Pomóżcie proszę początkującemu
Has thanked: 135 times
Gniazdko:
============ After Setup End =============
[ 30706][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 30708][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 30743][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x53ea)
[ 30744][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x8e
[ 30744][D][ZigbeeGateway.cpp:547] zbDeviceAnnce(): zbDeviceAnnce short address (0x53ea), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[ 30745][D][ZigbeeGateway.cpp:550] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x53ea), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[ 30746][I][ZigbeeGateway.cpp:574] zbDeviceAnnce(): Tuya magic last hope
[ 31279][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0x9b9b) is open for 180 seconds
[ 31284][I][ZigbeeGateway.cpp:363] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[ 31352][I][ZigbeeHandlers.cpp:62] zb_raw_cmd_handler(): cluster id: 0xa, command id: 0
[ 31353][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): src endpoint (0x2, dst endpoint 0x1
[ 31353][I][ZigbeeHandlers.cpp:64] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
[ 31354][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): manuf_specific 0x0
[ 31354][I][ZigbeeHandlers.cpp:67] zb_raw_cmd_handler(): RAW bufid: 14 size: 12
[ 31355][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x01
[ 31355][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 31356][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 31356][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x02
[ 31357][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x03
[ 31357][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 31357][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x04
[ 31358][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 31358][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x05
[ 31359][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 31359][I][ZigbeeHandlers.cpp:74] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x53ea, 0x53ea, 0x0, 0x0
[ 31360][I][ZigbeeHandlers.cpp:88] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[ 32288][I][ZigbeeGateway.cpp:369] zbQueryDeviceBasicCluster(): basic tsn 0x1
[ 35288][I][ZigbeeGateway.cpp:382] zbQueryDeviceBasicCluster(): basic tsn 0x2
[ 37288][E][ZigbeeGateway.cpp:385] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x4
[ 37288][D][ZigbeeGateway.cpp:478] bindDeviceCluster(): Requesting ZED (0x53ea), endpoint (0x23), cluster_id (0x500) to bind ZC
[ 37317][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0x53ea), endpoint (0x23), cluster (0x500)
[ 37318][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 37515][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0x53ea), endpoint (0x23), cluster (0x500)
[ 37516][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 37720][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0x53ea), endpoint (0x23), cluster (0x500)
[ 37721][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 37920][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0x53ea), endpoint (0x23), cluster (0x500)
[ 37921][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 38113][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0x53ea), endpoint (0x23), cluster (0x500)
[ 38113][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 38314][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0x53ea), endpoint (0x23), cluster (0x500)
[ 38315][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 38491][D][ZigbeeGateway.cpp:523] bindDeviceCluster(): Requesting ZC to bind ZED (0x53ea), endpoint (0x23), cluster_id (0x500)
[ 38494][I][ZigbeeGateway.cpp:212] bindCb(): ZC has bounded to ZED (0x53ea), endpoint (0x23) cluster (0x500)
[ 38495][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 43251][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[ 43291][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[ 45709][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[ 45734][I][ZigbeeCore.cpp:406] esp_zb_app_signal_handler(): Joined device is leaving network (short: 0x53ea), rejoin (NO)
[ 46292][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[ 55676][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 55678][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 55720][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x53ea)
[ 55721][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x8e
[ 55722][D][ZigbeeGateway.cpp:547] zbDeviceAnnce(): zbDeviceAnnce short address (0x53ea), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[ 55722][D][ZigbeeGateway.cpp:550] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x53ea), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[ 55723][I][ZigbeeGateway.cpp:574] zbDeviceAnnce(): Tuya magic last hope
[ 56250][I][ZigbeeGateway.cpp:363] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[ 56271][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0x9b9b) is open for 180 seconds
[ 56312][I][ZigbeeHandlers.cpp:62] zb_raw_cmd_handler(): cluster id: 0xa, command id: 0
[ 56313][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): src endpoint (0x2, dst endpoint 0x1
[ 56313][I][ZigbeeHandlers.cpp:64] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
[ 56314][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): manuf_specific 0x0
[ 56314][I][ZigbeeHandlers.cpp:67] zb_raw_cmd_handler(): RAW bufid: 7 size: 12
[ 56315][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x01
[ 56315][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 56316][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 56316][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x02
[ 56317][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 56317][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x03
[ 56318][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x04
[ 56318][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 56319][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x05
[ 56319][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 56319][I][ZigbeeHandlers.cpp:74] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x53ea, 0x53ea, 0x0, 0x0
[ 56320][I][ZigbeeHandlers.cpp:88] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[ 57250][I][ZigbeeGateway.cpp:369] zbQueryDeviceBasicCluster(): basic tsn 0x4
[ 60250][I][ZigbeeGateway.cpp:382] zbQueryDeviceBasicCluster(): basic tsn 0x5
[ 62250][E][ZigbeeGateway.cpp:385] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x4
[ 62250][D][ZigbeeGateway.cpp:478] bindDeviceCluster(): Requesting ZED (0x53ea), endpoint (0x23), cluster_id (0x500) to bind ZC
[ 62549][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0x53ea), endpoint (0x23), cluster (0x500)
[ 62550][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 62588][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0x53ea), endpoint (0x23), cluster (0x500)
[ 62589][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 62778][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0x53ea), endpoint (0x23), cluster (0x500)
[ 62778][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 62974][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0x53ea), endpoint (0x23), cluster (0x500)
[ 62975][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 63186][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0x53ea), endpoint (0x23), cluster (0x500)
[ 63186][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 63405][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0x53ea), endpoint (0x23), cluster (0x500)
[ 63406][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 63551][D][ZigbeeGateway.cpp:523] bindDeviceCluster(): Requesting ZC to bind ZED (0x53ea), endpoint (0x23), cluster_id (0x500)
[ 63554][I][ZigbeeGateway.cpp:212] bindCb(): ZC has bounded to ZED (0x53ea), endpoint (0x23) cluster (0x500)
[ 63555][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 68228][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[ 68253][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[ 70679][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[ 70705][I][ZigbeeCore.cpp:406] esp_zb_app_signal_handler(): Joined device is leaving network (short: 0x53ea), rejoin (NO)
[ 71254][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
NLME Status Indication, status: 0x0
[ 81045][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 81047][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 81077][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x53ea)
[ 81078][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x8e
[ 81079][D][ZigbeeGateway.cpp:547] zbDeviceAnnce(): zbDeviceAnnce short address (0x53ea), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[ 81079][D][ZigbeeGateway.cpp:550] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x53ea), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[ 81080][I][ZigbeeGateway.cpp:574] zbDeviceAnnce(): Tuya magic last hope
[ 81602][I][ZigbeeGateway.cpp:363] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[ 81613][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0x9b9b) is open for 180 seconds
[ 81644][I][ZigbeeHandlers.cpp:62] zb_raw_cmd_handler(): cluster id: 0xa, command id: 0
[ 81645][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): src endpoint (0x2, dst endpoint 0x1
[ 81645][I][ZigbeeHandlers.cpp:64] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
[ 81646][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): manuf_specific 0x0
[ 81646][I][ZigbeeHandlers.cpp:67] zb_raw_cmd_handler(): RAW bufid: 8 size: 12
[ 81647][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x01
[ 81647][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 81648][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 81648][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x02
[ 81649][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x03
[ 81649][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 81650][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x04
[ 81650][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 81650][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x05
[ 81651][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 81651][I][ZigbeeHandlers.cpp:74] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x53ea, 0x53ea, 0x0, 0x0
[ 81652][I][ZigbeeHandlers.cpp:88] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[ 82603][I][ZigbeeGateway.cpp:369] zbQueryDeviceBasicCluster(): basic tsn 0x7
[ 85603][I][ZigbeeGateway.cpp:382] zbQueryDeviceBasicCluster(): basic tsn 0x8
[ 87603][E][ZigbeeGateway.cpp:385] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x4
[ 87603][D][ZigbeeGateway.cpp:478] bindDeviceCluster(): Requesting ZED (0x53ea), endpoint (0x23), cluster_id (0x500) to bind ZC
[ 87635][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0x53ea), endpoint (0x23), cluster (0x500)
[ 87635][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 87832][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0x53ea), endpoint (0x23), cluster (0x500)
[ 87832][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 88023][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0x53ea), endpoint (0x23), cluster (0x500)
[ 88024][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 88229][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0x53ea), endpoint (0x23), cluster (0x500)
[ 88230][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 88437][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0x53ea), endpoint (0x23), cluster (0x500)
[ 88437][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 88631][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0x53ea), endpoint (0x23), cluster (0x500)
[ 88631][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 88806][D][ZigbeeGateway.cpp:523] bindDeviceCluster(): Requesting ZC to bind ZED (0x53ea), endpoint (0x23), cluster_id (0x500)
[ 88809][I][ZigbeeGateway.cpp:212] bindCb(): ZC has bounded to ZED (0x53ea), endpoint (0x23) cluster (0x500)
[ 88810][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[ 93585][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[ 93606][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[ 96048][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[ 96074][I][ZigbeeCore.cpp:406] esp_zb_app_signal_handler(): Joined device is leaving network (short: 0x53ea), rejoin (NO)
[ 96607][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[105700][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[105702][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[105732][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x53ea)
[105733][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x8e
[105733][D][ZigbeeGateway.cpp:547] zbDeviceAnnce(): zbDeviceAnnce short address (0x53ea), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[105734][D][ZigbeeGateway.cpp:550] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x53ea), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[105735][I][ZigbeeGateway.cpp:574] zbDeviceAnnce(): Tuya magic last hope
