endrju_88
Has thanked: 3 times
Been thanked: 4 times
vajera wrote: Tue Oct 21, 2025 3:34 pm A możecie podrzucić logi z wzbudzania czujnika?
Ok , logi z naruszenia detekcji czujnika.
17:43:49.160 -> [200048][I][Z2S_Gateway.ino:860] loop(): Memory information: Flash chip real size:4194304 B, Free Sketch Space:2621440 B, Free Heap:122520, Minimal Free Heap:102228 B, HeapSize:358476 B, MaxAllocHeap:102388 B, Supla uptime:200 s
17:43:55.676 -> Send: [53 55 50 4C 41 17 27 00 00 00 28 00 00 00 10 00 00 00 5B C6 F7 68 00 00 00 00 10 06 09 00 00 00 00 00 ]
17:43:55.676 -> Send: [53 55 50 4C 41 ]
17:43:55.816 -> Recv: [53 55 50 4C 41 17 21 00 00 00 32 00 00 00 10 00 00 00 3C AA F7 68 00 00 00 00 DE A6 03 00 00 00 00 00 53 55 50 4C 41 ]
17:43:57.082 -> [207976][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
17:43:57.082 -> [207977][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
17:43:57.082 ->
APSDE INDICATION - src_addr_mode: 183, cluster_id: 0xef00, asdu_length: 10
17:43:57.082 ->
APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0x3fb7
17:43:57.082 ->
APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 147, rx_time: 0
17:43:57.082 -> [207978][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0xef00, command id: 2
17:43:57.082 -> [207979][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
17:43:57.082 -> [207979][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 0, disable_default_response 0, is_manuf_specific 0
17:43:57.082 -> [207980][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
17:43:57.129 -> [207980][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 18 size: 7
17:43:57.129 -> [207981][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:43:57.129 -> [207981][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x01
17:43:57.129 -> [207982][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x04
17:43:57.129 -> [207982][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:43:57.129 -> [207982][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x01
17:43:57.129 -> [207983][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x3fb7, 0x3fb7, 0x0, 0x0
17:43:57.129 -> [207983][I][z2s_devices_table.cpp:3437] Z2S_onCustomCmdReceive(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, cluster 0xef00, cmd id 0x2
17:43:57.129 -> [207984][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:43:57.129 -> [207985][I][z2s_devices_table.cpp:3447] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
17:43:57.129 -> [207985][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
17:43:57.129 -> [207986][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x1040) callback
17:43:57.129 -> [207987][I][ZigbeeHandlers.cpp:484] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x3fb7
17:43:57.129 -> [207987][I][ZigbeeHandlers.cpp:485] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
17:43:57.129 -> [207988][I][ZigbeeHandlers.cpp:486] zb_cmd_custom_cluster_req_handler(): Payload size: 7
17:43:57.129 -> [207988][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
17:43:57.129 -> [207988][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x1
17:43:57.129 -> [207989][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x1
17:43:57.129 -> [207989][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x4
17:43:57.129 -> [207990][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
17:43:57.129 -> [207990][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
17:43:57.129 -> [207991][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x1
17:43:57.129 -> [207991][I][z2s_device_tuya_custom_cluster.cpp:2010] processTuyaCustomCluster(): processing Tuya custom cluster 0xEF00, command id 0x2
17:43:57.129 -> [207992][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:43:57.129 -> [207992][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x3e8
17:43:57.129 -> [207993][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:43:57.129 -> [207994][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xbde
17:43:57.129 -> [207995][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:43:57.129 -> [207995][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xb54
17:43:57.129 -> [207996][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xb54
17:43:57.644 -> [208536][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
17:43:57.644 -> [208536][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
17:43:57.644 ->
APSDE INDICATION - src_addr_mode: 183, cluster_id: 0x0500, asdu_length: 9
17:43:57.644 ->
17:43:57.644 ->
17:43:57.644 -> [208538][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x500, command id: 0
17:43:57.644 -> [208538][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
17:43:57.644 -> [208539][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 0, disable_default_response 1, is_manuf_specific 0
17:43:57.644 -> [208539][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
17:43:57.644 -> [208540][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 21 size: 6
17:43:57.644 -> [208540][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x01
