Licznik wody MBUS
rafalekkalwak@wp.pl
shimano73 wrote: Tue Aug 29, 2023 10:17 am
rafalekkalwak@wp.pl wrote: Tue Aug 29, 2023 10:06 am Można ale po co się męczyć :D Otwórz plik *.ino przez Arduino IDE
BTW czekam na ramkę, żeby sprawdzić ale wrzucę dziś poprawkę żeby można było liczniki rozróżnić.
Dlatego pytam żeby się nie męczyć poznając nowe , ja mam już swoje lata i drugie patrzałki :lol:
Akurat też byłem sceptycznie nastawiony do PlatformIO ale to jest jak jazda Mercedesem zamiast Maluchem :P
rafalekkalwak@wp.pl
Lector wrote: Mon Aug 28, 2023 8:22 pm Pojawił mi się licznik w cloud.
Na terminalu wali:
Connected to Supla Server
Current status: [10] Register in progress
Send: [53 55 50 4C 41 14 01 00 00 00 45 00 00 00 61 02 00 00 6C 65 63 74 6F 72 40 6F 6E 65 74 2E 65 75 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C2 F3 33 AE 8E B6 44 1E EE 9B D6 BC 08 DD D0 DF CD 1A 26 1A 92 4C 51 5A 1D 6A 63 39 06 1F F6 64 53 55 50 4C 41 2D 45 53 50 33 32 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
Send: [53 55 50 4C 41 ]
Recv: [53 55 50 4C 41 14 01 00 00 00 46 00 00 00 07 00 00 00 03 00 00 00 78 14 01 53 55 50 4C 41 ]
Device registered (activity timeout 120 s, server version: 20, server min version: 1)
Current status: [17] Registered and ready
Changing activity timeout to 30
Send: [53 55 50 4C 41 14 02 00 00 00 D2 00 00 00 01 00 00 00 1E ]
Recv: [53 55 50 4C 41 14 02 00 00 00 DC 00 00 00 03 00 00 00 1E 0A F0 53 55 50 4C 41 ]
Activity timeout set to 30 s
Send: [53 55 50 4C 41 14 03 00 00 00 28 00 00 00 10 00 00 00 23 00 00 00 00 00 00 00 C8 4C 01 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 14 03 00 00 00 32 00 00 00 10 00 00 00 76 06 ED 64 00 00 00 00 9C BF 01 00 00 00 00 00 53 55 50 4C 41 ]
Send: [53 55 50 4C 41 14 04 00 00 00 28 00 00 00 10 00 00 00 40 00 00 00 00 00 00 00 E2 D1 09 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 14 04 00 00 00 32 00 00 00 10 00 00 00 93 06 ED 64 00 00 00 00 F8 3C 0A 00 00 00 00 00 53 55 50 4C 41 ]
Gdzieś mam ustawić dane swojego licznika - liczników - mam dwa.
Zobacz sobie githuba, zaktualizowałem kod, że pokazuje tez ID licznika
Ok, wieczorkiem siądę to sprawdzę.
Jakby co to posiadam kilka sztuk płytek do kanapki.
Mam nadzieję że sygnał złapie piętro wyżej, bo tam mam kompa :)
PlatformIO jest super, sam pobiera to co jest potrzebne.
Arduino zawsze mnie wkurzało szukanie bibliotek, wpisujesz i wyskakuje z 10 i która instalować.
sixkiller
Pytanie od początkującego (pewnie inni też mogą się na to natknąć).
Pobrałem źródła z github do platformio, mam taki błąd przy próbie kompilacji:
Compiling .pio\build\esp32\src\wmbus_utils.cpp.o
C:/Users/Maciek/Downloads/cc1101_platformio_esp32_newer/src/arduino_cc1101_wmbus.ino: In function 'void setup()':
C:/Users/Maciek/Downloads/cc1101_platformio_esp32_newer/src/arduino_cc1101_wmbus.ino:93:21: error: 'serverVariable' was not declared in this scope
serverVariable, // SUPLA server address
C:/Users/Maciek/Downloads/cc1101_platformio_esp32_newer/src/arduino_cc1101_wmbus.ino:94:21: error: 'emailVariable' was not declared
in this scope
emailVariable, // Email address used to login to Supla Cloud
*** [.pio\build\esp32\src\arduino_cc1101_wmbus.ino.cpp.o] Error 1
jakaś wskazówka? To moje pierwsze kroki z Platformio, dotychczas generowałem sobie kody z gui-generic.
W głównym pliku musisz podać adres serwera supli oraz adres email.
Oba pola są komentowane, napiszę jak ja to zrobiłem.
Trzeba w pliku ino podać dane wifi, nazwę i hasło.
Jak będę przy kompie opiszę co i jak
rafalekkalwak@wp.pl
Namiary na suple są przeniesione do pliku którego nie ma w repozytorium o nazwie secrets.ini o zawartości:
[env:esp32]
build_flags =
-D emailVariable='"supla email"'
-D serverVariable='"supla serwer"'
W platformio. Ini jest wskazanie na ten plik. Jest to sposób żeby nie wrzucać do Repozytorium danych których tam być nie powinno
sixkiller
Plik secrets.ini stworzyłem, dane wifi wpisałem do pliku ino. Kompiluje się :)
Pozostaje kolejne pytanie, gdzie przypisać adresy pinów do jakich podpięte jest cc1101 do płytki?
rafalekkalwak@wp.pl
sixkiller wrote: Tue Aug 29, 2023 2:48 pm Plik secrets.ini stworzyłem, dane wifi wpisałem do pliku ino. Kompiluje się :)
W linijce :
new Supla::Sensor::WaterMeter();
konstruktor ma domyslne wartosci przypisane dla Esp32 DevKit, a mozesz podac swoje
WaterMeter(uint8_t mosi = 23, uint8_t miso = 19, uint8_t clk = 18, uint8_t cs = 5, uint8_t gdo0 = 4, uint8_t gdo2 = 2)
Korzystam z tej płytki https://github.com/SzczepanLeon/esphome-components
więc piny mam ustawić"
mosi_pin: GPIO13
  miso_pin: GPIO5
  clk_pin:  GPIO2
  cs_pin:   GPIO14
  gdo0_pin: GPIO15
  gdo2_pin: GPIO16
podaje same numery bez GPIO przed?
rafalekkalwak@wp.pl
W tym linku jest płytka cc1101 a nie esp jeśli dobrze widzę, od esp zależy które piny mają być w programie, szczególnie że SPI ma sztywne piny, i tak same liczby
