Raspberry pi4 Docker
Poszukaj jakiś błędów w /var/log
Przejrzałem to w miarę dokładnie i w logach nie ma żadnych błędów.
edit.
edit.
Suma-sumaru skończyło się na instalowaniu wszystkiego do nowa, na szczęście po przywróceniu kopi bazy danych wszystko działa
edit.
2024-08-02T20:24:17.975505+02:00 raspberrypi kernel: [ 20.888763] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
2024-08-02T20:24:17.980304+02:00 raspberrypi kernel: [ 20.892693] Bridge firewalling registered
2024-08-02T20:24:18.363450+02:00 raspberrypi kernel: [ 21.276323] Initializing XFRM netlink socket
2024-08-02T20:24:18.412627+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.4072] manager: (br-efd19d1309ee): new Bridge device (/org/freedesktop/NetworkManager/Devices/3)
2024-08-02T20:24:18.587959+02:00 raspberrypi avahi-daemon[516]: Joining mDNS multicast group on interface br-efd19d1309ee.IPv4 with address 172.18.0.1.
2024-08-02T20:24:18.588406+02:00 raspberrypi avahi-daemon[516]: New relevant interface br-efd19d1309ee.IPv4 for mDNS.
2024-08-02T20:24:18.588634+02:00 raspberrypi avahi-daemon[516]: Registering new address record for 172.18.0.1 on br-efd19d1309ee.IPv4.
2024-08-02T20:24:18.599105+02:00 raspberrypi NetworkManager[589]: <warn> [1722623058.5988] device (br-efd19d1309ee): failed to read bridge setting 'vlan_protocol'
2024-08-02T20:24:18.599627+02:00 raspberrypi NetworkManager[589]: <warn> [1722623058.5990] device (br-efd19d1309ee): failed to read bridge setting 'vlan_stats_enabled'
2024-08-02T20:24:18.605228+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.6050] device (br-efd19d1309ee): state change: unmanaged -> unavailable (reason 'connection-assumed', sys-iface-state: 'external')
2024-08-02T20:24:18.610530+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.6103] device (br-efd19d1309ee): state change: unavailable -> disconnected (reason 'connection-assumed', sys-iface-state: 'external')
2024-08-02T20:24:18.619391+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.6191] device (br-efd19d1309ee): Activation: starting connection 'br-efd19d1309ee' (72319318-b144-4991-bf4c-56d450200b8e)
2024-08-02T20:24:18.623922+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.6236] manager: (br-3db68600f72c): new Bridge device (/org/freedesktop/NetworkManager/Devices/4)
2024-08-02T20:24:18.627390+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.6271] device (br-efd19d1309ee): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'external')
2024-08-02T20:24:18.630154+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.6299] device (br-efd19d1309ee): state change: prepare -> config (reason 'none', sys-iface-state: 'external')
2024-08-02T20:24:18.632211+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.6319] device (br-efd19d1309ee): state change: config -> ip-config (reason 'none', sys-iface-state: 'external')
2024-08-02T20:24:18.635743+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.6354] device (br-efd19d1309ee): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'external')
2024-08-02T20:24:18.642857+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.6425] device (br-efd19d1309ee): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'external')
2024-08-02T20:24:18.647554+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.6451] device (br-efd19d1309ee): state change: secondaries -> activated (reason 'none', sys-iface-state: 'external')
2024-08-02T20:24:18.650649+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.6504] device (br-efd19d1309ee): Activation: successful, device activated.
2024-08-02T20:24:18.760762+02:00 raspberrypi avahi-daemon[516]: Joining mDNS multicast group on interface br-3db68600f72c.IPv4 with address 172.19.0.1.
2024-08-02T20:24:18.761093+02:00 raspberrypi avahi-daemon[516]: New relevant interface br-3db68600f72c.IPv4 for mDNS.
2024-08-02T20:24:18.761287+02:00 raspberrypi avahi-daemon[516]: Registering new address record for 172.19.0.1 on br-3db68600f72c.IPv4.
2024-08-02T20:24:18.765861+02:00 raspberrypi NetworkManager[589]: <warn> [1722623058.7656] device (br-3db68600f72c): failed to read bridge setting 'vlan_protocol'
2024-08-02T20:24:18.766318+02:00 raspberrypi NetworkManager[589]: <warn> [1722623058.7658] device (br-3db68600f72c): failed to read bridge setting 'vlan_stats_enabled'
2024-08-02T20:24:18.774398+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.7741] device (br-3db68600f72c): state change: unmanaged -> unavailable (reason 'connection-assumed', sys-iface-state: 'external')
2024-08-02T20:24:18.782456+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.7821] device (br-3db68600f72c): state change: unavailable -> disconnected (reason 'connection-assumed', sys-iface-state: 'external')
2024-08-02T20:24:18.787503+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.7872] device (br-3db68600f72c): Activation: starting connection 'br-3db68600f72c' (7a926f99-1935-4c94-b3a0-ffe6dcd2543c)
2024-08-02T20:24:18.788847+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.7886] device (br-3db68600f72c): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'external')
2024-08-02T20:24:18.791644+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.7914] device (br-3db68600f72c): state change: prepare -> config (reason 'none', sys-iface-state: 'external')
2024-08-02T20:24:18.795563+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.7935] device (br-3db68600f72c): state change: config -> ip-config (reason 'none', sys-iface-state: 'external')
2024-08-02T20:24:18.804201+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.8039] manager: (br-4719a1244efc): new Bridge device (/org/freedesktop/NetworkManager/Devices/5)
2024-08-02T20:24:18.812748+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.8125] device (br-3db68600f72c): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'external')
2024-08-02T20:24:18.819097+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.8188] device (br-3db68600f72c): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'external')
2024-08-02T20:24:18.820920+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.8207] device (br-3db68600f72c): state change: secondaries -> activated (reason 'none', sys-iface-state: 'external')
2024-08-02T20:24:18.825349+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.8251] device (br-3db68600f72c): Activation: successful, device activated.
2024-08-02T20:24:18.942197+02:00 raspberrypi NetworkManager[589]: <warn> [1722623058.9419] device (br-4719a1244efc): failed to read bridge setting 'vlan_protocol'
2024-08-02T20:24:18.942637+02:00 raspberrypi NetworkManager[589]: <warn> [1722623058.9420] device (br-4719a1244efc): failed to read bridge setting 'vlan_stats_enabled'
2024-08-02T20:24:18.946850+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.9466] device (br-4719a1244efc): state change: unmanaged -> unavailable (reason 'connection-assumed', sys-iface-state: 'external')
2024-08-02T20:24:18.949645+02:00 raspberrypi avahi-daemon[516]: Joining mDNS multicast group on interface br-4719a1244efc.IPv4 with address 172.20.0.1.
2024-08-02T20:24:18.949930+02:00 raspberrypi avahi-daemon[516]: New relevant interface br-4719a1244efc.IPv4 for mDNS.
2024-08-02T20:24:18.950074+02:00 raspberrypi avahi-daemon[516]: Registering new address record for 172.20.0.1 on br-4719a1244efc.IPv4.
2024-08-02T20:24:18.952943+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.9525] device (br-4719a1244efc): state change: unavailable -> disconnected (reason 'connection-assumed', sys-iface-state: 'external')
2024-08-02T20:24:18.961992+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.9614] device (br-4719a1244efc): Activation: starting connection 'br-4719a1244efc' (d2b73e6c-2b05-4a1c-9ab7-e7d19766ff45)
2024-08-02T20:24:18.963091+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.9628] device (br-4719a1244efc): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'external')
2024-08-02T20:24:18.974621+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.9680] device (br-4719a1244efc): state change: prepare -> config (reason 'none', sys-iface-state: 'external')
2024-08-02T20:24:18.974999+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.9691] device (br-4719a1244efc): state change: config -> ip-config (reason 'none', sys-iface-state: 'external')
2024-08-02T20:24:18.975235+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.9741] manager: (docker0): new Bridge device (/org/freedesktop/NetworkManager/Devices/6)
2024-08-02T20:24:18.977653+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.9773] device (br-4719a1244efc): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'external')
2024-08-02T20:24:18.984200+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.9839] device (br-4719a1244efc): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'external')
2024-08-02T20:24:18.985845+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.9855] device (br-4719a1244efc): state change: secondaries -> activated (reason 'none', sys-iface-state: 'external')
2024-08-02T20:24:18.989503+02:00 raspberrypi NetworkManager[589]: <info> [1722623058.9892] device (br-4719a1244efc): Activation: successful, device activated.
2024-08-02T20:24:19.134742+02:00 raspberrypi avahi-daemon[516]: Joining mDNS multicast group on interface docker0.IPv4 with address 172.17.0.1.