17:43:57.644 -> [208541][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:43:57.644 -> [208542][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:43:57.644 -> [208542][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x3fb7, 0x3fb7, 0x0, 0x0
17:43:57.691 -> [208543][I][z2s_devices_table.cpp:3437] Z2S_onCustomCmdReceive(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, cluster 0x500, cmd id 0x0
17:43:57.691 -> [208544][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:43:57.691 -> [208544][I][z2s_devices_table.cpp:3447] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
17:43:57.691 -> [208545][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
17:43:57.691 -> [208545][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x1031) callback
17:43:57.691 -> [208546][V][ZigbeeHandlers.cpp:435] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x3fb7) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x1), extended status (0x0), zone id (0x0), delay (0x0)
17:43:57.691 -> [208547][I][z2s_devices_table.cpp:3149] Z2S_onIASzoneStatusChangeNotification(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, cluster 0x500, zone status 0x1
17:43:57.691 -> [208548][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x3e8
17:43:57.691 -> [208549][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x3e8
17:43:57.691 -> [208549][I][z2s_devices_table.cpp:3202] Z2S_onIASzoneStatusChangeNotification(): IASZONE - IAS_ZONE_ALARM_2_SID: channel:0, status: 1
17:43:57.691 -> [208550][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x3e8
17:43:57.691 -> [208551][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x3e8
17:43:57.926 -> [208788][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
17:43:57.926 -> [208788][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
17:43:57.926 ->
APSDE INDICATION - src_addr_mode: 183, cluster_id: 0xef00, asdu_length: 13
17:43:57.926 ->
17:43:57.926 ->
17:43:57.926 -> [208790][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0xef00, command id: 2
17:43:57.926 -> [208790][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
17:43:57.926 -> [208791][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 0, disable_default_response 0, is_manuf_specific 0
17:43:57.926 -> [208791][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
17:43:57.926 -> [208792][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 3 size: 10
17:43:57.926 -> [208792][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:43:57.926 -> [208792][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x03
17:43:57.926 -> [208793][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x6A
17:43:57.926 -> [208793][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x02
17:43:57.926 -> [208793][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:43:57.926 -> [208794][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x04
17:43:57.926 -> [208794][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:43:57.926 -> [208795][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:43:57.926 -> [208795][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x5C
17:43:57.926 -> [208795][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x3fb7, 0x3fb7, 0x0, 0x0
17:43:57.926 -> [208796][I][z2s_devices_table.cpp:3437] Z2S_onCustomCmdReceive(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, cluster 0xef00, cmd id 0x2
17:43:57.926 -> [208797][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:43:57.926 -> [208797][I][z2s_devices_table.cpp:3447] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
17:43:57.926 -> [208798][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
17:43:57.926 -> [208798][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x1040) callback
17:43:57.926 -> [208799][I][ZigbeeHandlers.cpp:484] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x3fb7
17:43:57.926 -> [208800][I][ZigbeeHandlers.cpp:485] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
17:43:57.926 -> [208800][I][ZigbeeHandlers.cpp:486] zb_cmd_custom_cluster_req_handler(): Payload size: 10
17:43:57.926 -> [208801][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
17:43:57.926 -> [208801][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x3
17:43:57.926 -> [208802][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x6a
17:43:57.926 -> [208802][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
17:43:57.926 -> [208802][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
17:43:57.926 -> [208803][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
17:43:57.926 -> [208803][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
17:43:57.926 -> [208804][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
17:43:57.926 -> [208804][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
17:43:57.926 -> [208805][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x5c
17:43:57.926 -> [208805][I][z2s_device_tuya_custom_cluster.cpp:2010] processTuyaCustomCluster(): processing Tuya custom cluster 0xEF00, command id 0x2
