thermostat with settings from the Supla app
Read. (download pdf).
 viewtopic.php?f=32&t=4979
Skalar
Niestety nic nie udało się zrobić
Urządzenie jest w sieci ale nie łączy się z Suplą Cloud :(
Unfortunately nothing could be done
The device is on the network but does not connect to Supla Cloud
elmaya
Skalar wrote: Wed Sep 18, 2019 4:52 am Niestety nic nie udało się zrobić
Send me a PM with what comes out in the terminal.
elmaya
A different way to use the StatusLed.
This version of the Supla thermostat flashes the Led every second if it is not connected to the Wifi.
The Led will be on during WifiConfig.
Led off in normal state.
and blinks x times every 15 seconds according to the Supla cloud connection error.
For example, if status is BAD_CREDENTIALS, the Led flashes 13 times.
According to the following list:
Supla Status List:
2 _ALREADY_INITIALIZED
3 _CB_NOT_ASSIGNED
4 _INVALID_GUID -------- "Incorrect device GUID!"--"Incorrect AuthKey!"--"Registration disabled!"--"No location available!"--"User conflict!"
5 _UNKNOWN_SERVER_ADDRESS
6 _UNKNOWN_LOCATION_ID
7 _INITIALIZED
8 _CHANNEL_LIMIT_EXCEEDED
9 _DISCONNECTED
10 _REGISTER_IN_PROGRESS
11 _ITERATE_FAIL
12 _PROTOCOL_VERSION_ERROR
13 _BAD_CREDENTIALS
14 _TEMPORARILY_UNAVAILABLE
15 _LOCATION_CONFLICT
16 _CHANNEL_CONFLICT
17 _REGISTERED_AND_READY ------ connection ok Led Off -----
18 _DEVICE_IS_DISABLED
19 _LOCATION_IS_DISABLED
20 _DEVICE_LIMIT_EXCEEDED
supla_Termostst_Jled_2.ino:
#include <FS.h>       // ---- esp board manager 2.4.2 --- iwip Variant V2 higher Bandwidth
#include <ESP8266WiFi.h>
#define SUPLADEVICE_CPP
#include <SuplaDevice.h>
#include <math.h>
#include <DNSServer.h>
#include <WiFiManager.h>
#include <ArduinoJson.h> //--------- https://github.com/bblanchon/ArduinoJson/tree/v5.13.2 ------
#include <EEPROM.h>
#include <ESP8266WebServer.h>
#include <ESPEFC.h>  // modification of ESP8266HTTPUpdateServer that includes erases flash and wifi credentials
#include <OneWire.h>
extern "C"
#include "user_interface.h"
//#define D0 16  //no internal pullup resistor
//#define D1  5
//#define D2  4
//#define D3  0  //must not be pulled low during power on/reset, toggles value during boot
//#define D4  2  //must not be pulled low during power on/reset, toggles value during boot
//#define D5 14
//#define D6 12
//#define D7 13
//#define D8 15  //must not be pulled high during power on/reset
#define ONE_WIRE_BUS 2   //--------------------oneWire Dallas Temperature ----------
int relay_1 = 12;        //------------------- thermometer on off Led ----- active high
int relay_2 = 13;        //------------------- relay output ----- active high
int relay_3 = 120;       //------------------- thermostat temperature setting +/- 0.5º no Gpio -----
int button_1 = 4;        //------------------- automatic / manual thermostat change  ---- WiFi config 10 seconds  --------
int button_2 = 5;        //------------------- manual on / off ----
int button_3 = 121;      //------------------- No function ----
#define status_led 16    //------------------- status Led -----define led gpio before #include "StatusLed.h" ------------------
#include "StatusLed.h"      //for LED status--Dependent of jled libraries --https://github.com/jandelgado/jled---
OneWire oneWire(ONE_WIRE_BUS);
DeviceAddress tempDeviceAddress;
int  resolution = 11;
bool pr_wifi = true;
bool start = true;
bool eep = LOW;
int epr = 0;
int s = 1;
int an;
int buttonValue = 0;
int Term_Temp ;
int Term_Hist ;
double tr = -275;
unsigned long wifi_checkDelay = 20000;
unsigned long wifimilis;
unsigned long eep_milis;
unsigned long tr_milis;
int C_W_state = HIGH;
int last_C_W_state = HIGH;
unsigned long time_last_C_W_change = 0;
long C_W_delay = 10000;               // config delay 10 seconds           ----------        opóźnienie konfiguracji 10 sekund
#define BTN_COUNT 3
WiFiClient client;
ESP8266WebServer httpServer(81);
ESPEFC httpUpdater;
const char* update_path = "/update";
char Supla_server[80];
char Location_id[15];
char Location_Pass[34];
char Supla_name[51];
char up_host[21];
char update_username[21];
char update_password[21];
char term_temp[5];
char term_hist[5];
byte mac[6];
bool shouldSaveConfig = false;
bool initialConfig = false;
int timeout = 180;          // seconds to run the wifi config
void saveConfigCallback () {                 //callback notifying us of the need to save config
  Serial.println("Should save config");
  shouldSaveConfig = true;
void ondemandwifiCallback () {
        StatusLedOn();  //---------led on when wificonfig is opened (no callback her)