[106258][I][ZigbeeGateway.cpp:363] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[106287][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0x9b9b) is open for 180 seconds
[106588][I][ZigbeeHandlers.cpp:62] zb_raw_cmd_handler(): cluster id: 0xa, command id: 0
[106588][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): src endpoint (0x2, dst endpoint 0x1
[106589][I][ZigbeeHandlers.cpp:64] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
[106589][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): manuf_specific 0x0
[106590][I][ZigbeeHandlers.cpp:67] zb_raw_cmd_handler(): RAW bufid: 7 size: 12
[106590][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x01
[106591][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[106592][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x02
[106592][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[106593][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x03
[106593][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[106593][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x04
[106594][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[106594][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x05
[106595][I][ZigbeeHandlers.cpp:74] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x53ea, 0x53ea, 0x0, 0x0
[106595][I][ZigbeeHandlers.cpp:88] zb_raw_cmd_handler(): ----------------------------raw command not
[107259][I][ZigbeeGateway.cpp:369] zbQueryDeviceBasicCluster(): basic tsn 0xa
[110259][I][ZigbeeGateway.cpp:382] zbQueryDeviceBasicCluster(): basic tsn 0xb
[112259][E][ZigbeeGateway.cpp:385] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x4
[112259][D][ZigbeeGateway.cpp:478] bindDeviceCluster(): Requesting ZED (0x53ea), endpoint (0x23), cluster_id (0x500) to bind ZC
[112292][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0x53ea), endpoint (0x23), cluster (0x500)
[112293][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[112478][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0x53ea), endpoint (0x23), cluster (0x500)
[112479][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[112693][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0x53ea), endpoint (0x23), cluster (0x500)
[112694][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[112880][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0x53ea), endpoint (0x23), cluster (0x500)
[112880][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[113090][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0x53ea), endpoint (0x23), cluster (0x500)
[113091][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[113286][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0x53ea), endpoint (0x23), cluster (0x500)
[113287][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[113462][D][ZigbeeGateway.cpp:523] bindDeviceCluster(): Requesting ZC to bind ZED (0x53ea), endpoint (0x23), cluster_id (0x500)
[113465][I][ZigbeeGateway.cpp:212] bindCb(): ZC has bounded to ZED (0x53ea), endpoint (0x23) cluster (0x500)
[113466][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[118240][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[118262][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[120703][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[120727][I][ZigbeeCore.cpp:406] esp_zb_app_signal_handler(): Joined device is leaving network (short: 0x53ea), rejoin (NO)
[121263][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[125950][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[125952][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[125999][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x53ea)
[125999][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x8e
[126000][D][ZigbeeGateway.cpp:547] zbDeviceAnnce(): zbDeviceAnnce short address (0x53ea), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[126001][D][ZigbeeGateway.cpp:550] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x53ea), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[126002][I][ZigbeeGateway.cpp:574] zbDeviceAnnce(): Tuya magic last hope
[126509][I][ZigbeeGateway.cpp:363] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[126560][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0x9b9b) is open for 180 seconds
[126586][I][ZigbeeHandlers.cpp:62] zb_raw_cmd_handler(): cluster id: 0xa, command id: 0
[126587][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): src endpoint (0x2, dst endpoint 0x1
[126587][I][ZigbeeHandlers.cpp:64] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
[126588][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): manuf_specific 0x0
[126588][I][ZigbeeHandlers.cpp:67] zb_raw_cmd_handler(): RAW bufid: 26 size: 12
[126589][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x01
[126589][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[126590][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[126590][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x02
[126591][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[126591][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x03
[126592][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[126592][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x04
[126593][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x05
[126593][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[126593][I][ZigbeeHandlers.cpp:74] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x53ea, 0x53ea, 0x0, 0x0
[126594][I][ZigbeeHandlers.cpp:88] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[127510][I][ZigbeeGateway.cpp:369] zbQueryDeviceBasicCluster(): basic tsn 0xd
[130510][I][ZigbeeGateway.cpp:382] zbQueryDeviceBasicCluster(): basic tsn 0xe
[132510][E][ZigbeeGateway.cpp:385] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x4
[132510][D][ZigbeeGateway.cpp:478] bindDeviceCluster(): Requesting ZED (0x53ea), endpoint (0x23), cluster_id (0x500) to bind ZC
[132539][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0x53ea), endpoint (0x23), cluster (0x500)
[132540][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[132740][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0x53ea), endpoint (0x23), cluster (0x500)
[132740][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[132929][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0x53ea), endpoint (0x23), cluster (0x500)
[132930][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[133139][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0x53ea), endpoint (0x23), cluster (0x500)
[133140][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[133344][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0x53ea), endpoint (0x23), cluster (0x500)
[133345][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[133542][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0x53ea), endpoint (0x23), cluster (0x500)
[133543][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[133713][D][ZigbeeGateway.cpp:523] bindDeviceCluster(): Requesting ZC to bind ZED (0x53ea), endpoint (0x23), cluster_id (0x500)
[133716][I][ZigbeeGateway.cpp:212] bindCb(): ZC has bounded to ZED (0x53ea), endpoint (0x23) cluster (0x500)
[133717][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[138506][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[138513][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[140953][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[141047][I][ZigbeeCore.cpp:406] esp_zb_app_signal_handler(): Joined device is leaving network (short: 0x53ea), rejoin (NO)
[141514][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[148083][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[148085][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[148127][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xd76d)
[148128][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x8e
[148128][D][ZigbeeGateway.cpp:547] zbDeviceAnnce(): zbDeviceAnnce short address (0xd76d), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[148129][D][ZigbeeGateway.cpp:550] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0xd76d), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[148130][I][ZigbeeGateway.cpp:574] zbDeviceAnnce(): Tuya magic last hope
[148659][I][ZigbeeGateway.cpp:363] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[148663][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0x9b9b) is open for 180 seconds
[148696][I][ZigbeeHandlers.cpp:62] zb_raw_cmd_handler(): cluster id: 0xa, command id: 0
[148696][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): src endpoint (0x2, dst endpoint 0x1
[148697][I][ZigbeeHandlers.cpp:64] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
[148697][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): manuf_specific 0x0
[148698][I][ZigbeeHandlers.cpp:67] zb_raw_cmd_handler(): RAW bufid: 22 size: 12
[148698][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x01
[148699][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[148700][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x02
[148700][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[148700][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x03
[148701][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[148701][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x04
[148702][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[148702][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x05
[148703][I][ZigbeeHandlers.cpp:74] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xd76d, 0xd76d, 0x0, 0x0
[148703][I][ZigbeeHandlers.cpp:88] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[149660][I][ZigbeeGateway.cpp:369] zbQueryDeviceBasicCluster(): basic tsn 0x10
[152660][I][ZigbeeGateway.cpp:382] zbQueryDeviceBasicCluster(): basic tsn 0x11
[154660][E][ZigbeeGateway.cpp:385] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x4
[154660][D][ZigbeeGateway.cpp:478] bindDeviceCluster(): Requesting ZED (0xd76d), endpoint (0x23), cluster_id (0x500) to bind ZC
[154963][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xd76d), endpoint (0x23), cluster (0x500)
[154964][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[154999][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xd76d), endpoint (0x23), cluster (0x500)
[154999][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[155194][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xd76d), endpoint (0x23), cluster (0x500)
[155195][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[155392][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xd76d), endpoint (0x23), cluster (0x500)
[155393][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[155588][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xd76d), endpoint (0x23), cluster (0x500)
[155588][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[155786][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xd76d), endpoint (0x23), cluster (0x500)
[155787][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[155965][D][ZigbeeGateway.cpp:523] bindDeviceCluster(): Requesting ZC to bind ZED (0xd76d), endpoint (0x23), cluster_id (0x500)
[155968][I][ZigbeeGateway.cpp:212] bindCb(): ZC has bounded to ZED (0xd76d), endpoint (0x23) cluster (0x500)
[155969][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[160635][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[160663][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[163086][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[163104][I][ZigbeeCore.cpp:406] esp_zb_app_signal_handler(): Joined device is leaving network (short: 0xd76d), rejoin (NO)
[163664][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[172517][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[172520][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[172553][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xd76d)
[172553][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x8e
[172554][D][ZigbeeGateway.cpp:547] zbDeviceAnnce(): zbDeviceAnnce short address (0xd76d), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[172555][D][ZigbeeGateway.cpp:550] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0xd76d), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[172555][I][ZigbeeGateway.cpp:574] zbDeviceAnnce(): Tuya magic last hope
[173091][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0x9b9b) is open for 180 seconds
[173125][I][ZigbeeGateway.cpp:363] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[173150][I][ZigbeeHandlers.cpp:62] zb_raw_cmd_handler(): cluster id: 0xa, command id: 0
[173151][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): src endpoint (0x2, dst endpoint 0x1
[173151][I][ZigbeeHandlers.cpp:64] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
[173152][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): manuf_specific 0x0
[173152][I][ZigbeeHandlers.cpp:67] zb_raw_cmd_handler(): RAW bufid: 15 size: 12
[173153][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x01
[173153][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[173154][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[173154][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x02
