To skopiuj je sobie gdzieś.
Po skopiowaniu wykonaj w supla-core git reset —hard (dwa myślniki przed hard), potem git pull.
Reset wycofa zmiany które zrobiłeś (stad wcześniejsza kopia)
Supla - MQTT - Dashing
cino111
Naciśnięcie przycisku Kuchnia na DashboardzieBeku wrote: Sun Nov 17, 2019 6:03 pm To skopiuj je sobie gdzieś.
DEBUG[1574014608.286970] size of commands: 5
DEBUG[1574014608.447189] on_remote_call_received: 400
DEBUG[1574014608.447397] publishing supla/channels/status/relay/1172
DEBUG[1574014608.546327] on_remote_call_received: 400
DEBUG[1574014608.546698] publishing supla/channels/status/electricity/1202
DEBUG[1574014608.554815] on_remote_call_received: 190
DEBUG[1574014608.554885] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574014608.646768] on_remote_call_received: 405
DEBUG[1574014609.47576] on_remote_call_received: 400
DEBUG[1574014609.47823] publishing supla/channels/status/temperature_humidity/1160
cino111
Klikałem na kanał 1172 i 1174, czyli te zielone kropki. DS18B20 też mi ni pokazuje. DHT22 za to jest ok.
root@raspberrypi:/home/pi/supla-core/supla-mqtt-client/Debug# ./supla-mqtt-client -config /home/pi/supla-core/supla-mqtt-client/config/config_template.yaml
INFO[1574014540.458944] initializing main loop
INFO[1574014540.465052] Client GUID: 79DFA0C5DF1E529A8C63F9104FBF4B89
DEBUG[1574014540.467327] reading commands YAML flie
DEBUG[1574014540.477523] SUPLA PROTOCOL VERSION 10
INFO[1574014540.477626] SSL version: OpenSSL 1.1.1d 10 Sep 2019
INFO[1574014540.501532] Connecting...
DEBUG[1574014540.502188] connecting to 192.168.1.109 on port 1883 using protocol version 5
DEBUG[1574014540.503195] subscribing supla/channels/command/#
DEBUG[1574014540.571655] Connected with ECDHE-RSA-AES256-GCM-SHA384 encryption
DEBUG[1574014540.571725] Server certificates:
DEBUG[1574014540.572129] Subject: /C=PL/ST=SUPLA/L=SUPLA/O=SUPLA/CN=SUPLA
DEBUG[1574014540.572428] Issuer: /C=PL/ST=SUPLA/L=SUPLA/O=SUPLA/CN=SUPLA
DEBUG[1574014540.572735] EMAIL:
DEBUG[1574014540.618372] on_remote_call_received: 92
DEBUG[1574014540.618438] Registered.
DEBUG[1574014540.667885] on_remote_call_received: 140
DEBUG[1574014540.668184] Location #1: 2.Dom EOL=0
DEBUG[1574014540.668217] Location #2: 4.Ogrzewanie EOL=0
DEBUG[1574014540.668435] Location #3: 5.Piwnica EOL=0
DEBUG[1574014540.668641] Location #4: Testy EOL=0
DEBUG[1574014540.668845] Location #5: Wirtualna EOL=0
DEBUG[1574014540.669092] Location #6: 3.Alarm EOL=0
DEBUG[1574014540.669298] Location #7: RPI EOL=0
DEBUG[1574014540.669503] Location #8: Podgląd EOL=0
DEBUG[1574014540.669888] Location #9: 1.Szybki dostęp EOL=1
DEBUG[1574014540.671957] on_remote_call_received: 361
DEBUG[1574014540.672404] publishing supla/channels/status/4000/9
DEBUG[1574014540.672800] publishing supla/channels/status/relay/43
DEBUG[1574014540.673069] publishing supla/channels/status/thermometer/45
DEBUG[1574014540.673331] publishing supla/channels/status/thermometer/99
DEBUG[1574014540.673587] publishing supla/channels/status/thermometer/100
DEBUG[1574014540.673842] publishing supla/channels/status/thermometer/101
DEBUG[1574014540.674149] publishing supla/channels/status/thermometer/102
DEBUG[1574014540.674412] publishing supla/channels/status/thermometer/103
DEBUG[1574014540.674699] publishing supla/channels/status/thermometer/104
DEBUG[1574014540.674958] publishing supla/channels/status/thermometer/105
DEBUG[1574014540.675207] publishing supla/channels/status/switch/107
DEBUG[1574014540.675455] publishing supla/channels/status/switch/108
DEBUG[1574014540.675699] publishing supla/channels/status/2900/645
DEBUG[1574014540.675943] publishing supla/channels/status/switch/646
DEBUG[1574014540.676188] publishing supla/channels/status/2900/647
DEBUG[1574014540.676433] publishing supla/channels/status/2900/648
DEBUG[1574014540.676686] publishing supla/channels/status/switch/649
DEBUG[1574014540.678945] on_remote_call_received: 361
DEBUG[1574014540.679445] publishing supla/channels/status/switch/650
DEBUG[1574014540.679815] publishing supla/channels/status/2900/651
DEBUG[1574014540.680136] publishing supla/channels/status/switch/652
DEBUG[1574014540.680453] publishing supla/channels/status/switch/653
DEBUG[1574014540.680769] publishing supla/channels/status/1000/970
DEBUG[1574014540.681085] publishing supla/channels/status/1000/971
DEBUG[1574014540.681399] publishing supla/channels/status/1000/972
DEBUG[1574014540.681668] publishing supla/channels/status/1000/973
DEBUG[1574014540.681932] publishing supla/channels/status/1000/974
DEBUG[1574014540.682198] publishing supla/channels/status/1000/975
DEBUG[1574014540.682460] publishing supla/channels/status/1000/976
DEBUG[1574014540.682767] publishing supla/channels/status/1000/977
DEBUG[1574014540.683089] publishing supla/channels/status/1000/978
DEBUG[1574014540.683365] publishing supla/channels/status/1000/979
DEBUG[1574014540.683635] publishing supla/channels/status/switch/980
DEBUG[1574014540.683908] publishing supla/channels/status/switch/986
DEBUG[1574014540.684180] publishing supla/channels/status/switch/987
DEBUG[1574014540.684493] publishing supla/channels/status/switch/988
DEBUG[1574014540.684767] publishing supla/channels/status/switch/989
DEBUG[1574014540.685086] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574014540.686919] on_remote_call_received: 361
DEBUG[1574014540.687421] publishing supla/channels/status/switch/1053
DEBUG[1574014540.687720] publishing supla/channels/status/2900/1121
DEBUG[1574014540.688020] publishing supla/channels/status/1020/1135
DEBUG[1574014540.688310] publishing supla/channels/status/switch/1152
DEBUG[1574014540.688625] publishing supla/channels/status/temperature_humidity/1153
DEBUG[1574014540.688928] publishing supla/channels/status/switch/1159
DEBUG[1574014540.692139] on_remote_call_received: 361
DEBUG[1574014540.695617] on_remote_call_received: 405
mqtt client error MQTT_ERROR_SEND_BUFFER_IS_FULL
DEBUG[1574014540.704989] connecting to 192.168.1.109 on port 1883 using protocol version 5
DEBUG[1574014540.706258] subscribing supla/channels/command/#
DEBUG[1574014543.49558] on_remote_call_received: 400
DEBUG[1574014543.50369] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574014543.885721] on_remote_call_received: 400
DEBUG[1574014543.886543] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574014545.588472] on_remote_call_received: 400
DEBUG[1574014545.589138] publishing supla/channels/status/temperature_humidity/1153
DEBUG[1574014548.547468] on_remote_call_received: 400
DEBUG[1574014548.548269] publishing supla/channels/status/electricity/1202
DEBUG[1574014548.647161] on_remote_call_received: 405
DEBUG[1574014549.49318] on_remote_call_received: 400
DEBUG[1574014549.50132] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574014549.172403] on_remote_call_received: 400
DEBUG[1574014549.173202] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574014554.436315] on_remote_call_received: 400
DEBUG[1574014554.437223] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574014556.836729] on_remote_call_received: 400
DEBUG[1574014556.837634] publishing supla/channels/status/thermometer/45
DEBUG[1574014556.885657] on_remote_call_received: 400
DEBUG[1574014556.886265] publishing supla/channels/status/thermometer/105
DEBUG[1574014559.711312] on_remote_call_received: 400
DEBUG[1574014559.711972] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574014563.590137] on_remote_call_received: 400
DEBUG[1574014563.590382] publishing supla/channels/status/temperature_humidity/1153
DEBUG[1574014564.985927] on_remote_call_received: 400
DEBUG[1574014564.986159] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574014568.547317] on_remote_call_received: 400
DEBUG[1574014568.547688] publishing supla/channels/status/electricity/1202
DEBUG[1574014568.646783] on_remote_call_received: 405
DEBUG[1574014570.262782] on_remote_call_received: 400
DEBUG[1574014570.263615] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574014573.48174] on_remote_call_received: 400
DEBUG[1574014573.48419] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574014575.537681] on_remote_call_received: 400
DEBUG[1574014575.537920] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574014575.587238] on_remote_call_received: 400
DEBUG[1574014575.587485] publishing supla/channels/status/temperature_humidity/1153
DEBUG[1574014576.948300] size of commands: 5
DEBUG[1574014577.163395] on_remote_call_received: 400
DEBUG[1574014577.163609] publishing supla/channels/status/relay/1172
DEBUG[1574014577.380122] on_remote_call_received: 190
DEBUG[1574014577.380211] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574014577.550159] size of commands: 5
DEBUG[1574014577.770917] on_remote_call_received: 400
DEBUG[1574014577.771132] publishing supla/channels/status/relay/1172
DEBUG[1574014577.781997] on_remote_call_received: 190
DEBUG[1574014577.782060] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574014577.851329] size of commands: 5
DEBUG[1574014578.14404] on_remote_call_received: 400
DEBUG[1574014578.14615] publishing supla/channels/status/relay/1172
DEBUG[1574014578.79399] on_remote_call_received: 190
DEBUG[1574014578.79488] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574014578.789793] on_remote_call_received: 400
DEBUG[1574014578.790032] publishing supla/channels/status/thermometer/1162
DEBUG[1574014579.47774] on_remote_call_received: 400
DEBUG[1574014579.48028] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574014579.98434] on_remote_call_received: 400
DEBUG[1574014579.98678] publishing supla/channels/status/thermometer/1169
DEBUG[1574014580.812462] on_remote_call_received: 400
DEBUG[1574014580.812703] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574014583.789902] on_remote_call_received: 400
DEBUG[1574014583.790137] publishing supla/channels/status/thermometer/1162
