SUPLA Scripts
Been thanked: 9 times
Pobierz zmiany
git fetch
I zrób reset
git reset --hard origin/master
SOP 2023 :heavy_check_mark:
SOP 2024 :heavy_check_mark:
🧩: 🔑cz->b ⛴️+ila
PuteR
lesny8 wrote: Mon May 13, 2019 5:56 pm Pobierz zmiany
git fetch
I zrób reset
Coś ruszyło ale daje jakiś błąd
Connecting to 192.168.1.81 port 22, please wait...
login as:
[email protected]'s password:
Linux raspberrypi 4.14.79-v7+ #1159 SMP Sun Nov 4 17:50:20 GMT 2018 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Mon May 13 19:22:28 2019 from 192.168.1.65
pi@raspberrypi:~ $ git fetch
fatal: Not a git repository (or any of the parent directories): .git
pi@raspberrypi:~ $ cd supla-scripts
pi@raspberrypi:~/supla-scripts $ git fetch
pi@raspberrypi:~/supla-scripts $ git reset --hard origin/master
error: unable to unlink old 'var/config/config.sample.json': Brak dostępu
fatal: Could not reset index file to revision 'origin/master'.
pi@raspberrypi:~/supla-scripts $ sudo git reset --hard origin/master
HEAD is now at ccf39df Send metrics from thermostats immediately
pi@raspberrypi:~/supla-scripts $ git pull
Already up-to-date.
pi@raspberrypi:~/supla-scripts $ git reset --hard HEAD^
HEAD is now at 027be4e Measure SUPLA API calls
Updating 027be4e..ccf39df
Fast-forward
 backend/app/commands/DispatchThermostatCommand.php | 1 +
 1 file changed, 1 insertion(+)
pi@raspberrypi:~/supla-scripts $ docker/suplascripts.sh restart
Stopping SUPLA Scripts containers
SUPLA Scripts containers has been stopped.
  ___ _   _ ___ _      _
 / __| | | | _ \ |    /_\
 \__ \ |_| |  _/ |__ / _ \
 |___/\___/|_| |____/_/ \_\
 / __| __ _ _(_)_ __| |_ ___
 \__ \/ _| '_| | '_ \  _(_-
 |___/\__|_| |_| .__/\__/__/
               |_| by @fracz
Starting SUPLA Scripts containers
Pulling suplascripts-db (mysql:5.7)...
5.7: Pulling from library/mysql
ERROR: no matching manifest for unknown in the manifest list entries
pi@raspberrypi:~/supla-scripts $ docker/suplascripts.sh start
  ___ _   _ ___ _      _
               |_| by @fracz
Pokaż co daje
git status
git branch
🧩: 🔑cz->b ⛴️+ila
PuteR
lesny8 wrote: Mon May 13, 2019 6:10 pm Pokaż co daje
git status
git branch
pi@raspberrypi:~/supla-scripts $ git status
On branch master
Your branch is up-to-date with 'origin/master'.
nothing to commit, working tree clean
pi@raspberrypi:~/supla-scripts $ git branch
* master
Wygląda dobrze, startuj skrypty...
🧩: 🔑cz->b ⛴️+ila
PuteR
lesny8 wrote: Mon May 13, 2019 6:38 pm Wygląda dobrze, startuj skrypty...
Niestety...
pi@raspberrypi:~ $ supla-scripts/docker/suplascripts.sh start
  ___ _   _ ___ _      _
 \__ \/ _| '_| | '_ \  _(_-<
               |_| by @fracz
pi@raspberrypi:~ $
Problem został rozwiązany.
Błąd manifestu występował z powodu podwójnego wpisu w .env
COMPOSE_FILE=docker-compose.base.yml:docker-compose.proxy.yml:docker-compose.arm32v7.yml
COMPOSE_FILE=docker-compose.base.yml:docker-compose.proxy.yml:docker-compose.local.yml
Prawidłowa postać wpisu dla konfiguracji tej instancji to
COMPOSE_FILE=docker-compose.base.yml:docker-compose.proxy.yml:docker-compose.arm32v7.yml:docker-compose.local.yml
🧩: 🔑cz->b ⛴️+ila
sdsi
Dobry wieczór,
Zakładka Logi straciła logi - strona jest pusta. Kiedyś było. Proszę o sprawdzenie.
Dziękuję i pozdrawiam,
Gucio2607.
Wie ktoś może co oznacza ten błąd przy wywoływaniu linku do sceny publicznej?
Zainstalowane:
akszyn
konto supla mam od niedawna oraz nie mam własnej instancji a gdy daje zaloguj przez cloud supla i autoryzuj i takie coś mi wyskakuje (chrome win 10) svr24
Supla na pokładzie wemosa D1 mini z relay shield (gate Zybiego)z DS18B20 + sonoff basic (domyślny soft) + broadlink RM mini 3 + Philips hue white z bridge v1 + LoraTap (RF 433) z kinetycznym przełącznikiem + ai-speaker Dev1 i Dev3
Return to “SUPLA Scripts”