  WiFiManagerParameter custom_Supla_server("server", "supla server", Supla_server, 80);
  WiFiManagerParameter custom_Location_id("ID", "Location id", Location_id, 15);
  WiFiManagerParameter custom_Location_Pass("Password", "Location Pass", Location_Pass, 34);
  WiFiManagerParameter custom_Supla_name("name", "Supla Device Name", Supla_name, 51,"required");
  WiFiManagerParameter custom_up_host("DHCP_name", "xxxx (DHCP name)", up_host, 21,"required");
  WiFiManagerParameter custom_update_username("updateUsername", "update username", update_username, 21,"required");
  WiFiManagerParameter custom_update_password("updatePassword", "update password", update_password, 21,"required");
  WiFiManagerParameter custom_term_temp("Termostat", "Temp x 10", term_temp, 5,"required");
  WiFiManagerParameter custom_term_hist("Histerisis", "Histerisis x 10", term_hist, 5,"required");
  WiFiManager wifiManager;
  wifiManager.setBreakAfterConfig(true);
  wifiManager.setSaveConfigCallback(saveConfigCallback);
  wifiManager.addParameter(&custom_Supla_server);
  wifiManager.addParameter(&custom_Location_id);
  wifiManager.addParameter(&custom_Location_Pass);
  wifiManager.addParameter(&custom_Supla_name);
  wifiManager.addParameter(&custom_up_host);
  wifiManager.addParameter(&custom_update_username);
  wifiManager.addParameter(&custom_update_password);
  wifiManager.addParameter(&custom_term_temp);
  wifiManager.addParameter(&custom_term_hist);
  wifiManager.setCustomHeadElement("<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>");
  wifiManager.setMinimumSignalQuality(8);
  wifiManager.setConfigPortalTimeout(timeout);
    if (!wifiManager.startConfigPortal("Supla_Termostat")) {
      Serial.println("Not connected to WiFi but continuing anyway.");
    } else {
      Serial.println("connected...yeey :)");    //if you get here you have connected to the WiFi
    //read updated parameters
    strcpy(Supla_server, custom_Supla_server.getValue());
    strcpy(Location_id, custom_Location_id.getValue());
    strcpy(Location_Pass, custom_Location_Pass.getValue());
    strcpy(Supla_name, custom_Supla_name.getValue());
    strcpy(up_host, custom_up_host.getValue());
    strcpy(update_username, custom_update_username.getValue());
    strcpy(update_password, custom_update_password.getValue());
    strcpy(term_temp, custom_term_temp.getValue());
    strcpy(term_hist, custom_term_hist.getValue());
  WiFi.softAPdisconnect(true);   //  close AP
typedef struct {  //------------------------------------------- BTN ----------------------------------------------------
  int pin;
  int relay_pin;
  int channel;
  char last_val;
  int ms;
  unsigned long last_time;
  bool mem;
} _btn_t;
_btn_t btn[BTN_COUNT];
   double t = -275;
   switch(channelNumber)
            case 3:
         t = sensors.getTempCByIndex(0);
         if (t < -55){t = -275;}
                    break;
            case 4:
            double trd = (Term_Temp) ;
                  trd = (trd / 10) ;
            t = (trd);
                    break;
    return t;
void itrate_Term() {
    tr = sensors.getTempCByIndex(0);
    if (tr<-55){
      if ( digitalRead(btn[1].relay_pin-1) == 1){
          (btn[1].mem) = 0 ;
          Serial.println(" Relay off temp to low");
          SuplaDevice.relayOff(1);
          return ;
     double trt = (Term_Temp + Term_Hist) ;
      trt = (trt / 10);
       Serial.print("tr ");
       Serial.println(tr);
         if (tr >= trt) {
          if ( digitalRead(btn[1].relay_pin-1) == 1) {
          (btn[1].mem) = 0 ;
          Serial.println(" Relay off ");
     double trs = (Term_Temp - Term_Hist) ;
      trs = (trs / 10) ;
         if(tr <= trs) {
          if ( digitalRead(btn[1].relay_pin-1) == 0) {
         (btn[1].mem) = 1 ;
         Serial.println(" Relay on ");
          SuplaDevice.relayOn(1, 0);
void iterate_B() {
  char v;
  unsigned long now = millis();
  for(int a=0;a<2;a++)
    if (btn[a].pin > 0) {
        v = digitalRead(btn[a].pin-1);
        if (v != btn[a].last_val && now - btn[a].last_time ) {
           btn[a].last_val = v;
           btn[a].last_time = now;
           delay(75);
           if (v==0)
              if ( btn[a].ms > 0 ) {
                     SuplaDevice.relayOn(btn[a].channel, btn[a].ms);
                     Serial.println(" monostable");
                 } else {
                 if ( (btn[a].mem) == 1 ) {
                  SuplaDevice.relayOff(btn[a].channel);
                  Serial.print("BTN Switsh off relay ");