17:43:57.926 -> [208807][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:43:57.926 -> [208808][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x3e8
17:43:57.926 -> [208808][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:43:57.926 -> [208809][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:43:57.926 -> [208810][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xbde
17:43:57.926 -> [208810][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:43:57.926 -> [208811][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xb54
17:43:57.926 -> [208812][I][z2s_general_purpose_measurement.cpp:152] msgZ2SDeviceGeneralPurposeMeasurement(): channel(2), value: 92.000000
17:43:58.488 -> [209354][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
17:43:58.488 -> [209354][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
17:43:58.488 ->
APSDE INDICATION - src_addr_mode: 183, cluster_id: 0x0400, asdu_length: 8
17:43:58.488 ->
17:43:58.488 ->
APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 153, rx_time: 0
17:43:58.488 -> [209356][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x400, command id: 10
17:43:58.488 -> [209356][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
17:43:58.488 -> [209357][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
17:43:58.488 -> [209358][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
17:43:58.488 -> [209358][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 22 size: 5
17:43:58.488 -> [209358][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:43:58.488 -> [209359][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:43:58.488 -> [209359][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x21
17:43:58.488 -> [209359][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0xB3
17:43:58.488 -> [209360][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x4C
17:43:58.488 -> [209360][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x3fb7, 0x3fb7, 0x0, 0x0
17:43:58.488 -> [209361][I][z2s_devices_table.cpp:3437] Z2S_onCustomCmdReceive(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, cluster 0x400, cmd id 0xa
17:43:58.488 -> [209361][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:43:58.488 -> [209362][I][z2s_devices_table.cpp:3447] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
17:43:58.488 -> [209362][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
17:43:58.488 -> [209363][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x2000) callback
17:43:58.488 -> [209364][V][ZigbeeHandlers.cpp:234] zb_attribute_reporting_handler(): Received report from address(0x3fb7) src endpoint(1) to dst endpoint(1) cluster(0x400)
17:43:58.488 -> [209365][I][ZigbeeGateway.cpp:1008] zbAttributeReporting(): illuminance measurement 0x4cb3
17:43:58.488 -> [209365][I][z2s_devices_table.cpp:1810] Z2S_onIlluminanceReceive(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, illuminance 19635
17:43:58.488 -> [209366][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:43:58.488 -> [209366][I][z2s_general_purpose_measurement.cpp:152] msgZ2SDeviceGeneralPurposeMeasurement(): channel(2), value: 1963.000000
17:43:59.707 -> Channel(2) value changed to 1963.00
17:43:59.707 -> Send: [53 55 50 4C 41 17 28 00 00 00 67 00 00 00 0E 00 00 00 02 00 00 00 00 00 00 00 00 00 00 AC 9E 40 ]
17:43:59.707 -> Send: [53 55 50 4C 41 ]
17:44:08.472 -> [219344][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
17:44:08.472 -> [219345][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
17:44:08.472 ->
17:44:08.472 ->
17:44:08.472 ->
APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 132, rx_time: 0
17:44:08.472 -> [219347][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0xef00, command id: 2
17:44:08.472 -> [219348][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
17:44:08.472 -> [219348][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 0, disable_default_response 0, is_manuf_specific 0
17:44:08.472 -> [219348][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
17:44:08.472 -> [219349][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 14 size: 10
17:44:08.472 -> [219349][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:08.472 -> [219350][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x05
17:44:08.472 -> [219350][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x6F
17:44:08.472 -> [219350][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x02
17:44:08.472 -> [219350][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:08.472 -> [219351][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x04
17:44:08.472 -> [219351][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:08.472 -> [219352][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:08.472 -> [219352][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0xDD
17:44:08.472 -> [219352][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x3fb7, 0x3fb7, 0x0, 0x0
17:44:08.472 -> [219353][I][z2s_devices_table.cpp:3437] Z2S_onCustomCmdReceive(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, cluster 0xef00, cmd id 0x2