[173155][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[173155][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x03
[173156][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[173156][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x04
[173157][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x05
[173157][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[173157][I][ZigbeeHandlers.cpp:74] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xd76d, 0xd76d, 0x0, 0x0
[173158][I][ZigbeeHandlers.cpp:88] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[174127][I][ZigbeeGateway.cpp:369] zbQueryDeviceBasicCluster(): basic tsn 0x13
[177128][I][ZigbeeGateway.cpp:382] zbQueryDeviceBasicCluster(): basic tsn 0x14
[179129][E][ZigbeeGateway.cpp:385] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x4
[179130][D][ZigbeeGateway.cpp:478] bindDeviceCluster(): Requesting ZED (0xd76d), endpoint (0x23), cluster_id (0x500) to bind ZC
[179159][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xd76d), endpoint (0x23), cluster (0x500)
[179160][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[179361][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xd76d), endpoint (0x23), cluster (0x500)
[179361][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[179549][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xd76d), endpoint (0x23), cluster (0x500)
[179550][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[179760][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xd76d), endpoint (0x23), cluster (0x500)
[179760][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[179954][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xd76d), endpoint (0x23), cluster (0x500)
[179955][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[180152][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xd76d), endpoint (0x23), cluster (0x500)
[180153][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[180331][D][ZigbeeGateway.cpp:523] bindDeviceCluster(): Requesting ZC to bind ZED (0xd76d), endpoint (0x23), cluster_id (0x500)
[180334][I][ZigbeeGateway.cpp:212] bindCb(): ZC has bounded to ZED (0xd76d), endpoint (0x23) cluster (0x500)
[180335][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[185060][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[185130][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[187521][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
NLME Status Indication, status: 0x9
[188131][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[197438][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[197441][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[197484][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xb6ad)
[197484][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x8e
[197485][D][ZigbeeGateway.cpp:547] zbDeviceAnnce(): zbDeviceAnnce short address (0xb6ad), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[197486][D][ZigbeeGateway.cpp:550] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0xb6ad), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[197487][I][ZigbeeGateway.cpp:574] zbDeviceAnnce(): Tuya magic last hope
[198024][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0x9b9b) is open for 180 seconds
[198063][I][ZigbeeHandlers.cpp:62] zb_raw_cmd_handler(): cluster id: 0xa, command id: 0
[198063][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): src endpoint (0x2, dst endpoint 0x1
[198064][I][ZigbeeHandlers.cpp:64] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
[198065][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): manuf_specific 0x0
[198065][I][ZigbeeHandlers.cpp:67] zb_raw_cmd_handler(): RAW bufid: 17 size: 12
[198066][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x01
[198066][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[198067][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[198067][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x02
[198068][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x03
[198068][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[198068][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x04
[198069][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[198069][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x05
[198070][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[198070][I][ZigbeeHandlers.cpp:74] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb6ad, 0xb6ad, 0x0, 0x0
[198071][I][ZigbeeHandlers.cpp:88] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[198082][I][ZigbeeGateway.cpp:363] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[199083][I][ZigbeeGateway.cpp:369] zbQueryDeviceBasicCluster(): basic tsn 0x16
[202083][I][ZigbeeGateway.cpp:382] zbQueryDeviceBasicCluster(): basic tsn 0x17
[204083][E][ZigbeeGateway.cpp:385] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x4
[204083][D][ZigbeeGateway.cpp:478] bindDeviceCluster(): Requesting ZED (0xb6ad), endpoint (0x23), cluster_id (0x500) to bind ZC
[204120][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xb6ad), endpoint (0x23), cluster (0x500)
[204120][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[204311][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xb6ad), endpoint (0x23), cluster (0x500)
[204312][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[204509][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xb6ad), endpoint (0x23), cluster (0x500)
[204510][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[204711][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xb6ad), endpoint (0x23), cluster (0x500)
[204712][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[204910][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xb6ad), endpoint (0x23), cluster (0x500)
[204911][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[205110][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xb6ad), endpoint (0x23), cluster (0x500)
[205111][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[205286][D][ZigbeeGateway.cpp:523] bindDeviceCluster(): Requesting ZC to bind ZED (0xb6ad), endpoint (0x23), cluster_id (0x500)
[205289][I][ZigbeeGateway.cpp:212] bindCb(): ZC has bounded to ZED (0xb6ad), endpoint (0x23) cluster (0x500)
[205290][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[209991][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[210085][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[212442][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[212460][I][ZigbeeCore.cpp:406] esp_zb_app_signal_handler(): Joined device is leaving network (short: 0xb6ad), rejoin (NO)
[213086][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[223717][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[223720][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[223756][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xb6ad)
[223757][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x8e
[223758][D][ZigbeeGateway.cpp:547] zbDeviceAnnce(): zbDeviceAnnce short address (0xb6ad), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[223758][D][ZigbeeGateway.cpp:550] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0xb6ad), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[223759][I][ZigbeeGateway.cpp:574] zbDeviceAnnce(): Tuya magic last hope
[224289][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0x9b9b) is open for 180 seconds
[224323][I][ZigbeeHandlers.cpp:62] zb_raw_cmd_handler(): cluster id: 0xa, command id: 0
[224323][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): src endpoint (0x2, dst endpoint 0x1
[224324][I][ZigbeeHandlers.cpp:64] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
[224324][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): manuf_specific 0x0
[224325][I][ZigbeeHandlers.cpp:67] zb_raw_cmd_handler(): RAW bufid: 31 size: 12
[224325][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x01
[224326][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[224327][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x02
[224327][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[224328][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x03
[224328][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[224328][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x04
[224329][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[224329][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x05
[224330][I][ZigbeeHandlers.cpp:74] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb6ad, 0xb6ad, 0x0, 0x0
[224330][I][ZigbeeHandlers.cpp:88] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[224342][I][ZigbeeGateway.cpp:363] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[225343][I][ZigbeeGateway.cpp:369] zbQueryDeviceBasicCluster(): basic tsn 0x19
[228343][I][ZigbeeGateway.cpp:382] zbQueryDeviceBasicCluster(): basic tsn 0x1a
[230343][E][ZigbeeGateway.cpp:385] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x4
[230343][D][ZigbeeGateway.cpp:478] bindDeviceCluster(): Requesting ZED (0xb6ad), endpoint (0x23), cluster_id (0x500) to bind ZC
[230636][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xb6ad), endpoint (0x23), cluster (0x500)
[230637][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[230670][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xb6ad), endpoint (0x23), cluster (0x500)
[230671][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[230857][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xb6ad), endpoint (0x23), cluster (0x500)
[230858][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[231070][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xb6ad), endpoint (0x23), cluster (0x500)
[231071][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[231264][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xb6ad), endpoint (0x23), cluster (0x500)
[231265][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[231466][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xb6ad), endpoint (0x23), cluster (0x500)
[231467][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[231638][D][ZigbeeGateway.cpp:523] bindDeviceCluster(): Requesting ZC to bind ZED (0xb6ad), endpoint (0x23), cluster_id (0x500)
[231641][I][ZigbeeGateway.cpp:212] bindCb(): ZC has bounded to ZED (0xb6ad), endpoint (0x23) cluster (0x500)
[231642][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[236264][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[236346][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[238721][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[238747][I][ZigbeeCore.cpp:406] esp_zb_app_signal_handler(): Joined device is leaving network (short: 0xb6ad), rejoin (NO)
[239347][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[249657][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[249660][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[249700][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xb6ad)
[249700][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x8e
[249701][D][ZigbeeGateway.cpp:547] zbDeviceAnnce(): zbDeviceAnnce short address (0xb6ad), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[249702][D][ZigbeeGateway.cpp:550] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0xb6ad), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[249702][I][ZigbeeGateway.cpp:574] zbDeviceAnnce(): Tuya magic last hope
[250239][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0x9b9b) is open for 180 seconds
[250278][I][ZigbeeHandlers.cpp:62] zb_raw_cmd_handler(): cluster id: 0xa, command id: 0
[250279][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): src endpoint (0x2, dst endpoint 0x1
[250279][I][ZigbeeHandlers.cpp:64] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
[250280][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): manuf_specific 0x0
[250280][I][ZigbeeHandlers.cpp:67] zb_raw_cmd_handler(): RAW bufid: 27 size: 12
[250281][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x01
[250281][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[250282][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[250282][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x02
[250283][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[250283][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x03
[250284][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x04
[250284][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[250285][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x05
[250285][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[250285][I][ZigbeeHandlers.cpp:74] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb6ad, 0xb6ad, 0x0, 0x0
[250286][I][ZigbeeHandlers.cpp:88] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[250295][I][ZigbeeGateway.cpp:363] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[251295][I][ZigbeeGateway.cpp:369] zbQueryDeviceBasicCluster(): basic tsn 0x1c
[254295][I][ZigbeeGateway.cpp:382] zbQueryDeviceBasicCluster(): basic tsn 0x1d
[256295][E][ZigbeeGateway.cpp:385] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x4