                  Serial.println(btn[a].relay_pin-1);
                 } else {
                  SuplaDevice.relayOn(btn[a].channel, 0);
                  Serial.print("BTN Switsh on relay ");
void supla_btn_init() {
  for(int a=0;a<BTN_COUNT;a++)
        pinMode(btn[a].pin-1, INPUT_PULLUP);
        btn[a].last_val = digitalRead(btn[a].pin-1);
        btn[a].last_time = millis();
        pinMode(btn[a].relay_pin-1,OUTPUT);
int supla_DigitalRead(int channelNumber, uint8_t pin) {
      return btn[channelNumber].mem;
void suplaDigitalWrite(int channelNumber, uint8_t pin, uint8_t val) {
     btn[channelNumber].mem =val;
             case 0:
         if ( (btn[channelNumber].mem) == 0 ) {
                  Serial.print("Manual Mode ");
                  digitalWrite(btn[channelNumber].relay_pin-1, LOW);        //--------------- relay active High
                  Serial.println(" Relay off Manual Mode");
                  eep_milis = millis() + 2000 ;
                 }else {
                  Serial.print("Auto Mode ");
                  digitalWrite(btn[channelNumber].relay_pin-1, HIGH);        //--------------- relay active High
                    break;
             case 1:
                  Serial.print("Switsh off relay ");
                  Serial.println(btn[channelNumber].relay_pin-1);
                 }else {
                  Serial.print("Switsh on relay ");
                 break;
              case 2:
                  Serial.print("Temp - ");
                  Term_Temp = Term_Temp - 5 ;
                  Serial.println(Term_Temp);
                  tr_milis = millis() + 5000 ;
                 }else {
                  Serial.print("Temp + ");
                  Term_Temp = Term_Temp + 5 ;
                  trd = (trd / 10) ;
                  SuplaDevice.channelDoubleValueChanged(4,trd);
                    break;
  return;
void Eeprom_save() {                  //----------EEPROM write  ---------------------- EEprom
        if (start){
          return;
        if ( (btn[0].mem) == 0 ) {
      for(int e=0;e<BTN_COUNT;e++) {
         if ( btn[e].ms > 0 ) {
                     continue;
         } else {
        eep = (btn[e].mem);                    //  --- read relay state
        if (eep != EEPROM.read(e)){            //  --- compare relay state with memorized state
         EEPROM.write(e,eep);                  //  --- if different write memory
         Serial.print("EEPROM.");
         Serial.print(e);
         Serial.print(" write.");
         Serial.print((eep));
         Serial.print(" channel ");
         Serial.println((btn[e].channel));
         EEPROM.commit();
          if ( (btn[0].mem) == 1 ) {
         eep = (btn[0].mem);                    //  --- read relay state
        if (eep != EEPROM.read(0)){            //  --- compare relay state with memorized state
         EEPROM.write(0,eep);                  //  --- if different write memory
         Serial.print(0);
         Serial.println((btn[0].channel));
         EEPROM.commit();
void Eepron_read() {                  //----------EEPROM read  ---------------------- EEprom
       if ( btn[epr].ms > 0 ) {
                     return;
         } else {
         eep = EEPROM.read(epr);               //  ---read relay state
         Serial.print(epr);
         Serial.print(" read.");
         Serial.println((btn[epr].channel));
        if (eep == HIGH){                    //  --- if 1 send relay on
          (btn[epr].mem) = 1 ;
          SuplaDevice.relayOn(epr, 0);       //  --- only one channel on each pass
         if (eep == 1) {
         bool stat = digitalRead(btn[1].relay_pin-1);
         if (stat) SuplaDevice.relayOn(1, 0);
void status_func(int status, const char *msg) {     //    ------------------------ Status --------------------------
 s=status;                                          //    -- to check if we are registered and ready before restore from memory
void setup() {  //------------------------------------------------ Setup ----------------------------------------------
  wifi_set_sleep_type(NONE_SLEEP_T);
  Serial.begin(115200);
  delay(200);
  EEPROM.begin(512);
  sensors.begin();
  sensors.getAddress(tempDeviceAddress, 0);
  sensors.setResolution(tempDeviceAddress, resolution);
  sensors.setWaitForConversion(false);
  if (WiFi.SSID()==""){
    initialConfig = true;
    Serial.println("initial config");
  WiFi.mode(WIFI_STA); // Force to station mode because if device was switched off while in access point mode it will start up next time in access point mode.