2024-08-02T20:24:19.135145+02:00 raspberrypi avahi-daemon[516]: New relevant interface docker0.IPv4 for mDNS.
2024-08-02T20:24:19.135389+02:00 raspberrypi avahi-daemon[516]: Registering new address record for 172.17.0.1 on docker0.IPv4.
2024-08-02T20:24:19.142907+02:00 raspberrypi NetworkManager[589]: <warn> [1722623059.1425] device (docker0): failed to read bridge setting 'vlan_protocol'
2024-08-02T20:24:19.143296+02:00 raspberrypi NetworkManager[589]: <warn> [1722623059.1427] device (docker0): failed to read bridge setting 'vlan_stats_enabled'
2024-08-02T20:24:19.147765+02:00 raspberrypi NetworkManager[589]: <info> [1722623059.1473] device (docker0): state change: unmanaged -> unavailable (reason 'connection-assumed', sys-iface-state: 'external')
2024-08-02T20:24:19.150227+02:00 raspberrypi NetworkManager[589]: <info> [1722623059.1499] device (docker0): state change: unavailable -> disconnected (reason 'connection-assumed', sys-iface-state: 'external')
2024-08-02T20:24:19.153398+02:00 raspberrypi NetworkManager[589]: <info> [1722623059.1531] device (docker0): Activation: starting connection 'docker0' (6f727101-b7bb-4992-a03a-284ded93c95c)
2024-08-02T20:24:19.156555+02:00 raspberrypi NetworkManager[589]: <info> [1722623059.1561] manager: (hassio): new Bridge device (/org/freedesktop/NetworkManager/Devices/7)
2024-08-02T20:24:19.158482+02:00 raspberrypi NetworkManager[589]: <info> [1722623059.1581] device (docker0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'external')
2024-08-02T20:24:19.160639+02:00 raspberrypi NetworkManager[589]: <info> [1722623059.1602] device (docker0): state change: prepare -> config (reason 'none', sys-iface-state: 'external')
2024-08-02T20:24:19.161622+02:00 raspberrypi NetworkManager[589]: <info> [1722623059.1612] device (docker0): state change: config -> ip-config (reason 'none', sys-iface-state: 'external')
2024-08-02T20:24:19.162984+02:00 raspberrypi NetworkManager[589]: <info> [1722623059.1627] device (docker0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'external')
2024-08-02T20:24:19.175992+02:00 raspberrypi NetworkManager[589]: <info> [1722623059.1757] device (docker0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'external')
2024-08-02T20:24:19.178773+02:00 raspberrypi NetworkManager[589]: <info> [1722623059.1785] device (docker0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'external')
2024-08-02T20:24:19.184247+02:00 raspberrypi NetworkManager[589]: <info> [1722623059.1840] device (docker0): Activation: successful, device activated.
2024-08-02T20:24:19.306385+02:00 raspberrypi avahi-daemon[516]: Joining mDNS multicast group on interface hassio.IPv4 with address 172.30.32.1.
2024-08-02T20:24:19.306790+02:00 raspberrypi avahi-daemon[516]: New relevant interface hassio.IPv4 for mDNS.
2024-08-02T20:24:19.307055+02:00 raspberrypi avahi-daemon[516]: Registering new address record for 172.30.32.1 on hassio.IPv4.
2024-08-02T20:24:19.310581+02:00 raspberrypi NetworkManager[589]: <warn> [1722623059.3103] device (hassio): failed to read bridge setting 'vlan_protocol'
2024-08-02T20:24:19.310973+02:00 raspberrypi NetworkManager[589]: <warn> [1722623059.3104] device (hassio): failed to read bridge setting 'vlan_stats_enabled'
2024-08-02T20:24:19.315133+02:00 raspberrypi NetworkManager[589]: <info> [1722623059.3149] device (hassio): state change: unmanaged -> unavailable (reason 'connection-assumed', sys-iface-state: 'external')
2024-08-02T20:24:19.320239+02:00 raspberrypi NetworkManager[589]: <info> [1722623059.3198] device (hassio): state change: unavailable -> disconnected (reason 'connection-assumed', sys-iface-state: 'external')
2024-08-02T20:24:19.326280+02:00 raspberrypi NetworkManager[589]: <info> [1722623059.3257] device (hassio): Activation: starting connection 'hassio' (4f03eb0c-5d6d-4aea-a4b2-6a314a04f566)
2024-08-02T20:24:19.326800+02:00 raspberrypi NetworkManager[589]: <info> [1722623059.3266] device (hassio): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'external')
2024-08-02T20:24:19.329674+02:00 raspberrypi NetworkManager[589]: <info> [1722623059.3294] device (hassio): state change: prepare -> config (reason 'none', sys-iface-state: 'external')
2024-08-02T20:24:19.331722+02:00 raspberrypi NetworkManager[589]: <info> [1722623059.3312] device (hassio): state change: config -> ip-config (reason 'none', sys-iface-state: 'external')
2024-08-02T20:24:19.334090+02:00 raspberrypi NetworkManager[589]: <info> [1722623059.3336] device (hassio): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'external')
2024-08-02T20:24:19.342276+02:00 raspberrypi NetworkManager[589]: <info> [1722623059.3420] device (hassio): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'external')
2024-08-02T20:24:19.343182+02:00 raspberrypi NetworkManager[589]: <info> [1722623059.3429] device (hassio): state change: secondaries -> activated (reason 'none', sys-iface-state: 'external')
2024-08-02T20:24:19.345372+02:00 raspberrypi NetworkManager[589]: <info> [1722623059.3451] device (hassio): Activation: successful, device activated.
2024-08-02T20:24:19.708956+02:00 raspberrypi bash[694]: Starting net.fabricmc.loader.impl.game.minecraft.BundlerClassPathCapture
2024-08-02T20:24:19.792660+02:00 raspberrypi dockerd[774]: time="2024-08-02T20:24:19.791632951+02:00" level=error msg="getEndpointFromStore for eid b2946e87975bc1d66f692471147ab4d29fb77cab0e9f2cf56ebbf5e2327cc248 failed while trying to build sandbox for cleanup: could not find endpoint b2946e87975bc1d66f692471147ab4d29fb77cab0e9f2cf56ebbf5e2327cc248: Key not found in store"
2024-08-02T20:24:19.792949+02:00 raspberrypi dockerd[774]: time="2024-08-02T20:24:19.791802433+02:00" level=info msg="Removing stale sandbox 8a575c3df5afb76d987fc307e0f868165799ad36ac5abe31f6afa4917a89d020 (d95ff8915f8438cc36ac509de206487c7f78b6130fcea7e5ac3705cd6ec9d968)"
2024-08-02T20:24:19.793125+02:00 raspberrypi dockerd[774]: time="2024-08-02T20:24:19.792180192+02:00" level=warning msg="Failed deleting endpoint b2946e87975bc1d66f692471147ab4d29fb77cab0e9f2cf56ebbf5e2327cc248: failed to get endpoint from store during Delete: could not find endpoint b2946e87975bc1d66f692471147ab4d29fb77cab0e9f2cf56ebbf5e2327cc248: Key not found in store\n"
2024-08-02T20:24:19.796318+02:00 raspberrypi dockerd[774]: panic: assertion failed: write: circular dependency occurred
2024-08-02T20:24:19.796569+02:00 raspberrypi dockerd[774]: goroutine 1 [running, locked to thread]:
2024-08-02T20:24:19.796963+02:00 raspberrypi dockerd[774]: go.etcd.io/bbolt._assert(...)
