Start z arduino i ESP8266
lukfud
radzik_r wrote: Mon Nov 02, 2020 8:27 pm Co to jest to:
#include <io.h>
https://github.com/klew/arduino/blob/ma ... supla/io.h
Zaktualizuj bibliotekę ;)
elmaya
Updated example.
the supla dev library has changed a lot in these months.
#include <SPI.h>
#include <SuplaDevice.h>
#include <supla/io.h>
#include <Adafruit_MCP23017.h>
// Choose proper network interface for your card:
// Arduino Mega with EthernetShield W5100:
// #include <supla/network/ethernet_shield.h>
// Ethernet MAC address
// uint8_t mac[6] = {0x00, 0x01, 0x02, 0x03, 0x04, 0x05};
// Supla::EthernetShield ethernet(mac);
// Arduino Mega with ENC28J60:
// #include <supla/network/ENC28J60.h>
// Supla::ENC28J60 ethernet(mac);
// ESP8266 based board:
Supla::ESPWifi wifi("your_wifi_ssid", "your_wifi_password");
// ESP32 based board:
// #include <supla/network/esp32_wifi.h>
// Supla::ESP32Wifi wifi("your_wifi_ssid", "your_wifi_password");
Adafruit_MCP23017 mcp;
class MyMcp23017 : public Supla::Io {
  public:
    void customDigitalWrite(int channelNumber, uint8_t pin, uint8_t val) {
      if ((pin >= 100)&& (pin <= 115)){
        mcp.digitalWrite(pin - 100, val);
         return;
      if (pin <= 99) {
        return ::digitalWrite(pin,val);
   int customDigitalRead(int channelNumber, uint8_t pin) {
        return mcp.digitalRead(pin - 100);
      if (pin <= 99){
        return ::digitalRead(pin);
}MyMcp23017;
void setup() {
  Serial.begin(115200);
   mcp.begin();
  mcp.pinMode(0, OUTPUT);
  mcp.pinMode(1, OUTPUT);
  mcp.pinMode(2, OUTPUT);
  mcp.pinMode(3, OUTPUT);
  mcp.pinMode(4, OUTPUT);
  mcp.pinMode(5, OUTPUT);
  mcp.pinMode(6, OUTPUT);
  mcp.pinMode(7, OUTPUT);
  mcp.pinMode(8, OUTPUT);
  mcp.pinMode(9, OUTPUT);
  mcp.pinMode(10, OUTPUT);
  mcp.pinMode(11, OUTPUT);
  mcp.pinMode(12, OUTPUT);
  mcp.pinMode(13, OUTPUT);
  mcp.pinMode(14, OUTPUT);
  mcp.pinMode(15, OUTPUT);
  char GUID[SUPLA_GUID_SIZE] = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
  char AUTHKEY[SUPLA_AUTHKEY_SIZE] = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
    new Supla::Control::Relay(100, true);     // A0 //
    new Supla::Control::Relay(101, true);     // A1 //
    new Supla::Control::Relay(102, true);     // A2 //
    new Supla::Control::Relay(103, true);     // A3 //
    new Supla::Control::Relay(104, true);     // A4 //
    new Supla::Control::Relay(105, true);     // A5 //
    new Supla::Control::Relay(106, true);     // A6 //
    new Supla::Control::Relay(107, true);     // A7 //
    new Supla::Control::Relay(108, true);     // B0 //
    new Supla::Control::Relay(109, true);     // B1 //
    new Supla::Control::Relay(110, true);     // B2 //
    new Supla::Control::Relay(111, true);     // B3 //
    new Supla::Control::Relay(112, true);     // B4 //
    new Supla::Control::Relay(113, true);     // B5 //
    new Supla::Control::Relay(114, true);     // B6 //
    new Supla::Control::Relay(115, true);     // B7 //
   * SuplaDevice Initialization.
   * Server address, LocationID and LocationPassword are available at https://cloud.supla.org
                    "svr1.supla.org",  // SUPLA server address
                    "email@address",   // Email address used to login to Supla Cloud
                    AUTHKEY);          // Authorization key
void loop() {
  SuplaDevice.iterate();
  delay(15);
radzik_r
Cool.
These are the changes that I was struggling with today, and eventually I came to it myself.