   uint8_t mac[WL_MAC_ADDR_LENGTH];
   WiFi.macAddress(mac);
   char GUID[SUPLA_GUID_SIZE] = {mac[WL_MAC_ADDR_LENGTH - 6], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 3],
                                 mac[WL_MAC_ADDR_LENGTH - 2], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 2],
                                 mac[WL_MAC_ADDR_LENGTH - 3], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 6]};
  SuplaDevice.addRelay(101, false);
  SuplaDevice.addRelay(102, false);
  SuplaDevice.addRelay(103, false);
  memset(btn, 0, sizeof(btn));
  btn[0].pin =button_1 +1;          // pin gpio buton  +1
  btn[0].relay_pin =relay_1 +1;  // pin gpio Relay   +1
  btn[0].channel =0;      // channel
  btn[0].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[0].mem =0;
  btn[1].pin =button_2 +1;          // pin gpio buton  +1
  btn[1].relay_pin =relay_2 +1;  // pin gpio Relay   +1
  btn[1].channel =1;      // channel
  btn[1].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[1].mem =0;
  btn[2].pin =button_3 +1;          // pin gpio buton  +1
  btn[2].relay_pin =relay_3 +1;  // pin gpio Relay   +1
  btn[2].channel =2;      // channel
  btn[2].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[2].mem =0;
  supla_btn_init();
  //read configuration from FS json
  Serial.println("mounting FS...");
  if (SPIFFS.begin()) {
    Serial.println("mounted file system");
    if (SPIFFS.exists("/config.json")) {
      Serial.println("reading config file");
      File configFile = SPIFFS.open("/config.json", "r");
      if (configFile) {
        Serial.println("opened config file");
        size_t size = configFile.size();
        std::unique_ptr<char[]> buf(new char[size]);
        configFile.readBytes(buf.get(), size);
        DynamicJsonBuffer jsonBuffer;
        JsonObject& json = jsonBuffer.parseObject(buf.get());
        json.printTo(Serial);   //print config data to serial on startup
        if (json.success()) {
          Serial.println("\nparsed json");
          strcpy(Supla_server, json["Supla_server"]);
          strcpy(Location_id, json["Location_id"]);
          strcpy(Location_Pass, json["Location_Pass"]);
          strcpy(Supla_name, json["Supla_name"]);
          strcpy(up_host, json["up_host"]);
          strcpy(update_username, json["update_username"]);
          strcpy(update_password, json["update_password"]);
          strcpy(term_temp, json["term_temp"]);
          Term_Temp = (String(term_temp).toInt());
          strcpy(term_hist, json["term_hist"]);
          Term_Hist = (String(term_hist).toInt());
        } else {
          Serial.println("failed to load json config");
  } else {
    Serial.println("failed to mount FS");
  wifi_station_set_hostname(up_host);  //nazwa w sieci lokalnej  @cino111
  SuplaDevice.setDigitalReadFuncImpl(&supla_DigitalRead);    //            ------Send Value to server -------
  SuplaDevice.setDigitalWriteFuncImpl(&suplaDigitalWrite);   //        -------  Read Value from server   -------
  //SuplaDevice.setTimerFuncImpl(&supla_timer);
  SuplaDevice.setStatusFuncImpl(&status_func);    //   ----------------------------- Status -----------------------------
  SuplaDevice.setName(Supla_name);
  int LocationID = atoi(Location_id);
                    Supla_server,      // SUPLA server address
                    LocationID,        // Location ID
                    Location_Pass);    // Location Password
void loop() {
   StatusLed(s);  //------------------------------------------------ StatusLed callback ---------------------
   iterate_B();
  if (start){
    // read_initial_relay_state
    for(int i=0;i<BTN_COUNT;i++){      //  ---check relay except der have delay (staircase)
     if ( (btn[i].ms) > 0 ) {
      digitalWrite(btn[i].relay_pin-1, LOW);
                     continue;
         } else {
        eep = EEPROM.read(i);
       if (eep >= 2 ){
         EEPROM.write(i,0);
         Serial.println("epp correct");
         EEPROM.commit();
         Serial.print("Recover.");
         Serial.print(i);
         Serial.println((btn[i].channel));
         btn[i].mem =eep;
                  Serial.print((btn[i].relay_pin) -1);