DEBUG[1574014586.88001] on_remote_call_received: 400
DEBUG[1574014586.88243] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574014587.395459] on_remote_call_received: 400
DEBUG[1574014587.395665] publishing supla/channels/status/thermometer/103
DEBUG[1574014588.545114] on_remote_call_received: 400
DEBUG[1574014588.545492] publishing supla/channels/status/electricity/1202
DEBUG[1574014588.646824] on_remote_call_received: 405
DEBUG[1574014589.98891] on_remote_call_received: 400
DEBUG[1574014589.99131] publishing supla/channels/status/thermometer/1169
DEBUG[1574014591.362253] on_remote_call_received: 400
DEBUG[1574014591.362492] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574014593.587214] on_remote_call_received: 400
DEBUG[1574014593.587468] publishing supla/channels/status/temperature_humidity/1153
DEBUG[1574014594.98504] on_remote_call_received: 400
DEBUG[1574014594.98747] publishing supla/channels/status/thermometer/1169
DEBUG[1574014596.637897] on_remote_call_received: 400
DEBUG[1574014596.638140] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574014597.46319] on_remote_call_received: 400
DEBUG[1574014597.46567] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574014599.589209] on_remote_call_received: 400
DEBUG[1574014599.589468] publishing supla/channels/status/temperature_humidity/1153
DEBUG[1574014601.912703] on_remote_call_received: 400
DEBUG[1574014601.912949] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574014603.47650] on_remote_call_received: 400
DEBUG[1574014603.47903] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574014607.188437] on_remote_call_received: 400
DEBUG[1574014607.188680] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574014611.586022] on_remote_call_received: 400
DEBUG[1574014611.586275] publishing supla/channels/status/temperature_humidity/1153
DEBUG[1574014612.463626] on_remote_call_received: 400
DEBUG[1574014612.463866] publishing supla/channels/status/temperature_humidity/1052
^Croot@raspberrypi:/home/pi/supla-core/supla-mqtt-client/Debug#
root@raspberrypi:/home/pi/supla-core/supla-mqtt-client/Debug# DEBUG[1574014608.286970] size of commands: 5
bash: DEBUG[1574014608.286970]: command not found
root@raspberrypi:/home/pi/supla-core/supla-mqtt-client/Debug# DEBUG[1574014608.447189] on_remote_call_received: 400
bash: DEBUG[1574014608.447189]: command not found
root@raspberrypi:/home/pi/supla-core/supla-mqtt-client/Debug# DEBUG[1574014608.447397] publishing supla/channels/status/relay/1172
bash: DEBUG[1574014608.447397]: command not found
root@raspberrypi:/home/pi/supla-core/supla-mqtt-client/Debug# DEBUG[1574014608.546327] on_remote_call_received: 400
bash: DEBUG[1574014608.546327]: command not found
root@raspberrypi:/home/pi/supla-core/supla-mqtt-client/Debug# DEBUG[1574014608.546698] publishing supla/channels/status/electricity/1202
bash: DEBUG[1574014608.546698]: command not found
root@raspberrypi:/home/pi/supla-core/supla-mqtt-client/Debug# DEBUG[1574014608.554815] on_remote_call_received: 190
bash: DEBUG[1574014608.554815]: command not found
root@raspberrypi:/home/pi/supla-core/supla-mqtt-client/Debug# DEBUG[1574014608.554885] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
bash: DEBUG[1574014608.554885]: command not found
root@raspberrypi:/home/pi/supla-core/supla-mqtt-client/Debug# DEBUG[1574014608.646768] on_remote_call_received: 405
bash: DEBUG[1574014608.646768]: command not found
root@raspberrypi:/home/pi/supla-core/supla-mqtt-client/Debug# DEBUG[1574014609.47576] on_remote_call_received: 400
bash: DEBUG[1574014609.47576]: command not found
root@raspberrypi:/home/pi/supla-core/supla-mqtt-client/Debug# DEBUG[1574014609.47823] publishing supla/channels/status/temperature_humidity/1160
bash: DEBUG[1574014609.47823]: command not found
INFO[1574015129.356618] initializing main loop
INFO[1574015129.358442] Client GUID: 79DFA0C5DF1E529A8C63F9104FBF4B89
DEBUG[1574015129.360420] reading commands YAML flie
DEBUG[1574015129.370741] SUPLA PROTOCOL VERSION 10
INFO[1574015129.370851] SSL version: OpenSSL 1.1.1d 10 Sep 2019
INFO[1574015129.384862] Connecting...
DEBUG[1574015129.385484] connecting to 192.168.1.109 on port 1883 using protocol version 5
DEBUG[1574015129.386487] subscribing supla/channels/command/#
DEBUG[1574015129.464364] Connected with ECDHE-RSA-AES256-GCM-SHA384 encryption
DEBUG[1574015129.464437] Server certificates:
DEBUG[1574015129.464500] Subject: /C=PL/ST=SUPLA/L=SUPLA/O=SUPLA/CN=SUPLA
DEBUG[1574015129.464551] Issuer: /C=PL/ST=SUPLA/L=SUPLA/O=SUPLA/CN=SUPLA
DEBUG[1574015129.464668] EMAIL:
DEBUG[1574015129.530376] on_remote_call_received: 92
DEBUG[1574015129.530443] Registered.
DEBUG[1574015129.577943] on_remote_call_received: 140
DEBUG[1574015129.578008] Location #1: 2.Dom EOL=0
DEBUG[1574015129.578040] Location #2: 4.Ogrzewanie EOL=0
DEBUG[1574015129.578066] Location #3: 5.Piwnica EOL=0
DEBUG[1574015129.578091] Location #4: Testy EOL=0
DEBUG[1574015129.578116] Location #5: Wirtualna EOL=0
DEBUG[1574015129.578143] Location #6: 3.Alarm EOL=0
DEBUG[1574015129.578168] Location #7: RPI EOL=0
DEBUG[1574015129.578193] Location #8: Podgląd EOL=0
DEBUG[1574015129.578225] Location #9: 1.Szybki dostęp EOL=1
DEBUG[1574015129.580090] on_remote_call_received: 361
DEBUG[1574015129.580373] publishing supla/channels/status/4000/9
DEBUG[1574015129.580626] publishing supla/channels/status/relay/43
DEBUG[1574015129.580763] publishing supla/channels/status/thermometer/45
DEBUG[1574015129.580887] publishing supla/channels/status/thermometer/99
DEBUG[1574015129.581008] publishing supla/channels/status/thermometer/100
DEBUG[1574015129.581128] publishing supla/channels/status/thermometer/101
DEBUG[1574015129.581248] publishing supla/channels/status/thermometer/102
DEBUG[1574015129.581370] publishing supla/channels/status/thermometer/103
DEBUG[1574015129.581490] publishing supla/channels/status/thermometer/104
DEBUG[1574015129.581613] publishing supla/channels/status/thermometer/105
DEBUG[1574015129.581725] publishing supla/channels/status/switch/107
DEBUG[1574015129.581837] publishing supla/channels/status/switch/108
DEBUG[1574015129.581945] publishing supla/channels/status/2900/645
DEBUG[1574015129.582053] publishing supla/channels/status/switch/646
DEBUG[1574015129.582161] publishing supla/channels/status/2900/647
DEBUG[1574015129.582270] publishing supla/channels/status/2900/648
DEBUG[1574015129.582383] publishing supla/channels/status/switch/649
DEBUG[1574015129.584349] on_remote_call_received: 361
DEBUG[1574015129.584526] publishing supla/channels/status/switch/650
DEBUG[1574015129.584654] publishing supla/channels/status/2900/651
DEBUG[1574015129.584775] publishing supla/channels/status/switch/652
DEBUG[1574015129.584894] publishing supla/channels/status/switch/653
DEBUG[1574015129.585012] publishing supla/channels/status/1000/970
DEBUG[1574015129.585129] publishing supla/channels/status/1000/971
DEBUG[1574015129.585248] publishing supla/channels/status/1000/972
DEBUG[1574015129.585369] publishing supla/channels/status/1000/973
DEBUG[1574015129.585489] publishing supla/channels/status/1000/974
DEBUG[1574015129.585616] publishing supla/channels/status/1000/975
DEBUG[1574015129.585740] publishing supla/channels/status/1000/976
DEBUG[1574015129.585867] publishing supla/channels/status/1000/977
DEBUG[1574015129.585994] publishing supla/channels/status/1000/978
DEBUG[1574015129.586126] publishing supla/channels/status/1000/979
DEBUG[1574015129.586263] publishing supla/channels/status/switch/980
DEBUG[1574015129.586400] publishing supla/channels/status/switch/986
DEBUG[1574015129.586536] publishing supla/channels/status/switch/987
DEBUG[1574015129.586673] publishing supla/channels/status/switch/988
DEBUG[1574015129.586810] publishing supla/channels/status/switch/989
DEBUG[1574015129.587117] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574015129.589688] on_remote_call_received: 361
DEBUG[1574015129.589969] publishing supla/channels/status/switch/1053
DEBUG[1574015129.590131] publishing supla/channels/status/2900/1121
DEBUG[1574015129.590296] publishing supla/channels/status/1020/1135
DEBUG[1574015129.590448] publishing supla/channels/status/switch/1152
DEBUG[1574015129.590629] publishing supla/channels/status/temperature_humidity/1153
DEBUG[1574015129.590791] publishing supla/channels/status/switch/1159
DEBUG[1574015129.590962] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574015129.591132] publishing supla/channels/status/thermometer/1162
DEBUG[1574015129.591287] publishing supla/channels/status/relay/1163
DEBUG[1574015129.591441] publishing supla/channels/status/relay/1164
DEBUG[1574015129.591593] publishing supla/channels/status/relay/1165
DEBUG[1574015129.591751] publishing supla/channels/status/2900/1167
DEBUG[1574015129.591908] publishing supla/channels/status/switch/1168
DEBUG[1574015129.592080] publishing supla/channels/status/thermometer/1169
DEBUG[1574015129.592240] publishing supla/channels/status/relay/1172
DEBUG[1574015129.592403] publishing supla/channels/status/relay/1174
DEBUG[1574015129.592568] publishing supla/channels/status/switch/1193
DEBUG[1574015129.592855] publishing supla/channels/status/2900/1198
DEBUG[1574015129.593024] publishing supla/channels/status/relay/1201
DEBUG[1574015129.594353] on_remote_call_received: 361
DEBUG[1574015129.594767] publishing supla/channels/status/switch/1224
DEBUG[1574015129.594950] publishing supla/channels/status/switch/1225
DEBUG[1574015129.595126] publishing supla/channels/status/switch/1226
DEBUG[1574015129.595298] publishing supla/channels/status/switch/1227
DEBUG[1574015129.595996] publishing supla/channels/status/electricity/1233
DEBUG[1574015129.597874] on_remote_call_received: 405
DEBUG[1574015130.413318] on_remote_call_received: 400
DEBUG[1574015130.413545] publishing supla/channels/status/1020/1135
DEBUG[1574015131.413163] on_remote_call_received: 400
