Natywne wsparcie dla MQTT
podobnoja
Szukanie rozwiązania wysadziło mi HA... Zainstalowałem teraz na debianie (było na ubuntu).
Dodanie konfiguracji do configuration.yaml- zadziałało. Jednak zainstalowanie MQTT + MQTT broker = nie działa...
Używam Zerotierone - może to powoduję problemy?
Nie mam pojęcia jak zmusić HA/Suple do współpracy. Chyba szybciej będzie wrzucenie Tasmota/ESPhome.
Logi z MQTT broker:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[11:53:10] INFO: Setup mosquitto configuration
[11:53:10] INFO: No local user available
[11:53:11] INFO: Initialize Home Assistant Add-on services
[11:53:11] ERROR: Can't setup Home Assistant service mqtt
[11:53:11] INFO: Initialize Home Assistant discovery
[11:53:11] INFO: Start Mosquitto daemon
1615114391: mosquitto version 1.6.3 starting
1615114391: Config loaded from /etc/mosquitto.conf.
1615114391: Loading plugin: /usr/share/mosquitto/auth-plug.so
1615114391: ├── Username/password checking enabled.
1615114391: ├── TLS-PSK checking enabled.
1615114391: └── Extended authentication not enabled.
1615114391: |-- *** auth-plug: startup
1615114391: Opening ipv4 listen socket on port 1883.
1615114391: Opening ipv6 listen socket on port 1883.
1615114391: Opening websockets listen socket on port 1884.
1615114391: Opening ipv4 listen socket on port 8883.
1615114391: Opening ipv6 listen socket on port 8883.
1615114391: Opening websockets listen socket on port 8884.
1615114391: Warning: Mosquitto should not be run as root/administrator.
1615114391: New connection from 172.30.33.6 on port 1883.
[11:53:12] INFO: [INFO] found homeassistant on local database
1615114392: New client connected from 172.30.33.6 as mqttjs_f620675a (p2, c1, k60, u'homeassistant').
1615114398: New connection from 172.30.32.1 on port 1883.
1615114398: New connection from 172.30.33.7 on port 1883.
1615114398: New connection from 192.168.1.158 on port 1883.
1615114398: New connection from 192.168.1.159 on port 1883.
1615114398: New connection from 192.168.1.134 on port 1883.
1615114398: New client connected from 172.30.32.1 as 6CBIOipCZe8wQDfQfD2b8D (p2, c1, k60, u'homeassistant').
1615114398: New client connected from 172.30.33.7 as c4b647be41e84a7c9a0d448b6c8e68be (p2, c1, k15, u'homeassistant').
[11:53:19] INFO: [INFO] found Łukasz on Home Assistant
1615114399: New client connected from 192.168.1.158 as DVES_971D7A (p2, c1, k30, u'Łukasz').
1615114399: New client connected from 192.168.1.159 as DVES_C6DA02 (p2, c1, k30, u'Łukasz').
1615114399: New client connected from 192.168.1.134 as DVES_C5A1DC (p2, c1, k30, u'Łukasz').
pzygmunt wrote: Fri Mar 05, 2021 9:36 am Ale to są logi z rest-owej integracji. Wywal ją.
Przekombinowałeś. Nic nie trzeba „zmuszać”. Wystarczy wykonać polecenia z instrukcji. Nic więcej.
Goral64
Has thanked: 2 times
Próba integracji z AI-Speaker i próba zalogowania przez Oauth2... W czym może być problem?
Dostęp z internetu do Supla Cloud jest...
Zarejestrowałeś swoją instancję ?
Inne integracje przez OAuth Ci działają ?
Goral64
pzygmunt wrote: Tue Mar 09, 2021 2:17 pm Zarejestrowałeś swoją instancję ?
Ta jest pierwsza... czyli muszę się zalogować na publiczny serwer Supli i zarejestrować swój serwer?
lukfud
Has thanked: 13 times
Been thanked: 11 times
Goral64 wrote: Tue Mar 09, 2021 2:47 pm
https://cloud.supla.org/register-cloud
https://smartnerzeczy.pl
Goral64
lukfud wrote: Tue Mar 09, 2021 2:51 pm https://cloud.supla.org/register-cloud
Dzięki, nie mam pojęcia jak to przeoczyłem...
akszyn
Czy jest już jakaś instrukcja jak połączyć się z node-red?
Supla na pokładzie wemosa D1 mini z relay shield (gate Zybiego)z DS18B20 + sonoff basic (domyślny soft) + broadlink RM mini 3 + Philips hue white z bridge v1 + LoraTap (RF 433) z kinetycznym przełącznikiem + ai-speaker Dev1 i Dev3
akszyn
czy po wygenerowaniu nowego hasła do brokera mqtt nic się nie stanie z integracją z ais (czy nie będę musiał jej ponownie dodawać) oraz co gdzie powinienem wpisać przy konfiguracji połączenia w node-red? w zakładce security wypełniłem danymi z clouda ale mam status disconected w mqtt in
Return to “MQTT”