                  Serial.print(" set ");
                  Serial.println(eep);
    start = false;
  if (initialConfig){
        EEPROM.write(i, 0);
      EEPROM.commit();
      Serial.println("initial config triger");
    ondemandwifiCallback () ;
  if (shouldSaveConfig) {
    Serial.println("saving config");
    JsonObject& json = jsonBuffer.createObject();
    json["Supla_server"] = Supla_server;
    json["Location_id"] = Location_id;
    json["Location_Pass"] = Location_Pass;
    json["Supla_name"] = Supla_name;
    json["up_host"] = up_host;
    json["update_username"] = update_username;
    json["update_password"] = update_password;
    json["term_temp"] = term_temp;
    json["term_hist"] = term_hist;
    File configFile = SPIFFS.open("/config.json", "w");
    if (!configFile) {
      Serial.println("failed to open config file for writing");
    json.prettyPrintTo(Serial);
    json.printTo(configFile);
    configFile.close();
    Serial.println("config saved");
    ESP.restart();
    delay(5000);
  if (WiFi.status() != WL_CONNECTED) {
    WiFi_up();
  if (millis() > eep_milis){
     Eeprom_save() ;   //        ------------------------------Eepron save callback -----------------------------
     eep_milis = millis() + 5000 ;
  switch (s) {    //    ------------------------------------------------ Status ------------------------------------
  case 17:      // -----     STATUS_REGISTERED_AND_READY
  if (epr<2){
   Eepron_read() ;                // ------------------------------- Eeprom read callback -------------------------------
   epr = epr+1;// -------- 1 loop for each output  ----------
    break;
   case 10:      // --------------------- REGISTER_IN_PROGRESS  ----------------------
    epr = 0 ;
    break;
  int C_W_read = digitalRead(btn[0].pin-1);{
   if (C_W_read != last_C_W_state) {
     time_last_C_W_change = millis();
   if ((millis() - time_last_C_W_change) > C_W_delay) {
     if (C_W_read != C_W_state) {
       Serial.println("Triger sate changed");
       C_W_state = C_W_read;
       if (C_W_state == LOW) {
   last_C_W_state = C_W_read;
   if (WiFi.status() == WL_CONNECTED){
    SuplaDevice.iterate();
    if (pr_wifi == true){
     Serial.println("");
     Serial.println("CONNECTED");
     Serial.print("local IP: ");
     Serial.print("subnetMask: ");
     Serial.print("gatewayIP: ");
     long rssi = WiFi.RSSI();
     Serial.print("Signal Strength (RSSI): ");
     Serial.print(rssi);
     Serial.println(" dBm");
     pr_wifi = false;
     httpUpdater.setup(&httpServer, update_path, update_username, update_password);
     httpServer.begin();
     delay(100);
    httpServer.handleClient();
   if (millis() > tr_milis){
     if ((btn[0].mem) == true) itrate_Term();   //        ------------------------------Termostat callback -----------------------------
     if ((String(term_temp).toInt()) != Term_Temp){
      double trs = (Term_Temp) ;
      trs = (trs / 10) ;
      Serial.println(term_temp);
      Serial.println("save Temp_Term");
      itoa(Term_Temp ,term_temp ,10) ;
      // --------------------------save fs ----------------------------------------
      if (!configFile) {
      configFile.close();
// Supla.org ethernet layer
        if ( size > 0 ) {
        return -1;
          return client.connected();
         client.stop();
       WiFi_up();
          SuplaDeviceCallbacks cb;
          cb.get_temperature = &get_temperature;
          //cb.get_temperature = NULL;
          cb.get_rgbw_value = NULL;
          cb.set_rgbw_value = NULL;
          return cb;
void WiFi_up(){ // conect to wifi
  if (millis() > wifimilis)  {
  WiFi.begin();
  pr_wifi = true;
  Serial.println("CONNECTING WIFI");
  wifimilis = (millis() + wifi_checkDelay) ;
StatusLed.h:
## Example
void status_func(int status, const char *msg) {     //    --------------- Status ----------------------
 s=status;                                          //    -- to check if we are registered and ready --
void setup() {
void loop() {
  StatusLed(s);
other functions:
StatusLedOn()  // to turn on the Status Led (we use it to indicate wifi config).