17:44:08.472 -> [219354][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:44:08.472 -> [219354][I][z2s_devices_table.cpp:3447] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
17:44:08.472 -> [219355][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
17:44:08.472 -> [219355][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x1040) callback
17:44:08.472 -> [219356][I][ZigbeeHandlers.cpp:484] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x3fb7
17:44:08.472 -> [219356][I][ZigbeeHandlers.cpp:485] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
17:44:08.472 -> [219357][I][ZigbeeHandlers.cpp:486] zb_cmd_custom_cluster_req_handler(): Payload size: 10
17:44:08.472 -> [219357][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
17:44:08.472 -> [219358][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x5
17:44:08.472 -> [219358][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x6f
17:44:08.472 -> [219358][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
17:44:08.472 -> [219359][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
17:44:08.472 -> [219359][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
17:44:08.472 -> [219360][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
17:44:08.472 -> [219360][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
17:44:08.472 -> [219361][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
17:44:08.472 -> [219361][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0xdd
17:44:08.472 -> [219361][I][z2s_device_tuya_custom_cluster.cpp:2010] processTuyaCustomCluster(): processing Tuya custom cluster 0xEF00, command id 0x2
17:44:08.472 -> [219362][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:44:08.472 -> [219363][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x3e8
17:44:08.472 -> [219363][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:44:08.472 -> [219364][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:44:08.472 -> [219364][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xbde
17:44:08.472 -> [219365][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:44:08.472 -> [219366][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xb54
17:44:08.801 -> [219670][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
17:44:08.801 -> [219670][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
17:44:08.801 ->
17:44:08.801 ->
17:44:08.801 ->
APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 137, rx_time: 0
17:44:08.801 -> [219672][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0xef00, command id: 2
17:44:08.801 -> [219672][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
17:44:08.801 -> [219673][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 0, disable_default_response 0, is_manuf_specific 0
17:44:08.801 -> [219673][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
17:44:08.801 -> [219674][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 17 size: 10
17:44:08.801 -> [219674][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:08.801 -> [219674][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x06
17:44:08.801 -> [219675][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x65
17:44:08.801 -> [219675][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x02
17:44:08.801 -> [219675][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:08.801 -> [219676][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x04
17:44:08.801 -> [219676][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:08.801 -> [219677][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:08.801 -> [219677][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x38
17:44:08.801 -> [219677][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x3fb7, 0x3fb7, 0x0, 0x0
17:44:08.801 -> [219678][I][z2s_devices_table.cpp:3437] Z2S_onCustomCmdReceive(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, cluster 0xef00, cmd id 0x2
17:44:08.801 -> [219679][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:44:08.801 -> [219679][I][z2s_devices_table.cpp:3447] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
17:44:08.801 -> [219680][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
17:44:08.801 -> [219681][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x1040) callback
17:44:08.801 -> [219681][I][ZigbeeHandlers.cpp:484] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x3fb7
17:44:08.801 -> [219682][I][ZigbeeHandlers.cpp:485] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
17:44:08.801 -> [219682][I][ZigbeeHandlers.cpp:486] zb_cmd_custom_cluster_req_handler(): Payload size: 10
17:44:08.801 -> [219682][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
17:44:08.801 -> [219683][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x6
17:44:08.801 -> [219683][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x65
17:44:08.801 -> [219684][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
17:44:08.801 -> [219684][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
17:44:08.801 -> [219685][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
17:44:08.801 -> [219685][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