[256295][D][ZigbeeGateway.cpp:478] bindDeviceCluster(): Requesting ZED (0xb6ad), endpoint (0x23), cluster_id (0x500) to bind ZC
[256324][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xb6ad), endpoint (0x23), cluster (0x500)
[256324][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[256519][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xb6ad), endpoint (0x23), cluster (0x500)
[256520][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[256993][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xb6ad), endpoint (0x23), cluster (0x500)
[256993][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[257020][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xb6ad), endpoint (0x23), cluster (0x500)
[257021][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[257219][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xb6ad), endpoint (0x23), cluster (0x500)
[257220][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[257420][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xb6ad), endpoint (0x23), cluster (0x500)
[257420][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[257596][D][ZigbeeGateway.cpp:523] bindDeviceCluster(): Requesting ZC to bind ZED (0xb6ad), endpoint (0x23), cluster_id (0x500)
[257673][I][ZigbeeGateway.cpp:212] bindCb(): ZC has bounded to ZED (0xb6ad), endpoint (0x23) cluster (0x500)
[257673][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[262207][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[262297][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[264661][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[264679][I][ZigbeeCore.cpp:406] esp_zb_app_signal_handler(): Joined device is leaving network (short: 0xb6ad), rejoin (NO)
[265298][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[271355][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[271357][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[271392][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xb6ad)
[271393][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x8e
[271393][D][ZigbeeGateway.cpp:547] zbDeviceAnnce(): zbDeviceAnnce short address (0xb6ad), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[271394][D][ZigbeeGateway.cpp:550] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0xb6ad), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[271395][I][ZigbeeGateway.cpp:574] zbDeviceAnnce(): Tuya magic last hope
[271928][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0x9b9b) is open for 180 seconds
[271953][I][ZigbeeGateway.cpp:363] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[272531][I][ZigbeeHandlers.cpp:62] zb_raw_cmd_handler(): cluster id: 0xa, command id: 0
[272532][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): src endpoint (0x2, dst endpoint 0x1
[272532][I][ZigbeeHandlers.cpp:64] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
[272533][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): manuf_specific 0x0
[272533][I][ZigbeeHandlers.cpp:67] zb_raw_cmd_handler(): RAW bufid: 5 size: 12
[272534][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x01
[272534][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[272535][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[272535][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x02
[272536][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[272536][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x03
[272537][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x04
[272537][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[272537][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x05
[272538][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[272538][I][ZigbeeHandlers.cpp:74] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb6ad, 0xb6ad, 0x0, 0x0
[272539][I][ZigbeeHandlers.cpp:88] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[272956][I][ZigbeeGateway.cpp:369] zbQueryDeviceBasicCluster(): basic tsn 0x1f
[275956][I][ZigbeeGateway.cpp:382] zbQueryDeviceBasicCluster(): basic tsn 0x20
[277957][E][ZigbeeGateway.cpp:385] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x4
[277958][D][ZigbeeGateway.cpp:478] bindDeviceCluster(): Requesting ZED (0xb6ad), endpoint (0x23), cluster_id (0x500) to bind ZC
[277989][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xb6ad), endpoint (0x23), cluster (0x500)
[277990][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[278185][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xb6ad), endpoint (0x23), cluster (0x500)
[278186][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[278380][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xb6ad), endpoint (0x23), cluster (0x500)
[278380][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[278585][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xb6ad), endpoint (0x23), cluster (0x500)
[278585][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[278795][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xb6ad), endpoint (0x23), cluster (0x500)
[278796][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[278984][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xb6ad), endpoint (0x23), cluster (0x500)
[278985][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[279159][D][ZigbeeGateway.cpp:523] bindDeviceCluster(): Requesting ZC to bind ZED (0xb6ad), endpoint (0x23), cluster_id (0x500)
[279162][I][ZigbeeGateway.cpp:212] bindCb(): ZC has bounded to ZED (0xb6ad), endpoint (0x23) cluster (0x500)
[279163][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[283900][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[283958][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[286358][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[286959][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[293739][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[293741][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[293782][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xb6ad)
[293783][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x8e
[293783][D][ZigbeeGateway.cpp:547] zbDeviceAnnce(): zbDeviceAnnce short address (0xb6ad), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[293784][D][ZigbeeGateway.cpp:550] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0xb6ad), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[293785][I][ZigbeeGateway.cpp:574] zbDeviceAnnce(): Tuya magic last hope
[294308][I][ZigbeeGateway.cpp:363] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[294348][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0x9b9b) is open for 180 seconds
[294382][I][ZigbeeHandlers.cpp:62] zb_raw_cmd_handler(): cluster id: 0xa, command id: 0
[294383][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): src endpoint (0x2, dst endpoint 0x1
[294383][I][ZigbeeHandlers.cpp:64] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
[294384][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): manuf_specific 0x0
[294384][I][ZigbeeHandlers.cpp:67] zb_raw_cmd_handler(): RAW bufid: 31 size: 12
[294385][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x01
[294385][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[294386][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[294386][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x02
[294387][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[294387][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x03
[294388][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x04
[294388][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[294389][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x05
[294389][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[294389][I][ZigbeeHandlers.cpp:74] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb6ad, 0xb6ad, 0x0, 0x0
[294390][I][ZigbeeHandlers.cpp:88] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[295309][I][ZigbeeGateway.cpp:369] zbQueryDeviceBasicCluster(): basic tsn 0x22
[298309][I][ZigbeeGateway.cpp:382] zbQueryDeviceBasicCluster(): basic tsn 0x23
[300309][E][ZigbeeGateway.cpp:385] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x4
[300309][D][ZigbeeGateway.cpp:478] bindDeviceCluster(): Requesting ZED (0xb6ad), endpoint (0x23), cluster_id (0x500) to bind ZC
[300341][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xb6ad), endpoint (0x23), cluster (0x500)
[300342][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[300540][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xb6ad), endpoint (0x23), cluster (0x500)
[300541][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[300739][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xb6ad), endpoint (0x23), cluster (0x500)
[300739][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[300934][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xb6ad), endpoint (0x23), cluster (0x500)
[300935][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[301137][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xb6ad), endpoint (0x23), cluster (0x500)
[301138][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[301350][E][ZigbeeGateway.cpp:218] bindCb(): Binding failed (0x83)! Device (0xb6ad), endpoint (0x23), cluster (0x500)
[301351][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[301512][D][ZigbeeGateway.cpp:523] bindDeviceCluster(): Requesting ZC to bind ZED (0xb6ad), endpoint (0x23), cluster_id (0x500)
[301515][I][ZigbeeGateway.cpp:212] bindCb(): ZC has bounded to ZED (0xb6ad), endpoint (0x23) cluster (0x500)
[301516][I][ZigbeeGateway.cpp:228] bindCb(): Semaphore give in binding
[306290][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[306312][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[308742][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[308767][I][ZigbeeCore.cpp:406] esp_zb_app_signal_handler(): Joined device is leaving network (short: 0xb6ad), rejoin (NO)
[309313][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[313321][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[313323][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[313358][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x7b71)
[313359][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x8e
[   876][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0x58b9) is open for 180 seconds
[ 10144][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 10146][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 10185][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x19e6)
[ 10186][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x8e
[ 10186][D][ZigbeeGateway.cpp:547] zbDeviceAnnce(): zbDeviceAnnce short address (0x19e6), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[ 10187][D][ZigbeeGateway.cpp:550] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x19e6), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[ 10188][I][ZigbeeGateway.cpp:574] zbDeviceAnnce(): Tuya magic last hope
[ 10715][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0x58b9) is open for 180 seconds
[ 10755][I][ZigbeeHandlers.cpp:62] zb_raw_cmd_handler(): cluster id: 0xa, command id: 0
[ 10755][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): src endpoint (0x2, dst endpoint 0x1
[ 10756][I][ZigbeeHandlers.cpp:64] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
[ 10757][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): manuf_specific 0x0
[ 10757][I][ZigbeeHandlers.cpp:67] zb_raw_cmd_handler(): RAW bufid: 15 size: 12
[ 10758][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x01
[ 10758][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 10759][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 10759][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x02
[ 10760][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x03
[ 10760][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 10761][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x04
[ 10761][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 10761][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x05
[ 10762][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 10762][I][ZigbeeHandlers.cpp:74] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x19e6, 0x19e6, 0x0, 0x0
[ 10763][I][ZigbeeHandlers.cpp:88] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[ 10767][I][ZigbeeGateway.cpp:617] printJoinedDevices(): joined devices:
[ 10768][I][ZigbeeGateway.cpp:620] printJoinedDevices(): Device on endpoint 1, short address: 0x19e6
[ 10968][I][ZigbeeGateway.cpp:1806] sendCustomClusterCmd(): _custom_cmd_last_tsn = 1
[ 11168][I][ZigbeeGateway.cpp:1814] sendCustomClusterCmd(): _custom_cmd_last_tsn_flag = 2
[ 11169][I][ZigbeeGateway.cpp:363] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[ 12169][I][ZigbeeGateway.cpp:369] zbQueryDeviceBasicCluster(): basic tsn 0x2
[ 15169][I][ZigbeeGateway.cpp:382] zbQueryDeviceBasicCluster(): basic tsn 0x3
[ 17169][E][ZigbeeGateway.cpp:385] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x4
[ 17170][I][Z2S_Device_Scanner.ino:139] loop(): Error while pairing - cann't read manufacturer id. Gateway will restart, try to pair device once again!
