Normalnie reaguje na klik, wieloklik i dłuższe przytrzymanie, do tego na obroty prawo, lewo. Taki:
13:29:49.340> ============ After Setup End =============
13:29:54.514> [ 1941][I][ZigbeeCore.cpp:330] esp_zb_app_signal_handler(): Network(0x30f7) is open for 180 seconds
13:29:54.514>
13:30:30.341> [ 42522][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
13:30:30.341>
13:30:30.341> [ 42525][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
13:30:30.341>
13:30:30.866> [ 43056][I][ZigbeeCore.cpp:299] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xbc64)
13:30:30.866>
13:30:30.866> [ 43056][V][ZigbeeCore.cpp:303] esp_zb_app_signal_handler(): Device capabilities: 0x80
13:30:30.866>
13:30:30.993> [ 43176][D][ZigbeeGateway.cpp:128] find_Cb(): Sensor found: short address(0xbc64), endpoint(1)
13:30:30.993>
13:30:31.059> [ 43205][I][ZigbeeGateway.cpp:271] printJoinedDevices(): joined devices:
13:30:31.059>
13:30:31.059> [ 43205][I][ZigbeeGateway.cpp:274] printJoinedDevices(): Device on endpoint 1, short address: 0xbc64
13:30:31.059>
13:30:31.191> [ 43294][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1000) callback
13:30:31.191>
13:30:31.191> [ 43294][V][ZigbeeHandlers.cpp:94] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xbc64) src endpoint(1)
13:30:31.191> to dst endpoint(1) cluster(0x0)
13:30:31.191>
13:30:31.191> [ 43295][V][ZigbeeHandlers.cpp:103] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0
13:30:31.191> x4), type(0x42), value(16)
13:30:31.191>
13:30:31.191> [ 43296][I][ZigbeeEP.cpp:223] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_abrsvsou"
13:30:31.191>
13:30:31.191> [ 43206][I][Z2S_Device_Scanner.ino:88] loop(): manufacturer _TZ3000_abrsvsou
13:30:31.191>
13:30:31.614> [ 43416][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1000) callback
13:30:31.614>
13:30:31.614> [ 43416][V][ZigbeeHandlers.cpp:94] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xbc64) src endpoint(1)
13:30:31.614> to dst endpoint(1) cluster(0x0)
13:30:31.614>
13:30:31.614> [ 43417][V][ZigbeeHandlers.cpp:103] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0
13:30:31.614> x5), type(0x42), value(6)
13:30:31.614>
13:30:31.614> [ 43418][I][ZigbeeEP.cpp:232] zbReadBasicCluster(): Peer Model is "TS004F"
13:30:31.614>
13:30:31.614> [ 43297][I][Z2S_Device_Scanner.ino:89] loop(): model TS004F
13:30:31.614>
13:30:31.614> [ 43419][I][ZigbeeGateway.cpp:207] zbPrintDeviceDiscovery(): short_addr_req 48228
13:30:31.614>
13:30:31.614> [ 43537][I][ZigbeeGateway.cpp:141] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 48228, endpoints count 1
13:30:31.614>
13:30:31.614> [ 43537][I][ZigbeeGateway.cpp:144] Z2S_active_ep_req_cb(): Endpont # 1, id 1
13:30:31.614>
13:30:31.614> [ 43569][I][ZigbeeGateway.cpp:160] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 48228, endpoint # 1
13:30:31.614>
13:30:31.614> [ 43570][I][ZigbeeGateway.cpp:161] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 6, out clusters # 8
13:30:31.614>
13:30:31.614> [ 43571][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 1, id 1
13:30:31.614>
13:30:31.614> [ 43571][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 2, id 3
13:30:31.614>
13:30:31.614> [ 43571][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 3, id 4
13:30:31.614>
13:30:31.614> [ 43572][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 4, id 6
13:30:31.614>
13:30:31.614> [ 43572][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 5, id 4096
13:30:31.614>
13:30:31.614> [ 43573][I][ZigbeeGateway.cpp:165] Z2S_simple_desc_req_cb(): In cluster # 6, id 0
13:30:31.614>
13:30:31.614> [ 43573][I][ZigbeeGateway.cpp:180] Z2S_simple_desc_req_cb(): Out cluster # 1, id 3
13:30:31.614>
13:30:31.614> [ 43574][I][ZigbeeGateway.cpp:180] Z2S_simple_desc_req_cb(): Out cluster # 2, id 4
13:30:31.614>
13:30:31.614> [ 43574][I][ZigbeeGateway.cpp:180] Z2S_simple_desc_req_cb(): Out cluster # 3, id 5
13:30:31.614>