2024-08-02T20:24:19.797108+02:00 raspberrypi dockerd[774]: #011/root/build-deb/engine/vendor/go.etcd.io/bbolt/db.go:1387
2024-08-02T20:24:19.797194+02:00 raspberrypi dockerd[774]: go.etcd.io/bbolt.(*node).write(0x4e5e2c0, 0x4e75000)
2024-08-02T20:24:19.797300+02:00 raspberrypi dockerd[774]: #011/root/build-deb/engine/vendor/go.etcd.io/bbolt/node.go:237 +0x31c
2024-08-02T20:24:19.797407+02:00 raspberrypi dockerd[774]: go.etcd.io/bbolt.(*node).spill(0x4e5e2c0)
2024-08-02T20:24:19.797507+02:00 raspberrypi dockerd[774]: #011/root/build-deb/engine/vendor/go.etcd.io/bbolt/node.go:378 +0x2e4
2024-08-02T20:24:19.797594+02:00 raspberrypi dockerd[774]: go.etcd.io/bbolt.(*Bucket).spill(0x4e6e280)
2024-08-02T20:24:19.797697+02:00 raspberrypi dockerd[774]: #011/root/build-deb/engine/vendor/go.etcd.io/bbolt/bucket.go:592 +0x370
2024-08-02T20:24:19.797824+02:00 raspberrypi dockerd[774]: go.etcd.io/bbolt.(*Bucket).spill(0x4e5464c)
2024-08-02T20:24:19.797943+02:00 raspberrypi dockerd[774]: #011/root/build-deb/engine/vendor/go.etcd.io/bbolt/bucket.go:559 +0xe8
2024-08-02T20:24:19.798044+02:00 raspberrypi dockerd[774]: go.etcd.io/bbolt.(*Tx).Commit(0x4e54640)
2024-08-02T20:24:19.798155+02:00 raspberrypi dockerd[774]: #011/root/build-deb/engine/vendor/go.etcd.io/bbolt/tx.go:163 +0x10c
2024-08-02T20:24:19.798236+02:00 raspberrypi dockerd[774]: go.etcd.io/bbolt.(*DB).Update(0x4874f20, 0x4e9ea08)
2024-08-02T20:24:19.798315+02:00 raspberrypi dockerd[774]: #011/root/build-deb/engine/vendor/go.etcd.io/bbolt/db.go:893 +0x100
2024-08-02T20:24:19.798391+02:00 raspberrypi dockerd[774]: github.com/docker/docker/libnetwork/internal/kvstore/boltdb.(*BoltDB).Delete(0x4e04d80, {0x4b00fc0, 0x5d})
2024-08-02T20:24:19.798489+02:00 raspberrypi dockerd[774]: #011/root/build-deb/engine/libnetwork/internal/kvstore/boltdb/boltdb.go:189 +0xc4
2024-08-02T20:24:19.798595+02:00 raspberrypi dockerd[774]: github.com/docker/docker/libnetwork/datastore.(*Store).DeleteObject(0x4e266f0, {0x30fb178, 0x4e5e280})
2024-08-02T20:24:19.798708+02:00 raspberrypi dockerd[774]: #011/root/build-deb/engine/libnetwork/datastore/datastore.go:276 +0xf4
2024-08-02T20:24:19.798794+02:00 raspberrypi dockerd[774]: github.com/docker/docker/libnetwork.(*Sandbox).storeDelete(...)
2024-08-02T20:24:19.799308+02:00 raspberrypi dockerd[774]: #011/root/build-deb/engine/libnetwork/sandbox_store.go:162
2024-08-02T20:24:19.799491+02:00 raspberrypi dockerd[774]: github.com/docker/docker/libnetwork.(*Sandbox).delete(0x4b1e7e0, {0x30f2b54, 0x4dcbb30}, 0x1)
2024-08-02T20:24:19.799582+02:00 raspberrypi dockerd[774]: #011/root/build-deb/engine/libnetwork/sandbox.go:204 +0x738
2024-08-02T20:24:19.799657+02:00 raspberrypi dockerd[774]: github.com/docker/docker/libnetwork.(*Controller).sandboxCleanup(0x4893e00, 0x0)
2024-08-02T20:24:19.799732+02:00 raspberrypi dockerd[774]: #011/root/build-deb/engine/libnetwork/sandbox_store.go:252 +0x858
2024-08-02T20:24:19.799881+02:00 raspberrypi dockerd[774]: github.com/docker/docker/libnetwork.New({0x4727640, 0x9, 0x10})
2024-08-02T20:24:19.799983+02:00 raspberrypi dockerd[774]: #011/root/build-deb/engine/libnetwork/controller.go:159 +0x410
2024-08-02T20:24:19.800072+02:00 raspberrypi dockerd[774]: github.com/docker/docker/daemon.(*Daemon).initNetworkController(0x44e0000, 0x45de2c0, 0x495f060)
2024-08-02T20:24:19.800188+02:00 raspberrypi dockerd[774]: #011/root/build-deb/engine/daemon/daemon_unix.go:843 +0x78
2024-08-02T20:24:19.800273+02:00 raspberrypi dockerd[774]: github.com/docker/docker/daemon.(*Daemon).restore(0x44e0000, 0x45de2c0)
2024-08-02T20:24:19.800351+02:00 raspberrypi dockerd[774]: #011/root/build-deb/engine/daemon/daemon.go:581 +0x654
2024-08-02T20:24:19.800435+02:00 raspberrypi dockerd[774]: github.com/docker/docker/daemon.NewDaemon({0x30f2c78, 0x4514060}, 0x49382c0, 0x45143c0, 0x481b968)
2024-08-02T20:24:19.800515+02:00 raspberrypi dockerd[774]: #011/root/build-deb/engine/daemon/daemon.go:1246 +0x37b8
2024-08-02T20:24:19.800595+02:00 raspberrypi dockerd[774]: main.(*DaemonCli).start(0x4514030, 0x46bb9c0)
2024-08-02T20:24:19.800702+02:00 raspberrypi dockerd[774]: #011/root/build-deb/engine/cmd/dockerd/daemon.go:260 +0xf80
2024-08-02T20:24:19.800779+02:00 raspberrypi dockerd[774]: main.runDaemon(...)
2024-08-02T20:24:19.800854+02:00 raspberrypi dockerd[774]: #011/root/build-deb/engine/cmd/dockerd/docker_unix.go:13
2024-08-02T20:24:19.800958+02:00 raspberrypi dockerd[774]: main.newDaemonCommand.func1(0x4688480, {0x44c0fa8, 0x0, 0x3})
2024-08-02T20:24:19.801057+02:00 raspberrypi dockerd[774]: #011/root/build-deb/engine/cmd/dockerd/docker.go:37 +0xcc
2024-08-02T20:24:19.801141+02:00 raspberrypi dockerd[774]: github.com/spf13/cobra.(*Command).execute(0x4688480, {0x4400148, 0x3, 0x3})
2024-08-02T20:24:19.801265+02:00 raspberrypi dockerd[774]: #011/root/build-deb/engine/vendor/github.com/spf13/cobra/command.go:985 +0xad8
2024-08-02T20:24:19.801351+02:00 raspberrypi dockerd[774]: github.com/spf13/cobra.(*Command).ExecuteC(0x4688480)
2024-08-02T20:24:19.801433+02:00 raspberrypi dockerd[774]: #011/root/build-deb/engine/vendor/github.com/spf13/cobra/command.go:1117 +0x48c
2024-08-02T20:24:19.801539+02:00 raspberrypi dockerd[774]: github.com/spf13/cobra.(*Command).Execute(...)
2024-08-02T20:24:19.801617+02:00 raspberrypi dockerd[774]: #011/root/build-deb/engine/vendor/github.com/spf13/cobra/command.go:1041
2024-08-02T20:24:19.801694+02:00 raspberrypi dockerd[774]: main.main()
2024-08-02T20:24:19.801790+02:00 raspberrypi dockerd[774]: #011/root/build-deb/engine/cmd/dockerd/docker.go:106 +0x20c
2024-08-02T20:24:19.802464+02:00 raspberrypi systemd[1]: run-docker-netns-8a575c3df5af.mount: Deactivated successfully.
2024-08-02T20:24:19.832084+02:00 raspberrypi systemd[1]: docker.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
2024-08-02T20:24:19.832473+02:00 raspberrypi systemd[1]: docker.service: Failed with result 'exit-code'.
2024-08-02T20:24:19.832745+02:00 raspberrypi systemd[1]: Failed to start docker.service - Docker Application Container Engine.
2024-08-02T20:24:19.833040+02:00 raspberrypi systemd[1]: docker.service: Consumed 3.655s CPU time.
2024-08-02T20:24:19.833347+02:00 raspberrypi systemd[1]: Reached target multi-user.target - Multi-User System.
2024-08-02T20:24:19.833643+02:00 raspberrypi systemd[1]: Reached target graphical.target - Graphical Interface.
2024-08-02T20:24:19.885802+02:00 raspberrypi systemd[1]: Starting systemd-update-utmp-runlevel.service - Record Runlevel Change in UTMP...
2024-08-02T20:24:19.911140+02:00 raspberrypi systemd[1]: systemd-update-utmp-runlevel.service: Deactivated successfully.
2024-08-02T20:24:19.914707+02:00 raspberrypi systemd[1]: Finished systemd-update-utmp-runlevel.service - Record Runlevel Change in UTMP.
2024-08-02T20:24:19.916134+02:00 raspberrypi systemd[1]: Startup finished in 2.405s (kernel) + 20.419s (userspace) = 22.824s.
2024-08-02T20:24:21.125070+02:00 raspberrypi systemd[1]: systemd-rfkill.service: Deactivated successfully.