Scheduling soft restart in 0 ms
Current status: [41] Software reset
[ 17173][I][ZigbeeGateway.cpp:1388] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
[ 17373][I][ZigbeeGateway.cpp:322] zbPrintDeviceDiscovery(): short_addr_req 6630
[ 17690][I][ZigbeeGateway.cpp:256] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 6630, endpoints count 2
[ 17691][I][ZigbeeGateway.cpp:259] Z2S_active_ep_req_cb(): Endpont # 1, id 2
[ 17691][I][ZigbeeGateway.cpp:259] Z2S_active_ep_req_cb(): Endpont # 2, id 1
[ 17731][I][ZigbeeGateway.cpp:275] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 6630, endpoint # 2
[ 17732][I][ZigbeeGateway.cpp:276] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 9, out clusters # 5
[ 17733][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
[ 17733][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 2, id 1794
[ 17734][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 3, id 3
[ 17734][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 4, id 9
[ 17735][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 5, id 2820
[ 17735][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 6, id 6
[ 17736][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 7, id 4
[ 17736][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 8, id 5
[ 17737][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 9, id 2
[ 17737][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 1, id 0
[ 17738][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 2, id 25
[ 17738][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 3, id 10
[ 17739][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 4, id 3
[ 17739][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 5, id 1030
[ 17796][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 17797][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0x19e6), src_endpoint(2) to dst_endpoint(1), cluster(0x0) for command (0xc) with status 0x84
[ 17798][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 17799][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 5, _custom_cmd_last_tsn = 1, _custom_cmd_last_tsn_flag = 2
[ 17799][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 5, _custom_cmd_last_tsn_flag = 2
[ 17800][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -68
[ 17816][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 17816][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0x19e6), src_endpoint(2) to dst_endpoint(1), cluster(0x702) for command (0xc) with status 0x84
[ 17817][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 17818][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 6, _custom_cmd_last_tsn = 1, _custom_cmd_last_tsn_flag = 2
[ 17818][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 6, _custom_cmd_last_tsn_flag = 2
[ 17819][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -67
[ 17832][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 17833][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0x19e6), src_endpoint(2) to dst_endpoint(1), cluster(0x3) for command (0xc) with status 0x84
[ 17834][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 17834][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 7, _custom_cmd_last_tsn = 1, _custom_cmd_last_tsn_flag = 2
[ 17835][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 7, _custom_cmd_last_tsn_flag = 2
[ 17836][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -68
[ 17851][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 17851][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0x19e6), src_endpoint(2) to dst_endpoint(1), cluster(0x9) for command (0xc) with status 0x84
[ 17853][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 17853][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 8, _custom_cmd_last_tsn = 1, _custom_cmd_last_tsn_flag = 2
[ 17854][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 8, _custom_cmd_last_tsn_flag = 2
[ 17855][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -65
[ 17860][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 17861][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0x19e6), src_endpoint(2) to dst_endpoint(1), cluster(0xb04) for command (0xc) with status 0x84
[ 17862][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 17862][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 9, _custom_cmd_last_tsn = 1, _custom_cmd_last_tsn_flag = 2
[ 17863][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 9, _custom_cmd_last_tsn_flag = 2
[ 17864][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -64
[ 17882][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 17883][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0x19e6), src_endpoint(2) to dst_endpoint(1), cluster(0x6) for command (0xc) with status 0x84
[ 17884][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 17884][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 10, _custom_cmd_last_tsn = 1, _custom_cmd_last_tsn_flag = 2
[ 17885][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 10, _custom_cmd_last_tsn_flag = 2
[ 17886][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -68
[ 17900][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 17900][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0x19e6), src_endpoint(2) to dst_endpoint(1), cluster(0x4) for command (0xc) with status 0x84
[ 17901][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 17902][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 11, _custom_cmd_last_tsn = 1, _custom_cmd_last_tsn_flag = 2
[ 17903][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 11, _custom_cmd_last_tsn_flag = 2
[ 17903][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -63
[ 17921][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 17921][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0x19e6), src_endpoint(2) to dst_endpoint(1), cluster(0x5) for command (0xc) with status 0x84
[ 17922][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 17923][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 12, _custom_cmd_last_tsn = 1, _custom_cmd_last_tsn_flag = 2
[ 17924][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 12, _custom_cmd_last_tsn_flag = 2
[ 17925][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -64
[ 17937][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 17938][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0x19e6), src_endpoint(2) to dst_endpoint(1), cluster(0x2) for command (0xc) with status 0x84
[ 17939][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 17939][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 13, _custom_cmd_last_tsn = 1, _custom_cmd_last_tsn_flag = 2
[ 17940][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 13, _custom_cmd_last_tsn_flag = 2
[ 17941][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -67
[ 17963][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 17964][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0x19e6), src_endpoint(2) to dst_endpoint(1), cluster(0x0) for command (0xc) with status 0x84
[ 17965][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 17966][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 14, _custom_cmd_last_tsn = 1, _custom_cmd_last_tsn_flag = 2
[ 17966][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 14, _custom_cmd_last_tsn_flag = 2
[ 17967][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -68
[ 20783][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 20783][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0x19e6), src_endpoint(2) to dst_endpoint(1), cluster(0x0) for command (0xc) with status 0x84
[ 20784][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 20785][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 5, _custom_cmd_last_tsn = 1, _custom_cmd_last_tsn_flag = 2
[ 20786][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 5, _custom_cmd_last_tsn_flag = 2
[ 20786][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -68
[ 20803][I][ZigbeeHandlers.cpp:62] zb_raw_cmd_handler(): cluster id: 0x19, command id: 11
[ 20804][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): src endpoint (0x2, dst endpoint 0x1
[ 20804][I][ZigbeeHandlers.cpp:64] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 1
[ 20805][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): manuf_specific 0x6
[ 20806][I][ZigbeeHandlers.cpp:67] zb_raw_cmd_handler(): RAW bufid: 12 size: 2
[ 20806][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x0C
[ 20806][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x84
[ 20807][I][ZigbeeHandlers.cpp:74] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x19e6, 0x19e6, 0x0, 0x0
[ 20807][I][ZigbeeHandlers.cpp:88] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[ 20819][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 20819][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0x19e6), src_endpoint(2) to dst_endpoint(1), cluster(0xa) for command (0xc) with status 0x84
[ 20820][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 20821][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 16, _custom_cmd_last_tsn = 1, _custom_cmd_last_tsn_flag = 2
[ 20822][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 16, _custom_cmd_last_tsn_flag = 2
[ 20822][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -64
[ 20834][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 20835][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0x19e6), src_endpoint(2) to dst_endpoint(1), cluster(0x3) for command (0xc) with status 0x84
[ 20836][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 20837][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 17, _custom_cmd_last_tsn = 1, _custom_cmd_last_tsn_flag = 2
[ 20837][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 17, _custom_cmd_last_tsn_flag = 2
[ 20838][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -68
[ 20857][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 20858][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0x19e6), src_endpoint(2) to dst_endpoint(1), cluster(0x406) for command (0xc) with status 0x84
[ 20859][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 20859][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 18, _custom_cmd_last_tsn = 1, _custom_cmd_last_tsn_flag = 2
[ 20860][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 18, _custom_cmd_last_tsn_flag = 2
[ 20861][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -68
[ 22693][I][ZigbeeGateway.cpp:310] Z2S_simple_desc_req_cb(): Z2S simple desc failed
[ 22693][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[ 22773][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[ 23173][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[ 25147][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[ 25213][I][ZigbeeCore.cpp:406] esp_zb_app_signal_handler(): Joined device is leaving network (short: 0x19e6), rejoin (NO)
[ 26174][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
NLME Status Indication, status: 0x0
[ 33951][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 33953][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 33999][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xb563)
[ 34000][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x8e
[ 34000][D][ZigbeeGateway.cpp:547] zbDeviceAnnce(): zbDeviceAnnce short address (0xb563), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[ 34001][D][ZigbeeGateway.cpp:550] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0xb563), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[ 34002][I][ZigbeeGateway.cpp:574] zbDeviceAnnce(): Tuya magic last hope
[ 34521][I][ZigbeeGateway.cpp:617] printJoinedDevices(): joined devices:
[ 34522][I][ZigbeeGateway.cpp:620] printJoinedDevices(): Device on endpoint 1, short address: 0xb563
[ 34552][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0x58b9) is open for 180 seconds
[ 34591][I][ZigbeeHandlers.cpp:62] zb_raw_cmd_handler(): cluster id: 0xa, command id: 0
[ 34592][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): src endpoint (0x2, dst endpoint 0x1
[ 34592][I][ZigbeeHandlers.cpp:64] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
[ 34593][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): manuf_specific 0x0
[ 34593][I][ZigbeeHandlers.cpp:67] zb_raw_cmd_handler(): RAW bufid: 17 size: 12
[ 34594][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x01
[ 34594][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 34595][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 34595][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x02
[ 34596][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 34596][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x03
[ 34597][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x04
[ 34597][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 34597][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x05
[ 34598][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 34598][I][ZigbeeHandlers.cpp:74] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb563, 0xb563, 0x0, 0x0
[ 34599][I][ZigbeeHandlers.cpp:88] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[ 34722][I][ZigbeeGateway.cpp:1806] sendCustomClusterCmd(): _custom_cmd_last_tsn = 20
[ 34922][I][ZigbeeGateway.cpp:1814] sendCustomClusterCmd(): _custom_cmd_last_tsn_flag = 2
[ 34923][I][ZigbeeGateway.cpp:363] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[ 35923][I][ZigbeeGateway.cpp:369] zbQueryDeviceBasicCluster(): basic tsn 0x15
[ 38923][I][ZigbeeGateway.cpp:382] zbQueryDeviceBasicCluster(): basic tsn 0x16
[ 40923][E][ZigbeeGateway.cpp:385] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x4
[ 40924][I][Z2S_Device_Scanner.ino:139] loop(): Error while pairing - cann't read manufacturer id. Gateway will restart, try to pair device once again!