13:30:31.614> [ 43574][I][ZigbeeGateway.cpp:180] Z2S_simple_desc_req_cb(): Out cluster # 4, id 6
13:30:31.614>
13:30:31.614> [ 43575][I][ZigbeeGateway.cpp:180] Z2S_simple_desc_req_cb(): Out cluster # 5, id 8
13:30:31.614>
13:30:31.614> [ 43575][I][ZigbeeGateway.cpp:180] Z2S_simple_desc_req_cb(): Out cluster # 6, id 4096
13:30:31.614>
13:30:31.614> [ 43576][I][ZigbeeGateway.cpp:180] Z2S_simple_desc_req_cb(): Out cluster # 7, id 25
13:30:31.614>
13:30:31.614> [ 43576][I][ZigbeeGateway.cpp:180] Z2S_simple_desc_req_cb(): Out cluster # 8, id 10
13:30:31.614>
13:30:31.614> [ 43696][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
13:30:31.614>
13:30:31.615> [ 43697][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:31.615> ce endpoint 1, source cluster 1, attribute id 0, data type 33
13:30:31.615>
13:30:31.615> [ 43698][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:31.615> (0x1), source cluster (0x1), attribute id (0x0), data type (0x21)
13:30:31.615>
13:30:31.615> [ 43699][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:31.615> ce endpoint 1, source cluster 1, attribute id 32, data type 32
13:30:31.615>
13:30:31.615> [ 43699][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:31.615> (0x1), source cluster (0x1), attribute id (0x20), data type (0x20)
13:30:31.615>
13:30:31.615> [ 43700][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:31.615> ce endpoint 1, source cluster 1, attribute id 33, data type 32
13:30:31.615>
13:30:31.615> [ 43701][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:31.615> (0x1), source cluster (0x1), attribute id (0x21), data type (0x20)
13:30:31.615>
13:30:31.615> [ 43702][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:31.615> ce endpoint 1, source cluster 1, attribute id 65533, data type 33
13:30:31.615>
13:30:31.615> [ 43703][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:31.615> (0x1), source cluster (0x1), attribute id (0xfffd), data type (0x21)
13:30:31.615>
13:30:31.615> [ 43718][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
13:30:31.615>
13:30:31.615> [ 43718][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:31.615> ce endpoint 1, source cluster 3, attribute id 0, data type 33
13:30:31.615>
13:30:31.615> [ 43719][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:31.615> (0x1), source cluster (0x3), attribute id (0x0), data type (0x21)
13:30:31.615>
13:30:31.615> [ 43720][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:31.615> ce endpoint 1, source cluster 3, attribute id 65533, data type 33
13:30:31.615>
13:30:31.615> [ 43721][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:31.615> (0x1), source cluster (0x3), attribute id (0xfffd), data type (0x21)
13:30:31.615>
13:30:31.615> [ 43735][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
13:30:31.615>
13:30:31.615> [ 43736][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:31.615> ce endpoint 1, source cluster 4, attribute id 0, data type 24
13:30:31.615>
13:30:31.615> [ 43737][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:31.615> (0x1), source cluster (0x4), attribute id (0x0), data type (0x18)
13:30:31.615>
13:30:31.615> [ 43738][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:31.615> ce endpoint 1, source cluster 4, attribute id 65533, data type 33
13:30:31.615>
13:30:31.615> [ 43738][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:31.615> (0x1), source cluster (0x4), attribute id (0xfffd), data type (0x21)
13:30:31.615>
13:30:31.615> [ 43752][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
13:30:31.615>
13:30:31.615> [ 43753][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:31.615> ce endpoint 1, source cluster 6, attribute id 32772, data type 48
13:30:31.615>
13:30:31.615> [ 43754][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:31.615> (0x1), source cluster (0x6), attribute id (0x8004), data type (0x30)
13:30:31.615>
13:30:31.615> [ 43768][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
13:30:31.615>