2024-08-02T20:24:21.247320+02:00 raspberrypi bluetoothd[965]: src/adv_monitor.c:btd_adv_monitor_power_down() Unexpected NULL btd_adv_monitor_manager object upon power down
2024-08-02T20:24:21.254775+02:00 raspberrypi bthelper[1740]: Changing power off succeeded
2024-08-02T20:24:21.406197+02:00 raspberrypi bthelper[960]: Changing power on succeeded
2024-08-02T20:24:22.077350+02:00 raspberrypi systemd[1]: docker.service: Scheduled restart job, restart counter is at 1.
2024-08-02T20:24:22.077958+02:00 raspberrypi systemd[1]: Stopped docker.service - Docker Application Container Engine.
2024-08-02T20:24:22.078257+02:00 raspberrypi systemd[1]: docker.service: Consumed 3.655s CPU time.
2024-08-02T20:24:22.128658+02:00 raspberrypi systemd[1]: Starting docker.service - Docker Application Container Engine...
2024-08-02T20:24:22.232087+02:00 raspberrypi dockerd[1742]: time="2024-08-02T20:24:22.231115728+02:00" level=info msg="Starting up"
2024-08-02T20:24:22.278844+02:00 raspberrypi bash[694]: [20:24:22] [main/INFO]: Loading Minecraft 1.20.4 with Fabric Loader 0.15.6
2024-08-02T20:24:22.333235+02:00 raspberrypi dockerd[1742]: time="2024-08-02T20:24:22.332827339+02:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
2024-08-02T20:24:22.549608+02:00 raspberrypi dockerd[1742]: time="2024-08-02T20:24:22.548868524+02:00" level=info msg="Loading containers: start."
2024-08-02T20:24:23.338518+02:00 raspberrypi bash[694]: [20:24:23] [main/INFO]: Loading 58 mods:
2024-08-02T20:24:23.338965+02:00 raspberrypi bash[694]: #011- fabric-api 0.95.4+1.20.4
2024-08-02T20:24:23.339152+02:00 raspberrypi bash[694]: #011 |-- fabric-api-base 0.4.36+78d798af4f
2024-08-02T20:24:23.339271+02:00 raspberrypi bash[694]: #011 |-- fabric-api-lookup-api-v1 1.6.48+82b1bb3e4f
2024-08-02T20:24:23.339433+02:00 raspberrypi bash[694]: #011 |-- fabric-biome-api-v1 13.0.16+78d798af4f
2024-08-02T20:24:23.339580+02:00 raspberrypi bash[694]: #011 |-- fabric-block-api-v1 1.0.16+3e2216cb4f
2024-08-02T20:24:23.339680+02:00 raspberrypi bash[694]: #011 |-- fabric-block-view-api-v2 1.0.4+78d798af4f
2024-08-02T20:24:23.339772+02:00 raspberrypi bash[694]: #011 |-- fabric-blockrenderlayer-v1 1.1.46+78d798af4f
2024-08-02T20:24:23.339863+02:00 raspberrypi bash[694]: #011 |-- fabric-client-tags-api-v1 1.1.7+78d798af4f
2024-08-02T20:24:23.339954+02:00 raspberrypi bash[694]: #011 |-- fabric-command-api-v1 1.2.41+f71b366f4f
2024-08-02T20:24:23.340044+02:00 raspberrypi bash[694]: #011 |-- fabric-command-api-v2 2.2.20+78d798af4f
2024-08-02T20:24:23.340122+02:00 raspberrypi bash[694]: #011 |-- fabric-commands-v0 0.2.58+df3654b34f
2024-08-02T20:24:23.340249+02:00 raspberrypi bash[694]: #011 |-- fabric-containers-v0 0.1.86+df3654b34f
2024-08-02T20:24:23.340341+02:00 raspberrypi bash[694]: #011 |-- fabric-content-registries-v0 5.0.12+78d798af4f
2024-08-02T20:24:23.340430+02:00 raspberrypi bash[694]: #011 |-- fabric-convention-tags-v1 1.5.10+78d798af4f
2024-08-02T20:24:23.340532+02:00 raspberrypi bash[694]: #011 |-- fabric-crash-report-info-v1 0.2.23+78d798af4f
2024-08-02T20:24:23.340613+02:00 raspberrypi bash[694]: #011 |-- fabric-data-attachment-api-v1 1.0.2+25e1b4764f
2024-08-02T20:24:23.340710+02:00 raspberrypi bash[694]: #011 |-- fabric-data-generation-api-v1 13.2.1+5c0133444f
2024-08-02T20:24:23.340785+02:00 raspberrypi bash[694]: #011 |-- fabric-dimensions-v1 2.1.61+78d798af4f
2024-08-02T20:24:23.340870+02:00 raspberrypi bash[694]: #011 |-- fabric-entity-events-v1 1.6.0+44c0f8c64f
2024-08-02T20:24:23.340956+02:00 raspberrypi bash[694]: #011 |-- fabric-events-interaction-v0 0.7.1+389931eb4f
2024-08-02T20:24:23.341042+02:00 raspberrypi bash[694]: #011 |-- fabric-events-lifecycle-v0 0.2.73+df3654b34f
2024-08-02T20:24:23.341153+02:00 raspberrypi bash[694]: #011 |-- fabric-game-rule-api-v1 1.0.46+78d798af4f
2024-08-02T20:24:23.341244+02:00 raspberrypi bash[694]: #011 |-- fabric-item-api-v1 2.2.0+d6f2b0844f
2024-08-02T20:24:23.341323+02:00 raspberrypi bash[694]: #011 |-- fabric-item-group-api-v1 4.0.23+78d798af4f
2024-08-02T20:24:23.341401+02:00 raspberrypi bash[694]: #011 |-- fabric-key-binding-api-v1 1.0.41+78d798af4f
2024-08-02T20:24:23.341494+02:00 raspberrypi bash[694]: #011 |-- fabric-keybindings-v0 0.2.39+df3654b34f
2024-08-02T20:24:23.341569+02:00 raspberrypi bash[694]: #011 |-- fabric-lifecycle-events-v1 2.2.31+eabbae364f
2024-08-02T20:24:23.341642+02:00 raspberrypi bash[694]: #011 |-- fabric-loot-api-v2 2.1.7+78d798af4f
2024-08-02T20:24:23.341757+02:00 raspberrypi bash[694]: #011 |-- fabric-message-api-v1 6.0.5+78d798af4f
2024-08-02T20:24:23.341844+02:00 raspberrypi bash[694]: #011 |-- fabric-mining-level-api-v1 2.1.62+78d798af4f
2024-08-02T20:24:23.341930+02:00 raspberrypi bash[694]: #011 |-- fabric-model-loading-api-v1 1.0.8+78d798af4f
2024-08-02T20:24:23.342014+02:00 raspberrypi bash[694]: #011 |-- fabric-models-v0 0.4.7+9386d8a74f
2024-08-02T20:24:23.342090+02:00 raspberrypi bash[694]: #011 |-- fabric-networking-api-v1 3.1.7+2e5ac5484f
2024-08-02T20:24:23.342185+02:00 raspberrypi bash[694]: #011 |-- fabric-object-builder-api-v1 13.0.11+06274a474f
2024-08-02T20:24:23.342273+02:00 raspberrypi bash[694]: #011 |-- fabric-particles-v1 1.1.7+78d798af4f
2024-08-02T20:24:23.342359+02:00 raspberrypi bash[694]: #011 |-- fabric-recipe-api-v1 2.0.20+78d798af4f
2024-08-02T20:24:23.342433+02:00 raspberrypi bash[694]: #011 |-- fabric-registry-sync-v0 4.0.18+78d798af4f
2024-08-02T20:24:23.342513+02:00 raspberrypi bash[694]: #011 |-- fabric-renderer-api-v1 3.2.4+78d798af4f
2024-08-02T20:24:23.342613+02:00 raspberrypi bash[694]: #011 |-- fabric-renderer-indigo 1.5.4+78d798af4f
