vajera wrote: Thu Feb 27, 2025 6:04 pm
Znaczy się full disco
Zostały jeszcze jakieś kombinacje do obsłużenia? Dwukliki itp. - możesz podejrzeć w logach czy dana czynność generuje Ikea custom command i czy nie pojawia się komunikat raw command not processed.
W zasadzie jest ok ale pojawił mi się raz taki:
20:39:57.866 -> [8139418][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
20:39:57.911 -> [8139420][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0x8, command id: 1
20:39:57.911 -> [8139421][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
20:39:57.911 -> [8139421][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 0, disable_default_response 1, is_manuf_specific 0
20:39:57.911 -> [8139422][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
20:39:57.911 -> [8139422][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 19 size: 4
20:39:57.911 -> [8139423][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
20:39:57.911 -> [8139423][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0xC3
20:39:57.911 -> [8139424][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
20:39:57.911 -> [8139424][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x296e, 0x296e, 0x0, 0x0
20:39:57.911 -> [8139424][I][z2s_devices_table.cpp:522] Z2S_onCustomCmdReceive(): Z2S_onCustomCmdReceive cluster 0x8, command id 0x1, rssi: -84
20:39:57.911 -> [8139425][I][z2s_devices_table.cpp:65] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0x80:0x4b:0x50:0xff:0xfe:0xed:0xa2:0xda, endpoint 0x1, channel type 0xffffffff
20:39:57.911 -> [8139426][I][z2s_devices_table.cpp:531] Z2S_onCustomCmdReceive(): z2s_devices_table[channel_number_slot].Supla_channel 0x0
20:39:57.911 -> [8139426][I][z2s_devices_table.cpp:469] processIkeaSymfoniskCommands(): IKEA SYMFONISK command: cluster(0x8), command id(0x1),
20:39:57.911 -> [8139427][I][z2s_devices_table.cpp:65] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0x80:0x4b:0x50:0xff:0xfe:0xed:0xa2:0xda, endpoint 0x1, channel type 0x2af8
20:39:57.911 -> Relay[1] toggle (duration 0 ms)
20:39:57.911 -> Relay[1] turn OFF (duration 0 ms)
20:39:57.911 -> Channel(1) value changed to 0
20:39:57.911 -> [8139428][I][Z2S_virtual_relay_scene_switch.cpp:67] turnOff(): Relay[1] turn OFF as following time passed (time 304 ms)
20:39:57.911 -> [8139429][I][ZigbeeHandlers.cpp:80] zb_raw_cmd_handler(): ----------------------------raw command proccessed---------------------------------------------------------------
20:39:57.911 -> Send: [53 55 50 4C 41 17 A8 01 00 00 67 00 00 00 0E 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
20:39:57.911 -> Send: [53 55 50 4C 41 ]
20:39:58.097 -> [8139619][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0x8, command id: 3
20:39:58.097 -> [8139619][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
20:39:58.097 -> [8139620][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 0, disable_default_response 1, is_manuf_specific 0
20:39:58.097 -> [8139620][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
20:39:58.097 -> [8139621][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 15 size: 2
20:39:58.097 -> [8139621][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
20:39:58.097 -> [8139622][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
20:39:58.097 -> [8139622][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x296e, 0x296e, 0x0, 0x0
20:39:58.097 -> [8139623][I][z2s_devices_table.cpp:522] Z2S_onCustomCmdReceive(): Z2S_onCustomCmdReceive cluster 0x8, command id 0x3, rssi: -80
20:39:58.097 -> [8139623][I][z2s_devices_table.cpp:65] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0x80:0x4b:0x50:0xff:0xfe:0xed:0xa2:0xda, endpoint 0x1, channel type 0xffffffff
20:39:58.097 -> [8139624][I][z2s_devices_table.cpp:531] Z2S_onCustomCmdReceive(): z2s_devices_table[channel_number_slot].Supla_channel 0x0
20:39:58.097 -> [8139624][I][z2s_devices_table.cpp:469] processIkeaSymfoniskCommands(): IKEA SYMFONISK command: cluster(0x8), command id(0x3),
20:39:58.097 -> [8139625][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
20:40:00.518 -> Wrote 1 bytes to storage at 16
ok udało się powtórzyć pojawia się przy obrocie w prawo taka sekwencja