DEBUG[1574015131.413382] publishing supla/channels/status/1020/1135
DEBUG[1574015134.95012] size of commands: 5
DEBUG[1574015134.328394] on_remote_call_received: 400
DEBUG[1574015134.328612] publishing supla/channels/status/relay/1172
DEBUG[1574015134.572429] on_remote_call_received: 190
DEBUG[1574015134.572520] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574015134.704094] on_remote_call_received: 400
DEBUG[1574015134.704336] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574015135.197786] size of commands: 5
DEBUG[1574015135.452057] on_remote_call_received: 400
DEBUG[1574015135.452266] publishing supla/channels/status/relay/1172
DEBUG[1574015135.474949] on_remote_call_received: 190
DEBUG[1574015135.475020] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574015136.586190] on_remote_call_received: 400
DEBUG[1574015136.586393] publishing supla/channels/status/thermometer/101
DEBUG[1574015137.40749] on_remote_call_received: 400
DEBUG[1574015137.40994] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574015137.702376] size of commands: 5
DEBUG[1574015137.865198] on_remote_call_received: 400
DEBUG[1574015137.865401] publishing supla/channels/status/relay/1172
DEBUG[1574015137.897778] on_remote_call_received: 190
DEBUG[1574015137.897857] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574015139.576603] on_remote_call_received: 400
DEBUG[1574015139.576849] publishing supla/channels/status/temperature_humidity/1153
DEBUG[1574015139.730188] on_remote_call_received: 400
DEBUG[1574015139.730368] publishing supla/channels/status/1000/973
DEBUG[1574015139.976226] on_remote_call_received: 400
DEBUG[1574015139.976464] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574015140.207114] size of commands: 5
DEBUG[1574015140.334294] on_remote_call_received: 400
DEBUG[1574015140.334509] publishing supla/channels/status/relay/1174
DEBUG[1574015140.541155] on_remote_call_received: 190
DEBUG[1574015140.541247] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574015141.427241] on_remote_call_received: 400
DEBUG[1574015141.427423] publishing supla/channels/status/1000/975
DEBUG[1574015141.509740] size of commands: 5
DEBUG[1574015141.673365] on_remote_call_received: 400
DEBUG[1574015141.673580] publishing supla/channels/status/relay/1174
DEBUG[1574015141.746060] on_remote_call_received: 190
DEBUG[1574015141.746149] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574015143.39580] on_remote_call_received: 400
DEBUG[1574015143.39819] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574015143.88707] on_remote_call_received: 400
DEBUG[1574015143.88855] publishing supla/channels/status/1000/974
DEBUG[1574015143.113050] size of commands: 5
DEBUG[1574015143.239660] on_remote_call_received: 400
DEBUG[1574015143.239872] publishing supla/channels/status/relay/1174
DEBUG[1574015143.281233] on_remote_call_received: 190
DEBUG[1574015143.281304] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574015145.254104] on_remote_call_received: 400
DEBUG[1574015145.254426] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574015145.577678] on_remote_call_received: 400
DEBUG[1574015145.578004] publishing supla/channels/status/temperature_humidity/1153
DEBUG[1574015146.618832] size of commands: 5
DEBUG[1574015146.746777] on_remote_call_received: 400
DEBUG[1574015146.747150] publishing supla/channels/status/relay/1174
DEBUG[1574015146.847805] on_remote_call_received: 190
DEBUG[1574015146.847967] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574015147.162541] on_remote_call_received: 400
DEBUG[1574015147.162787] publishing supla/channels/status/1000/973
DEBUG[1574015148.547237] on_remote_call_received: 400
DEBUG[1574015148.547689] publishing supla/channels/status/electricity/1202
DEBUG[1574015148.646692] on_remote_call_received: 405
DEBUG[1574015148.910521] on_remote_call_received: 400
DEBUG[1574015148.910774] publishing supla/channels/status/1000/975
DEBUG[1574015149.123140] size of commands: 5
DEBUG[1574015149.527683] on_remote_call_received: 400
DEBUG[1574015149.527966] publishing supla/channels/status/relay/1172
DEBUG[1574015149.540476] on_remote_call_received: 400
DEBUG[1574015149.540679] publishing supla/channels/status/thermometer/45
DEBUG[1574015150.325787] size of commands: 5
DEBUG[1574015150.328613] on_remote_call_received: 190
DEBUG[1574015150.328752] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574015150.501518] on_remote_call_received: 400
DEBUG[1574015150.501721] publishing supla/channels/status/relay/1172
DEBUG[1574015150.511197] on_remote_call_received: 190
DEBUG[1574015150.511258] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574015150.558056] on_remote_call_received: 400
DEBUG[1574015150.558307] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574015150.750227] on_remote_call_received: 400
DEBUG[1574015150.750413] publishing supla/channels/status/1000/974
DEBUG[1574015151.728813] size of commands: 5
DEBUG[1574015151.938211] on_remote_call_received: 400
DEBUG[1574015151.938425] publishing supla/channels/status/relay/1172
DEBUG[1574015151.950871] on_remote_call_received: 190
DEBUG[1574015151.950933] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574015155.805075] on_remote_call_received: 400
DEBUG[1574015155.805323] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574015156.924020] on_remote_call_received: 400
DEBUG[1574015156.924230] publishing supla/channels/status/thermometer/105
DEBUG[1574015159.759822] on_remote_call_received: 400
DEBUG[1574015159.760019] publishing supla/channels/status/thermometer/45
DEBUG[1574015161.80810] on_remote_call_received: 400
DEBUG[1574015161.81060] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574015166.355727] on_remote_call_received: 400
DEBUG[1574015166.355976] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574015167.39315] on_remote_call_received: 400
DEBUG[1574015167.39594] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574015167.681195] on_remote_call_received: 400
DEBUG[1574015167.681407] publishing supla/channels/status/relay/1172
DEBUG[1574015168.281396] on_remote_call_received: 400
DEBUG[1574015168.281611] publishing supla/channels/status/relay/1172
DEBUG[1574015168.481057] on_remote_call_received: 400
DEBUG[1574015168.481273] publishing supla/channels/status/relay/1172
DEBUG[1574015168.546702] on_remote_call_received: 400
DEBUG[1574015168.547144] publishing supla/channels/status/electricity/1202
DEBUG[1574015168.645777] on_remote_call_received: 405
DEBUG[1574015169.691962] on_remote_call_received: 400
DEBUG[1574015169.692173] publishing supla/channels/status/relay/1172
DEBUG[1574015170.490533] on_remote_call_received: 400
DEBUG[1574015170.490746] publishing supla/channels/status/relay/1172
DEBUG[1574015171.630258] on_remote_call_received: 400
DEBUG[1574015171.630507] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574015173.39758] on_remote_call_received: 400
DEBUG[1574015173.40011] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574015176.906785] on_remote_call_received: 400
DEBUG[1574015176.907110] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574015177.264003] on_remote_call_received: 400
DEBUG[1574015177.264212] publishing supla/channels/status/thermometer/103
DEBUG[1574015179.38991] on_remote_call_received: 400
DEBUG[1574015179.39245] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574015181.575891] on_remote_call_received: 400
DEBUG[1574015181.576145] publishing supla/channels/status/temperature_humidity/1153
DEBUG[1574015182.184191] on_remote_call_received: 400
DEBUG[1574015182.184436] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574015185.39284] on_remote_call_received: 400
DEBUG[1574015185.39536] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574015187.434075] on_remote_call_received: 400
DEBUG[1574015187.434274] publishing supla/channels/status/thermometer/101
DEBUG[1574015187.457745] on_remote_call_received: 400
DEBUG[1574015187.457934] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574015188.546821] on_remote_call_received: 400
DEBUG[1574015188.547290] publishing supla/channels/status/electricity/1202
DEBUG[1574015188.645788] on_remote_call_received: 405
DEBUG[1574015191.39271] on_remote_call_received: 400
DEBUG[1574015191.39523] publishing supla/channels/status/temperature_humidity/1160
Beku
Pobierz plik który dałem w załaczniku.
Musisz przegrać 2 pliki znajdujące się w tym archiwum przy czym:
client_subscriber.cpp musisz skopiować do katalogu supla-core/supla-mqtt-client/src
natomiast plik mqtt_client.cpp do katalogu supla-core/supla-mqtt-client/src/mqtt
następnie make all w katalogu debug i uruchomienie klienta. i podejślij wtedy log.
cino111
Zauważyłem, że jak wcisne te zielone przyciski to w Apce na telefonie pokazuje mi się "Supla MQTT Proxy włączył / wyłączył światło choć fizycznie mi się nie zapala no i przyciska dalej jest zielony. DS18B20 zaczął dobrze pokazywać temperaturę.Beku wrote: Sun Nov 17, 2019 6:43 pm Pobierz plik który dałem w załaczniku.
INFO[1574019358.92780] initializing main loop
INFO[1574019358.96816] Client GUID: 79DFA0C5DF1E529A8C63F9104FBF4B89
DEBUG[1574019358.103229] reading commands YAML flie
DEBUG[1574019358.115476] SUPLA PROTOCOL VERSION 10
INFO[1574019358.115587] SSL version: OpenSSL 1.1.1d 10 Sep 2019
INFO[1574019358.139570] Connecting...
DEBUG[1574019358.139685] connecting to 192.168.1.109 on port 1883 using protocol version 5
DEBUG[1574019358.140399] subscribing supla/channels/command/#
DEBUG[1574019358.201218] Connected with ECDHE-RSA-AES256-GCM-SHA384 encryption
DEBUG[1574019358.201290] Server certificates:
DEBUG[1574019358.201357] Subject: /C=PL/ST=SUPLA/L=SUPLA/O=SUPLA/CN=SUPLA
DEBUG[1574019358.201404] Issuer: /C=PL/ST=SUPLA/L=SUPLA/O=SUPLA/CN=SUPLA
DEBUG[1574019358.201538] EMAIL:
DEBUG[1574019358.254643] on_remote_call_received: 92
DEBUG[1574019358.254701] Registered.