2024-08-02T20:24:23.342687+02:00 raspberrypi bash[694]: #011 |-- fabric-renderer-registries-v1 3.2.52+df3654b34f
2024-08-02T20:24:23.342843+02:00 raspberrypi bash[694]: #011 |-- fabric-rendering-data-attachment-v1 0.3.42+73761d2e4f
2024-08-02T20:24:23.342924+02:00 raspberrypi bash[694]: #011 |-- fabric-rendering-fluids-v1 3.0.33+78d798af4f
2024-08-02T20:24:23.343013+02:00 raspberrypi bash[694]: #011 |-- fabric-rendering-v0 1.1.55+df3654b34f
2024-08-02T20:24:23.343099+02:00 raspberrypi bash[694]: #011 |-- fabric-rendering-v1 3.1.0+0d29db764f
2024-08-02T20:24:23.343173+02:00 raspberrypi bash[694]: #011 |-- fabric-resource-conditions-api-v1 2.3.14+78d798af4f
2024-08-02T20:24:23.343258+02:00 raspberrypi bash[694]: #011 |-- fabric-resource-loader-v0 0.11.18+b66dcf784f
2024-08-02T20:24:23.343354+02:00 raspberrypi bash[694]: #011 |-- fabric-screen-api-v1 2.0.17+78d798af4f
2024-08-02T20:24:23.343448+02:00 raspberrypi bash[694]: #011 |-- fabric-screen-handler-api-v1 1.3.55+78d798af4f
2024-08-02T20:24:23.343577+02:00 raspberrypi bash[694]: #011 |-- fabric-sound-api-v1 1.0.17+78d798af4f
2024-08-02T20:24:23.343657+02:00 raspberrypi bash[694]: #011 |-- fabric-transfer-api-v1 4.0.9+e84342304f
2024-08-02T20:24:23.343751+02:00 raspberrypi bash[694]: #011 \-- fabric-transitive-access-wideners-v1 5.0.14+78d798af4f
2024-08-02T20:24:23.343835+02:00 raspberrypi bash[694]: #011- fabricloader 0.15.6
2024-08-02T20:24:23.343906+02:00 raspberrypi bash[694]: #011 \-- mixinextras 0.3.2
2024-08-02T20:24:23.343991+02:00 raspberrypi bash[694]: #011- java 17
2024-08-02T20:24:23.344062+02:00 raspberrypi bash[694]: #011- minecraft 1.20.4
2024-08-02T20:24:23.344133+02:00 raspberrypi bash[694]: #011- minimotd-fabric 2.1.0
2024-08-02T20:24:23.344203+02:00 raspberrypi bash[694]: #011 \-- adventure-platform-fabric 5.11.0-SNAPSHOT
2024-08-02T20:24:23.344275+02:00 raspberrypi bash[694]: #011 |-- net_kyori_adventure-api 4.15.0
2024-08-02T20:24:23.344347+02:00 raspberrypi bash[694]: #011 |-- net_kyori_adventure-key 4.15.0
2024-08-02T20:24:23.344419+02:00 raspberrypi bash[694]: #011 |-- net_kyori_adventure-platform-api 4.3.2
2024-08-02T20:24:23.344518+02:00 raspberrypi bash[694]: #011 |-- net_kyori_adventure-text-logger-slf4j 4.15.0
2024-08-02T20:24:23.344625+02:00 raspberrypi bash[694]: #011 |-- net_kyori_adventure-text-minimessage 4.15.0
2024-08-02T20:24:23.344715+02:00 raspberrypi bash[694]: #011 |-- net_kyori_adventure-text-serializer-ansi 4.15.0
2024-08-02T20:24:23.344812+02:00 raspberrypi bash[694]: #011 |-- net_kyori_adventure-text-serializer-gson 4.15.0
2024-08-02T20:24:23.344890+02:00 raspberrypi bash[694]: #011 |-- net_kyori_adventure-text-serializer-json 4.15.0
2024-08-02T20:24:23.344983+02:00 raspberrypi bash[694]: #011 |-- net_kyori_adventure-text-serializer-plain 4.15.0
2024-08-02T20:24:23.345062+02:00 raspberrypi bash[694]: #011 |-- net_kyori_ansi 1.0.3
2024-08-02T20:24:23.345158+02:00 raspberrypi bash[694]: #011 |-- net_kyori_examination-api 1.3.0
2024-08-02T20:24:23.345238+02:00 raspberrypi bash[694]: #011 |-- net_kyori_examination-string 1.3.0
2024-08-02T20:24:23.345314+02:00 raspberrypi bash[694]: #011 \-- net_kyori_option 1.0.0
2024-08-02T20:24:23.345409+02:00 raspberrypi bash[694]: #011- voicechat 1.20.4-2.5.1
2024-08-02T20:24:23.345488+02:00 raspberrypi bash[694]: #011 \-- fabric-key-binding-api-v1 1.0.39+f4b7e42432
2024-08-02T20:24:23.950692+02:00 raspberrypi bash[694]: [20:24:23] [main/INFO]: SpongePowered MIXIN Subsystem Version=0.8.5 Source=file:/home/pi/minecraft/libraries/net/fabricmc/sponge-mixin/0.12.5+mixin.0.8.5/sponge-mixin-0.12.5+mixin.0.8.5.jar Service=Knot/Fabric Env=SERVER
2024-08-02T20:24:24.453989+02:00 raspberrypi bash[694]: [20:24:24] [main/INFO]: Compatibility level set to JAVA_17
2024-08-02T20:24:24.566849+02:00 raspberrypi dockerd[1742]: time="2024-08-02T20:24:24.564926097+02:00" level=error msg="getEndpointFromStore for eid f7e26092f1274980e7ba766924cc6ae972b5b277cbbc5d3a099e5c7fd8978199 failed while trying to build sandbox for cleanup: could not find endpoint f7e26092f1274980e7ba766924cc6ae972b5b277cbbc5d3a099e5c7fd8978199: Key not found in store"
2024-08-02T20:24:24.567110+02:00 raspberrypi dockerd[1742]: time="2024-08-02T20:24:24.565080819+02:00" level=info msg="Removing stale sandbox 7a58e55c3e495af137749c8bef8c395a1bd92b33c25255d3da260d6af4f0a8da (bc2d97a846c9c1a1832859f56a95bfb3cc923c12f0750acd0b545c3feee70c35)"
2024-08-02T20:24:24.567241+02:00 raspberrypi dockerd[1742]: time="2024-08-02T20:24:24.565375282+02:00" level=warning msg="Failed deleting endpoint f7e26092f1274980e7ba766924cc6ae972b5b277cbbc5d3a099e5c7fd8978199: failed to get endpoint from store during Delete: could not find endpoint f7e26092f1274980e7ba766924cc6ae972b5b277cbbc5d3a099e5c7fd8978199: Key not found in store\n"
2024-08-02T20:24:24.570061+02:00 raspberrypi systemd[1]: run-docker-netns-7a58e55c3e49.mount: Deactivated successfully.
2024-08-02T20:24:24.572662+02:00 raspberrypi dockerd[1742]: time="2024-08-02T20:24:24.572266097+02:00" level=info msg="stopping event stream following graceful shutdown" error="context canceled" module=libcontainerd namespace=plugins.moby
2024-08-02T20:24:24.574105+02:00 raspberrypi dockerd[1742]: time="2024-08-02T20:24:24.573704263+02:00" level=info msg="stopping event stream following graceful shutdown" error="context canceled" module=libcontainerd namespace=moby
2024-08-02T20:24:24.576698+02:00 raspberrypi dockerd[1742]: panic: assertion failed: write: circular dependency occurred
2024-08-02T20:24:24.576974+02:00 raspberrypi dockerd[1742]: goroutine 1 [running, locked to thread]:
2024-08-02T20:24:24.577332+02:00 raspberrypi dockerd[1742]: go.etcd.io/bbolt._assert(...)
