po wcześniejszych problemach z kopmilacją kodu teraz kolejne godziny walki. Po wgraniu kodu do ESP w monitorze mam takie oto cuś:
09:20:36.967 ->
09:20:36.967 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
09:20:36.967 ->
09:20:36.967 -> Soft WDT reset
09:20:36.967 ->
09:20:36.967 -> >>>stack>>>
09:20:36.967 ->
09:20:36.967 -> ctx: cont
09:20:36.967 -> sp: 3ffffdd0 end: 3fffffc0 offset: 01a0
09:20:36.967 -> 3fffff70: 3fffdad0 3ffef990 00000064 402015f0
09:20:36.967 -> 3fffff80: 0001c200 0000001c 00000000 3ffefb38
09:20:36.967 -> 3fffff90: 3fffdad0 3ffeeac8 3ffef9e4 4020167c
09:20:36.967 -> 3fffffa0: feefeffe 00000000 3ffefb24 40208e0c
09:20:36.967 -> 3fffffb0: feefeffe feefeffe 3ffe862c 40100d41
09:20:36.967 -> <<<stack<<<
09:20:36.967 ->
09:20:36.967 ->
09:20:36.967 -> ets Jan 8 2013,rst cause:2, boot mode:(3,7)
09:20:36.967 ->
09:20:36.967 -> load 0x4010f000, len 3460, room 16
09:20:36.967 -> tail 4
09:20:36.967 -> chksum 0xcc
09:20:36.967 -> load 0x3fff20b8, len 40, room 4
09:20:36.967 -> chksum 0xc9
09:20:36.967 -> csum 0xc9
09:20:36.967 -> v00062bd0
09:20:36.967 -> ~ld
09:20:37.058 ->
09:20:40.279 ->
09:20:40.279 -> --------------- CUT HERE FOR EXCEPTION DECODER ---------------
09:20:40.279 ->
09:20:40.279 -> Soft WDT reset
09:20:40.279 ->
09:20:40.279 -> >>>stack>>>
....... i tak w koło
Czy ktoś ma może jakiś pomysł co jest nie tak?
Dodam, że uzupełniłem kod o te informacje:
Supla::ESPWifi wifi("ssid", "password");
//************************SUPLA SETUP*****************************
char GUID[SUPLA_GUID_SIZE] = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
char AUTHKEY[SUPLA_AUTHKEY_SIZE] = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
const char* SERVER_SUPLA = "svrX.supla.org";
const char* Email_adres = "twoj_adres_email";
//*****************AIRLY SETUP******************************
String lat = "50.XXXXXX"; //Swoją lokalizację można pobrać z https://mapy.google.pl klikajac na swoj dom. Na dole ekranu pojawią się współrzędne
String lon = "17.XXXXXX";
String distance = "2.0"; //Określamy promień od naszej lokalizacji, gdzie AIRLY będzie szukać najbliższego nam czujnika
String apiKey = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"; //https://developer.airly.eu/api
Czy jeszcze coś mam uzupełnić?