13:30:31.615> [ 43784][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
13:30:31.615>
13:30:31.615> [ 43784][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:31.615> ce endpoint 1, source cluster 0, attribute id 0, data type 32
13:30:31.615>
13:30:31.615> [ 43785][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:31.615> (0x1), source cluster (0x0), attribute id (0x0), data type (0x20)
13:30:31.615>
13:30:31.615> [ 43786][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:31.615> ce endpoint 1, source cluster 0, attribute id 1, data type 32
13:30:31.615>
13:30:31.615> [ 43787][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:31.615> (0x1), source cluster (0x0), attribute id (0x1), data type (0x20)
13:30:31.615>
13:30:31.615> [ 43788][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:31.615> ce endpoint 1, source cluster 0, attribute id 2, data type 32
13:30:31.615>
13:30:31.615> [ 43788][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:31.615> (0x1), source cluster (0x0), attribute id (0x2), data type (0x20)
13:30:31.615>
13:30:31.615> [ 43789][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:31.615> ce endpoint 1, source cluster 0, attribute id 3, data type 32
13:30:31.615>
13:30:31.615> [ 43790][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:31.615> (0x1), source cluster (0x0), attribute id (0x3), data type (0x20)
13:30:31.615>
13:30:31.615> [ 43791][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:31.615> ce endpoint 1, source cluster 0, attribute id 4, data type 66
13:30:31.615>
13:30:31.615> [ 43792][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:31.615> (0x1), source cluster (0x0), attribute id (0x4), data type (0x42)
13:30:31.615>
13:30:31.615> [ 43793][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:31.615> ce endpoint 1, source cluster 0, attribute id 5, data type 66
13:30:31.615>
13:30:31.615> [ 43794][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:31.615> (0x1), source cluster (0x0), attribute id (0x5), data type (0x42)
13:30:31.615>
13:30:31.615> [ 43794][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:31.615> ce endpoint 1, source cluster 0, attribute id 6, data type 66
13:30:31.615>
13:30:31.615> [ 43795][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:31.615> (0x1), source cluster (0x0), attribute id (0x6), data type (0x42)
13:30:31.615>
13:30:31.615> [ 43796][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:31.615> ce endpoint 1, source cluster 0, attribute id 7, data type 48
13:30:31.615>
13:30:31.615> [ 43797][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:31.615> (0x1), source cluster (0x0), attribute id (0x7), data type (0x30)
13:30:31.615>
13:30:31.615> [ 43798][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:31.616> ce endpoint 1, source cluster 0, attribute id 65502, data type 32
13:30:31.616>
13:30:31.616> [ 43799][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:31.616> (0x1), source cluster (0x0), attribute id (0xffde), data type (0x20)
13:30:31.616>
13:30:31.616> [ 43800][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:31.616> ce endpoint 1, source cluster 0, attribute id 65533, data type 33
13:30:31.616>
13:30:31.616> [ 43800][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:31.616> (0x1), source cluster (0x0), attribute id (0xfffd), data type (0x21)
13:30:31.616>
13:30:31.616> [ 43801][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:31.616> ce endpoint 1, source cluster 0, attribute id 65534, data type 48
13:30:31.616>
13:30:31.616> [ 43802][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:31.616> (0x1), source cluster (0x0), attribute id (0xfffe), data type (0x30)
13:30:31.616>
13:30:31.616> [ 43803][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:31.616> ce endpoint 1, source cluster 0, attribute id 65506, data type 32
13:30:31.616>
13:30:31.616> [ 43804][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:31.616> (0x1), source cluster (0x0), attribute id (0xffe2), data type (0x20)