17:44:08.801 -> [219686][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
17:44:08.801 -> [219686][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
17:44:08.801 -> [219686][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x38
17:44:08.801 -> [219687][I][z2s_device_tuya_custom_cluster.cpp:2010] processTuyaCustomCluster(): processing Tuya custom cluster 0xEF00, command id 0x2
17:44:08.801 -> [219688][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:44:08.801 -> [219688][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x3e8
17:44:08.801 -> [219689][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:44:08.801 -> [219690][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xbde
17:44:08.801 -> [219691][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:44:08.801 -> [219691][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xb54
17:44:08.801 -> [219692][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xb54
17:44:09.129 -> Channel(1) value changed to temp(22.10), humi(56.00)
17:44:09.129 -> Send: [53 55 50 4C 41 17 29 00 00 00 67 00 00 00 0E 00 00 00 01 00 00 00 00 00 54 56 00 00 C0 DA 00 00 ]
17:44:09.176 -> Send: [53 55 50 4C 41 ]
17:44:09.176 -> [220052][I][Z2S_Gateway.ino:860] loop(): Memory information: Flash chip real size:4194304 B, Free Sketch Space:2621440 B, Free Heap:118784, Minimal Free Heap:102228 B, HeapSize:358476 B, MaxAllocHeap:102388 B, Supla uptime:220 s
17:44:09.363 -> [220229][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
17:44:09.363 -> [220230][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
17:44:09.363 ->
APSDE INDICATION - src_addr_mode: 183, cluster_id: 0x0402, asdu_length: 8
17:44:09.363 ->
17:44:09.363 ->
APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 127, rx_time: 0
17:44:09.363 -> [220232][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x402, command id: 10
17:44:09.363 -> [220232][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
17:44:09.363 -> [220233][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
17:44:09.363 -> [220233][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
17:44:09.363 -> [220234][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 2 size: 5
17:44:09.363 -> [220234][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:09.363 -> [220235][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x29
17:44:09.363 -> [220235][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0xA2
17:44:09.363 -> [220235][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x08
17:44:09.363 -> [220236][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x3fb7, 0x3fb7, 0x0, 0x0
17:44:09.363 -> [220236][I][z2s_devices_table.cpp:3437] Z2S_onCustomCmdReceive(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, cluster 0x402, cmd id 0xa
17:44:09.363 -> [220237][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:44:09.363 -> [220237][I][z2s_devices_table.cpp:3447] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
17:44:09.363 -> [220238][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
17:44:09.363 -> [220239][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x2000) callback
17:44:09.363 -> [220239][V][ZigbeeHandlers.cpp:234] zb_attribute_reporting_handler(): Received report from address(0x3fb7) src endpoint(1) to dst endpoint(1) cluster(0x402)
17:44:09.363 -> [220240][I][ZigbeeGateway.cpp:963] zbAttributeReporting(): temperature measurement 22.100000
17:44:09.363 -> [220241][I][z2s_devices_table.cpp:1751] Z2S_onTemperatureReceive(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, temperature 22.100000
17:44:09.363 -> [220241][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xbde
17:44:19.160 -> [230055][I][Z2S_Gateway.ino:860] loop(): Memory information: Flash chip real size:4194304 B, Free Sketch Space:2621440 B, Free Heap:122520, Minimal Free Heap:102228 B, HeapSize:358476 B, MaxAllocHeap:102388 B, Supla uptime:230 s
17:44:20.801 -> Send: [53 55 50 4C 41 17 2A 00 00 00 28 00 00 00 10 00 00 00 74 C6 F7 68 00 00 00 00 19 E3 0A 00 00 00 00 00 ]
17:44:20.801 -> Send: [53 55 50 4C 41 ]
17:44:21.270 -> Recv: [53 55 50 4C 41 17 22 00 00 00 32 00 00 00 10 00 00 00 55 AA F7 68 00 00 00 00 1E 49 06 00 00 00 00 00 53 55 50 4C 41 ]
17:44:29.145 -> [240023][I][Z2S_Gateway.ino:715] loop(): New UTC time 814383869, new local time 814383869
17:44:29.145 -> [240024][I][Z2S_Gateway.ino:761] loop():
17:44:29.145 ->
Local Time Cluster Time status attribute 2
17:44:29.145 ->
UTC time attribute 814383869
17:44:29.145 ->
local time attribute 814383869
17:44:29.145 -> [240026][I][z2s_web_gui.cpp:751] fillMemoryUptimeInformation(): Memory & uptime information <b><i>Flash chip real size:</b></i> 4194304 B <b>| <i>Free Sketch Space:</b></i> 2621440 B<br><b><i>HeapSize:</b></i> 358476 B <b>| <i>FreeHeap:</b></i> 122584 B <b>| <i>MinimalFreeHeap:</b></i> 102228 B <b>| <i>MaxAllocHeap:</b></i> 102388 B<br><b><i>uxTaskGetStackHighWaterMark:</b></i> 3128 B <br><b><i>Total PSRAM:</b></i> 0 B <b>| <i>Free PSRAM:</b></i> 0 B<br><br><b><i>Local time:</i></b> Tue Oct 21 17:44:29 2025
17:44:29.145 -> <b><i>Supla uptime:</i></b> 240 s
