GUI Generic - Błąd generowania
myszektbg
Sprawdziłem. Działa na Testowej GG v7.13.0. Korekty się przyjęły i są zgodne, chmura z LCD.
Yepestis
Możecie sprawdzić dlaczego nie generuje się soft
https://gui-generic-builder.supla.io/?f ... a210838a4e
Z góry dziękuję :)
ZgredekLCD
Siemka,
Błąd podczas generowania binarki z wykorzystaniem BME280 + Pushover. Ewidentnie nie podoba mu się, że znaleziono 2 biblioteki: SoftwareSerial
In file included from GUI-Generic_bv6.0_gv7.12.08_pl_2b2a3a0fe1483435045d421163af4fd4/SuplaDeviceGUI.h:59,
                 from GUI-Generic_bv6.0_gv7.12.08_pl_2b2a3a0fe1483435045d421163af4fd4/GUIGenericCommon.cpp:18:
GUI-Generic_bv6.0_gv7.12.08_pl_2b2a3a0fe1483435045d421163af4fd4/SuplaConditions.h:114:5: error: 'S_CHANNEL_VALUE' was not declared in this scope
  114 |     S_CHANNEL_VALUE S_SPACE S_ON_LESS,
In file included from GUI-Generic_bv6.0_gv7.12.08_pl_2b2a3a0fe1483435045d421163af4fd4/GUIGenericCommon.h:21,
                 from GUI-Generic_bv6.0_gv7.12.08_pl_2b2a3a0fe1483435045d421163af4fd4/GUIGenericCommon.cpp:17:
GUI-Generic_bv6.0_gv7.12.08_pl_2b2a3a0fe1483435045d421163af4fd4/src/language/common.h:5:17: error: expected '}' before string constant
    5 | #define S_SPACE " "
GUI-Generic_bv6.0_gv7.12.08_pl_2b2a3a0fe1483435045d421163af4fd4/SuplaConditions.h:114:21: note: in expansion of macro 'S_SPACE'
GUI-Generic_bv6.0_gv7.12.08_pl_2b2a3a0fe1483435045d421163af4fd4/SuplaConditions.h:112:49: note: to match this '{'
  112 | const char* const CONDITIONS_TYPE_P[] PROGMEM = {
GUI-Generic_bv6.0_gv7.12.08_pl_2b2a3a0fe1483435045d421163af4fd4/SuplaConditions.h:137:1: error: expected declaration before '}' token
  137 | };
Multiple libraries were found for "SoftwareSerial.h"
  Used: /var/www/html/github/GUI-Generic/lib/EspSoftwareSerial
  Not used: /var/www/html/github/GUI-Generic/lib/EspSoftwareSerial
  Not used: .arduino15/packages/esp8266/hardware/esp8266/3.1.2/libraries/SoftwareSerial
Error during build: exit status 1
xxxxxxxxxxxxxxxxxx
BOARD esp8266:esp8266:generic:eesz=4M1M,xtal=160
BOARD_NAME
TEMPLATE_JSON
JSON_DEFINITION
OPTIONS -DATOMIC_FS_UPDATE -DMIMETYPE_MINIMAL -DBEARSSL_SSL_BASIC -DNDEBUG -DSUPLA_BME280 -DSUPLA_CONFIG -DSUPLA_DEEP_SLEEP -DSUPLA_DISABLE_LOGS
-DSUPLA_ENABLE_GUI -DSUPLA_EXCLUDE_LITTLEFS_CONFIG -DSUPLA_OTA -DSUPLA_PUSHOVER
wojtas567
A odhacz powiadomienia i zobacz?
Zauważyłem że nie generator nie lubi powiadomień :(
kurus
Ewentualnie zaznacz jeszcze warunkowanie jak wybierasz Pushover
A nie łatwiej wygenerować najnowszą wersję? :)
wojtas567
Kompiluje się prawie, bo zginęła opcja "korekta" chyba ze tak miało być.
wojtas567 wrote: Thu Feb 08, 2024 9:45 pm Kompiluje się prawie, bo zginęła opcja "korekta" chyba ze tak miało być.
Korektę teraz ustawia się w cloud a nie na urządzeniu.
ZgredekLCD
wojtas567 wrote: Thu Feb 08, 2024 7:40 pm A odhacz powiadomienia i zobacz?
Tak, bez powiadomień build działa bez zarzutu, już to testowałem :D
wojtas567
Oki :)
Return to “GUI Generic”