2024-08-02T20:24:24.577520+02:00 raspberrypi dockerd[1742]: #011/root/build-deb/engine/vendor/go.etcd.io/bbolt/db.go:1387
2024-08-02T20:24:24.577616+02:00 raspberrypi dockerd[1742]: go.etcd.io/bbolt.(*node).write(0x5135cc0, 0x520f000)
2024-08-02T20:24:24.577739+02:00 raspberrypi dockerd[1742]: #011/root/build-deb/engine/vendor/go.etcd.io/bbolt/node.go:237 +0x31c
2024-08-02T20:24:24.577854+02:00 raspberrypi dockerd[1742]: go.etcd.io/bbolt.(*node).spill(0x5135cc0)
2024-08-02T20:24:24.577965+02:00 raspberrypi dockerd[1742]: #011/root/build-deb/engine/vendor/go.etcd.io/bbolt/node.go:378 +0x2e4
2024-08-02T20:24:24.578073+02:00 raspberrypi dockerd[1742]: go.etcd.io/bbolt.(*Bucket).spill(0x5167c60)
2024-08-02T20:24:24.578179+02:00 raspberrypi dockerd[1742]: #011/root/build-deb/engine/vendor/go.etcd.io/bbolt/bucket.go:592 +0x370
2024-08-02T20:24:24.578278+02:00 raspberrypi dockerd[1742]: go.etcd.io/bbolt.(*Bucket).spill(0x52063cc)
2024-08-02T20:24:24.578388+02:00 raspberrypi dockerd[1742]: #011/root/build-deb/engine/vendor/go.etcd.io/bbolt/bucket.go:559 +0xe8
2024-08-02T20:24:24.578479+02:00 raspberrypi dockerd[1742]: go.etcd.io/bbolt.(*Tx).Commit(0x52063c0)
2024-08-02T20:24:24.578600+02:00 raspberrypi dockerd[1742]: #011/root/build-deb/engine/vendor/go.etcd.io/bbolt/tx.go:163 +0x10c
2024-08-02T20:24:24.578692+02:00 raspberrypi dockerd[1742]: go.etcd.io/bbolt.(*DB).Update(0x51cc160, 0x579ea08)
2024-08-02T20:24:24.578801+02:00 raspberrypi dockerd[1742]: #011/root/build-deb/engine/vendor/go.etcd.io/bbolt/db.go:893 +0x100
2024-08-02T20:24:24.579413+02:00 raspberrypi dockerd[1742]: github.com/docker/docker/libnetwork/internal/kvstore/boltdb.(*BoltDB).Delete(0x5359a10, {0x517cea0, 0x5d})
2024-08-02T20:24:24.579687+02:00 raspberrypi dockerd[1742]: #011/root/build-deb/engine/libnetwork/internal/kvstore/boltdb/boltdb.go:189 +0xc4
2024-08-02T20:24:24.579820+02:00 raspberrypi dockerd[1742]: github.com/docker/docker/libnetwork/datastore.(*Store).DeleteObject(0x50ff410, {0x31c9178, 0x5135c80})
2024-08-02T20:24:24.579949+02:00 raspberrypi dockerd[1742]: #011/root/build-deb/engine/libnetwork/datastore/datastore.go:276 +0xf4
2024-08-02T20:24:24.580039+02:00 raspberrypi dockerd[1742]: github.com/docker/docker/libnetwork.(*Sandbox).storeDelete(...)
2024-08-02T20:24:24.580128+02:00 raspberrypi dockerd[1742]: #011/root/build-deb/engine/libnetwork/sandbox_store.go:162
2024-08-02T20:24:24.580210+02:00 raspberrypi dockerd[1742]: github.com/docker/docker/libnetwork.(*Sandbox).delete(0x4e967e0, {0x31c0b54, 0x51379f8}, 0x1)
2024-08-02T20:24:24.580334+02:00 raspberrypi dockerd[1742]: #011/root/build-deb/engine/libnetwork/sandbox.go:204 +0x738
2024-08-02T20:24:24.580417+02:00 raspberrypi dockerd[1742]: github.com/docker/docker/libnetwork.(*Controller).sandboxCleanup(0x5274700, 0x0)
2024-08-02T20:24:24.580541+02:00 raspberrypi dockerd[1742]: #011/root/build-deb/engine/libnetwork/sandbox_store.go:252 +0x858
2024-08-02T20:24:24.583215+02:00 raspberrypi dockerd[1742]: github.com/docker/docker/libnetwork.New({0x4fb6f40, 0x9, 0x10})
2024-08-02T20:24:24.583380+02:00 raspberrypi dockerd[1742]: #011/root/build-deb/engine/libnetwork/controller.go:159 +0x410
2024-08-02T20:24:24.583507+02:00 raspberrypi dockerd[1742]: github.com/docker/docker/daemon.(*Daemon).initNetworkController(0x51cc000, 0x50a2000, 0x528eb60)
2024-08-02T20:24:24.583613+02:00 raspberrypi dockerd[1742]: #011/root/build-deb/engine/daemon/daemon_unix.go:843 +0x78
2024-08-02T20:24:24.583697+02:00 raspberrypi dockerd[1742]: github.com/docker/docker/daemon.(*Daemon).restore(0x51cc000, 0x50a2000)
2024-08-02T20:24:24.583796+02:00 raspberrypi dockerd[1742]: #011/root/build-deb/engine/daemon/daemon.go:581 +0x654
2024-08-02T20:24:24.583921+02:00 raspberrypi dockerd[1742]: github.com/docker/docker/daemon.NewDaemon({0x31c0c78, 0x50a4840}, 0x4e52580, 0x5186300, 0x4dd8360)
2024-08-02T20:24:24.584035+02:00 raspberrypi dockerd[1742]: #011/root/build-deb/engine/daemon/daemon.go:1246 +0x37b8
2024-08-02T20:24:24.584120+02:00 raspberrypi dockerd[1742]: main.(*DaemonCli).start(0x50a4810, 0x4f79980)
2024-08-02T20:24:24.584225+02:00 raspberrypi dockerd[1742]: #011/root/build-deb/engine/cmd/dockerd/daemon.go:260 +0xf80
2024-08-02T20:24:24.584310+02:00 raspberrypi dockerd[1742]: main.runDaemon(...)
2024-08-02T20:24:24.584389+02:00 raspberrypi dockerd[1742]: #011/root/build-deb/engine/cmd/dockerd/docker_unix.go:13
2024-08-02T20:24:24.584519+02:00 raspberrypi dockerd[1742]: main.newDaemonCommand.func1(0x4e01080, {0x51b7458, 0x0, 0x3})
2024-08-02T20:24:24.584646+02:00 raspberrypi dockerd[1742]: #011/root/build-deb/engine/cmd/dockerd/docker.go:37 +0xcc
2024-08-02T20:24:24.584736+02:00 raspberrypi dockerd[1742]: github.com/spf13/cobra.(*Command).execute(0x4e01080, {0x4d92108, 0x3, 0x3})
2024-08-02T20:24:24.584846+02:00 raspberrypi dockerd[1742]: #011/root/build-deb/engine/vendor/github.com/spf13/cobra/command.go:985 +0xad8
2024-08-02T20:24:24.585064+02:00 raspberrypi dockerd[1742]: github.com/spf13/cobra.(*Command).ExecuteC(0x4e01080)
2024-08-02T20:24:24.585203+02:00 raspberrypi dockerd[1742]: #011/root/build-deb/engine/vendor/github.com/spf13/cobra/command.go:1117 +0x48c
2024-08-02T20:24:24.585307+02:00 raspberrypi dockerd[1742]: github.com/spf13/cobra.(*Command).Execute(...)
2024-08-02T20:24:24.585390+02:00 raspberrypi dockerd[1742]: #011/root/build-deb/engine/vendor/github.com/spf13/cobra/command.go:1041
2024-08-02T20:24:24.585477+02:00 raspberrypi dockerd[1742]: main.main()
2024-08-02T20:24:24.585589+02:00 raspberrypi dockerd[1742]: #011/root/build-deb/engine/cmd/dockerd/docker.go:106 +0x20c
2024-08-02T20:24:24.604879+02:00 raspberrypi systemd[1]: docker.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
2024-08-02T20:24:24.605363+02:00 raspberrypi systemd[1]: docker.service: Failed with result 'exit-code'.
2024-08-02T20:24:24.609369+02:00 raspberrypi systemd[1]: Failed to start docker.service - Docker Application Container Engine.
2024-08-02T20:24:24.609707+02:00 raspberrypi systemd[1]: docker.service: Consumed 2.347s CPU time.
2024-08-02T20:24:25.805556+02:00 raspberrypi systemd[1]: Created slice user-1000.slice - User Slice of UID 1000.
2024-08-02T20:24:25.832713+02:00 raspberrypi systemd[1]: Starting user-runtime-dir@1000.service - User Runtime Directory /run/user/1000...
2024-08-02T20:24:25.900557+02:00 raspberrypi systemd[1]: Finished user-runtime-dir@1000.service - User Runtime Directory /run/user/1000.
2024-08-02T20:24:25.963714+02:00 raspberrypi systemd[1]: Starting user@1000.service - User Manager for UID 1000...
2024-08-02T20:24:26.631941+02:00 raspberrypi systemd[2153]: Queued start job for default target default.target.
2024-08-02T20:24:26.637390+02:00 raspberrypi systemd[2153]: Created slice app.slice - User Application Slice.
2024-08-02T20:24:26.637961+02:00 raspberrypi systemd[2153]: Reached target paths.target - Paths.
2024-08-02T20:24:26.638379+02:00 raspberrypi systemd[2153]: Reached target timers.target - Timers.
2024-08-02T20:24:26.642181+02:00 raspberrypi systemd[2153]: Starting dbus.socket - D-Bus User Message Bus Socket...
2024-08-02T20:24:26.642740+02:00 raspberrypi systemd[2153]: Listening on dirmngr.socket - GnuPG network certificate management daemon.
2024-08-02T20:24:26.643504+02:00 raspberrypi systemd[2153]: Listening on gpg-agent-browser.socket - GnuPG cryptographic agent and passphrase cache (access for web browsers).