DEBUG[1574019358.298462] on_remote_call_received: 140
DEBUG[1574019358.298529] Location #1: 2.Dom EOL=0
DEBUG[1574019358.298557] Location #2: 4.Ogrzewanie EOL=0
DEBUG[1574019358.298584] Location #3: 5.Piwnica EOL=0
DEBUG[1574019358.298609] Location #4: Testy EOL=0
DEBUG[1574019358.298636] Location #5: Wirtualna EOL=0
DEBUG[1574019358.298662] Location #6: 3.Alarm EOL=0
DEBUG[1574019358.298689] Location #7: RPI EOL=0
DEBUG[1574019358.298715] Location #8: Podgląd EOL=0
DEBUG[1574019358.298748] Location #9: 1.Szybki dostęp EOL=1
DEBUG[1574019358.300878] on_remote_call_received: 361
DEBUG[1574019358.301150] publishing supla/channels/status/4000/9
DEBUG[1574019358.301401] publishing supla/channels/status/relay/43
DEBUG[1574019358.301538] publishing supla/channels/status/thermometer/45
DEBUG[1574019358.301660] publishing supla/channels/status/thermometer/99
DEBUG[1574019358.301781] publishing supla/channels/status/thermometer/100
DEBUG[1574019358.301901] publishing supla/channels/status/thermometer/101
DEBUG[1574019358.302020] publishing supla/channels/status/thermometer/102
DEBUG[1574019358.302142] publishing supla/channels/status/thermometer/103
DEBUG[1574019358.302263] publishing supla/channels/status/thermometer/104
DEBUG[1574019358.302386] publishing supla/channels/status/thermometer/105
DEBUG[1574019358.302498] publishing supla/channels/status/switch/107
DEBUG[1574019358.302609] publishing supla/channels/status/switch/108
DEBUG[1574019358.302718] publishing supla/channels/status/2900/645
DEBUG[1574019358.302826] publishing supla/channels/status/switch/646
DEBUG[1574019358.302935] publishing supla/channels/status/2900/647
DEBUG[1574019358.303043] publishing supla/channels/status/2900/648
DEBUG[1574019358.303157] publishing supla/channels/status/switch/649
DEBUG[1574019358.305353] on_remote_call_received: 361
DEBUG[1574019358.305524] publishing supla/channels/status/switch/650
DEBUG[1574019358.305656] publishing supla/channels/status/2900/651
DEBUG[1574019358.305777] publishing supla/channels/status/switch/652
DEBUG[1574019358.305922] publishing supla/channels/status/switch/653
DEBUG[1574019358.306044] publishing supla/channels/status/1000/970
DEBUG[1574019358.306164] publishing supla/channels/status/1000/971
DEBUG[1574019358.306285] publishing supla/channels/status/1000/972
DEBUG[1574019358.306409] publishing supla/channels/status/1000/973
DEBUG[1574019358.306530] publishing supla/channels/status/1000/974
DEBUG[1574019358.306658] publishing supla/channels/status/1000/975
DEBUG[1574019358.306785] publishing supla/channels/status/1000/976
DEBUG[1574019358.306912] publishing supla/channels/status/1000/977
DEBUG[1574019358.307040] publishing supla/channels/status/1000/978
DEBUG[1574019358.307169] publishing supla/channels/status/1000/979
DEBUG[1574019358.307300] publishing supla/channels/status/switch/980
DEBUG[1574019358.307533] publishing supla/channels/status/switch/986
DEBUG[1574019358.307675] publishing supla/channels/status/switch/987
DEBUG[1574019358.307815] publishing supla/channels/status/switch/988
DEBUG[1574019358.307957] publishing supla/channels/status/switch/989
DEBUG[1574019358.308140] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019358.310307] on_remote_call_received: 361
DEBUG[1574019358.310509] publishing supla/channels/status/switch/1053
DEBUG[1574019358.310667] publishing supla/channels/status/2900/1121
DEBUG[1574019358.310829] publishing supla/channels/status/1020/1135
DEBUG[1574019358.310982] publishing supla/channels/status/switch/1152
DEBUG[1574019358.311162] publishing supla/channels/status/temperature_humidity/1153
DEBUG[1574019358.311320] publishing supla/channels/status/switch/1159
DEBUG[1574019358.311496] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574019358.311670] publishing supla/channels/status/thermometer/1162
DEBUG[1574019358.311826] publishing supla/channels/status/relay/1163
DEBUG[1574019358.311980] publishing supla/channels/status/relay/1164
DEBUG[1574019358.312135] publishing supla/channels/status/relay/1165
DEBUG[1574019358.312295] publishing supla/channels/status/2900/1167
DEBUG[1574019358.312453] publishing supla/channels/status/switch/1168
DEBUG[1574019358.312631] publishing supla/channels/status/thermometer/1169
DEBUG[1574019358.312793] publishing supla/channels/status/relay/1172
DEBUG[1574019358.312957] publishing supla/channels/status/relay/1174
DEBUG[1574019358.313122] publishing supla/channels/status/switch/1193
DEBUG[1574019358.313414] publishing supla/channels/status/2900/1198
DEBUG[1574019358.313583] publishing supla/channels/status/relay/1201
DEBUG[1574019358.315194] on_remote_call_received: 361
DEBUG[1574019358.315573] publishing supla/channels/status/switch/1224
DEBUG[1574019358.315750] publishing supla/channels/status/switch/1225
DEBUG[1574019358.315924] publishing supla/channels/status/switch/1226
DEBUG[1574019358.316095] publishing supla/channels/status/switch/1227
DEBUG[1574019358.316778] publishing supla/channels/status/electricity/1233
DEBUG[1574019358.319049] on_remote_call_received: 405
DEBUG[1574019358.814747] on_remote_call_received: 400
DEBUG[1574019358.814991] publishing supla/channels/status/thermometer/1162
DEBUG[1574019360.120040] on_remote_call_received: 400
DEBUG[1574019360.120287] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019363.915579] on_remote_call_received: 400
DEBUG[1574019363.915764] publishing supla/channels/status/1000/973
DEBUG[1574019365.394472] on_remote_call_received: 400
DEBUG[1574019365.394716] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019365.651647] on_remote_call_received: 400
DEBUG[1574019365.651834] publishing supla/channels/status/1000/975
DEBUG[1574019366.992140] on_remote_call_received: 400
DEBUG[1574019366.992303] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574019367.418882] on_remote_call_received: 400
DEBUG[1574019367.419007] publishing supla/channels/status/thermometer/105
DEBUG[1574019367.563569] on_remote_call_received: 400
DEBUG[1574019367.563682] publishing supla/channels/status/1000/974
DEBUG[1574019368.558913] on_remote_call_received: 400
DEBUG[1574019368.559151] publishing supla/channels/status/electricity/1202
DEBUG[1574019368.660387] on_remote_call_received: 405
DEBUG[1574019369.700618] on_remote_call_received: 400
DEBUG[1574019369.700795] publishing supla/channels/status/1020/1135
DEBUG[1574019370.668987] on_remote_call_received: 400
DEBUG[1574019370.669158] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019370.703095] on_remote_call_received: 400
DEBUG[1574019370.703237] publishing supla/channels/status/1020/1135
DEBUG[1574019371.481366] on_remote_call_received: 400
DEBUG[1574019371.481493] publishing supla/channels/status/1000/973
DEBUG[1574019371.704993] on_remote_call_received: 400
DEBUG[1574019371.705146] publishing supla/channels/status/1020/1135
DEBUG[1574019372.720517] on_remote_call_received: 400
DEBUG[1574019372.720680] publishing supla/channels/status/1020/1135
DEBUG[1574019372.990312] on_remote_call_received: 400
DEBUG[1574019372.990497] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574019373.243439] on_remote_call_received: 400
DEBUG[1574019373.243565] publishing supla/channels/status/1000/975
DEBUG[1574019374.710444] on_remote_call_received: 400
DEBUG[1574019374.710588] publishing supla/channels/status/1020/1135
DEBUG[1574019375.53965] on_remote_call_received: 400
DEBUG[1574019375.54080] publishing supla/channels/status/1000/974
DEBUG[1574019375.943498] on_remote_call_received: 400
DEBUG[1574019375.943657] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019376.713351] on_remote_call_received: 400
DEBUG[1574019376.713498] publishing supla/channels/status/1020/1135
DEBUG[1574019377.589190] on_remote_call_received: 400
DEBUG[1574019377.589327] publishing supla/channels/status/thermometer/103
DEBUG[1574019377.591961] on_remote_call_received: 400
DEBUG[1574019377.592086] publishing supla/channels/status/thermometer/105
DEBUG[1574019378.815078] on_remote_call_received: 400
DEBUG[1574019378.815237] publishing supla/channels/status/thermometer/1162
DEBUG[1574019381.219760] on_remote_call_received: 400
DEBUG[1574019381.219922] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019383.816216] on_remote_call_received: 400
DEBUG[1574019383.816379] publishing supla/channels/status/thermometer/1162
DEBUG[1574019386.494520] on_remote_call_received: 400
DEBUG[1574019386.494683] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019387.510854] on_remote_call_received: 400
DEBUG[1574019387.511012] publishing supla/channels/status/temperature_humidity/1153
DEBUG[1574019387.759079] on_remote_call_received: 400
DEBUG[1574019387.759217] publishing supla/channels/status/thermometer/105
DEBUG[1574019388.559625] on_remote_call_received: 400
DEBUG[1574019388.559851] publishing supla/channels/status/electricity/1202
DEBUG[1574019388.662649] on_remote_call_received: 405
DEBUG[1574019390.467933] on_remote_call_received: 400
DEBUG[1574019390.468061] publishing supla/channels/status/thermometer/45
DEBUG[1574019391.769765] on_remote_call_received: 400
DEBUG[1574019391.769919] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019393.510389] on_remote_call_received: 400
DEBUG[1574019393.510544] publishing supla/channels/status/temperature_humidity/1153
DEBUG[1574019396.924603] on_remote_call_received: 400
DEBUG[1574019396.924745] publishing supla/channels/status/1020/1135
DEBUG[1574019396.989754] on_remote_call_received: 400
DEBUG[1574019396.989911] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574019397.45540] on_remote_call_received: 400
DEBUG[1574019397.45695] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019397.928148] on_remote_call_received: 400
DEBUG[1574019397.928293] publishing supla/channels/status/1020/1135
DEBUG[1574019397.930135] on_remote_call_received: 400
DEBUG[1574019397.930265] publishing supla/channels/status/thermometer/103
DEBUG[1574019400.683794] on_remote_call_received: 400
DEBUG[1574019400.683931] publishing supla/channels/status/thermometer/45
