O, to za jakiś czas w końcu zatrybiękkarnas wrote: Sun Jul 28, 2019 11:43 am pewnie informatycy po studiach i z 10 letnią praktyką trybią czemu coś nie działa jak powinno działać.
Raspberry PI - Instalacja dockerowa
Moderator: fracz
Od wczoraj próbuję na nowej malinie postawić suplę, ale pokazuje mi się
a niby wszystko zrobiłem ok. O co chodzi?
./supla-docker/supla.sh: line 33: docker-compose: command not found
docker-compose -v
Faktycznie problem z dockerem - nie było.
pip install --upgrade setuptools
sudo apt-get install libffi-dev
Traceback (most recent call last):
File "/usr/local/bin/docker-compose", line 6, in <module>
from compose.cli.main import main
File "/usr/local/lib/python2.7/dist-packages/compose/cli/main.py", line 17, in <module>
import docker
File "/usr/local/lib/python2.7/dist-packages/docker/__init__.py", line 2, in <module>
from .api import APIClient
File "/usr/local/lib/python2.7/dist-packages/docker/api/__init__.py", line 2, in <module>
from .client import APIClient
File "/usr/local/lib/python2.7/dist-packages/docker/api/client.py", line 10, in <module>
from .build import BuildApiMixin
File "/usr/local/lib/python2.7/dist-packages/docker/api/build.py", line 6, in <module>
from .. import auth
File "/usr/local/lib/python2.7/dist-packages/docker/auth.py", line 9, in <module>
from .utils import config
File "/usr/local/lib/python2.7/dist-packages/docker/utils/__init__.py", line 3, in <module>
from .decorators import check_resource, minimum_version, update_headers
File "/usr/local/lib/python2.7/dist-packages/docker/utils/decorators.py", line 4, in <module>
from . import utils
File "/usr/local/lib/python2.7/dist-packages/docker/utils/utils.py", line 13, in <module>
from .. import tls
File "/usr/local/lib/python2.7/dist-packages/docker/tls.py", line 5, in <module>
from .transport import SSLHTTPAdapter
File "/usr/local/lib/python2.7/dist-packages/docker/transport/__init__.py", line 3, in <module>
from .ssladapter import SSLHTTPAdapter
File "/usr/local/lib/python2.7/dist-packages/docker/transport/ssladapter.py", line 23, in <module>
from backports.ssl_match_hostname import match_hostname
ImportError: No module named ssl_match_hostname
Edit:
Poszło tak
pip uninstall docker
apt install python-docker
u mnie działa ale mam kilka pytań jak:
1. jak zmienić język na polski,
2. jak dopiąć układy do tego serwera
3. jak podpiąć aplikację smartfonową
4. jak wypełnić żółte i zielone zakładki "adres serwera"
chciałbym zrobić serwer lokalny z AP w sieci wewnętrznej.
Dziękuję za świetną instrukcję! To mega przydatny temat.
Główkuję jednak - w jaki sposób uczynić serwer w domu - serwerem, którym mogę sterować będąc poza lokalną siecią?
Na tą chwile poczyniłem następujące kroki:
- DMZ w routerze przekierowane na lokalne ip raspberry
- NO-iP domena do zmiany dynamicznego ip,
co dalej? będę wdzięczny za pomoc.
Musisz przekierować na malinę porty TCP - 80, 443, 2015, 2016
Dokładnie tak jak napisał @Michael. Nie rób DMZ, bo to proszenie się o kłopoty. DMZ-etem otwierasz dostęp do swojej maliny na wszystkich portach.
Cześć, próbuje postawić suple na RPI3B+. Próba instalacji docker-compose kończy się tak...
Wiecie jak sobie z tym poradzić??
UPGRADE:
rozwiązanie...
pi@raspberrypi:~ $ docker-compose -v
File "/usr/local/lib/python2.7/dist-packages/compose/cli/main.py", line 52, in <module>
from .formatter import ConsoleWarningFormatter
File "/usr/local/lib/python2.7/dist-packages/compose/cli/formatter.py", line 15, in <module>
from backports.shutil_get_terminal_size import get_terminal_size
ImportError: No module named shutil_get_terminal_size
pi@raspberrypi:~ $ docker -v
Docker version 19.03.8, build afacb8b
UPGRADE:
rozwiązanie...
sudo apt-get -y install python3-pip
pip3 install docker-compose
Pogodynka >>
Mam pytanie jaką wersję Rosberypi 4 zamówić, zeby postawić sobie swój serwetek do supli ? , czy wersja 2 GB wystarczy czy brać 4Gb ?