2024-08-02T20:24:26.643863+02:00 raspberrypi systemd[2153]: Listening on gpg-agent-extra.socket - GnuPG cryptographic agent and passphrase cache (restricted).
2024-08-02T20:24:26.644269+02:00 raspberrypi systemd[2153]: Listening on gpg-agent-ssh.socket - GnuPG cryptographic agent (ssh-agent emulation).
2024-08-02T20:24:26.645080+02:00 raspberrypi systemd[2153]: Listening on gpg-agent.socket - GnuPG cryptographic agent and passphrase cache.
2024-08-02T20:24:26.645511+02:00 raspberrypi systemd[1]: docker.service: Scheduled restart job, restart counter is at 2.
2024-08-02T20:24:26.646306+02:00 raspberrypi systemd[1]: Stopped docker.service - Docker Application Container Engine.
2024-08-02T20:24:26.646708+02:00 raspberrypi systemd[1]: docker.service: Consumed 2.347s CPU time.
2024-08-02T20:24:26.688071+02:00 raspberrypi systemd[2153]: Listening on dbus.socket - D-Bus User Message Bus Socket.
2024-08-02T20:24:26.688655+02:00 raspberrypi systemd[2153]: Reached target sockets.target - Sockets.
2024-08-02T20:24:26.688968+02:00 raspberrypi systemd[2153]: Reached target basic.target - Basic System.
2024-08-02T20:24:26.689216+02:00 raspberrypi systemd[2153]: Reached target default.target - Main User Target.
2024-08-02T20:24:26.689496+02:00 raspberrypi systemd[2153]: Startup finished in 662ms.
2024-08-02T20:24:26.708646+02:00 raspberrypi systemd[1]: Starting docker.service - Docker Application Container Engine...
2024-08-02T20:24:26.709517+02:00 raspberrypi systemd[1]: Started user@1000.service - User Manager for UID 1000.
2024-08-02T20:24:26.713805+02:00 raspberrypi systemd[1]: Started session-1.scope - Session 1 of User pi.
2024-08-02T20:24:26.902633+02:00 raspberrypi dockerd[2180]: time="2024-08-02T20:24:26.901042410+02:00" level=info msg="Starting up"
2024-08-02T20:24:27.113601+02:00 raspberrypi dockerd[2180]: time="2024-08-02T20:24:27.113220836+02:00" level=info msg="[graphdriver] using prior storage driver: overlay2"
2024-08-02T20:24:27.419216+02:00 raspberrypi dockerd[2180]: time="2024-08-02T20:24:27.417971447+02:00" level=info msg="Loading containers: start."
2024-08-02T20:24:29.441668+02:00 raspberrypi systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
2024-08-02T20:24:30.021781+02:00 raspberrypi bash[694]: [20:24:30] [main/INFO]: Initializing MixinExtras via com.llamalad7.mixinextras.service.MixinExtrasServiceImpl(version=0.3.2).
2024-08-02T20:24:31.460042+02:00 raspberrypi dockerd[2180]: time="2024-08-02T20:24:31.459166852+02:00" level=info msg="Removing stale sandbox ea8cb6693034e7da0f0083601dfd86de27243a2e651fa8354c3a510629a120b8 (895edfa2a1f87ace119213c0de0977d92629a5387ab01781f9eb650bb82d4415)"
2024-08-02T20:24:31.590359+02:00 raspberrypi dockerd[2180]: time="2024-08-02T20:24:31.589945666+02:00" level=info msg="stopping event stream following graceful shutdown" error="context canceled" module=libcontainerd namespace=moby
2024-08-02T20:24:31.590733+02:00 raspberrypi dockerd[2180]: time="2024-08-02T20:24:31.590016278+02:00" level=info msg="stopping event stream following graceful shutdown" error="context canceled" module=libcontainerd namespace=plugins.moby
2024-08-02T20:24:31.593104+02:00 raspberrypi dockerd[2180]: panic: assertion failed: write: circular dependency occurred [recovered]
2024-08-02T20:24:31.593413+02:00 raspberrypi dockerd[2180]: #011panic: assertion failed: write: circular dependency occurred
2024-08-02T20:24:31.593530+02:00 raspberrypi dockerd[2180]: goroutine 1 [running, locked to thread]:
2024-08-02T20:24:31.593676+02:00 raspberrypi dockerd[2180]: go.opentelemetry.io/otel/sdk/trace.(*recordingSpan).End.func1()
2024-08-02T20:24:31.594699+02:00 raspberrypi dockerd[2180]: #011/root/build-deb/engine/vendor/go.opentelemetry.io/otel/sdk/trace/span.go:388 +0x30
2024-08-02T20:24:31.594882+02:00 raspberrypi dockerd[2180]: go.opentelemetry.io/otel/sdk/trace.(*recordingSpan).End(0x6d1a1e0, {0x0, 0x0, 0x0})
2024-08-02T20:24:31.595028+02:00 raspberrypi dockerd[2180]: #011/root/build-deb/engine/vendor/go.opentelemetry.io/otel/sdk/trace/span.go:426 +0x7a4
2024-08-02T20:24:31.595136+02:00 raspberrypi dockerd[2180]: panic({0x2ef2cc8, 0x683e280})
2024-08-02T20:24:31.595242+02:00 raspberrypi dockerd[2180]: #011/usr/local/go/src/runtime/panic.go:914 +0x26c
2024-08-02T20:24:31.595322+02:00 raspberrypi dockerd[2180]: go.etcd.io/bbolt._assert(...)
2024-08-02T20:24:31.597428+02:00 raspberrypi dockerd[2180]: #011/root/build-deb/engine/vendor/go.etcd.io/bbolt/db.go:1387
2024-08-02T20:24:31.597563+02:00 raspberrypi dockerd[2180]: go.etcd.io/bbolt.(*node).write(0x696b340, 0x69f1000)
2024-08-02T20:24:31.597682+02:00 raspberrypi dockerd[2180]: #011/root/build-deb/engine/vendor/go.etcd.io/bbolt/node.go:237 +0x31c
2024-08-02T20:24:31.597779+02:00 raspberrypi dockerd[2180]: go.etcd.io/bbolt.(*node).spill(0x696b340)
2024-08-02T20:24:31.597889+02:00 raspberrypi dockerd[2180]: #011/root/build-deb/engine/vendor/go.etcd.io/bbolt/node.go:378 +0x2e4
2024-08-02T20:24:31.597981+02:00 raspberrypi dockerd[2180]: go.etcd.io/bbolt.(*Bucket).spill(0x6849a60)
2024-08-02T20:24:31.598082+02:00 raspberrypi dockerd[2180]: #011/root/build-deb/engine/vendor/go.etcd.io/bbolt/bucket.go:592 +0x370
2024-08-02T20:24:31.598174+02:00 raspberrypi dockerd[2180]: go.etcd.io/bbolt.(*Bucket).spill(0x6c0ba4c)
2024-08-02T20:24:31.598272+02:00 raspberrypi dockerd[2180]: #011/root/build-deb/engine/vendor/go.etcd.io/bbolt/bucket.go:559 +0xe8
2024-08-02T20:24:31.598351+02:00 raspberrypi dockerd[2180]: go.etcd.io/bbolt.(*Tx).Commit(0x6c0ba40)
2024-08-02T20:24:31.598442+02:00 raspberrypi dockerd[2180]: #011/root/build-deb/engine/vendor/go.etcd.io/bbolt/tx.go:163 +0x10c
2024-08-02T20:24:31.598529+02:00 raspberrypi dockerd[2180]: go.etcd.io/bbolt.(*DB).Update(0x651bce0, 0x6e28700)
2024-08-02T20:24:31.598658+02:00 raspberrypi dockerd[2180]: #011/root/build-deb/engine/vendor/go.etcd.io/bbolt/db.go:893 +0x100
2024-08-02T20:24:31.598742+02:00 raspberrypi dockerd[2180]: github.com/docker/docker/libnetwork/internal/kvstore/boltdb.(*BoltDB).AtomicPut(0x6d89aa0, {0x6790380, 0x65}, {0x69de1c0, 0x1ac, 0x1c0}, 0x68499c0)
2024-08-02T20:24:31.598841+02:00 raspberrypi dockerd[2180]: #011/root/build-deb/engine/libnetwork/internal/kvstore/boltdb/boltdb.go:206 +0x12c
2024-08-02T20:24:31.598975+02:00 raspberrypi dockerd[2180]: github.com/docker/docker/libnetwork/datastore.(*Store).PutObjectAtomic(0x6da4330, {0x32b00d0, 0x69a23c0})