DEBUG[1574019401.25366] on_remote_call_received: 400
DEBUG[1574019401.25515] publishing supla/channels/status/1020/1135
DEBUG[1574019402.27582] on_remote_call_received: 400
DEBUG[1574019402.27722] publishing supla/channels/status/1020/1135
DEBUG[1574019402.321150] on_remote_call_received: 400
DEBUG[1574019402.321305] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019404.31465] on_remote_call_received: 400
DEBUG[1574019404.31610] publishing supla/channels/status/1020/1135
DEBUG[1574019405.33634] on_remote_call_received: 400
DEBUG[1574019405.33772] publishing supla/channels/status/1020/1135
DEBUG[1574019405.510622] on_remote_call_received: 400
DEBUG[1574019405.510782] publishing supla/channels/status/temperature_humidity/1153
DEBUG[1574019407.595800] on_remote_call_received: 400
DEBUG[1574019407.595960] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019408.99390] on_remote_call_received: 400
DEBUG[1574019408.99543] publishing supla/channels/status/thermometer/105
DEBUG[1574019408.561754] on_remote_call_received: 400
DEBUG[1574019408.561981] publishing supla/channels/status/electricity/1202
DEBUG[1574019408.662373] on_remote_call_received: 405
DEBUG[1574019408.990864] on_remote_call_received: 400
DEBUG[1574019408.991018] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574019409.96068] on_remote_call_received: 400
DEBUG[1574019409.96222] publishing supla/channels/status/thermometer/1169
DEBUG[1574019412.136649] on_remote_call_received: 400
DEBUG[1574019412.136792] publishing supla/channels/status/1020/1135
DEBUG[1574019412.869962] on_remote_call_received: 400
DEBUG[1574019412.870141] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019413.137499] on_remote_call_received: 400
DEBUG[1574019413.137642] publishing supla/channels/status/1020/1135
DEBUG[1574019418.143628] on_remote_call_received: 400
DEBUG[1574019418.143778] publishing supla/channels/status/1020/1135
DEBUG[1574019418.144611] on_remote_call_received: 400
DEBUG[1574019418.144744] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019419.96052] on_remote_call_received: 400
DEBUG[1574019419.96216] publishing supla/channels/status/thermometer/1169
DEBUG[1574019419.242087] on_remote_call_received: 400
DEBUG[1574019419.242244] publishing supla/channels/status/1020/1135
DEBUG[1574019423.419224] on_remote_call_received: 400
DEBUG[1574019423.419722] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019423.507954] on_remote_call_received: 400
DEBUG[1574019423.508466] publishing supla/channels/status/temperature_humidity/1153
DEBUG[1574019424.96456] on_remote_call_received: 400
DEBUG[1574019424.96937] publishing supla/channels/status/thermometer/1169
DEBUG[1574019426.989677] on_remote_call_received: 400
DEBUG[1574019426.990310] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574019428.440535] on_remote_call_received: 400
DEBUG[1574019428.440999] publishing supla/channels/status/thermometer/105
DEBUG[1574019428.561580] on_remote_call_received: 400
DEBUG[1574019428.562120] publishing supla/channels/status/electricity/1202
DEBUG[1574019428.661144] on_remote_call_received: 405
DEBUG[1574019428.691653] on_remote_call_received: 400
DEBUG[1574019428.692363] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019428.814530] on_remote_call_received: 400
DEBUG[1574019428.815094] publishing supla/channels/status/thermometer/1162
DEBUG[1574019429.348330] on_remote_call_received: 400
DEBUG[1574019429.348482] publishing supla/channels/status/1020/1135
DEBUG[1574019431.352305] on_remote_call_received: 400
DEBUG[1574019431.352944] publishing supla/channels/status/1020/1135
DEBUG[1574019432.990217] on_remote_call_received: 400
DEBUG[1574019432.990377] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574019433.815299] on_remote_call_received: 400
DEBUG[1574019433.815929] publishing supla/channels/status/thermometer/1162
DEBUG[1574019433.966631] on_remote_call_received: 400
DEBUG[1574019433.967174] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019434.95994] on_remote_call_received: 400
DEBUG[1574019434.96513] publishing supla/channels/status/thermometer/1169
DEBUG[1574019438.612297] on_remote_call_received: 400
DEBUG[1574019438.612763] publishing supla/channels/status/thermometer/105
DEBUG[1574019438.989600] on_remote_call_received: 400
DEBUG[1574019438.990149] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574019439.96327] on_remote_call_received: 400
DEBUG[1574019439.96828] publishing supla/channels/status/thermometer/1169
DEBUG[1574019439.239784] on_remote_call_received: 400
DEBUG[1574019439.240332] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019444.515285] on_remote_call_received: 400
DEBUG[1574019444.515455] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019444.989158] on_remote_call_received: 400
DEBUG[1574019444.989694] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574019445.461911] on_remote_call_received: 400
DEBUG[1574019445.462402] publishing supla/channels/status/1020/1135
DEBUG[1574019448.559760] on_remote_call_received: 400
DEBUG[1574019448.559987] publishing supla/channels/status/electricity/1202
DEBUG[1574019448.660924] on_remote_call_received: 405
DEBUG[1574019448.781907] on_remote_call_received: 400
DEBUG[1574019448.782044] publishing supla/channels/status/thermometer/104
DEBUG[1574019448.784280] on_remote_call_received: 400
DEBUG[1574019448.784399] publishing supla/channels/status/thermometer/105
DEBUG[1574019449.562517] on_remote_call_received: 400
DEBUG[1574019449.562661] publishing supla/channels/status/1020/1135
DEBUG[1574019449.790112] on_remote_call_received: 400
DEBUG[1574019449.790266] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019450.989824] on_remote_call_received: 400
DEBUG[1574019450.989996] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574019455.63694] on_remote_call_received: 400
DEBUG[1574019455.63848] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019458.952093] on_remote_call_received: 400
DEBUG[1574019458.952236] publishing supla/channels/status/thermometer/105
DEBUG[1574019459.507120] on_remote_call_received: 400
DEBUG[1574019459.507273] publishing supla/channels/status/temperature_humidity/1153
DEBUG[1574019460.337506] on_remote_call_received: 400
DEBUG[1574019460.337662] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019460.591548] on_remote_call_received: 400
DEBUG[1574019460.591663] publishing supla/channels/status/4000/9
DEBUG[1574019460.669841] on_remote_call_received: 400
DEBUG[1574019460.669988] publishing supla/channels/status/1020/1135
DEBUG[1574019461.999102] on_remote_call_received: 400
DEBUG[1574019461.999236] publishing supla/channels/status/thermometer/45
DEBUG[1574019462.672393] on_remote_call_received: 400
DEBUG[1574019462.672531] publishing supla/channels/status/1020/1135
DEBUG[1574019463.674198] on_remote_call_received: 400
DEBUG[1574019463.674341] publishing supla/channels/status/1020/1135
DEBUG[1574019464.677216] on_remote_call_received: 400
DEBUG[1574019464.677508] publishing supla/channels/status/1020/1135
DEBUG[1574019465.507260] on_remote_call_received: 400
DEBUG[1574019465.507587] publishing supla/channels/status/temperature_humidity/1153
DEBUG[1574019465.611083] on_remote_call_received: 400
DEBUG[1574019465.611330] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019468.562363] on_remote_call_received: 400
DEBUG[1574019468.562738] publishing supla/channels/status/electricity/1202
DEBUG[1574019468.662546] on_remote_call_received: 405
DEBUG[1574019468.815773] on_remote_call_received: 400
DEBUG[1574019468.816012] publishing supla/channels/status/thermometer/1162
DEBUG[1574019468.990511] on_remote_call_received: 400
DEBUG[1574019468.990757] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574019469.121849] on_remote_call_received: 400
DEBUG[1574019469.122062] publishing supla/channels/status/thermometer/105
DEBUG[1574019470.778874] on_remote_call_received: 400
DEBUG[1574019470.779097] publishing supla/channels/status/1020/1135
DEBUG[1574019470.886083] on_remote_call_received: 400
DEBUG[1574019470.886319] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019471.508155] on_remote_call_received: 400
DEBUG[1574019471.508401] publishing supla/channels/status/temperature_humidity/1153
DEBUG[1574019472.221910] on_remote_call_received: 400
DEBUG[1574019472.222103] publishing supla/channels/status/thermometer/45
DEBUG[1574019473.815865] on_remote_call_received: 400
DEBUG[1574019473.816102] publishing supla/channels/status/thermometer/1162
DEBUG[1574019474.784302] on_remote_call_received: 400
DEBUG[1574019474.784522] publishing supla/channels/status/1020/1135
DEBUG[1574019474.990502] on_remote_call_received: 400
DEBUG[1574019474.990748] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574019476.161136] on_remote_call_received: 400
DEBUG[1574019476.161381] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019477.510219] on_remote_call_received: 400
DEBUG[1574019477.510465] publishing supla/channels/status/temperature_humidity/1153
DEBUG[1574019477.892561] on_remote_call_received: 400
DEBUG[1574019477.892742] publishing supla/channels/status/4000/9
DEBUG[1574019479.292099] on_remote_call_received: 400
DEBUG[1574019479.292308] publishing supla/channels/status/thermometer/105
DEBUG[1574019480.603707] size of commands: 5
DEBUG[1574019480.844156] on_remote_call_received: 400
DEBUG[1574019480.844373] publishing supla/channels/status/relay/1172
DEBUG[1574019480.988768] on_remote_call_received: 190
DEBUG[1574019480.988864] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574019481.436281] on_remote_call_received: 400
DEBUG[1574019481.436527] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019481.887901] on_remote_call_received: 400
DEBUG[1574019481.888122] publishing supla/channels/status/1020/1135
DEBUG[1574019482.447850] on_remote_call_received: 400
DEBUG[1574019482.448043] publishing supla/channels/status/thermometer/45
DEBUG[1574019483.507839] on_remote_call_received: 400
DEBUG[1574019483.508084] publishing supla/channels/status/temperature_humidity/1153