17:44:33.176 -> [244053][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
17:44:33.176 -> [244054][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
17:44:33.176 ->
17:44:33.176 ->
17:44:33.176 ->
APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 142, rx_time: 0
17:44:33.176 -> [244055][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0xef00, command id: 2
17:44:33.176 -> [244056][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
17:44:33.176 -> [244056][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 0, disable_default_response 0, is_manuf_specific 0
17:44:33.176 -> [244057][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
17:44:33.176 -> [244057][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 15 size: 7
17:44:33.176 -> [244058][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:33.176 -> [244058][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x09
17:44:33.176 -> [244058][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x01
17:44:33.176 -> [244059][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x04
17:44:33.176 -> [244059][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:33.176 -> [244059][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x01
17:44:33.176 -> [244060][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x3fb7, 0x3fb7, 0x0, 0x0
17:44:33.176 -> [244060][I][z2s_devices_table.cpp:3437] Z2S_onCustomCmdReceive(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, cluster 0xef00, cmd id 0x2
17:44:33.176 -> [244061][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:44:33.176 -> [244062][I][z2s_devices_table.cpp:3447] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
17:44:33.176 -> [244062][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
17:44:33.176 -> [244063][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x1040) callback
17:44:33.176 -> [244063][I][ZigbeeHandlers.cpp:484] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x3fb7
17:44:33.176 -> [244064][I][ZigbeeHandlers.cpp:485] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
17:44:33.176 -> [244064][I][ZigbeeHandlers.cpp:486] zb_cmd_custom_cluster_req_handler(): Payload size: 7
17:44:33.176 -> [244065][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
17:44:33.176 -> [244065][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x9
17:44:33.176 -> [244066][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x1
17:44:33.176 -> [244066][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x4
17:44:33.176 -> [244066][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
17:44:33.176 -> [244067][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
17:44:33.176 -> [244067][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
17:44:33.176 -> [244068][I][z2s_device_tuya_custom_cluster.cpp:2010] processTuyaCustomCluster(): processing Tuya custom cluster 0xEF00, command id 0x2
17:44:33.176 -> [244068][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:44:33.176 -> [244069][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x3e8
17:44:33.176 -> [244070][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:44:33.176 -> [244071][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xbde
17:44:33.176 -> [244072][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:44:33.176 -> [244072][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xb54
17:44:33.176 -> [244073][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xb54
17:44:33.270 -> Channel(0) value changed to 0
17:44:33.270 -> Send: [53 55 50 4C 41 17 2B 00 00 00 67 00 00 00 0E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
17:44:33.270 -> Send: [53 55 50 4C 41 ]
17:44:33.738 -> [244613][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
17:44:33.738 -> [244613][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
17:44:33.738 ->
17:44:33.738 ->
17:44:33.738 ->
17:44:33.738 -> [244615][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x500, command id: 0
17:44:33.738 -> [244615][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
17:44:33.738 -> [244616][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 0, disable_default_response 1, is_manuf_specific 0
17:44:33.738 -> [244616][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
17:44:33.738 -> [244617][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 26 size: 6
17:44:33.738 -> [244617][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:33.738 -> [244618][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:33.738 -> [244619][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:33.738 -> [244619][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x3fb7, 0x3fb7, 0x0, 0x0
17:44:33.738 -> [244619][I][z2s_devices_table.cpp:3437] Z2S_onCustomCmdReceive(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, cluster 0x500, cmd id 0x0
17:44:33.738 -> [244620][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:44:33.738 -> [244621][I][z2s_devices_table.cpp:3447] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
17:44:33.738 -> [244621][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
