hej potrzebuje pomocy z uruchomieniem trybu flashowania.
elmaya
There is only 1 thermometer, I guess something has failed connecting to the cloud.
delete from the cloud and add new.
Volturio
Termometr & termo salon the same.
elmaya
carefully check your cloud settings
select by channels and search where it comes from
Volturio
ok sprawdziłem. Udało mi się wyłączyć zdublowany kanał i działa.
Dzieki za pomoc.
ok checked. I was able to disable the duplicate channel and it works.
Thanks for the help.
Zidane
elmaya wrote: Wed Apr 29, 2020 7:23 pm carefully check your cloud settings
Cześć
Czy na tym sofcie będzie działać DS18b20+dht22+RF? Dla Sonoff T1 R2 ver 1.0 EU RF
Hi
Will DS18b20 + dht22 + RF work on this software? Sonoff T1 R2 ver 1.0 EU RF
1xS.Basic+DS18B20
4xS.Basic
1xS.RF+DHT22
1xS.Touch 1CH+DS18B20+DHT22
3xS.Touch 1CH+DS18B20
1xS.Touch 2CH+DS18B20+DHT22
1xWemos D1 mini+PMS5003T+DS18B20
1xNodeMCUv3+PMS5003T+DS18B20+DHT22
1xESP-01S+PZEM V3+DS18B20
1xESP-12F+Ikea VINDRIKTNING
1xSP111
Volturio
Hej elmaya.
Czy jest możliwość aby zwiększyć maksymalny czas działania wyłącznika w trybie schodowy ?
Aktualnie najwięcej co można ustawić to 3600 sek.
(Czas załączenia przekaźnika 3600 sek.)
Hey elmaya.
Is it possible to increase the maximum operating time of the switch in staircase mode?
Currently, the most that can be set is 3600 seconds.
(Relay ON time 3600 sec.)
elmaya
Volturio wrote: Sun Nov 29, 2020 3:38 pm Hej elmaya.
Hey elmaya.
I have not tried but in "turnOn (_supla_int_t duration)" _supla_int_t is 32 bits so in theory the maximum would be "2,147,483,647" microseconds.
what do you intend to do?
Volturio
I need a solution for an Amplifier connected to Chromecast. Using supla I turn on the receiver and cast, and I want to listen to music for 2 hours or 3 hours.
Then I want to do nothing and everything would turn off after 2-3 hours, which is exactly what I need.
Now it works like after an hour sonoff turns off (3600 sec. sonoff goes out.)