13:30:31.616>
13:30:31.616> [ 43805][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:31.616> ce endpoint 1, source cluster 0, attribute id 65507, data type 72
13:30:31.616>
13:30:31.616> [ 43806][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:31.616> (0x1), source cluster (0x0), attribute id (0xffe3), data type (0x48)
13:30:31.616>
13:30:39.017> [ 43820][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
13:30:39.017>
13:30:39.017> [ 43820][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:39.017> ce endpoint 1, source cluster 3, attribute id 0, data type 33
13:30:39.017>
13:30:39.017> [ 43821][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:39.017> (0x1), source cluster (0x3), attribute id (0x0), data type (0x21)
13:30:39.017>
13:30:39.017> [ 43822][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:39.017> ce endpoint 1, source cluster 3, attribute id 65533, data type 33
13:30:39.017>
13:30:39.017> [ 43823][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:39.017> (0x1), source cluster (0x3), attribute id (0xfffd), data type (0x21)
13:30:39.017>
13:30:39.017> [ 43837][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
13:30:39.017>
13:30:39.017> [ 43838][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:39.017> ce endpoint 1, source cluster 4, attribute id 0, data type 24
13:30:39.017>
13:30:39.017> [ 43838][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:39.017> (0x1), source cluster (0x4), attribute id (0x0), data type (0x18)
13:30:39.017>
13:30:39.017> [ 43839][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:39.017> ce endpoint 1, source cluster 4, attribute id 65533, data type 33
13:30:39.017>
13:30:39.017> [ 43840][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:39.017> (0x1), source cluster (0x4), attribute id (0xfffd), data type (0x21)
13:30:39.017>
13:30:39.017> [ 43854][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
13:30:39.017>
13:30:39.017> [ 43855][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:39.017> ce endpoint 1, source cluster 5, attribute id 65533, data type 33
13:30:39.017>
13:30:39.017> [ 43856][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:39.017> (0x1), source cluster (0x5), attribute id (0xfffd), data type (0x21)
13:30:39.017>
13:30:39.017> [ 43870][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
13:30:39.017>
13:30:39.017> [ 43870][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:39.017> ce endpoint 1, source cluster 6, attribute id 32772, data type 48
13:30:39.017>
13:30:39.017> [ 43871][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:39.017> (0x1), source cluster (0x6), attribute id (0x8004), data type (0x30)
13:30:39.017>
13:30:39.017> [ 43885][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
13:30:39.017>
13:30:39.017> [ 43885][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:39.017> ce endpoint 1, source cluster 8, attribute id 65533, data type 33
13:30:39.017>
13:30:39.017> [ 43886][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:39.017> (0x1), source cluster (0x8), attribute id (0xfffd), data type (0x21)
13:30:39.017>
13:30:39.017> [ 43901][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
13:30:39.017>
13:30:39.017> [ 43916][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
13:30:39.017>
13:30:39.017> [ 43917][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:39.017> ce endpoint 1, source cluster 25, attribute id 0, data type 240
13:30:39.017>
13:30:39.017> [ 43917][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:39.017> (0x1), source cluster (0x19), attribute id (0x0), data type (0xf0)
13:30:39.017>
13:30:39.017> [ 43918][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:39.017> ce endpoint 1, source cluster 25, attribute id 1, data type 35
13:30:39.017>
13:30:39.017> [ 43919][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:39.017> (0x1), source cluster (0x19), attribute id (0x1), data type (0x23)
