8 buttons and 8 relays in esp with hc595
elmaya
Sun Mar 24, 2019 2:26 pm
selo wrote:
Sun Mar 24, 2019 12:32 am
Thanks for this.
How can i use it for roller shutters?
viewtopic.php?f=24&t=3833&p=38209&hilit=elmaya#p38209
selo
Mon Mar 25, 2019 12:29 am
Thanks for your reply.
I have replaced
  //SuplaDevice.addRelay(101, false);
  //SuplaDevice.addRelay(102, false);
  //SuplaDevice.addRelay(103, false);
  //SuplaDevice.addRelay(104, false);
  //SuplaDevice.addRelay(105, false);
  //SuplaDevice.addRelay(106, false);
  //SuplaDevice.addRelay(107, false);
  //SuplaDevice.addRelay(108, false);
  // CHANNEL8 - Thermometer DS18B20
  memset(btn, 0, sizeof(btn));
  btn[0].pin =5;          // pin gpio buton  0 = no buton
  btn[0].relay_pin =101;  // pin gpio Relay
  btn[0].channel =0;      // channel
  btn[0].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[0].mem =0;
  btn[1].pin =4;          // pin gpio buton  0 = no buton
  btn[1].relay_pin =102;  // pin gpio Relay
  btn[1].channel =1;      // channel
  btn[1].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[1].mem =0;
  btn[2].pin =2;          // pin gpio buton  0 = no buton
  btn[2].relay_pin =103;  // pin gpio Relay
  btn[2].channel =2;      // channel
  btn[2].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[2].mem =0;
  btn[3].pin =14;         // pin gpio buton  0 = no buton
  btn[3].relay_pin =104;  // pin gpio Relay
  btn[3].channel =3;      // channel
  btn[3].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[3].mem =0;
  btn[4].pin =12;         // pin gpio buton  0 = no buton
  btn[4].relay_pin =105;  // pin gpio Relay
  btn[4].channel =4;      // channel
  btn[4].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[4].mem =0;
  btn[5].pin =13;         // pin gpio buton  0 = no buton
  btn[5].relay_pin =106;  // pin gpio Relay
  btn[5].channel =5;      // channel
  btn[5].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[5].mem =0;
  btn[6].pin =3;         // pin gpio buton  0 = no buton
  btn[6].relay_pin =107;    // pin gpio Relay
  btn[6].channel =6;      // channel
  btn[6].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[6].mem =0;
  btn[7].pin =1;          // pin gpio buton  0 = no buton
  btn[7].relay_pin =108;  // pin gpio Relay
  btn[7].channel =7;      // channel
  btn[7].ms =0;           //  if = 0 Bistable -- if > 0 Monostable for X ms
  btn[7].mem =0;
  supla_btn_init();
with
   // CHANNEL0 - TWO RELAYS (Roller shutter operation)
  SuplaDevice.addRollerShutterRelays(101,     // Pin number where the 1st relay is connected
                                     102, false);    // Pin number where the 2nd relay is connected
   SuplaDevice.setRollerShutterButtons(0,    // Channel Number
                                       5,   // Pin where the 1st button is connected
                                       4);  // Pin where the 2nd button is connected
   // CHANNEL1 - TWO RELAYS (Roller shutter operation)
  SuplaDevice.addRollerShutterRelays(103,     // Pin number where the 1st relay is connected
                                     104, false);    // Pin number where the 2nd relay is connected
   SuplaDevice.setRollerShutterButtons(1,    // Channel Number
                                       2,   // Pin where the 1st button is connected
                                       14); // Pin where the 2nd button is connected
      // CHANNEL2 - TWO RELAYS (Roller shutter operation)
  SuplaDevice.addRollerShutterRelays(105,     // Pin number where the 1st relay is connected
                                     106, false);    // Pin number where the 2nd relay is connected
   SuplaDevice.setRollerShutterButtons(2,    // Channel Number
                                       12,   // Pin where the 1st button is connected
                                       13);  // Pin where the 2nd button is connected
      // CHANNEL3 - TWO RELAYS (Roller shutter operation)
  SuplaDevice.addRollerShutterRelays(107,     // Pin number where the 1st relay is connected
                                     108, false);    // Pin number where the 2nd relay is connected
   SuplaDevice.setRollerShutterButtons(3,    // Channel Number
                                       3,   // Pin where the 1st button is connected
                                       1);  // Pin where the 2nd button is connected
It work's perfect from Supla app. But the physical buttons take double time to close and open roller shutters. Have you any idea?
Contact:
Mon Mar 25, 2019 10:04 am
Do not worry about it. This is how it should work when fully closed / opened.
edm
Mon Apr 01, 2019 9:10 pm
elmaya wrote:
Fri Jan 25, 2019 6:53 pm
16 push button, 16 relay
Thank you.
See here, first attempts viewtopic.php?f=6&t=4629
bulek68
Wed Oct 02, 2019 2:22 pm
7x inCan
4x SRW-01
1x SLW-01
1x ROW-02
1x WEMOS Supla Button 8 direct links by Elmaya
1x Yunshan 8xDS+DHT22+TIMER.CWU+OLED by Zybi
1x Sonoff Dual R2 2xGATE+DHT22 by Zybi
1x Sonoff BASIC
2x MELINK
elmaya
Wed Oct 02, 2019 2:36 pm
These modules it's ok?
https://allegro.pl/oferta/74hc595-rejes ... 7594566453
https://allegro.pl/oferta/8-kanalowy-mo ... 8047947761
https://allegro.pl/oferta/wemos-d1-mini ... 7804539515
I need only flash wemos with suitable bin and next connect all?
The relay module is active low.
the outputs will be on when the app shows off.
Better to use relay with active high .
the rest ok ;)
bulek68
Wed Oct 02, 2019 2:59 pm
This will be ok ;)
https://botland.com.pl/en/relays/2357-r ... 41373.html
7x inCan
4x SRW-01
1x SLW-01
1x ROW-02
1x Sonoff BASIC
2x MELINK
elmaya
Wed Oct 02, 2019 3:04 pm
This will be ok ;)
yes
bulek68
Wed Oct 02, 2019 5:19 pm
yes
elmaya thx!
Ps.
I have a question.
Is it possible to combine functionality. It means.... 8x realy and 8 Supla direct link on one WEMOS?
7x inCan
4x SRW-01
1x SLW-01
1x ROW-02
1x Sonoff BASIC
2x MELINK
elmaya
Wed Oct 02, 2019 6:03 pm
yes
elmaya thx!
Ps.
I have a question.
It's not a good idea, it slows down the code a lot.
esp 8266 are very cheap, better a separate one. ;)
Post Reply
