shimano73 wrote: Sat Aug 31, 2019 10:34 am
Niestety nie pomogło, i wydaje mi się że fragment poniżej robi to samo
SuplaDeviceCallbacks supla_arduino_get_callbacks(void) { SuplaDeviceCallbacks cb; cb.tcp_read = &supla_arduino_tcp_read; cb.tcp_write = &supla_arduino_tcp_write; cb.eth_setup = &supla_arduino_eth_setup; cb.svr_connected = &supla_arduino_svr_connected; cb.svr_connect = &supla_arduino_svr_connect; cb.svr_disconnect = &supla_arduino_svr_disconnect; cb.get_temperature = &get_temperature; cb.get_temperature_and_humidity = &get_temperature_and_humidity; cb.get_rgbw_value = &get_rgbw_value; cb.set_rgbw_value = &set_rgbw_value; cb.read_supla_relay_state = &read_supla_relay_state; cb.save_supla_relay_state = &save_supla_relay_state; return cb; }
temat widze trochę umarł, ale moze jest juz dopracowana obsługa ws2812?