[ 40927][I][ZigbeeGateway.cpp:1388] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
[ 41127][I][ZigbeeGateway.cpp:322] zbPrintDeviceDiscovery(): short_addr_req 46435
[ 41147][I][ZigbeeGateway.cpp:256] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 46435, endpoints count 2
[ 41148][I][ZigbeeGateway.cpp:259] Z2S_active_ep_req_cb(): Endpont # 1, id 2
[ 41148][I][ZigbeeGateway.cpp:259] Z2S_active_ep_req_cb(): Endpont # 2, id 1
[ 41175][I][ZigbeeGateway.cpp:275] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 46435, endpoint # 2
[ 41176][I][ZigbeeGateway.cpp:276] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 9, out clusters # 5
[ 41176][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
[ 41177][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 2, id 1794
[ 41177][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 3, id 3
[ 41178][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 4, id 9
[ 41178][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 5, id 2820
[ 41179][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 6, id 6
[ 41179][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 7, id 4
[ 41180][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 8, id 5
[ 41180][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 9, id 2
[ 41181][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 1, id 0
[ 41181][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 2, id 25
[ 41182][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 3, id 10
[ 41182][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 4, id 3
[ 41183][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 5, id 1030
[ 41262][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 41262][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0xb563), src_endpoint(2) to dst_endpoint(1), cluster(0x0) for command (0xc) with status 0x84
[ 41264][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 41264][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 24, _custom_cmd_last_tsn = 20, _custom_cmd_last_tsn_flag = 2
[ 41265][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 24, _custom_cmd_last_tsn_flag = 2
[ 41266][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -58
[ 41287][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 41288][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0xb563), src_endpoint(2) to dst_endpoint(1), cluster(0x702) for command (0xc) with status 0x84
[ 41289][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 41289][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 25, _custom_cmd_last_tsn = 20, _custom_cmd_last_tsn_flag = 2
[ 41290][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 25, _custom_cmd_last_tsn_flag = 2
[ 41291][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -58
[ 41305][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 41305][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0xb563), src_endpoint(2) to dst_endpoint(1), cluster(0x3) for command (0xc) with status 0x84
[ 41306][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 41307][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 26, _custom_cmd_last_tsn = 20, _custom_cmd_last_tsn_flag = 2
[ 41307][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 26, _custom_cmd_last_tsn_flag = 2
[ 41308][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -59
[ 41320][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 41320][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0xb563), src_endpoint(2) to dst_endpoint(1), cluster(0x9) for command (0xc) with status 0x84
[ 41321][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 41322][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 27, _custom_cmd_last_tsn = 20, _custom_cmd_last_tsn_flag = 2
[ 41323][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 27, _custom_cmd_last_tsn_flag = 2
[ 41323][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -58
[ 41334][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 41335][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0xb563), src_endpoint(2) to dst_endpoint(1), cluster(0xb04) for command (0xc) with status 0x84
[ 41336][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 41336][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 28, _custom_cmd_last_tsn = 20, _custom_cmd_last_tsn_flag = 2
[ 41337][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 28, _custom_cmd_last_tsn_flag = 2
[ 41338][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -57
[ 41360][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 41360][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0xb563), src_endpoint(2) to dst_endpoint(1), cluster(0x6) for command (0xc) with status 0x84
[ 41361][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 41362][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 29, _custom_cmd_last_tsn = 20, _custom_cmd_last_tsn_flag = 2
[ 41362][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 29, _custom_cmd_last_tsn_flag = 2
[ 41363][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -59
[ 41382][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 41382][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0xb563), src_endpoint(2) to dst_endpoint(1), cluster(0x4) for command (0xc) with status 0x84
[ 41383][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 41384][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 30, _custom_cmd_last_tsn = 20, _custom_cmd_last_tsn_flag = 2
[ 41385][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 30, _custom_cmd_last_tsn_flag = 2
[ 41385][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -59
[ 41404][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 41404][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0xb563), src_endpoint(2) to dst_endpoint(1), cluster(0x5) for command (0xc) with status 0x84
[ 41405][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 41406][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 31, _custom_cmd_last_tsn = 20, _custom_cmd_last_tsn_flag = 2
[ 41406][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 31, _custom_cmd_last_tsn_flag = 2
[ 41407][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -57
[ 41423][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 41423][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0xb563), src_endpoint(2) to dst_endpoint(1), cluster(0x2) for command (0xc) with status 0x84
[ 41424][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 41425][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 32, _custom_cmd_last_tsn = 20, _custom_cmd_last_tsn_flag = 2
[ 41425][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 32, _custom_cmd_last_tsn_flag = 2
[ 41426][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -59
[ 41435][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 41436][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0xb563), src_endpoint(2) to dst_endpoint(1), cluster(0x0) for command (0xc) with status 0x84
[ 41437][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 41438][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 33, _custom_cmd_last_tsn = 20, _custom_cmd_last_tsn_flag = 2
[ 41438][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 33, _custom_cmd_last_tsn_flag = 2
[ 41439][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -60
[ 44278][I][ZigbeeHandlers.cpp:62] zb_raw_cmd_handler(): cluster id: 0x19, command id: 11
[ 44278][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): src endpoint (0x2, dst endpoint 0x1
[ 44279][I][ZigbeeHandlers.cpp:64] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 1
[ 44280][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): manuf_specific 0xa
[ 44280][I][ZigbeeHandlers.cpp:67] zb_raw_cmd_handler(): RAW bufid: 31 size: 2
[ 44281][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x0C
[ 44281][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x84
[ 44281][I][ZigbeeHandlers.cpp:74] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb563, 0xb563, 0x0, 0x0
[ 44282][I][ZigbeeHandlers.cpp:88] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[ 44297][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 44297][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0xb563), src_endpoint(2) to dst_endpoint(1), cluster(0xa) for command (0xc) with status 0x84
[ 44298][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 44299][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 35, _custom_cmd_last_tsn = 20, _custom_cmd_last_tsn_flag = 2
[ 44300][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 35, _custom_cmd_last_tsn_flag = 2
[ 44300][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -50
[ 44319][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 44320][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0xb563), src_endpoint(2) to dst_endpoint(1), cluster(0x3) for command (0xc) with status 0x84
[ 44321][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 44321][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 36, _custom_cmd_last_tsn = 20, _custom_cmd_last_tsn_flag = 2
[ 44322][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 36, _custom_cmd_last_tsn_flag = 2
[ 44323][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -52
[ 44337][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 44337][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0xb563), src_endpoint(2) to dst_endpoint(1), cluster(0x406) for command (0xc) with status 0x84
[ 44338][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 44339][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 37, _custom_cmd_last_tsn = 20, _custom_cmd_last_tsn_flag = 2
[ 44339][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 37, _custom_cmd_last_tsn_flag = 2
[ 44340][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -51
[ 46149][I][ZigbeeGateway.cpp:310] Z2S_simple_desc_req_cb(): Z2S simple desc failed
[ 46507][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[ 46527][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[ 46927][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[ 48954][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[ 48974][I][ZigbeeCore.cpp:406] esp_zb_app_signal_handler(): Joined device is leaving network (short: 0xb563), rejoin (NO)
[ 49928][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[ 54113][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 54115][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 54162][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xb563)
[ 54162][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x8e
[ 54163][D][ZigbeeGateway.cpp:547] zbDeviceAnnce(): zbDeviceAnnce short address (0xb563), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[ 54164][D][ZigbeeGateway.cpp:550] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0xb563), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[ 54164][I][ZigbeeGateway.cpp:574] zbDeviceAnnce(): Tuya magic last hope
[ 54668][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[ 54671][I][ZigbeeGateway.cpp:617] printJoinedDevices(): joined devices:
[ 54671][I][ZigbeeGateway.cpp:620] printJoinedDevices(): Device on endpoint 1, short address: 0xb563
[ 54702][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0x58b9) is open for 180 seconds
[ 54731][I][ZigbeeHandlers.cpp:62] zb_raw_cmd_handler(): cluster id: 0xa, command id: 0
[ 54732][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): src endpoint (0x2, dst endpoint 0x1
[ 54732][I][ZigbeeHandlers.cpp:64] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
[ 54733][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): manuf_specific 0x0
[ 54733][I][ZigbeeHandlers.cpp:67] zb_raw_cmd_handler(): RAW bufid: 12 size: 12
[ 54734][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x01
[ 54734][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 54735][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 54735][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x02
[ 54736][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 54736][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x03
[ 54737][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x04
[ 54737][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 54737][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x05
[ 54738][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 54738][I][ZigbeeHandlers.cpp:74] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb563, 0xb563, 0x0, 0x0
[ 54739][I][ZigbeeHandlers.cpp:88] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[ 54871][I][ZigbeeGateway.cpp:1806] sendCustomClusterCmd(): _custom_cmd_last_tsn = 39
[ 55071][I][ZigbeeGateway.cpp:1814] sendCustomClusterCmd(): _custom_cmd_last_tsn_flag = 2
[ 55072][I][ZigbeeGateway.cpp:363] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[ 56072][I][ZigbeeGateway.cpp:369] zbQueryDeviceBasicCluster(): basic tsn 0x28
[ 59072][I][ZigbeeGateway.cpp:382] zbQueryDeviceBasicCluster(): basic tsn 0x29
[ 61072][E][ZigbeeGateway.cpp:385] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x4
[ 61073][I][Z2S_Device_Scanner.ino:139] loop(): Error while pairing - cann't read manufacturer id. Gateway will restart, try to pair device once again!