DEBUG[1574019483.891136] on_remote_call_received: 400
DEBUG[1574019483.891359] publishing supla/channels/status/1020/1135
DEBUG[1574019483.909731] size of commands: 5
DEBUG[1574019484.98200] on_remote_call_received: 400
DEBUG[1574019484.98410] publishing supla/channels/status/relay/1172
DEBUG[1574019484.107145] on_remote_call_received: 190
DEBUG[1574019484.107213] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574019484.678412] on_remote_call_received: 400
DEBUG[1574019484.678594] publishing supla/channels/status/1000/973
DEBUG[1574019485.813480] size of commands: 5
DEBUG[1574019485.992359] on_remote_call_received: 400
DEBUG[1574019485.992571] publishing supla/channels/status/relay/1172
DEBUG[1574019486.55924] on_remote_call_received: 190
DEBUG[1574019486.56017] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574019486.388922] on_remote_call_received: 400
DEBUG[1574019486.389107] publishing supla/channels/status/1000/975
DEBUG[1574019486.709116] on_remote_call_received: 400
DEBUG[1574019486.709363] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019486.916209] size of commands: 5
DEBUG[1574019487.93958] on_remote_call_received: 400
DEBUG[1574019487.94166] publishing supla/channels/status/relay/1172
DEBUG[1574019487.155920] on_remote_call_received: 190
DEBUG[1574019487.156016] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574019487.896944] on_remote_call_received: 400
DEBUG[1574019487.897160] publishing supla/channels/status/1020/1135
DEBUG[1574019488.27049] on_remote_call_received: 400
DEBUG[1574019488.27237] publishing supla/channels/status/1000/974
DEBUG[1574019488.563185] on_remote_call_received: 400
DEBUG[1574019488.563561] publishing supla/channels/status/electricity/1202
DEBUG[1574019488.664244] on_remote_call_received: 405
DEBUG[1574019488.719869] size of commands: 5
DEBUG[1574019488.898692] on_remote_call_received: 400
DEBUG[1574019488.898897] publishing supla/channels/status/1020/1135
DEBUG[1574019488.903217] on_remote_call_received: 400
DEBUG[1574019488.903400] publishing supla/channels/status/relay/1172
DEBUG[1574019488.950120] on_remote_call_received: 190
DEBUG[1574019488.950218] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574019489.221577] size of commands: 5
DEBUG[1574019489.392587] on_remote_call_received: 400
DEBUG[1574019489.392794] publishing supla/channels/status/relay/1172
DEBUG[1574019489.450312] on_remote_call_received: 190
DEBUG[1574019489.450404] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574019489.498393] on_remote_call_received: 400
DEBUG[1574019489.498586] publishing supla/channels/status/thermometer/105
DEBUG[1574019489.507379] on_remote_call_received: 400
DEBUG[1574019489.507665] publishing supla/channels/status/temperature_humidity/1153
DEBUG[1574019490.924819] size of commands: 5
DEBUG[1574019491.124082] on_remote_call_received: 400
DEBUG[1574019491.124299] publishing supla/channels/status/relay/1174
DEBUG[1574019491.208516] on_remote_call_received: 190
DEBUG[1574019491.208608] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574019491.426309] size of commands: 5
DEBUG[1574019491.635391] on_remote_call_received: 400
DEBUG[1574019491.635605] publishing supla/channels/status/relay/1174
DEBUG[1574019491.710947] on_remote_call_received: 190
DEBUG[1574019491.711029] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574019491.957768] on_remote_call_received: 400
DEBUG[1574019491.957948] publishing supla/channels/status/1000/973
DEBUG[1574019491.984092] on_remote_call_received: 400
DEBUG[1574019491.984400] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019491.997291] on_remote_call_received: 400
DEBUG[1574019491.997696] publishing supla/channels/status/1020/1135
DEBUG[1574019492.528706] size of commands: 5
DEBUG[1574019492.661681] on_remote_call_received: 400
DEBUG[1574019492.661875] publishing supla/channels/status/thermometer/45
DEBUG[1574019492.873460] on_remote_call_received: 400
DEBUG[1574019492.873673] publishing supla/channels/status/relay/1174
DEBUG[1574019492.988633] on_remote_call_received: 400
DEBUG[1574019492.988880] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574019492.999565] on_remote_call_received: 400
DEBUG[1574019492.999734] publishing supla/channels/status/1020/1135
DEBUG[1574019493.149599] on_remote_call_received: 190
DEBUG[1574019493.149708] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574019493.531012] size of commands: 5
DEBUG[1574019493.661797] on_remote_call_received: 400
DEBUG[1574019493.662008] publishing supla/channels/status/relay/1174
DEBUG[1574019493.686390] on_remote_call_received: 400
DEBUG[1574019493.686544] publishing supla/channels/status/1000/975
DEBUG[1574019493.749764] on_remote_call_received: 190
DEBUG[1574019493.749861] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574019494.2411] on_remote_call_received: 400
DEBUG[1574019494.2622] publishing supla/channels/status/1020/1135
DEBUG[1574019495.556278] on_remote_call_received: 400
DEBUG[1574019495.556461] publishing supla/channels/status/1000/974
DEBUG[1574019496.4826] on_remote_call_received: 400
DEBUG[1574019496.5048] publishing supla/channels/status/1020/1135
DEBUG[1574019497.259080] on_remote_call_received: 400
DEBUG[1574019497.259326] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019498.989288] on_remote_call_received: 400
DEBUG[1574019498.989561] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574019499.632126] on_remote_call_received: 400
DEBUG[1574019499.632329] publishing supla/channels/status/thermometer/104
DEBUG[1574019499.634329] on_remote_call_received: 400
DEBUG[1574019499.634480] publishing supla/channels/status/thermometer/105
DEBUG[1574019500.104380] on_remote_call_received: 400
DEBUG[1574019500.104608] publishing supla/channels/status/1020/1135
DEBUG[1574019501.106834] on_remote_call_received: 400
DEBUG[1574019501.107061] publishing supla/channels/status/1020/1135
DEBUG[1574019501.506326] on_remote_call_received: 400
DEBUG[1574019501.506576] publishing supla/channels/status/temperature_humidity/1153
DEBUG[1574019501.942567] size of commands: 5
DEBUG[1574019502.112862] on_remote_call_received: 400
DEBUG[1574019502.113082] publishing supla/channels/status/1020/1135
DEBUG[1574019502.114221] on_remote_call_received: 400
DEBUG[1574019502.114398] publishing supla/channels/status/relay/1172
DEBUG[1574019502.148106] on_remote_call_received: 190
DEBUG[1574019502.148199] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574019502.533208] on_remote_call_received: 400
DEBUG[1574019502.533454] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019503.817351] on_remote_call_received: 400
DEBUG[1574019503.817665] publishing supla/channels/status/thermometer/1162
DEBUG[1574019504.991236] on_remote_call_received: 400
DEBUG[1574019504.991485] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574019505.719517] on_remote_call_received: 400
DEBUG[1574019505.719697] publishing supla/channels/status/1000/973
DEBUG[1574019506.114170] on_remote_call_received: 400
DEBUG[1574019506.114400] publishing supla/channels/status/1020/1135
DEBUG[1574019507.569396] on_remote_call_received: 400
DEBUG[1574019507.569610] publishing supla/channels/status/1000/975
DEBUG[1574019507.807150] on_remote_call_received: 400
DEBUG[1574019507.807393] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019508.562420] on_remote_call_received: 400
DEBUG[1574019508.562802] publishing supla/channels/status/electricity/1202
DEBUG[1574019508.661227] on_remote_call_received: 405
DEBUG[1574019509.118163] on_remote_call_received: 400
DEBUG[1574019509.118391] publishing supla/channels/status/1020/1135
DEBUG[1574019509.333607] on_remote_call_received: 400
DEBUG[1574019509.333793] publishing supla/channels/status/1000/974
DEBUG[1574019509.802551] on_remote_call_received: 400
DEBUG[1574019509.802764] publishing supla/channels/status/thermometer/103
DEBUG[1574019509.804821] on_remote_call_received: 400
DEBUG[1574019509.804982] publishing supla/channels/status/thermometer/104
DEBUG[1574019510.214801] on_remote_call_received: 400
DEBUG[1574019510.215027] publishing supla/channels/status/1020/1135
DEBUG[1574019512.219646] on_remote_call_received: 400
DEBUG[1574019512.219872] publishing supla/channels/status/1020/1135
DEBUG[1574019513.81459] on_remote_call_received: 400
DEBUG[1574019513.81709] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019513.178110] on_remote_call_received: 400
DEBUG[1574019513.178291] publishing supla/channels/status/1000/973
DEBUG[1574019513.222595] on_remote_call_received: 400
DEBUG[1574019513.222782] publishing supla/channels/status/1020/1135
DEBUG[1574019513.506561] on_remote_call_received: 400
DEBUG[1574019513.506811] publishing supla/channels/status/temperature_humidity/1153
DEBUG[1574019514.223968] on_remote_call_received: 400
DEBUG[1574019514.224193] publishing supla/channels/status/1020/1135
DEBUG[1574019515.226088] on_remote_call_received: 400
DEBUG[1574019515.226316] publishing supla/channels/status/1020/1135
DEBUG[1574019515.259229] on_remote_call_received: 400
DEBUG[1574019515.259379] publishing supla/channels/status/1000/975
DEBUG[1574019515.462644] size of commands: 5
DEBUG[1574019515.620916] on_remote_call_received: 400
DEBUG[1574019515.621124] publishing supla/channels/status/relay/1172
DEBUG[1574019515.758086] on_remote_call_received: 190
DEBUG[1574019515.758180] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574019516.988926] on_remote_call_received: 400
DEBUG[1574019516.989188] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574019517.97169] on_remote_call_received: 400
DEBUG[1574019517.97356] publishing supla/channels/status/1000/974
DEBUG[1574019518.355717] on_remote_call_received: 400
DEBUG[1574019518.355967] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019518.467756] size of commands: 5
DEBUG[1574019518.633209] on_remote_call_received: 400
DEBUG[1574019518.633419] publishing supla/channels/status/relay/1172
DEBUG[1574019518.661397] on_remote_call_received: 190
DEBUG[1574019518.661480] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574019518.816583] on_remote_call_received: 400
