serwer supla na linux
Mariusz
Ktoś testował dockera jako armhf i mam taki komunikat.lesny8 wrote: Fri Jun 05, 2026 7:23 pm
a później możesz już kontynuować od pkt.2 według oficjalnej dokumentacji
https://github.com/SUPLA/supla-docker#installation
pi@raspberrypi:~ $ docker run armhf/hello-world
Unable to find image 'armhf/hello-world:latest' locally
docker: Error response from daemon: manifest for armhf/hello-world:latest not found: manifest unknown: manifest unknown
Run 'docker run --help' for more information
potem
pi@raspberrypi:~ $ docker run hello-world
Unable to find image 'hello-world:latest' locally
latest: Pulling from library/hello-world
8593da9e4aa9: Pull complete
Digest: sha256:0e760fdfbc48ba8041e7c6db999bb40bfca508b4be580ac75d32c4e29d202ce1
Status: Downloaded newer image for hello-world:latest
Zrobił
To generate this message, Docker took the following steps:
1. The Docker client contacted the Docker daemon.
2. The Docker daemon pulled the "hello-world" image from the Docker Hub.
(arm32v7)
Czyli jest docker działa - trochę jest tam wpisów, jest jakby na zielono
pi@raspberrypi:~/supla-docker $ sudo systemctl status docker
○ docker.service - Docker Application Container Engine
Loaded: loaded (/lib/systemd/system/docker.service; enabled; preset: enabled)
Active: inactive (dead) since Sun 2026-06-07 17:59:00 BST; 14s ago
Duration: 15min 39.950s
TriggeredBy: ● docker.socket
Docs: https://docs.docker.com
Process: 725 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock (code=exited, status=0/SUCCESS)
Main PID: 725 (code=exited, status=0/SUCCESS)
CPU: 4.176s
Jun 07 17:43:20 raspberrypi dockerd[725]: time="2026-06-07T17:43:20.553388063+01:00" level=info msg="API listen on /run/docker.sock"
Jun 07 17:49:11 raspberrypi dockerd[725]: time="2026-06-07T17:49:11.136511690+01:00" level=error msg="Not continuing with pull after error" error="manifest unknown: manifest unknown"
Jun 07 17:53:08 raspberrypi dockerd[725]: time="2026-06-07T17:53:08.194243253+01:00" level=info msg="ignoring event" container=98b16e0ddf5016ccdea3252e0a918cd43b3852be63aa8912d5a84b63d073b>
Jun 07 17:59:00 raspberrypi dockerd[725]: time="2026-06-07T17:59:00.501954783+01:00" level=info msg="Processing signal 'terminated'"
Jun 07 17:59:00 raspberrypi systemd[1]: Stopping docker.service - Docker Application Container Engine...
Jun 07 17:59:00 raspberrypi dockerd[725]: time="2026-06-07T17:59:00.511917905+01:00" level=info msg="stopping event stream following graceful shutdown" error="<nil>" module=libcontainerd n>
Jun 07 17:59:00 raspberrypi dockerd[725]: time="2026-06-07T17:59:00.515899623+01:00" level=info msg="Daemon shutdown complete"
Jun 07 17:59:00 raspberrypi systemd[1]: docker.service: Deactivated successfully.
Jun 07 17:59:00 raspberrypi systemd[1]: Stopped docker.service - Docker Application Container Engine.
Jun 07 17:59:00 raspberrypi systemd[1]: docker.service: Consumed 4.176s CPU time.
Jaki masz dokładnie OS?
uznane -aSOP 2023
SOP 2024
cz->b
+ila
SOP 2024
Mariusz
Mam tak
pi@raspberrypi:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 12 (bookworm)"
NAME="Raspbian GNU/Linux"
VERSION_ID="12"
VERSION="12 (bookworm)"
VERSION_CODENAME=bookworm
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
pi@raspberrypi:~ $ uname -m
armv7l
Mariusz
Aha czyli SUPLA nie będzie działać - to na czym to można postawić?
Mariusz
Kiedyś to działało
pi@raspberrypi:~ $ cat /sys/firmware/devicetree/base/model
Raspberry Pi 3 Model B Plus Rev 1.3pi@raspberrypi:~ $
@Mariusz, może słownik mi zrobił psikusa i zamiast
wyszło co innego, a Ty zamiast dać wynik z parametrem -a dałeś z -m, ale pisząc armv7l już jest oczywiste, że na tym RPi3B+ instalujesz system 32bitowy, a nie 64bit.
Na 32bitowy system nie ma już od jakiegoś czasu obrazów Supli, więc po prostu zainstaluj system 64bit, i jakbyś nie wiedział to procek na tym Pi go obsłuży
Tu masz obraz do wersji RaspiOS Lite opartej na Debianie 12 bookworm
https://downloads.raspberrypi.com/raspi ... ite.img.xz
Pobierz, nagraj Pi Imagerem na kartę i zainstaluj wszystko tak jak Ci podałem wyżej, zadziała na 100%
uname -aNa 32bitowy system nie ma już od jakiegoś czasu obrazów Supli, więc po prostu zainstaluj system 64bit, i jakbyś nie wiedział to procek na tym Pi go obsłuży
SOP 2023
SOP 2024
cz->b
+ila
SOP 2024