[ 61076][I][ZigbeeGateway.cpp:1388] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
[ 61276][I][ZigbeeGateway.cpp:322] zbPrintDeviceDiscovery(): short_addr_req 46435
[ 61559][I][ZigbeeGateway.cpp:256] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 46435, endpoints count 2
[ 61560][I][ZigbeeGateway.cpp:259] Z2S_active_ep_req_cb(): Endpont # 1, id 2
[ 61560][I][ZigbeeGateway.cpp:259] Z2S_active_ep_req_cb(): Endpont # 2, id 1
[ 61652][I][ZigbeeGateway.cpp:275] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 46435, endpoint # 2
[ 61653][I][ZigbeeGateway.cpp:276] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 9, out clusters # 5
[ 61653][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
[ 61654][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 2, id 1794
[ 61655][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 3, id 3
[ 61655][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 4, id 9
[ 61655][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 5, id 2820
[ 61656][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 6, id 6
[ 61656][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 7, id 4
[ 61657][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 8, id 5
[ 61657][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 9, id 2
[ 61658][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 1, id 0
[ 61658][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 2, id 25
[ 61659][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 3, id 10
[ 61659][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 4, id 3
[ 61660][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 5, id 1030
[ 61737][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 61738][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0xb563), src_endpoint(2) to dst_endpoint(1), cluster(0x0) for command (0xc) with status 0x84
[ 61739][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 61739][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 43, _custom_cmd_last_tsn = 39, _custom_cmd_last_tsn_flag = 2
[ 61740][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 43, _custom_cmd_last_tsn_flag = 2
[ 61741][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -57
[ 61755][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 61756][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0xb563), src_endpoint(2) to dst_endpoint(1), cluster(0x702) for command (0xc) with status 0x84
[ 61757][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 61757][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 44, _custom_cmd_last_tsn = 39, _custom_cmd_last_tsn_flag = 2
[ 61758][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 44, _custom_cmd_last_tsn_flag = 2
[ 61759][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -55
[ 61772][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 61772][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0xb563), src_endpoint(2) to dst_endpoint(1), cluster(0x3) for command (0xc) with status 0x84
[ 61773][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 61774][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 45, _custom_cmd_last_tsn = 39, _custom_cmd_last_tsn_flag = 2
[ 61775][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 45, _custom_cmd_last_tsn_flag = 2
[ 61775][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -57
[ 61782][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 61783][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0xb563), src_endpoint(2) to dst_endpoint(1), cluster(0x9) for command (0xc) with status 0x84
[ 61784][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 61784][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 46, _custom_cmd_last_tsn = 39, _custom_cmd_last_tsn_flag = 2
[ 61785][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 46, _custom_cmd_last_tsn_flag = 2
[ 61786][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -56
[ 61807][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 61808][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0xb563), src_endpoint(2) to dst_endpoint(1), cluster(0xb04) for command (0xc) with status 0x84
[ 61809][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 61810][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 47, _custom_cmd_last_tsn = 39, _custom_cmd_last_tsn_flag = 2
[ 61810][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 47, _custom_cmd_last_tsn_flag = 2
[ 61811][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -56
[ 61824][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 61825][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0xb563), src_endpoint(2) to dst_endpoint(1), cluster(0x6) for command (0xc) with status 0x84
[ 61826][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 61826][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 48, _custom_cmd_last_tsn = 39, _custom_cmd_last_tsn_flag = 2
[ 61827][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 48, _custom_cmd_last_tsn_flag = 2
[ 61828][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -56
[ 61837][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 61837][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0xb563), src_endpoint(2) to dst_endpoint(1), cluster(0x4) for command (0xc) with status 0x84
[ 61838][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 61839][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 49, _custom_cmd_last_tsn = 39, _custom_cmd_last_tsn_flag = 2
[ 61840][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 49, _custom_cmd_last_tsn_flag = 2
[ 61841][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -56
[ 61856][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 61856][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0xb563), src_endpoint(2) to dst_endpoint(1), cluster(0x5) for command (0xc) with status 0x84
[ 61857][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 61858][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 50, _custom_cmd_last_tsn = 39, _custom_cmd_last_tsn_flag = 2
[ 61859][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 50, _custom_cmd_last_tsn_flag = 2
[ 61859][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -55
[ 61872][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 61873][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0xb563), src_endpoint(2) to dst_endpoint(1), cluster(0x2) for command (0xc) with status 0x84
[ 61874][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 61875][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 51, _custom_cmd_last_tsn = 39, _custom_cmd_last_tsn_flag = 2
[ 61875][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 51, _custom_cmd_last_tsn_flag = 2
[ 61876][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -57
[ 61893][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 61893][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0xb563), src_endpoint(2) to dst_endpoint(1), cluster(0x0) for command (0xc) with status 0x84
[ 61894][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 61895][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 52, _custom_cmd_last_tsn = 39, _custom_cmd_last_tsn_flag = 2
[ 61896][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 52, _custom_cmd_last_tsn_flag = 2
[ 61896][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -57
[ 64744][I][ZigbeeHandlers.cpp:62] zb_raw_cmd_handler(): cluster id: 0x19, command id: 11
[ 64745][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): src endpoint (0x2, dst endpoint 0x1
[ 64745][I][ZigbeeHandlers.cpp:64] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 1
[ 64746][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): manuf_specific 0xd
[ 64746][I][ZigbeeHandlers.cpp:67] zb_raw_cmd_handler(): RAW bufid: 7 size: 2
[ 64747][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x0C
[ 64747][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x84
[ 64747][I][ZigbeeHandlers.cpp:74] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb563, 0xb563, 0x0, 0x0
[ 64748][I][ZigbeeHandlers.cpp:88] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[ 64762][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 64762][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0xb563), src_endpoint(2) to dst_endpoint(1), cluster(0xa) for command (0xc) with status 0x84
[ 64763][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 64764][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 54, _custom_cmd_last_tsn = 39, _custom_cmd_last_tsn_flag = 2
[ 64765][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 54, _custom_cmd_last_tsn_flag = 2
[ 64765][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -59
[ 64785][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 64785][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0xb563), src_endpoint(2) to dst_endpoint(1), cluster(0x3) for command (0xc) with status 0x84
[ 64786][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 64787][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 55, _custom_cmd_last_tsn = 39, _custom_cmd_last_tsn_flag = 2
[ 64787][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 55, _custom_cmd_last_tsn_flag = 2
[ 64788][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -58
[ 64805][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 64806][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0xb563), src_endpoint(2) to dst_endpoint(1), cluster(0x406) for command (0xc) with status 0x84
[ 64807][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 64808][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 56, _custom_cmd_last_tsn = 39, _custom_cmd_last_tsn_flag = 2
[ 64808][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 56, _custom_cmd_last_tsn_flag = 2
[ 64809][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -58
[ 66561][I][ZigbeeGateway.cpp:310] Z2S_simple_desc_req_cb(): Z2S simple desc failed
[ 66669][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[ 66676][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[ 67076][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[ 69117][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[ 69149][I][ZigbeeCore.cpp:406] esp_zb_app_signal_handler(): Joined device is leaving network (short: 0xb563), rejoin (NO)
[ 70077][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[ 79256][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 79259][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 79291][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xb563)
[ 79292][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x8e
[ 79293][D][ZigbeeGateway.cpp:547] zbDeviceAnnce(): zbDeviceAnnce short address (0xb563), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[ 79293][D][ZigbeeGateway.cpp:550] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0xb563), ieee_addr (0x0):(0x15):(0xbc):(0x0):(0x2f):(0x0):(0x24):(0xe8)
[ 79294][I][ZigbeeGateway.cpp:574] zbDeviceAnnce(): Tuya magic last hope
[ 79831][I][ZigbeeGateway.cpp:617] printJoinedDevices(): joined devices:
[ 79832][I][ZigbeeGateway.cpp:620] printJoinedDevices(): Device on endpoint 1, short address: 0xb563
[ 79836][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0x58b9) is open for 180 seconds
[ 79865][I][ZigbeeHandlers.cpp:62] zb_raw_cmd_handler(): cluster id: 0xa, command id: 0
[ 79866][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): src endpoint (0x2, dst endpoint 0x1
[ 79866][I][ZigbeeHandlers.cpp:64] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
[ 79867][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): manuf_specific 0x0
[ 79867][I][ZigbeeHandlers.cpp:67] zb_raw_cmd_handler(): RAW bufid: 10 size: 12
[ 79868][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x01
[ 79868][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 79869][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 79869][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x02
[ 79870][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 79870][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x03
[ 79871][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x04
[ 79871][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 79871][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x05
[ 79872][I][ZigbeeHandlers.cpp:69] zb_raw_cmd_handler(): 0x00
[ 79872][I][ZigbeeHandlers.cpp:74] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xb563, 0xb563, 0x0, 0x0
[ 79873][I][ZigbeeHandlers.cpp:88] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[ 80032][I][ZigbeeGateway.cpp:1806] sendCustomClusterCmd(): _custom_cmd_last_tsn = 58
[ 80232][I][ZigbeeGateway.cpp:1814] sendCustomClusterCmd(): _custom_cmd_last_tsn_flag = 2
[ 80233][I][ZigbeeGateway.cpp:363] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[ 80586][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Unavailable (0x3c), status: ESP_OK
[ 81233][I][ZigbeeGateway.cpp:369] zbQueryDeviceBasicCluster(): basic tsn 0x3b
[ 84233][I][ZigbeeGateway.cpp:382] zbQueryDeviceBasicCluster(): basic tsn 0x3c
[ 86233][E][ZigbeeGateway.cpp:385] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x4
[ 86234][I][Z2S_Device_Scanner.ino:139] loop(): Error while pairing - cann't read manufacturer id. Gateway will restart, try to pair device once again!
[ 86237][I][ZigbeeGateway.cpp:1388] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
[ 86437][I][ZigbeeGateway.cpp:322] zbPrintDeviceDiscovery(): short_addr_req 46435
[ 86464][I][ZigbeeGateway.cpp:256] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 46435, endpoints count 2
[ 86465][I][ZigbeeGateway.cpp:259] Z2S_active_ep_req_cb(): Endpont # 1, id 2
[ 86466][I][ZigbeeGateway.cpp:259] Z2S_active_ep_req_cb(): Endpont # 2, id 1
[ 86532][I][ZigbeeGateway.cpp:275] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 46435, endpoint # 2
[ 86533][I][ZigbeeGateway.cpp:276] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 9, out clusters # 5
[ 86534][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
[ 86534][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 2, id 1794
[ 86535][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 3, id 3
[ 86535][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 4, id 9
[ 86536][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 5, id 2820
[ 86536][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 6, id 6
[ 86537][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 7, id 4
[ 86537][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 8, id 5
[ 86538][I][ZigbeeGateway.cpp:280] Z2S_simple_desc_req_cb(): In cluster # 9, id 2
[ 86538][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 1, id 0
[ 86539][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 2, id 25
[ 86539][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 3, id 10
[ 86540][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 4, id 3
[ 86540][I][ZigbeeGateway.cpp:295] Z2S_simple_desc_req_cb(): Out cluster # 5, id 1030
[ 86606][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 86607][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0xb563), src_endpoint(2) to dst_endpoint(1), cluster(0x0) for command (0xc) with status 0x84
[ 86608][V][ZigbeeHandlers.cpp:280] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 86608][I][ZigbeeGateway.cpp:1756] zbCmdDefaultResponse(): tsn = 62, _custom_cmd_last_tsn = 58, _custom_cmd_last_tsn_flag = 2
[ 86609][I][ZigbeeGateway.cpp:1770] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 62, _custom_cmd_last_tsn_flag = 2
[ 86610][I][ZigbeeGateway.cpp:1772] zbCmdDefaultResponse(): custom cmd rssi -63
[ 86624][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 86624][V][ZigbeeHandlers.cpp:276] zb_cmd_default_resp_handler(): Received default response: from address(0xb563), src_endpoint(2) to dst_endpoint(1), cluster(0x702) for command (0xc) with status 0x84
Has thanked: 290 times
klew wrote: Mon Aug 18, 2025 7:44 am
============ After Setup End =============
OK, tutaj powinno być łatwiej, aczkolwiek jaka twisted idea :twisted: kierowała osobą przypisującą numery endpointów (1 -> 2, 2 ->1)?