DEBUG[1574019518.816825] publishing supla/channels/status/thermometer/1162
DEBUG[1574019519.69669] size of commands: 5
DEBUG[1574019519.233558] on_remote_call_received: 400
DEBUG[1574019519.233765] publishing supla/channels/status/relay/1172
DEBUG[1574019519.261674] on_remote_call_received: 190
DEBUG[1574019519.261740] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574019519.506457] on_remote_call_received: 400
DEBUG[1574019519.506713] publishing supla/channels/status/temperature_humidity/1153
DEBUG[1574019519.974980] on_remote_call_received: 400
DEBUG[1574019519.975190] publishing supla/channels/status/thermometer/105
DEBUG[1574019520.973370] size of commands: 5
DEBUG[1574019521.135731] on_remote_call_received: 400
DEBUG[1574019521.135942] publishing supla/channels/status/relay/1172
DEBUG[1574019521.181842] on_remote_call_received: 190
DEBUG[1574019521.181935] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574019522.576296] size of commands: 5
DEBUG[1574019522.735414] on_remote_call_received: 400
DEBUG[1574019522.735624] publishing supla/channels/status/relay/1172
DEBUG[1574019522.777407] size of commands: 5
DEBUG[1574019522.779336] on_remote_call_received: 190
DEBUG[1574019522.779434] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574019522.938911] on_remote_call_received: 400
DEBUG[1574019522.939119] publishing supla/channels/status/relay/1172
DEBUG[1574019522.990364] on_remote_call_received: 400
DEBUG[1574019522.990651] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574019523.78747] on_remote_call_received: 190
DEBUG[1574019523.78838] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574019523.379680] size of commands: 5
DEBUG[1574019523.546490] on_remote_call_received: 400
DEBUG[1574019523.546709] publishing supla/channels/status/relay/1172
DEBUG[1574019523.579027] on_remote_call_received: 190
DEBUG[1574019523.579097] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574019523.633114] on_remote_call_received: 400
DEBUG[1574019523.633363] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019523.781318] size of commands: 5
DEBUG[1574019523.940477] on_remote_call_received: 400
DEBUG[1574019523.940691] publishing supla/channels/status/relay/1172
DEBUG[1574019523.979027] on_remote_call_received: 190
DEBUG[1574019523.979106] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574019525.334028] on_remote_call_received: 400
DEBUG[1574019525.334257] publishing supla/channels/status/1020/1135
DEBUG[1574019525.510676] on_remote_call_received: 400
DEBUG[1574019525.510927] publishing supla/channels/status/temperature_humidity/1153
DEBUG[1574019526.335272] on_remote_call_received: 400
DEBUG[1574019526.335496] publishing supla/channels/status/1020/1135
DEBUG[1574019527.85976] size of commands: 5
DEBUG[1574019527.274892] on_remote_call_received: 400
DEBUG[1574019527.275106] publishing supla/channels/status/relay/1174
DEBUG[1574019527.337886] on_remote_call_received: 400
DEBUG[1574019527.338113] publishing supla/channels/status/1020/1135
DEBUG[1574019527.372856] on_remote_call_received: 190
DEBUG[1574019527.372926] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574019528.339770] on_remote_call_received: 400
DEBUG[1574019528.339999] publishing supla/channels/status/1020/1135
DEBUG[1574019528.566678] on_remote_call_received: 400
DEBUG[1574019528.567099] publishing supla/channels/status/electricity/1202
DEBUG[1574019528.663029] on_remote_call_received: 405
DEBUG[1574019528.910120] on_remote_call_received: 400
DEBUG[1574019528.910370] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019530.146668] on_remote_call_received: 400
DEBUG[1574019530.146883] publishing supla/channels/status/thermometer/105
DEBUG[1574019531.510089] on_remote_call_received: 400
DEBUG[1574019531.510338] publishing supla/channels/status/temperature_humidity/1153
DEBUG[1574019532.296942] size of commands: 5
DEBUG[1574019532.439326] on_remote_call_received: 400
DEBUG[1574019532.439556] publishing supla/channels/status/1020/1135
DEBUG[1574019532.493094] on_remote_call_received: 400
DEBUG[1574019532.493292] publishing supla/channels/status/relay/1174
DEBUG[1574019532.588245] on_remote_call_received: 190
DEBUG[1574019532.588338] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574019533.443362] on_remote_call_received: 400
DEBUG[1574019533.443584] publishing supla/channels/status/1020/1135
DEBUG[1574019534.185676] on_remote_call_received: 400
DEBUG[1574019534.185917] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019534.443648] on_remote_call_received: 400
DEBUG[1574019534.443871] publishing supla/channels/status/1020/1135
DEBUG[1574019534.502086] size of commands: 5
DEBUG[1574019534.654819] on_remote_call_received: 400
DEBUG[1574019534.655036] publishing supla/channels/status/relay/1174
DEBUG[1574019534.823481] on_remote_call_received: 190
DEBUG[1574019534.823569] Event: 70, SenderID: 6, SenderName: Supla MQTT Proxy
DEBUG[1574019535.445284] on_remote_call_received: 400
DEBUG[1574019535.445535] publishing supla/channels/status/1020/1135
DEBUG[1574019536.448390] on_remote_call_received: 400
DEBUG[1574019536.448613] publishing supla/channels/status/1020/1135
DEBUG[1574019537.449631] on_remote_call_received: 400
DEBUG[1574019537.449927] publishing supla/channels/status/1020/1135
DEBUG[1574019538.451488] on_remote_call_received: 400
DEBUG[1574019538.451709] publishing supla/channels/status/1020/1135
DEBUG[1574019539.461193] on_remote_call_received: 400
DEBUG[1574019539.461468] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019541.550719] on_remote_call_received: 400
DEBUG[1574019541.550940] publishing supla/channels/status/1020/1135
DEBUG[1574019543.755525] on_remote_call_received: 400
DEBUG[1574019543.755722] publishing supla/channels/status/thermometer/45
DEBUG[1574019544.564208] on_remote_call_received: 400
DEBUG[1574019544.564430] publishing supla/channels/status/1020/1135
DEBUG[1574019544.735826] on_remote_call_received: 400
DEBUG[1574019544.736064] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019545.556490] on_remote_call_received: 400
DEBUG[1574019545.556788] publishing supla/channels/status/1020/1135
DEBUG[1574019548.562804] on_remote_call_received: 400
DEBUG[1574019548.563305] publishing supla/channels/status/electricity/1202
DEBUG[1574019548.663069] on_remote_call_received: 405
DEBUG[1574019549.508425] on_remote_call_received: 400
DEBUG[1574019549.508748] publishing supla/channels/status/temperature_humidity/1153
DEBUG[1574019550.9331] on_remote_call_received: 400
DEBUG[1574019550.9652] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019550.487739] on_remote_call_received: 400
DEBUG[1574019550.488024] publishing supla/channels/status/thermometer/105
DEBUG[1574019552.988398] on_remote_call_received: 400
DEBUG[1574019552.988719] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574019555.288874] on_remote_call_received: 400
DEBUG[1574019555.289186] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019555.507773] on_remote_call_received: 400
DEBUG[1574019555.508096] publishing supla/channels/status/temperature_humidity/1153
DEBUG[1574019555.662276] on_remote_call_received: 400
DEBUG[1574019555.662579] publishing supla/channels/status/1020/1135
DEBUG[1574019557.665557] on_remote_call_received: 400
DEBUG[1574019557.665849] publishing supla/channels/status/1020/1135
DEBUG[1574019558.988214] on_remote_call_received: 400
DEBUG[1574019558.988538] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574019559.670881] on_remote_call_received: 400
DEBUG[1574019559.671180] publishing supla/channels/status/1020/1135
DEBUG[1574019560.561609] on_remote_call_received: 400
DEBUG[1574019560.561929] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019560.766541] on_remote_call_received: 400
DEBUG[1574019560.766837] publishing supla/channels/status/1020/1135
DEBUG[1574019562.771205] on_remote_call_received: 400
DEBUG[1574019562.771497] publishing supla/channels/status/1020/1135
DEBUG[1574019563.772969] on_remote_call_received: 400
DEBUG[1574019563.773321] publishing supla/channels/status/1020/1135
DEBUG[1574019563.816214] on_remote_call_received: 400
DEBUG[1574019563.816506] publishing supla/channels/status/thermometer/1162
DEBUG[1574019564.193415] on_remote_call_received: 400
DEBUG[1574019564.193685] publishing supla/channels/status/thermometer/45
DEBUG[1574019565.776063] on_remote_call_received: 400
DEBUG[1574019565.776354] publishing supla/channels/status/1020/1135
DEBUG[1574019565.890258] on_remote_call_received: 400
DEBUG[1574019565.890572] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019566.778516] on_remote_call_received: 400
DEBUG[1574019566.778813] publishing supla/channels/status/1020/1135
DEBUG[1574019567.780396] on_remote_call_received: 400
DEBUG[1574019567.780692] publishing supla/channels/status/1020/1135
DEBUG[1574019568.563143] on_remote_call_received: 400
DEBUG[1574019568.563649] publishing supla/channels/status/electricity/1202
DEBUG[1574019568.662675] on_remote_call_received: 405
DEBUG[1574019568.782437] on_remote_call_received: 400
DEBUG[1574019568.782704] publishing supla/channels/status/1020/1135
DEBUG[1574019568.816902] on_remote_call_received: 400
DEBUG[1574019568.817172] publishing supla/channels/status/thermometer/1162
DEBUG[1574019569.783724] on_remote_call_received: 400
DEBUG[1574019569.784017] publishing supla/channels/status/1020/1135
DEBUG[1574019570.828318] on_remote_call_received: 400
DEBUG[1574019570.828603] publishing supla/channels/status/thermometer/103
DEBUG[1574019570.891616] on_remote_call_received: 400
DEBUG[1574019570.891896] publishing supla/channels/status/thermometer/105
DEBUG[1574019570.894803] on_remote_call_received: 400
DEBUG[1574019570.895059] publishing supla/channels/status/1020/1135
DEBUG[1574019571.111817] on_remote_call_received: 400
DEBUG[1574019571.112130] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019572.883743] on_remote_call_received: 400
DEBUG[1574019572.884035] publishing supla/channels/status/1020/1135