I also added a second MCP as buttons. I don't know if I made it right but it works.
of course with replacing button.h from elmaya
Adafruit_MCP23017 mcp2;
  public:
      if ((pin >= 100) && (pin <= 115)) {
               return;
      if (pin <= 99) {
        return ::digitalWrite(pin, val);  // ------------------------------ so that the other channels work normally
      if (pin <= 99) {
        return ::digitalRead(pin);  // ------------------------------ so that the other channels work normally
      if ((pin >= 200) && (pin <= 215)) {
        return mcp2.digitalRead(pin - 200);
} MyMcp23017;
  auto r1 = new Supla::Control::Relay(100);
  auto b1 = new Supla::Control::Button(200);//, true, true); // przycisk na pin3, z input pullup i odwróconą logiką (zwieranie do gnd)
  b1->addAction(Supla::TOGGLE , r1, Supla::ON_PRESS);
elmaya
I guess you also added the initialization of the second Mcp23017 in setup
  mcp2.begin(1);
  mcp2.pinMode(0, INPUT);  mcp2.pullUp(0, HIGH);  // turn on a 100K pullup internally
  mcp2.pinMode(1, INPUT);  mcp2.pullUp(1, HIGH);  // turn on a 100K pullup internally
  mcp2.pinMode(2, INPUT);  mcp2.pullUp(2, HIGH);  // turn on a 100K pullup internally
  mcp2.pinMode(3, INPUT);  mcp2.pullUp(3, HIGH);  // turn on a 100K pullup internally
  mcp2.pinMode(4, INPUT);  mcp2.pullUp(4, HIGH);  // turn on a 100K pullup internally
  mcp2.pinMode(5, INPUT);  mcp2.pullUp(5, HIGH);  // turn on a 100K pullup internally
  mcp2.pinMode(6, INPUT);  mcp2.pullUp(6, HIGH);  // turn on a 100K pullup internally
  mcp2.pinMode(7, INPUT);  mcp2.pullUp(7, HIGH);  // turn on a 100K pullup internally
  mcp2.pinMode(8, INPUT);  mcp2.pullUp(8, HIGH);  // turn on a 100K pullup internally
  mcp2.pinMode(9, INPUT);  mcp2.pullUp(9, HIGH);  // turn on a 100K pullup internally
  mcp2.pinMode(10, INPUT);  mcp2.pullUp(10, HIGH);  // turn on a 100K pullup internally
  mcp2.pinMode(11, INPUT);  mcp2.pullUp(11, HIGH);  // turn on a 100K pullup internally
  mcp2.pinMode(12, INPUT);  mcp2.pullUp(12, HIGH);  // turn on a 100K pullup internally
  mcp2.pinMode(13, INPUT);  mcp2.pullUp(13, HIGH);  // turn on a 100K pullup internally
  mcp2.pinMode(14, INPUT);  mcp2.pullUp(14, HIGH);  // turn on a 100K pullup internally
  mcp2.pinMode(15, INPUT);  mcp2.pullUp(15, HIGH);  // turn on a 100K pullup internally
radzik_r
Yes of course
my design ideas have too little gpio in esp so mcp is a lifesaver
I used for
for (int i = 0; i <= 15; i++) {
    mcp2.pinMode(i, INPUT);  mcp2.pullUp(i, HIGH);  // turn on a 100K pullup internally
Moezzz
radzik_r wrote: Tue Nov 03, 2020 6:36 pm Cool.
  public:
               return;
      if (pin <= 99) {
      if (pin <= 99) {
} MyMcp23017;
Dobry wieczór
Nie rozumiem, jak wskazałeś adresy I2C dwóch mcps. proszę wyjaśnić tę kwestię
michcio667
Moezzz wrote: Thu Jan 21, 2021 7:48 pm
  public:
               return;
      if (pin <= 99) {
      if (pin <= 99) {
} MyMcp23017;
Dobry wieczór
Cześć.
W funkcji mcp.begin(); użyty jest adres 0x20. A w deklaracji mcp.begin(1); użyty jest adres 0x21. A fizycznie o ile się nie mylę to wejścia w układzie MCP a0,a1,a2 powinny być połączone do gnd do expandera pierwszego. A dla drugiego expandera a0 podajemy logiczną 1(+5v) i a1 oraz a2 do gnd. I tak kolejny expander jak deklarujemy to musimy zmienić adres fizyczny za pomocą wejść w układzie a0-a2. Oraz deklaracje w programie.
jaku2k
gdzie ustawia się piny, do których podpięty jest MCP?
Jakub
radzik_r
jaku2k wrote: Tue Jul 13, 2021 1:41 pm
nigdzie się nie ustawia.
MCP23017 podłącza się do wemosa poprzez I2C.
D1(gpio5) SCL
D2(gpio4) SDA
elmaya
radzik_r wrote: Tue Jul 13, 2021 2:43 pm
D1(gpio5) SCL
D2(gpio4) SDA
@radzik_r are you sure about that?
in your 12 blind code you have this in "setup" before "mcp1.begin":
mcp1.init(4, 5); // init(uint8_t sda, uint8_t scl, bool fast)  =  Wire.begin
Return to “Arduino IDE”
