Supla Counter reset / settings
Post Reply
Maas
Hello,
I need to reset the Counter for Actual Power . In the cloud i can only find the Value add menue.
Thanks
Jörg
Contact:
You can reset the counter from the device level or from the cloud level if the counter supports this functionality.
Maas
Hello pzygmunt,
That it is what I have expected… but can you tell me also how to do?
Br
Jörg
Contact:
What hardware and firmware do you have there?
Maas
SUPLA version 2.3.47
Zamel MEW–01
EFBB89C7–DFB5–6FC4–86EB–74E4FB8C79FE
ID 591
soft/ Ver 2.8.31
Contact:
In the case of MEW-01, you can only reset all counters. You can do it after switching MEW-01 into configuration mode. After connecting to the WiFi network broadcast by MEW-01, open the website http://192.168.4.1 There, type "RESET" in capital letters in the field "Reset" and save. After doing this, I recommend that you delete your history from cloud.supla.org.
In the newer version of MEW, you will be able to reset the counter from cloud.supla.org
Maas
Great, thanks for quick response
Br
Jörg
Post Reply
Return to “General discussion”
