Sonoff Pow R2 Arduino
elmaya wrote: Sun Feb 21, 2021 11:27 am @Robert Błaszczak could you add what reading is the A0 if there is no button pressed?
3.3V (I replaced the picture).
elmaya wrote: Sun Feb 21, 2021 11:27 am in Gpio4 is it in low state while the overload lasts or does USB power turn off?
Yes, USB power is turning off. One could use, for example, Pushower to send a message.
elmaya wrote: Sun Feb 21, 2021 11:27 am on buttons 1-3 are there LEDs that indicate the status?
Yes, 3 LEDs on the buttons and a fourth one above the USB. All LEDs are controlled together with relays.
elmaya
OK so:
The white led should be on if any of the 4 channels is on, off if none of the 4 channels is on and flashing if it detects USB overload.
Pushower we'll see. ;)
I am making some changes in the code and I also want to add the possibility of setting the consumed energy from WiFiConfig in Wh.
I'll contact you as soon as I have something to test "possibly this afternoon"
How have you measured the voltage in A0?
normally the limit is 1.1v is there a resistive divider?
in your list Gpio 16 should be INPUT
elmaya wrote: Sun Feb 21, 2021 12:20 pm OK so:
Yes, exactly.
elmaya wrote: Sun Feb 21, 2021 12:20 pm Pushower we'll see. ;)
If it succeeds, it will be fun :)
elmaya wrote: Sun Feb 21, 2021 12:20 pm I am making some changes in the code and I also want to add the possibility of setting the consumed energy from WiFiConfig in Wh.
Ok.
elmaya wrote: Sun Feb 21, 2021 12:20 pm How have you measured the voltage in A0?
I measured the voltage on the pin of the entire module (photo below).
elmaya wrote: Sun Feb 21, 2021 12:20 pm in your list Gpio 16 should be INPUT
Fact, my mistake :)
W temacie listwy Gosund P1 założyłem nowy wątek: viewtopic.php?f=27&t=8122
lukfud
Zauważyłem, że w aplikacji na telefonie wartości A, W, var, VA i φ pokazują się po kilku sek. na chwilę, po czym zerują i znów pokazują po kilku sek. na chwilę.
Też tak macie na tej kompilacji?
- edycja -
@elmaya podpowiedział, że poniżej 10W mogą powstawać takie anomalie, a testowałem na żarówce 3,6W.
Na 16W wentylatorze odczyty są ciągłe.
Jacaxx1
Witam między wgrałem soft zrobiłem kalibrację i nic się nie dzieje brak odczytów w czym szukać problemu?Image
Simono
Koledzy ja mam taki problem, że daję clear counter ponieważ przełożyłem licznik do pomiaru innego odbiornika i licznik na urządzeniu się nie zeruje. W chmurze i aplikacji cały czas widzę parę tysięcy kwh.
Jak rozwiązać ten problem?
iM@rek
Simono wrote: Fri Nov 04, 2022 3:51 pm Koledzy ja mam taki problem, że daję clear counter ponieważ przełożyłem licznik do pomiaru innego odbiornika i licznik na urządzeniu się nie zeruje. W chmurze i aplikacji cały czas widzę parę tysięcy kwh.
O ile jeszcze aktualne:
Spróbuj:
viewtopic.php?p=109075#p109075
u mnie zadziałało
Alpines
Mam prośbę - z czeluści szuflady wygrzebałem coś takiego :
Na pokładzie jest sonoff powr2
GIU generatorem przygotowałem sobie wkład do niego - niestety prócz przełącznika on off - nie chce wystartować licznik energii - czy ktoś z naszych szanownych kolegów ma może jakiś sprawdzony soft który mogę tam wgrać?
Próbowałem ten z wątku
viewtopic.php?t=7717
Niestety licznik również nie odpala
djack2017
Return to “Sonoff POW”