13:30:39.017>
13:30:39.017> [ 43920][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:39.017> ce endpoint 1, source cluster 25, attribute id 2, data type 35
13:30:39.017>
13:30:39.017> [ 43921][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:39.017> (0x1), source cluster (0x19), attribute id (0x2), data type (0x23)
13:30:39.017>
13:30:39.017> [ 43922][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:39.017> ce endpoint 1, source cluster 25, attribute id 3, data type 33
13:30:39.017>
13:30:39.017> [ 43922][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:39.017> (0x1), source cluster (0x19), attribute id (0x3), data type (0x21)
13:30:39.017>
13:30:39.017> [ 43923][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:39.017> ce endpoint 1, source cluster 25, attribute id 4, data type 35
13:30:39.017>
13:30:39.017> [ 43924][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:39.017> (0x1), source cluster (0x19), attribute id (0x4), data type (0x23)
13:30:39.017>
13:30:39.017> [ 43925][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:39.017> ce endpoint 1, source cluster 25, attribute id 5, data type 33
13:30:39.017>
13:30:39.017> [ 43926][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:39.017> (0x1), source cluster (0x19), attribute id (0x5), data type (0x21)
13:30:39.017>
13:30:39.017> [ 43927][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:39.017> ce endpoint 1, source cluster 25, attribute id 6, data type 48
13:30:39.017>
13:30:39.017> [ 43928][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:39.017> (0x1), source cluster (0x19), attribute id (0x6), data type (0x30)
13:30:39.017>
13:30:39.017> [ 43928][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:39.017> ce endpoint 1, source cluster 25, attribute id 7, data type 33
13:30:39.017>
13:30:39.017> [ 43929][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:39.017> (0x1), source cluster (0x19), attribute id (0x7), data type (0x21)
13:30:39.017>
13:30:39.017> [ 43930][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:39.017> ce endpoint 1, source cluster 25, attribute id 8, data type 33
13:30:39.017>
13:30:39.017> [ 43931][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:39.017> (0x1), source cluster (0x19), attribute id (0x8), data type (0x21)
13:30:39.017>
13:30:39.017> [ 43932][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:39.017> ce endpoint 1, source cluster 25, attribute id 9, data type 33
13:30:39.017>
13:30:39.017> [ 43933][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:39.017> (0x1), source cluster (0x19), attribute id (0x9), data type (0x21)
13:30:39.017>
13:30:39.017> [ 43934][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:39.019> ce endpoint 1, source cluster 25, attribute id 65533, data type 33
13:30:39.019>
13:30:39.019> [ 43934][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:39.019> (0x1), source cluster (0x19), attribute id (0xfffd), data type (0x21)
13:30:39.019>
13:30:39.019> [ 43938][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1004) callback
13:30:39.019>
13:30:39.019> [ 43938][I][ZigbeeHandlers.cpp:197] zb_core_cmd_disc_attr_resp_handler(): Attribute Discovery Message - device address 48228, sour
13:30:39.019> ce endpoint 1, source cluster 10, attribute id 65533, data type 33
13:30:39.019>
13:30:39.019> [ 43939][I][ZigbeeGateway.cpp:358] zbCmdDiscAttrResponse(): Attribute Discovery Message - device address (0xbc64), source endpoint
13:30:39.019> (0x1), source cluster (0xa), attribute id (0xfffd), data type (0x21)
13:30:39.019>
13:30:39.019> [ 44497][V][ZigbeeCore.cpp:343] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
13:30:39.019>
13:30:39.019> [ 44581][I][ZigbeeCore.cpp:330] esp_zb_app_signal_handler(): Network(0x30f7) is open for 180 seconds
I reakcje po sparowaniu (klik, dwuklik, dłuższe przytrzymanie, obrót lewo, obrót prawo - jeśli nic mi się dodatkowo nie kliknęło):
