Supla Button 4 direct links
elmaya
Wed Jan 30, 2019 11:00 pm
maffiu wrote:
Wed Jan 30, 2019 9:49 pm
would it be possible to connect a PIR sensor?
yes for active high you can use bistable to toggle state while the sensor is active
what do you have in mind?
maffiu
Thu Jan 31, 2019 6:46 am
thanks, I will check and show results
elmaya
Thu Jan 31, 2019 4:16 pm
direct link Pir
fast Led flash 0.2": WiFi config
slow Led flash 0.8": connecting WiFi
2 short Led flashes: link send successfull
Link 1 - link sent when the sensor is high
Link 2 - link sent when the sensor is low
pinout:
wifi config - D3 - Gpio 0
status Led - D4 - Gpio 2
Sensor Pin - D6 - Gpio12
Initial parameters for "ESP Falsh Download Tool":
CreystalFreq 26M
SPI SPEED 40 MHz
SPI MODE DOUT
BAUDRATE 11520
FLASH SIZE 32Mbit (4MByte)
D_Link_Pir.bin ------------> 0x00000
D_Link_Pir.rar
compiled firmware
(419.3 KiB) Downloaded 84 times
miko1282
Thu Feb 07, 2019 1:18 pm
Why can not I unpack this rar archive? It's empty
elmaya
Thu Feb 07, 2019 7:56 pm
winRar V5??? ;)
miko1282
Thu Feb 07, 2019 9:48 pm
winRar V5??? ;)
Yes, even newer than 5v :/
Jeki87
Fri Feb 08, 2019 9:12 am
hi, whether on wemosa, for example https://botland.com.pl/pl/produkty-wyco ... duino.html, will it work soft Direct link 6?
or it must be a pro version
elmaya
Sun Feb 10, 2019 12:18 am
it will work
miko1282
Sun Feb 10, 2019 3:39 pm
Hi, why configuration are not the saved after unplugging the power and connecting them?
elmaya
Sun Feb 10, 2019 3:53 pm
:D
which software,which esp,arduino or Bin?
Post Reply