17:44:33.738 -> [244622][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x1031) callback
17:44:33.738 -> [244622][V][ZigbeeHandlers.cpp:435] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x3fb7) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x0), extended status (0x0), zone id (0x0), delay (0x0)
17:44:33.738 -> [244623][I][z2s_devices_table.cpp:3149] Z2S_onIASzoneStatusChangeNotification(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, cluster 0x500, zone status 0x0
17:44:33.738 -> [244624][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x3e8
17:44:33.738 -> [244625][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x3e8
17:44:33.738 -> [244626][I][z2s_devices_table.cpp:3202] Z2S_onIASzoneStatusChangeNotification(): IASZONE - IAS_ZONE_ALARM_2_SID: channel:0, status: 0
17:44:33.738 -> [244627][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x3e8
17:44:33.785 -> Channel(0) value changed to 1
17:44:33.785 -> Send: [53 55 50 4C 41 17 2C 00 00 00 67 00 00 00 0E 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 ]
17:44:33.785 -> Send: [53 55 50 4C 41 ]
17:44:35.519 -> [246394][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
17:44:35.519 -> [246395][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
17:44:35.519 ->
17:44:35.519 ->
17:44:35.519 ->
17:44:35.519 -> [246397][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0xef00, command id: 2
17:44:35.519 -> [246397][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
17:44:35.519 -> [246398][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 0, disable_default_response 0, is_manuf_specific 0
17:44:35.519 -> [246398][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
17:44:35.519 -> [246398][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 5 size: 10
17:44:35.519 -> [246399][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:35.519 -> [246399][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x0B
17:44:35.519 -> [246399][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x6A
17:44:35.519 -> [246400][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x02
17:44:35.519 -> [246400][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:35.519 -> [246400][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x04
17:44:35.519 -> [246401][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:35.519 -> [246402][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x53
17:44:35.519 -> [246402][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x3fb7, 0x3fb7, 0x0, 0x0
17:44:35.519 -> [246402][I][z2s_devices_table.cpp:3437] Z2S_onCustomCmdReceive(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, cluster 0xef00, cmd id 0x2
17:44:35.519 -> [246403][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:44:35.519 -> [246404][I][z2s_devices_table.cpp:3447] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
17:44:35.519 -> [246404][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
17:44:35.519 -> [246405][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x1040) callback
17:44:35.519 -> [246405][I][ZigbeeHandlers.cpp:484] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x3fb7
17:44:35.519 -> [246406][I][ZigbeeHandlers.cpp:485] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
17:44:35.519 -> [246406][I][ZigbeeHandlers.cpp:486] zb_cmd_custom_cluster_req_handler(): Payload size: 10
17:44:35.519 -> [246407][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
17:44:35.519 -> [246407][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0xb
17:44:35.519 -> [246408][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x6a
17:44:35.519 -> [246408][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
17:44:35.519 -> [246409][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
17:44:35.519 -> [246409][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
17:44:35.519 -> [246409][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
17:44:35.519 -> [246410][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
17:44:35.519 -> [246410][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
17:44:35.519 -> [246411][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x53
17:44:35.519 -> [246411][I][z2s_device_tuya_custom_cluster.cpp:2010] processTuyaCustomCluster(): processing Tuya custom cluster 0xEF00, command id 0x2
17:44:35.519 -> [246412][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:44:35.519 -> [246412][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x3e8
17:44:35.519 -> [246413][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:44:35.519 -> [246414][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:44:35.519 -> [246414][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xbde
17:44:35.519 -> [246415][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:44:35.519 -> [246415][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xb54
17:44:35.519 -> [246416][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xb54
17:44:35.519 -> [246417][I][z2s_general_purpose_measurement.cpp:152] msgZ2SDeviceGeneralPurposeMeasurement(): channel(2), value: 83.000000