Wybywam na parę dni z rodziną i obiecałem im, że nie zabieram komputera, więc wrócę do tematu od 23.08.
Has thanked: 3 times
Been thanked: 3 times
Wątek co prawda trochę skręcił ale temat mi pasuje więc tutaj napiszę ... "pomóżcie początkującemu" :)
Cały dział Z2S rozrósł się do niemożebnych rozmiarów i ciężko cokolwiek znaleźć bez przeczytania całości. Jak się domyślacie chęci na to mało. Stąd pytania wprost o pomoc i ułatwienie. Łukaszowi nie będę zawracał głowy ale może ktoś na szybko podlinkuje mnie do odpowiedzi:
1. Temp&Humi sensor Sonoff SNZB-02P - nie pokazuje stanu baterii - tak ma być? Jak to naprawić
2. Motion sensor Sonoff SNZB-03 - pomimo wpisania VMax w Battery Panel 250 - pokazuje cały czas 100%
3. Jakiś link do opisu działów GUI? (Clusters&Attributes, Attribute commands, Asynchronous command,Tuya custom cluster (0xEF00) devices, etc.)
4. Głowice Avatto TRV07 oraz TRV16 -
a. TRV07 - się przedstawia: Unknown model _TZE204_ltwbm23f::TS0601 no binding is possible i moduł pozostaje "zawieszony" z zaświeconą czerwoną diodą (nie da się przełączyć w parowanie) ale w tle działa i po dłuższej chwili dioda gaśnie -> teraz można znowu włączyć parowanie
b. TRV16 się dodała za drugim razem jako termostat oraz czujnik temperatury i wilgotności (sic), który jednak nie pokazuje temperatury tylko "?" a wilgotność -1%, nie pokazuje baterii
- co z tym fantem powinienem zrobić? Skaner (Z2S_Device_Scanner.ino.merged.bin) wrzucić na esp i wrzucić tutaj logi? dobrze kojarzę z wątków? Czy wystarczy logi z seriala?
5. Co to jest IAS ZONE NOTIFICATIONS (jest na ten temat kilka postów ale nie łapię) - weszło z automatu na świeżą bramkę?
6. czujnik ruchu załącza się szybko ale długo się "wyłącza" - to jest ustawienie sensora czy w bramce (jeżeli tak to ktora opcja)?
kiler88
Na programowaniu się nie znam, ale coś tam czytałem.
Ad.1 Próbowałeś wymusić komunikację wciskając na chwilę przycisk parowania? Kiedyś wtedy niektóre czujniki wysyłały stan baterii i pojawiała się informacja w apce.
Ad.4 Ostatnio były jakieś poprawki do głowic, prace trwają, próbowałeś na najnowszej wersji?
Ad.5 Włącza/wyłącza wysyłanie powiadomień z urządzeń na danej bramce, ma to służyć głownie jako prosty alarm z czujników ruchu i otwarcia okien.
Ad.6 Funkcja czujnika, moje też tak mają, bardziej zaawansowany ktoś podpowie jak to zmienić wysyłając polecenia w GUI.
YoMan wrote: Tue Aug 26, 2025 8:28 pm Wątek co prawda trochę skręcił ale temat mi pasuje więc tutaj napiszę ... "pomóżcie początkującemu" :)
Stan baterii zwykle pojawia się do 24h, ale można spróbować odczytać go jednorazowo lub ustawić cykliczne raportowanie.
To nie jest takie proste, niestety. To czujnik "decyduje" czy będzie wysyłać komunikat BATTERY_PERCENATGE czy BATTERY_VOLTAGE, w tym pierwszym przypadku Vmin i Vmax nie będą miały wpływu na pokazywany stan baterii. BTW. skąd to Vmax na poziomie 2,5V?
Staram się pisać mini poradniki w tym wątku:
Muszę dodać ten model.
Temat znany - kiedyś ;) dorobię czujnik temperatury oparty o Zigbee, póki co z lenistwa jest T/H. Temperatura pojawia się po jakimś czasie, @Zibi_007 napisał kiedyś poradnik aktywowania stanu baterii, możesz też wrzucić konkretny model tej głowicy.
Dla wszystkich czujników binarnych Zigbee możesz dodać powiadomienia, które bramka wysyła za pośrednictwem Cloud. Ten przełącznik służy do globalnego włączania/wyłączania tych powiadomień.
GUI -> Zigbee channels-> wybierasz konkretny kanał czujnika i ustawiasz mu parametr autoset w panelu Timings (trzeci od góry) - czas w sekundach, po którym czujnik zostanie wyzerowany, nawet jeżeli nie przyszedł jeszcze komunikat z samego czujnika.
vajera wrote: Wed Aug 27, 2025 9:06 am
Dzięki wielkie chociaż miałem nadzieję, że ktoś inny Cię wyręczy i nie będziesz poświęcał cennego czasu na wyjaśnienia :)
YoMan wrote: Tue Aug 26, 2025 8:28 pm 1. Temp&Humi sensor Sonoff SNZB-02P - nie pokazuje stanu baterii - tak ma być? Jak to naprawić
vajera wrote: Wed Aug 27, 2025 9:06 am Stan baterii zwykle pojawia się do 24h, ale można spróbować odczytać go jednorazowo lub ustawić cykliczne raportowanie.
Nie wiem jeszcze jak wymusić odczyt więc poczekam do 24h (na razie jest ok. 12h)
YoMan wrote: Tue Aug 26, 2025 8:28 pm 2. Motion sensor Sonoff SNZB-03 - pomimo wpisania VMax w Battery Panel 250 - pokazuje cały czas 100%
vajera wrote: Wed Aug 27, 2025 9:06 am To nie jest takie proste, niestety. To czujnik "decyduje" czy będzie wysyłać komunikat BATTERY_PERCENATGE czy BATTERY_VOLTAGE, w tym pierwszym przypadku Vmin i Vmax nie będą miały wpływu na pokazywany stan baterii. BTW. skąd to Vmax na poziomie 2,5V?
Czyli muszę poklikać testowo w obie opcje czy gdzieś odczytam w logach, którą wersję wysyła czujnik?
BTW: 250 to chyba 25,0V - ustawiłem maxa, żeby sprawdzić czy coś się zmieni ale dalej mam 100% :)
YoMan wrote: Tue Aug 26, 2025 8:28 pm a. TRV07 - się przedstawia: Unknown model _TZE204_ltwbm23f::TS0601 no binding is possible i moduł pozostaje "zawieszony" z zaświeconą czerwoną diodą (nie da się przełączyć w parowanie) ale w tle działa i po dłuższej chwili dioda gaśnie -> teraz można znowu włączyć parowanie
vajera wrote: Wed Aug 27, 2025 9:06 am Muszę dodać ten model.
Coś ode mnie ci pomoże? Logi, jakiś skaner, etc.?
YoMan wrote: Tue Aug 26, 2025 8:28 pm b. TRV16 się dodała za drugim razem jako termostat oraz czujnik temperatury i wilgotności (sic), który jednak nie pokazuje temperatury tylko "?" a wilgotność -1%, nie pokazuje baterii
vajera wrote: Wed Aug 27, 2025 9:06 am Temat znany - kiedyś ;) dorobię czujnik temperatury oparty o Zigbee, póki co z lenistwa jest T/H. Temperatura pojawia się po jakimś czasie, @Zibi_007 napisał kiedyś poradnik aktywowania stanu baterii, możesz też wrzucić konkretny model tej głowicy.
Na chwilę obecną po ok. 12h nic sie nie pojawiło. @Zibi_007 podlinkujesz poradnik?
Konkretny model - wystarczy ci info z opakowania, naklejki na głowicy, logów, skanera, etc.?
YoMan wrote: Tue Aug 26, 2025 8:28 pm6. czujnik ruchu załącza się szybko ale długo się "wyłącza" - to jest ustawienie sensora czy w bramce (jeżeli tak to ktora opcja)?
vajera wrote: Wed Aug 27, 2025 9:06 am GUI -> Zigbee channels-> wybierasz konkretny kanał czujnika i ustawiasz mu parametr autoset w panelu Timings (trzeci od góry) - czas w sekundach, po którym czujnik zostanie wyzerowany, nawet jeżeli nie przyszedł jeszcze komunikat z samego czujnika.
OK. Będę testował :)
YoMan wrote: Wed Aug 27, 2025 9:43 am
Poczytaj w tym poradniku, jak odczytać atrybuty klastra POWER CONFIG w GUI oraz jak ustawić ich cykliczne raportowanie.
Zobacz pytanie powyżej - sprawdź czy czujnik zwraca wartość atrybutów BATTERY_PERCENTAGE i BATTERY_VOLTAGE - to już będzie jakiś początek.
Faktycznie ;)
To mi wystarczy Unknown model _TZE204_ltwbm23f::TS0601
Skoro dodał się do bramki, to potrzebuje manufacturer_id/model_id, które znajdziesz w GUI w zakładce Zigbee devices.
vajera wrote: Wed Aug 27, 2025 10:06 am
Manufacturer name _TZE200_rxntag7i | model ID TS0601 | Z2S model Unknown Zigbee model [0x6011]
YoMan wrote: Wed Aug 27, 2025 7:58 pm
To jest model ME167 - poszukaj na forum wskazówek o baterii, rozumiem, że poza tym działa prawidłowo?
