Utworzyłem termostat w nowej usłudze
Nowy plik yaml :
name: Thermostat 4 linux
log_level: debug
state_files_path: "/home/dariusz/Thermostat"
security_level: 2 # disable certyficate verification
supla:
server: beta-cloud.supla.org
mail: dariuszjszymanski@gmail.com
channels:
- type: ThermHygroMeterParsed
source:
type: File
file: "/home/dariusz/MiTemperature2/A4:C1:38:3F:9C:2C.txt"
expiration_time_sec: 120
parser:
type: Simple
refresh_time_ms: 5000
temperature: 0
humidity: 1
multiplier_temp: 1
multiplier_humi: 1
battery_level: 2
# Termostaty
- type: Hvac
cmd_on: "echo 0 > /sys/class/gpio/gpio20/value"
cmd_off: "echo 1 > /sys/class/gpio/gpio20/value"
# cmd_on_secondary:
# cmd_off_secondary:
main_thermometer_channel_no: 0
aux_thermometer_channel_no: 0
default_function: heat
Zauwazłem iż ten "aux_thermometer_channel_no" musi być przypisany bo jeśli jest za remowany / jego brak, to usługa się crashuje
dariusz@attic:~/Thermostat $ sudo systemctl status supla-therm.service
● supla-therm.service - Supla Thermostat
Loaded: loaded (/etc/systemd/system/supla-therm.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Tue 2023-11-21 08:40:05 CET; 3s ago
Process: 27177 ExecStart=/home/dariusz/supla-device/extras/examples/linux/build/supla-device-linux -c /etc/supla-therm.yaml (code=exited, status=1/FAILU>
Main PID: 27177 (code=exited, status=1/FAILURE)
CPU: 51ms
Nov 21 08:40:05 attic supla-device-linux[27177]: INFO[1700552405.1700552405] Read write config: initializing storage from file...
Nov 21 08:40:05 attic supla-device-linux[27177]: INFO[1700552405.1700552405] *** Starting supla-device ***
Nov 21 08:40:05 attic supla-device-linux[27177]: INFO[1700552405.1700552405] Using config file /etc/supla-therm.yaml
Nov 21 08:40:05 attic supla-device-linux[27177]: INFO[1700552405.1700552405] Channel[0] config: adding ThermHygroMeterParsed
Nov 21 08:40:05 attic supla-device-linux[27177]: INFO[1700552405.1700552405] Channel[1] config: adding Hvac
Nov 21 08:40:05 attic supla-device-linux[27177]: ERR[1700552405.1700552405] Channel[1] config: missing mandatory "aux_thermometer_channel_no" parameter
Nov 21 08:40:05 attic supla-device-linux[27177]: ERR[1700552405.1700552405] Config: parsing channel 1 failed
Nov 21 08:40:05 attic supla-device-linux[27177]: ERR[1700552405.1700552405] Loading channels failed. Exit
Nov 21 08:40:05 attic systemd[1]: supla-therm.service: Main process exited, code=exited, status=1/FAILURE
Nov 21 08:40:05 attic systemd[1]: supla-therm.service: Failed with result 'exit-code'.
lines 1-17/17 (END)
W działaniu termostatu na razie bez zmian ale ikonka wskazuje że grzać
Mój GKW ma ID22431 na beta-cloud