17:44:36.082 -> [246945][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
17:44:36.082 -> [246946][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
17:44:36.082 ->
17:44:36.082 ->
17:44:36.082 ->
17:44:36.082 -> [246948][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x400, command id: 10
17:44:36.082 -> [246948][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
17:44:36.082 -> [246948][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
17:44:36.082 -> [246949][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
17:44:36.082 -> [246949][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 6 size: 5
17:44:36.082 -> [246950][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:36.082 -> [246950][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x21
17:44:36.082 -> [246951][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0xF3
17:44:36.082 -> [246951][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x4A
17:44:36.082 -> [246951][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x3fb7, 0x3fb7, 0x0, 0x0
17:44:36.082 -> [246952][I][z2s_devices_table.cpp:3437] Z2S_onCustomCmdReceive(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, cluster 0x400, cmd id 0xa
17:44:36.082 -> [246953][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:44:36.082 -> [246953][I][z2s_devices_table.cpp:3447] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
17:44:36.082 -> [246954][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
17:44:36.082 -> [246955][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x2000) callback
17:44:36.082 -> [246955][V][ZigbeeHandlers.cpp:234] zb_attribute_reporting_handler(): Received report from address(0x3fb7) src endpoint(1) to dst endpoint(1) cluster(0x400)
17:44:36.082 -> [246956][I][ZigbeeGateway.cpp:1008] zbAttributeReporting(): illuminance measurement 0x4af3
17:44:36.082 -> [246956][I][z2s_devices_table.cpp:1810] Z2S_onIlluminanceReceive(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, illuminance 19187
17:44:36.082 -> [246957][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:44:36.082 -> [246957][I][z2s_general_purpose_measurement.cpp:152] msgZ2SDeviceGeneralPurposeMeasurement(): channel(2), value: 1918.000000
17:44:39.176 -> [250059][I][Z2S_Gateway.ino:860] loop(): Memory information: Flash chip real size:4194304 B, Free Sketch Space:2621440 B, Free Heap:122520, Minimal Free Heap:102228 B, HeapSize:358476 B, MaxAllocHeap:102388 B, Supla uptime:250 s
17:44:39.691 -> Channel(2) value changed to 1918.00
17:44:39.691 -> Send: [53 55 50 4C 41 17 2D 00 00 00 67 00 00 00 0E 00 00 00 02 00 00 00 00 00 00 00 00 00 00 F8 9D 40 ]
17:44:39.691 -> Send: [53 55 50 4C 41 ]
PijanySmerf
Mam czujnik zamontowany w oknie, który czasami nie reaguje na otwarcie. Wystarczy go jednak kilka razy otworzyć i zamknąć, żeby nagle zaczął działać
Has thanked: 291 times
endrju_88 wrote: Tue Oct 21, 2025 3:48 pm
Tutaj faktycznie coś nie bangla - to jest ten mały czujnik PIR/światło, prawda? Dawno go dodawałeś do tej bramki? Jesteś w stanie zrobić mu Remove device with all channels i wtedy dodać go jeszcze raz? Testowałem go u siebie na biurku i działał, ale nie jestem pewny, czy tam się coś w definicji nie zmieniło. Jeżeli masz go mocno pospinanego w logikę, to nie usuwaj póki co, tylko wrzuć mi wtedy screeny z channel info tego czujnika.
endrju_88
vajera wrote: Tue Oct 21, 2025 4:19 pm
To jest ten czujnik 4w1 akurat (_TZE200_rhgsbacq::TS0601). Dodawałem go po wcześniejszym wgraniu pliku merged , jak i jeszcze wcześniej pliku Z2S 2.3Mb. Aktualnie mam wgraną wersję 0.9.102 ,myślałem ,że od tej wersji weszła jakaś zmiana po której się coś posypało. Kolejne wersje od 102 do 105 problem nadal występuje. Nie mam go spięte z reakcjami , jest dodany do bramki testowej , tak więc bez problemu. Channel info - o to chodzi ?
PijanySmerf wrote: Tue Oct 21, 2025 3:49 pm Mam czujnik zamontowany w oknie, który czasami nie reaguje na otwarcie. Wystarczy go jednak kilka razy otworzyć i zamknąć, żeby nagle zaczął działać
Przy takich objawach podejrzewałbym:
- nieprawidłowy montaż czujnika,
- problem z zasięgiem,
- bateria,
- niskiej jakości czujnik, chociaż w przypadku najzwyklejszego kontaktronu trudno jest coś zepsuć...
endrju_88 wrote: Tue Oct 21, 2025 4:38 pm
O to - nie masz tam przypadkiem włączonej flagi disable single channel notifications przypadkiem nim?
PijanySmerf
vajera wrote: Tue Oct 21, 2025 4:48 pm
- bateria,
Mały off-topic:
Jak montujecie kontaktrony w oknach tak, żeby działały przy otwarciu jednego lub drugiego skrzydła, korzystając z jednego czujnika?
PijanySmerf wrote: Tue Oct 21, 2025 5:13 pm
- bateria,
Mały off-topic:
Nie mam takich okien 😉, niemniej wydaje mi, że wtedy potrzebujesz 2 kontaktrony?
endrju_88
vajera wrote: Tue Oct 21, 2025 4:56 pm
Niestety. Nigdy nie używałem tej funkcji jak i również przy tym czujniku.
Has thanked: 13 times
Been thanked: 25 times
PijanySmerf wrote: Tue Oct 21, 2025 5:13 pm Mały off-topic:
Mam dwa czujniki.
Próbowałem na jednym, ale jak oba uchylisz to czujnik pokazuje zamknięte :P
https://pool.lector.top/