DEBUG[1574019573.886647] on_remote_call_received: 400
DEBUG[1574019573.886939] publishing supla/channels/status/1020/1135
DEBUG[1574019574.889952] on_remote_call_received: 400
DEBUG[1574019574.890244] publishing supla/channels/status/1020/1135
DEBUG[1574019576.387159] on_remote_call_received: 400
DEBUG[1574019576.387549] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019577.891869] on_remote_call_received: 400
DEBUG[1574019577.892163] publishing supla/channels/status/1020/1135
DEBUG[1574019581.663654] on_remote_call_received: 400
DEBUG[1574019581.663969] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019581.992314] on_remote_call_received: 400
DEBUG[1574019581.992599] publishing supla/channels/status/1020/1135
DEBUG[1574019582.994227] on_remote_call_received: 400
DEBUG[1574019582.994522] publishing supla/channels/status/1020/1135
DEBUG[1574019584.631999] on_remote_call_received: 400
DEBUG[1574019584.632267] publishing supla/channels/status/thermometer/45
DEBUG[1574019586.939049] on_remote_call_received: 400
DEBUG[1574019586.939365] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019588.349] on_remote_call_received: 400
DEBUG[1574019588.646] publishing supla/channels/status/1020/1135
DEBUG[1574019588.561437] on_remote_call_received: 400
DEBUG[1574019588.561944] publishing supla/channels/status/electricity/1202
DEBUG[1574019588.662419] on_remote_call_received: 405
DEBUG[1574019590.3332] on_remote_call_received: 400
DEBUG[1574019590.3624] publishing supla/channels/status/1020/1135
DEBUG[1574019592.215403] on_remote_call_received: 400
DEBUG[1574019592.215715] publishing supla/channels/status/temperature_humidity/1052
^A^ADEBUG[1574019597.491342] on_remote_call_received: 400
DEBUG[1574019597.491654] publishing supla/channels/status/temperature_humidity/1052
aaa
DEBUG[1574019600.988220] on_remote_call_received: 400
DEBUG[1574019600.988531] publishing supla/channels/status/temperature_humidity/1160
eDEBUG[1574019601.206775] on_remote_call_received: 400
DEBUG[1574019601.206982] publishing supla/channels/status/1020/1135
DEBUG[1574019601.338393] on_remote_call_received: 400
DEBUG[1574019601.338604] publishing supla/channels/status/thermometer/103
DEBUG[1574019601.340645] on_remote_call_received: 400
DEBUG[1574019601.340789] publishing supla/channels/status/thermometer/105
xitDEBUG[1574019602.208761] on_remote_call_received: 400
DEBUG[1574019602.209047] publishing supla/channels/status/1020/1135
DEBUG[1574019602.779916] on_remote_call_received: 400
DEBUG[1574019602.780164] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019603.506983] on_remote_call_received: 400
DEBUG[1574019603.507229] publishing supla/channels/status/temperature_humidity/1153
DEBUG[1574019605.70071] on_remote_call_received: 400
DEBUG[1574019605.70272] publishing supla/channels/status/thermometer/45
quit
DEBUG[1574019606.999267] on_remote_call_received: 400
DEBUG[1574019606.999583] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574019608.44304] on_remote_call_received: 400
DEBUG[1574019608.44619] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019608.563255] on_remote_call_received: 400
DEBUG[1574019608.563766] publishing supla/channels/status/electricity/1202
DEBUG[1574019608.663802] on_remote_call_received: 405
DEBUG[1574019609.507976] on_remote_call_received: 400
DEBUG[1574019609.508295] publishing supla/channels/status/temperature_humidity/1153
DEBUG[1574019612.23789] on_remote_call_received: 400
DEBUG[1574019612.26796] on_remote_call_received: 405
DEBUG[1574019613.319035] on_remote_call_received: 400
DEBUG[1574019613.319354] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019617.319782] on_remote_call_received: 400
DEBUG[1574019617.320082] publishing supla/channels/status/1020/1135
DEBUG[1574019618.594900] on_remote_call_received: 400
DEBUG[1574019618.595221] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019618.988371] on_remote_call_received: 400
DEBUG[1574019618.988701] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574019619.323318] on_remote_call_received: 400
DEBUG[1574019619.323615] publishing supla/channels/status/1020/1135
DEBUG[1574019620.324846] on_remote_call_received: 400
DEBUG[1574019620.325160] publishing supla/channels/status/1020/1135
DEBUG[1574019621.421477] on_remote_call_received: 400
DEBUG[1574019621.421766] publishing supla/channels/status/1020/1135
DEBUG[1574019622.21663] on_remote_call_received: 400
DEBUG[1574019622.22908] on_remote_call_received: 405
DEBUG[1574019623.870904] on_remote_call_received: 400
DEBUG[1574019623.871223] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019624.987985] on_remote_call_received: 400
DEBUG[1574019624.988300] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574019625.427106] on_remote_call_received: 400
DEBUG[1574019625.427399] publishing supla/channels/status/1020/1135
DEBUG[1574019625.507306] on_remote_call_received: 400
DEBUG[1574019625.507583] publishing supla/channels/status/thermometer/45
DEBUG[1574019627.22809] on_remote_call_received: 400
DEBUG[1574019627.24042] on_remote_call_received: 405
DEBUG[1574019627.429876] on_remote_call_received: 400
DEBUG[1574019627.430169] publishing supla/channels/status/1020/1135
DEBUG[1574019628.563330] on_remote_call_received: 400
DEBUG[1574019628.563836] publishing supla/channels/status/electricity/1202
DEBUG[1574019628.662330] on_remote_call_received: 405
DEBUG[1574019629.143298] on_remote_call_received: 400
DEBUG[1574019629.143603] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019630.987678] on_remote_call_received: 400
DEBUG[1574019630.988005] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574019632.21090] on_remote_call_received: 400
DEBUG[1574019632.22366] on_remote_call_received: 405
DEBUG[1574019632.532881] on_remote_call_received: 400
DEBUG[1574019632.533170] publishing supla/channels/status/1020/1135
DEBUG[1574019633.535397] on_remote_call_received: 400
DEBUG[1574019633.535697] publishing supla/channels/status/1020/1135
DEBUG[1574019634.424750] on_remote_call_received: 400
DEBUG[1574019634.425066] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019636.988052] on_remote_call_received: 400
DEBUG[1574019636.988379] publishing supla/channels/status/temperature_humidity/1160
DEBUG[1574019637.539960] on_remote_call_received: 400
DEBUG[1574019637.540255] publishing supla/channels/status/1020/1135
DEBUG[1574019638.507213] on_remote_call_received: 400
DEBUG[1574019638.507525] publishing supla/channels/status/1000/973
DEBUG[1574019638.541640] on_remote_call_received: 400
DEBUG[1574019638.541937] publishing supla/channels/status/1020/1135
DEBUG[1574019639.543756] on_remote_call_received: 400
DEBUG[1574019639.544052] publishing supla/channels/status/1020/1135
DEBUG[1574019639.696119] on_remote_call_received: 400
DEBUG[1574019639.696443] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019640.297944] on_remote_call_received: 400
DEBUG[1574019640.298205] publishing supla/channels/status/1000/975
DEBUG[1574019641.645444] on_remote_call_received: 400
DEBUG[1574019641.645735] publishing supla/channels/status/1020/1135
DEBUG[1574019642.19743] on_remote_call_received: 400
DEBUG[1574019642.20024] publishing supla/channels/status/thermometer/105
DEBUG[1574019642.23371] on_remote_call_received: 400
DEBUG[1574019642.25578] on_remote_call_received: 405
DEBUG[1574019642.51352] on_remote_call_received: 400
DEBUG[1574019642.51610] publishing supla/channels/status/1000/974
DEBUG[1574019642.645251] on_remote_call_received: 400
DEBUG[1574019642.645550] publishing supla/channels/status/1020/1135
DEBUG[1574019643.647121] on_remote_call_received: 400
DEBUG[1574019643.647418] publishing supla/channels/status/1020/1135
DEBUG[1574019644.649245] on_remote_call_received: 400
DEBUG[1574019644.649541] publishing supla/channels/status/1020/1135
DEBUG[1574019644.971475] on_remote_call_received: 400
DEBUG[1574019644.971794] publishing supla/channels/status/temperature_humidity/1052
DEBUG[1574019645.651133] on_remote_call_received: 400
DEBUG[1574019645.651430] publishing supla/channels/status/1020/1135
DEBUG[1574019645.994725] on_remote_call_received: 400
DEBUG[1574019645.994973] publishing supla/channels/status/1000/973
DEBUG[1574019646.652747] on_remote_call_received: 400
DEBUG[1574019646.653062] publishing supla/channels/status/1020/1135
DEBUG[1574019647.655328] on_remote_call_received: 400
DEBUG[1574019647.655627] publishing supla/channels/status/1020/1135
DEBUG[1574019647.770789] on_remote_call_received: 400
DEBUG[1574019647.771058] publishing supla/channels/status/1000/975
DEBUG[1574019648.563391] on_remote_call_received: 400
DEBUG[1574019648.563891] publishing supla/channels/status/electricity/1202
DEBUG[1574019648.662350] on_remote_call_received: 405
DEBUG[1574019648.987788] on_remote_call_received: 400
DEBUG[1574019648.988538] publishing supla/channels/status/temperature_humidity/1160
Beku
Pod koniec tygodnia będę miał nowa wersje. Spróbujemy to na niej opanować.
cino111
Elegancko. W tygodniu i tak człowiek zarobionyBeku wrote: Mon Nov 18, 2019 11:29 am Pod koniec tygodnia będę miał nowa wersje. Spróbujemy to na niej opanować.
Swoją drogą mając wszystkie stany kanałów Supli na serwerze MQTT nie dało by się tu opanować logiki? Pewnie przez jakiś dodatkowy komponent, ale już połowa roboty za nami
Beku
Dałoby się za pomocą np. NodeRed. Ale wymaga to wiedzy programistycznej.
desaint
Rewelacja!!!!
Bridge supla<-->MQTT jest zajebisty. Brawo.
To jest to czego mi trzeba bo nie ma tego w supli a logika to jedna z najważniejszych rzeczy inteligentnego domu.
Właśnie skończyłem to instalowac i konfigurować, nie powiem że kłopotów nie było ale jakoś poszło.
Dodam, że jak ktoś woli to jest biblioteka PHP do mosquito i można kontrolować wszystkie kanały i zrobić sobie własną logikę bardzo prosto. Nie instalowałem dashboardow już bo późno było.
Tak więc uważam że ten bridge+mosquito+biblioteka PHP i można zdziałać wiele rzeczy.
BTW, jak będą sceny w supli to będzie to wysyłalo powiadomienia do mqtt? Powiadomienie jedno o scenie czy kilka o każdym elemencie sceny?