2024-08-02T20:24:31.599097+02:00 raspberrypi dockerd[2180]: #011/root/build-deb/engine/libnetwork/datastore/datastore.go:174 +0x230
2024-08-02T20:24:31.599199+02:00 raspberrypi dockerd[2180]: github.com/docker/docker/libnetwork/drivers/bridge.(*driver).storeUpdate(0x6d9c3c0, {0x32a7b14, 0x4443dd8}, {0x32b00d0, 0x69a23c0})
2024-08-02T20:24:31.599313+02:00 raspberrypi dockerd[2180]: #011/root/build-deb/engine/libnetwork/drivers/bridge/bridge_store.go:111 +0x2ec
2024-08-02T20:24:31.599437+02:00 raspberrypi dockerd[2180]: github.com/docker/docker/libnetwork/drivers/bridge.(*driver).RevokeExternalConnectivity(0x6d9c3c0, {0x6d14f40, 0x40}, {0x6d15b40, 0x40})
2024-08-02T20:24:31.600079+02:00 raspberrypi dockerd[2180]: #011/root/build-deb/engine/libnetwork/drivers/bridge/bridge_linux.go:1484 +0x19c
2024-08-02T20:24:31.600548+02:00 raspberrypi dockerd[2180]: github.com/docker/docker/libnetwork.(*Endpoint).sbLeave(0x6b03600, {0x32a7b54, 0x66fb9b0}, 0x68af440, 0x1)
2024-08-02T20:24:31.601553+02:00 raspberrypi dockerd[2180]: #011/root/build-deb/engine/libnetwork/endpoint.go:753 +0x538
2024-08-02T20:24:31.603086+02:00 raspberrypi dockerd[2180]: github.com/docker/docker/libnetwork.(*Endpoint).Delete(0x6b03550, {0x32a7b54, 0x66fb8f8}, 0x1)
2024-08-02T20:24:31.603692+02:00 raspberrypi dockerd[2180]: #011/root/build-deb/engine/libnetwork/endpoint.go:854 +0x288
2024-08-02T20:24:31.604181+02:00 raspberrypi dockerd[2180]: github.com/docker/docker/libnetwork.(*Sandbox).delete(0x68af440, {0x32a7b54, 0x66fb730}, 0x1)
2024-08-02T20:24:31.604661+02:00 raspberrypi dockerd[2180]: #011/root/build-deb/engine/libnetwork/sandbox.go:179 +0x354
2024-08-02T20:24:31.605078+02:00 raspberrypi dockerd[2180]: github.com/docker/docker/libnetwork.(*Controller).sandboxCleanup(0x6a79800, 0x0)
2024-08-02T20:24:31.605745+02:00 raspberrypi dockerd[2180]: #011/root/build-deb/engine/libnetwork/sandbox_store.go:252 +0x858
2024-08-02T20:24:31.606280+02:00 raspberrypi dockerd[2180]: github.com/docker/docker/libnetwork.New({0x66ceb00, 0x9, 0x10})
2024-08-02T20:24:31.606780+02:00 raspberrypi dockerd[2180]: #011/root/build-deb/engine/libnetwork/controller.go:159 +0x410
2024-08-02T20:24:31.607300+02:00 raspberrypi dockerd[2180]: github.com/docker/docker/daemon.(*Daemon).initNetworkController(0x64282c0, 0x6668b00, 0x6848ca0)
2024-08-02T20:24:31.607870+02:00 raspberrypi dockerd[2180]: #011/root/build-deb/engine/daemon/daemon_unix.go:843 +0x78
2024-08-02T20:24:31.611753+02:00 raspberrypi dockerd[2180]: github.com/docker/docker/daemon.(*Daemon).restore(0x64282c0, 0x6668b00)
2024-08-02T20:24:31.612353+02:00 raspberrypi dockerd[2180]: #011/root/build-deb/engine/daemon/daemon.go:581 +0x654
2024-08-02T20:24:31.613370+02:00 raspberrypi dockerd[2180]: github.com/docker/docker/daemon.NewDaemon({0x32a7c78, 0x648a090}, 0x697c000, 0x6852450, 0x6834090)
2024-08-02T20:24:31.614101+02:00 raspberrypi dockerd[2180]: #011/root/build-deb/engine/daemon/daemon.go:1246 +0x37b8
2024-08-02T20:24:31.614775+02:00 raspberrypi dockerd[2180]: main.(*DaemonCli).start(0x67e20f0, 0x6730380)
2024-08-02T20:24:31.615307+02:00 raspberrypi dockerd[2180]: #011/root/build-deb/engine/cmd/dockerd/daemon.go:260 +0xf80
2024-08-02T20:24:31.615891+02:00 raspberrypi dockerd[2180]: main.runDaemon(...)
2024-08-02T20:24:31.616394+02:00 raspberrypi dockerd[2180]: #011/root/build-deb/engine/cmd/dockerd/docker_unix.go:13
2024-08-02T20:24:31.616824+02:00 raspberrypi dockerd[2180]: main.newDaemonCommand.func1(0x6996000, {0x6882210, 0x0, 0x3})
2024-08-02T20:24:31.617284+02:00 raspberrypi dockerd[2180]: #011/root/build-deb/engine/cmd/dockerd/docker.go:37 +0xcc
2024-08-02T20:24:31.617674+02:00 raspberrypi dockerd[2180]: github.com/spf13/cobra.(*Command).execute(0x6996000, {0x6400168, 0x3, 0x3})
2024-08-02T20:24:31.618110+02:00 raspberrypi dockerd[2180]: #011/root/build-deb/engine/vendor/github.com/spf13/cobra/command.go:985 +0xad8
2024-08-02T20:24:31.618535+02:00 raspberrypi dockerd[2180]: github.com/spf13/cobra.(*Command).ExecuteC(0x6996000)
2024-08-02T20:24:31.619003+02:00 raspberrypi dockerd[2180]: #011/root/build-deb/engine/vendor/github.com/spf13/cobra/command.go:1117 +0x48c
2024-08-02T20:24:31.619508+02:00 raspberrypi dockerd[2180]: github.com/spf13/cobra.(*Command).Execute(...)
2024-08-02T20:24:31.619868+02:00 raspberrypi dockerd[2180]: #011/root/build-deb/engine/vendor/github.com/spf13/cobra/command.go:1041
2024-08-02T20:24:31.620176+02:00 raspberrypi dockerd[2180]: main.main()
2024-08-02T20:24:31.620503+02:00 raspberrypi dockerd[2180]: #011/root/build-deb/engine/cmd/dockerd/docker.go:106 +0x20c
2024-08-02T20:24:31.624403+02:00 raspberrypi systemd[1]: docker.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
2024-08-02T20:24:31.624834+02:00 raspberrypi systemd[1]: docker.service: Failed with result 'exit-code'.
2024-08-02T20:24:31.625095+02:00 raspberrypi systemd[1]: docker.service: Unit process 2491 (docker-proxy) remains running after unit stopped.
2024-08-02T20:24:31.625365+02:00 raspberrypi systemd[1]: Failed to start docker.service - Docker Application Container Engine.
2024-08-02T20:24:31.625688+02:00 raspberrypi systemd[1]: docker.service: Consumed 3.726s CPU time.
2024-08-02T20:24:33.878544+02:00 raspberrypi systemd[1]: docker.service: Scheduled restart job, restart counter is at 3.
2024-08-02T20:24:33.880806+02:00 raspberrypi systemd[1]: Stopped docker.service - Docker Application Container Engine.
2024-08-02T20:24:33.881631+02:00 raspberrypi systemd[1]: docker.service: Consumed 3.727s CPU time.
2024-08-02T20:24:33.882222+02:00 raspberrypi systemd[1]: docker.service: Start request repeated too quickly.
2024-08-02T20:24:33.882800+02:00 raspberrypi systemd[1]: docker.service: Failed with result 'exit-code'.
2024-08-02T20:24:33.883325+02:00 raspberrypi systemd[1]: Failed to start docker.service - Docker Application Container Engine.
2024-08-02T20:24:33.884654+02:00 raspberrypi systemd[1]: docker.socket: Failed with result 'service-start-limit-hit'.
2024-08-02T20:24:36.459511+02:00 raspberrypi systemd[1]: systemd-fsckd.service: Deactivated successfully.
2024-08-02T20:24:52.479416+02:00 raspberrypi systemd-timesyncd[510]: Contacted time server 46.174.178.150:123 (2.debian.pool.ntp.org).
2024-08-02T20:24:52.479883+02:00 raspberrypi systemd-timesyncd[510]: Initial clock synchronization to Fri 2024-08-02 20:24:52.476659 CEST.
Wszyscy mają prawo do szczęścia, ale nie wszyscy mają szczęście do prawa
