished in 0ms
supla-cloud     |   ++ used 18M memory
supla-cloud     |   ++ 6 migrations executed
supla-cloud     |   ++ 13 sql queries
supla-cloud     |
supla-cloud     |  [OK] The "async" transport was set up successfully.
supla-cloud     |
supla-cloud     | Client for webapp exists.
supla-cloud     |
supla-cloud     |  // Warming up the cache for the prod environment with debug
supla-cloud     |  // false
supla-cloud     |
restart robiłem i teraz urządzenia przynajmniej połączyły się z serwerem, działa też aplikacja. Jedynie co nie działa to nie mogę wejść na clouda wyświetla błąd
502 Bad Gateway
nie dokonywałem żadnych zmian w sieci po za aktualizacją.
fracz
@lukfud, czy problem u Ciebie równiez jest na malinie?
Ta aktualizacja ma sporo migracji, i malina pewnie wykonuje je dłużej niż serwer zakłada. Postaram się uniemożliwić taką sytuację w następnym wydaniu. Na teraz - restart powinien pomóc (serwer jeszcze raz sprawdzi, czy jest ok - i już powinno być ok).
lukfud
Has thanked: 13 times
Been thanked: 11 times
fracz wrote: Sun Jul 31, 2022 8:47 pm @lukfud, czy problem u Ciebie równiez jest na malinie?
Tak, na malinie.
U mnie cloud nie pokazuje żadnych logów, pusto.
pi@raspi:~/supla-docker $ docker-compose logs supla-cloud
do tego 100% procesora na
php bin/console supla:initialize
https://smartnerzeczy.pl
fracz
Problem z malinami zdiagnozowany. Niestety wymagana jest Wasza akcja, by aplikacja ruszyła...
Opis tutaj: viewtopic.php?p=127216
fracz
YoMan wrote: Sun Jul 31, 2022 2:55 pm Nie wiem czy to niszowy problem ...
na Firefoxie 103.0 (64bit) nie działają harmonogramy dostępu. Pojawia się pusta tabelka, w której nic nie można zaznaczyć.
Niestety problem nie jest niszowy. Firefox nie ogarnął mojej weny. Do poprawy, dzięki!
rafalfarba
Czy jest możliwe, że po wprowadzeniu v22.7 skomplikowała się komunikacja ze skryptami? Mam nadal sceny po stronie skryptów i widzę, że czasami coś wstrzymuje wykonanie sceny. Problem znika po ponownym zalogowaniu do skryptów.
EDIT:
Ponownie dzisiaj, niezadziałała scena powodu niespełnionego warunku. Który po ponownym zalogowaniu już był spełniony.
4xSonoff RF (GUI Generic), 3xSonoff Basic (GUI Generic), 5×ESP-01S (GUI Generic), 1xWemosD1(termostat), Yunshan (Gate module od Zybi), 2xSonoff Mini (soft od djack2017). 1xWemosD1 (GUI Generic licznik impulsów + czujnik ilości opału HC-SR04+przekaźnik)
arqiu70
pzygmunt wrote: Sun Jul 31, 2022 7:56 pm Problem dot. GH i Alexy powinien być już rozwiązany.
Potwierdzam działa wielkie dzięki.
Arghatell
rafalfarba wrote: Mon Aug 01, 2022 12:41 pm Czy jest możliwe, że po wprowadzeniu v22.7 skomplikowała się komunikacja ze skryptami? Mam nadal sceny po stronie skryptów i widzę, że czasami coś wstrzymuje wykonanie sceny. Problem znika po ponownym zalogowaniu do skryptów.
EDIT:
U mnie też takie rzeczy. Obecnie nie działa logowanie do svr35 a od niedzieli wykonywanie skryptów wznawia się po zalogowaniu do skryptów randomowo/czasowo. Dzisiaj padło ok 16:00. U mnie problem dość osobliwy, bo kontroluję pracę urządzeń (kamery, alarm, pompka w oczku itp, które głównie pracują z PV przy nadmiarze napięcia) w oparciu o stan napięcia akumulatorów (zasilane z paneli) i jeśli skrypty nie wyłączą prądożernych urządzeń, to system mi padnie z powodu braku zasilania w nocy. Gdybym wiedział, to bym nie włączał wcześniej.
Przeloguj się w cloud i w skryptach.
Return to “Nowości”