StatusLedOff() // to turn off the Status Led
Supla Status List:
  3 _CB_NOT_ASSIGNED
  7 _INITIALIZED
  9 _DISCONNECTED
 11 _ITERATE_FAIL
 13 _BAD_CREDENTIALS
#include <jled.h>  //--https://github.com/jandelgado/jled---
constexpr auto PIN_LED = status_led;
auto led = JLed(PIN_LED).LowActive().Blink(1000, 1000).Forever();
unsigned long statusmilis;
void StatusLedOn(){
   led.Reset();
   JLed(PIN_LED).LowActive().On().Update();
void StatusLedOff(){
   led.Reset();
   JLed(PIN_LED).LowActive().Off().Update();
void StatusLed(int Lstate){
        led.Update();
      if ((WiFi.status() == WL_CONNECTED) && (millis() > statusmilis) && (Lstate != 17)){ //----- check if Wi-Fi is connected, if Supla is not (REGISTERED_AND_READY) and if enough time has elapsed since the last pass.
        Serial.print("Status Led ");
        Serial.println(Lstate);
        led.Reset().Update();
        led = JLed(PIN_LED).LowActive().Blink(300, 250).Repeat(uint16_t(Lstate));   //----Flashing X times depending on the connection state
        statusmilis = (millis() + 15000) ;
      if ((WiFi.status() != WL_CONNECTED) && (led.IsRunning()== false)){  //---- check if WiFi is disconnected and if the Status Led is not running.
        Serial.println("Status No Wifi ");
        led = JLed(PIN_LED).LowActive().Blink(1000, 1000).Forever();  //----Flashing every second
        statusmilis = (millis() + 5000) ;
      if ((Lstate == 17) && (led.IsRunning()== true) && (WiFi.status() == WL_CONNECTED)){  //---- check if Wi-Fi is connected, if Supla is (REGISTERED_AND_READY) and if the Status Led is running
        Serial.println("Status Supla OK ");
        led.Stop();
        JLed(PIN_LED).LowActive().Off().Update();  //----Led Off
in total 5 channels
channel 0 = automatic / manual thermostat
channel 1 = manual relay on / off
channel 2 = to the left the temperature decreases by 0.5º the right increases by 0.5º
channel 3 = temperature DS18B20
channel 4 = thermostat temperature
temperature and hysterysis are adjusted in wificonfig
temperature in x10 format (22º is written 220 in the configuration)
It can be changed from the app in 0.5º steps and will be stored
hysterisis in x10 format (+/- 1 is written 10 in the configuration)
Gpio
int relay_1 = 12; //------------------- automatic / manual Led ----- active high
int relay_3 = 120; //------------------- no Gpio -----
supla_Termostst_Jled_2.rar
piomar2
This is the third thermostat tested by me created by elemaya. In all cases, the software works flawlessly. There are no problems logging in to wifi or supla. I like the oled version the most. Well, but everyone has a choice.
best regards
piotrekk
I would like to add one relay to your thermostat, I want to additionally turn on the valve which is not controlled by the thermostat but is next to not adding a second esp
elmaya
added extra channel,
added relay to D5
SuplaTermostst_easy_led_mDNS_H_C_1_DOUT_16Mbit.rar
piotrekk
can you share the arduino code?
elmaya
piotrekk wrote: Fri Feb 07, 2020 2:53 pm can you share the arduino code?
SuplaTermostst_easy_led_mDNS_H_C_1.rar
piotrekk
thank you very much
Return to “Ideas and concepts”
