klimasstudio
LINK: https://klimastech.eu.org/supla-docker- ... r-compose/
Mam nadzieję że w miarę wszystko jasno opisałem.
edm
klimasstudio wrote: Tue Dec 27, 2022 10:07 am foto-zajawka-supla-combo.png
Dziękuję. Popraw linka w 1 punkcie dotyczy darmowa-domena-eu-org-w-cloudflare-w-5-krokach
klimasstudio
Dzięki ;) Nie ma to jak double copy paste :D
Mam nadzieję że bardzo to ułatwi instalacje i konfigurację.
krzys4m
Witajcie.
Kolejny upgrade, kolejny problem. Nie wstaje supla-cloud. Pomożecie?
EDIT. Problem rozwiązany. viewtopic.php?p=118100&hilit=mariadb#p118100
CONTAINER ID   IMAGE                        COMMAND                  CREATED          STATUS                             PORTS                                                           NAMES
977e76367dbf   supla/supla-server:arm32v7   "/usr/bin/server-ent…"   27 seconds ago   Up 25 seconds (health: starting)   0.0.0.0:2015-2016->2015-2016/tcp, :::2015-2016->2015-2016/tcp   supla-server
79edd1ab1eb7   supla/supla-cloud:arm32v7    "docker-php-entrypoi…"   29 seconds ago   Restarting (255) 1 second ago        supla-cloud
4737fcffae17   mariadb:10.6.4-focal         "docker-entrypoint.s…"   3 minutes ago    Up 28 seconds                      3306/tcp                                                        supla-db
docker logs --tail=50 supla-cloud
  SQLSTATE[42S21]: Column already exists: 1060 Duplicate column name 'issued_
  with_refresh_token_id'
In PDOConnection.php line 141:
doctrine:migrations:migrate [--write-sql [WRITE-SQL]] [--dry-run] [--query-time] [--allow-no-migration] [--all-or-nothing [ALL-OR-NOTHING]] [--configuration [CONFIGURATION]] [--db-configuration [DB-CONFIGURATION]] [--db DB] [--em EM] [--shard SHARD] [-h|--help] [-q|--quiet] [-v|vv|vvv|--verbose] [-V|--version] [--ansi] [--no-ansi] [-n|--no-interaction] [-e|--env ENV] [--no-debug] [--] <command> [<version>]
Database connection has been established.
                    Application Migrations
Migrating up to 20221219113615 from 20221020225729
  ++ migrating 20221124222346
     -> ALTER TABLE supla_oauth_access_tokens ADD issued_with_refresh_token_id INT DEFAULT NULL
Migration 20221124222346 failed during Execution. Error An exception occurred while executing 'ALTER TABLE supla_oauth_access_tokens ADD issued_with_refresh_token_id INT DEFAULT NULL':
SQLSTATE[42S21]: Column already exists: 1060 Duplicate column name 'issued_with_refresh_token_id'
In AbstractMySQLDriver.php line 84:
In Exception.php line 18:
po przeczytaniu poradnika rozumiem, że ta procedura będzie trwać ok miesiąc? Czy da się coś pominąć a potem podmienić domenę?
I przy okazji .... nawet jak nie rozumiem to lubię wiedzieć co robię przynajmniej w zarysie :) Możesz objaśnić w skrócie co robi cloudflare, clouddns dla zielonego? I druga kwestia sens kontenerów jakoś ogarniam, a co to stack?
Wziąłem udział w Supla Offline Party 2023 ;)
klimasstudio
YoMan wrote: Sat Jan 28, 2023 5:14 pm po przeczytaniu poradnika rozumiem, że ta procedura będzie trwać ok miesiąc? Czy da się coś pominąć a potem podmienić domenę?
Uzyskanie domeny z końcówką .eu.org trwa zazwyczaj do miesiąca nic na to nie poradzisz ale masz za darmo domene.
CloudFlare pozwoli Ci zabezpieczyć swoje domeny/subdomeny i zarządzać strefą DNS swoich domen.
Stack jak wolne tłumaczenie to stos, czyli w jednym stacku wpisujesz konfiguracje np dla serwera www, bazy danych . Możesz też np. uruchomić kilka serwerów jednoczeńie z różnymi portami i parametrami. Uruchamiasz 1 stack a nie kazdy kontener po kolei. Czasem musisz najpierw uruchomić bazę danych a później serwer który z niej korzysta w razie nie wykrycia bazy miałbyś błąd i przerwanie działania. W takim stocie (czyli defakto docker-compose) masz nawet zmienne mówiące ze aplikacja sie dopiero uruchomi jak wystartuje kontener z baza danych.
Można przyjąć ze to co masz w pliku docker-compose.yml mozesz wkleić do stacka w portainerze. Chyba każdemu nowicjuszowi łatwiej kopiuj wklej i widzieć co się dzieje niż na ślepo klepać komendy.
To tak w skrócie. Mam nadzieję że wyjaśniłem w zadowalającym stopniu :D
klimasstudio wrote: Sat Jan 28, 2023 5:34 pm
nie powiem, żebym stał się jakoś dużo mądrzejszy :) ale będę próbował. Dzięki.
Czekam zatem na domenę i wrócę do próby postawienia serwera. Tymczasowo na zwykłym starym lapku w ramach nauki. I tak wychodzi na to, że Plus ma zablokowane porty więc nic nie zdziałam, czekam na światłowód.
Plus ma zablokowane porty, bo oferuje dostęp do Internetu za NAT'em (czyli X użytkowników może być pod jednym, publicznym adresem IP). Jeśli chciałbyś mieć z Plusa pełny dostęp, to musiałbyś wykupić sobie usługę dynamicznego, publicznego adresu IP w cenie 5 zł netto / m-c lub stałego, publicznego adresu IP w cenie 15 zł netto / m-c.
Tak podejrzewałem. Zatem pozostaje poczekać kilka miesięcy na kabel.
klimasstudio
Zawsze można używać supli lokalnie lub... ale to już zaawansowana procedura zestawić tunel np. WireGuard do VPSa z publicznym IP. Łącząc się na adres IP
VPSa, będziemy przekierowywani tunelem do naszej supli za NATem.
Ale to już zbyt skomplikowane aby tak hop siup na szybko tłumaczyć.
