SuplaSatelIntegrator - program do integracji Supla z SATEL
Duch__
Been thanked: 6 times
     // if(strefa_uzb[1] == 1 && strefa_uzb_old[1] == 0){ //Jesli strefa 1 zostala uzbrojona
          strefa_uzb_old[1] = 1;
          adr_url = "/api/scenes/execute/XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX";
          token   = "Authorization: Bearer XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX";
          goto wyslij_do_remote_host;
      // if(strefa_alarm[13] == 1 && strefa_alarm_old[13] == 0){ //Jesli strefa 13 jest w alarmie
          strefa_alarm_old[16] = 1;
Tutaj masz błędy które uniemożliwią skompilowanie
WojtekWS
A jeśli nie chcę korzystać z tych funkcji to co mam zrobić ? bo jeśli to usunę to błąd też się pojawia .
Duch__
          //strefa_uzb_old[1] = 1;
          //adr_url = "/api/scenes/execute/XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX";
          //token   = "Authorization: Bearer //XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX//XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX//XXXXXXXXXXXXXXX";
          //goto wyslij_do_remote_host;
      //    strefa_alarm_old[16] = 1;
       //   adr_url = "/api/scenes/execute/XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX";
       //   token   = "Authorization: Bearer //XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX//XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX//XXXXXXXXXXXXXXX";
//          goto wyslij_do_remote_host;
Przed każdym wierszem którego nie chcesz używać powinieneś dać znacznik komentarza // a nie tylko przy jednym.
Jak chcesz globalnie zaznaczyć kilka wierszy to robisz tak:
/*Zrób to
Zrób tamto
a potem jeszcze to
i może to
a na koniec to
Przy takim sposobie komentowania wykona ci się polecenie tylko "a na koniec to"
WojtekWS
cino111 wrote: Tue Dec 04, 2018 4:11 pm Weź to edytuj i wklej jako kod
w ten sposób
Podaj wersję Arduino Ide i wersję bibliotek
Wersja IDE 1.8.7 temat ruszył dograłem biblioteki ,ale teraz pokazuje mi się coś takiego
Arduino:1.8.7 (Windows 7), Płytka:"WeMos D1 R1, 80 MHz, Flash, 4M (1M SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 921600"
Opcje projektu zmienione, przeładuj całość
C:\Users\Wojtek\Documents\Arduino\integra\integra.ino: In function 'void loop()':
integra:208:12: error: 'client' was not declared in this scope
if (!client.connected()) {
integra:213:11: error: 'client' was not declared in this scope
if (client.connected()) {
integra:292:9: error: 'client' was not declared in this scope
client.stop();
exit status 1
Duch__
cino111 wrote: Wed Oct 17, 2018 5:38 pm Hej.
Zrobiłem instrukcję ze scr. Na forum chyba nie można wklejać zdjęć pomiędzy tekst, więc zrobiłem w PDF.
A tak wygląda mój serwer z zasilaniem prosto z routera :D Wemos d mini za jakieś 8zl na Ali.
O ja Cię!!! Dopiero teraz zauważyłem tą instrukcję :shock: :D :D :D
cino111
:D
Has thanked: 37 times
Been thanked: 27 times
Informacyjnie dla pytających o możliwość integracji Satel Versa Plus z Suplą - niestety moduł ETH zastosowany w tej centrali nie ma opcji integracji z innymi systemami.
Duch__
Dlatego tak wielbie centralę integra, chociaż powiem szczerze każdą centrale da się osuplować.
mirizag
A czy da radę połączyć się z satel perfecta
Duch__
Nie. Program umożliwia tylko i wyłącznie połączenie z centralą Satel z serii Integra.
Return to “Nowości”
