]krycha88 wrote: Sat May 21, 2022 3:22 pmPokaż screena z jakimi parametrami i pod jakie adresy wrzucasz pliki.
Wygląda na poprawne. Spróbuj jeszcze wgrać soft za pomocą buildera.
Za pomocą buildera wgrywałem w środę i też nie działało, zaraz spróbuję jeszcze raz.krycha88 wrote: Sun May 22, 2022 6:46 am Wygląda na poprawne. Spróbuj jeszcze wgrać soft za pomocą buildera.
ELF file SHA256: 0000000000000000
Rebooting...
ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 188777542, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1184
load:0x40078000,len:12804
ho 0 tail 12 room 4
load:0x40080400,len:3032
entry 0x400805e4
E (380) cpu_start: Running on single core variant of a chip, but app is built with multi-core support.
E (380) cpu_start: Check that CONFIG_FREERTOS_UNICORE is enabled in menuconfig
abort() was called at PC 0x40082b71 on core 0
Backtrace:0x400835a9:0x3ffe3b800x4008b5e9:0x3ffe3ba0 0x4009070d:0x3ffe3bc0 0x40082b71:0x3ffe3c40 0x400791f2:0x3ffe3c90 |<-CORRUPTED
SPI Speed ustaw na 80MHzstachu1000 wrote: Sun May 22, 2022 9:19 am Wgrałem przez buildera i nie działa, może log z Putty ci coś powie o tym:Code: Select all
ELF file SHA256: 0000000000000000 Rebooting... ets Jul 29 2019 12:21:46 rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) configsip: 188777542, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:1 load:0x3fff0030,len:1184 load:0x40078000,len:12804 ho 0 tail 12 room 4 load:0x40080400,len:3032 entry 0x400805e4 E (380) cpu_start: Running on single core variant of a chip, but app is built with multi-core support. E (380) cpu_start: Check that CONFIG_FREERTOS_UNICORE is enabled in menuconfig abort() was called at PC 0x40082b71 on core 0 Backtrace:0x400835a9:0x3ffe3b800x4008b5e9:0x3ffe3ba0 0x4009070d:0x3ffe3bc0 0x40082b71:0x3ffe3c40 0x400791f2:0x3ffe3c90 |<-CORRUPTED
To samo:
Rebooting...
mode:DOUT, clock div:1
ho 0 tail 12 room 4
entry 0x400805e4
E (386) cpu_start: Running on single core variant of a chip, but app is built with multi-core support.
E (387) cpu_start: Check that CONFIG_FREERTOS_UNICORE is enabled in menuconfig
