Ok , logi z naruszenia detekcji czujnika.
17:43:49.160 -> [200048][I][Z2S_Gateway.ino:860] loop(): Memory information: Flash chip real size:4194304 B, Free Sketch Space:2621440 B, Free Heap:122520, Minimal Free Heap:102228 B, HeapSize:358476 B, MaxAllocHeap:102388 B, Supla uptime:200 s
17:43:55.676 -> Send: [53 55 50 4C 41 17 27 00 00 00 28 00 00 00 10 00 00 00 5B C6 F7 68 00 00 00 00 10 06 09 00 00 00 00 00 ]
17:43:55.676 -> Send: [53 55 50 4C 41 ]
17:43:55.816 -> Recv: [53 55 50 4C 41 17 21 00 00 00 32 00 00 00 10 00 00 00 3C AA F7 68 00 00 00 00 DE A6 03 00 00 00 00 00 53 55 50 4C 41 ]
17:43:57.082 -> [207976][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
17:43:57.082 -> [207977][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
17:43:57.082 ->
APSDE INDICATION - src_addr_mode: 183, cluster_id: 0xef00, asdu_length: 10
17:43:57.082 ->
APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0x3fb7
17:43:57.082 ->
APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 147, rx_time: 0
17:43:57.082 -> [207978][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0xef00, command id: 2
17:43:57.082 -> [207979][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
17:43:57.082 -> [207979][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 0, disable_default_response 0, is_manuf_specific 0
17:43:57.082 -> [207980][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
17:43:57.129 -> [207980][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 18 size: 7
17:43:57.129 -> [207981][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:43:57.129 -> [207981][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x01
17:43:57.129 -> [207982][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x04
17:43:57.129 -> [207982][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:43:57.129 -> [207982][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x01
17:43:57.129 -> [207983][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x3fb7, 0x3fb7, 0x0, 0x0
17:43:57.129 -> [207983][I][z2s_devices_table.cpp:3437] Z2S_onCustomCmdReceive(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, cluster 0xef00, cmd id 0x2
17:43:57.129 -> [207984][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:43:57.129 -> [207985][I][z2s_devices_table.cpp:3447] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
17:43:57.129 -> [207985][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
17:43:57.129 -> [207986][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x1040) callback
17:43:57.129 -> [207987][I][ZigbeeHandlers.cpp:484] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x3fb7
17:43:57.129 -> [207987][I][ZigbeeHandlers.cpp:485] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
17:43:57.129 -> [207988][I][ZigbeeHandlers.cpp:486] zb_cmd_custom_cluster_req_handler(): Payload size: 7
17:43:57.129 -> [207988][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
17:43:57.129 -> [207988][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x1
17:43:57.129 -> [207989][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x1
17:43:57.129 -> [207989][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x4
17:43:57.129 -> [207990][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
17:43:57.129 -> [207990][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
17:43:57.129 -> [207991][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x1
17:43:57.129 -> [207991][I][z2s_device_tuya_custom_cluster.cpp:2010] processTuyaCustomCluster(): processing Tuya custom cluster 0xEF00, command id 0x2
17:43:57.129 -> [207992][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:43:57.129 -> [207992][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x3e8
17:43:57.129 -> [207993][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:43:57.129 -> [207994][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xbde
17:43:57.129 -> [207995][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:43:57.129 -> [207995][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xb54
17:43:57.129 -> [207996][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xb54
17:43:57.644 -> [208536][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
17:43:57.644 -> [208536][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
17:43:57.644 ->
APSDE INDICATION - src_addr_mode: 183, cluster_id: 0x0500, asdu_length: 9
17:43:57.644 ->
17:43:57.644 ->
17:43:57.644 -> [208538][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x500, command id: 0
17:43:57.644 -> [208538][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
17:43:57.644 -> [208539][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 0, disable_default_response 1, is_manuf_specific 0
17:43:57.644 -> [208539][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
17:43:57.644 -> [208540][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 21 size: 6
17:43:57.644 -> [208540][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x01
17:43:57.644 -> [208541][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:43:57.644 -> [208542][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:43:57.644 -> [208542][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x3fb7, 0x3fb7, 0x0, 0x0
17:43:57.691 -> [208543][I][z2s_devices_table.cpp:3437] Z2S_onCustomCmdReceive(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, cluster 0x500, cmd id 0x0
17:43:57.691 -> [208544][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:43:57.691 -> [208544][I][z2s_devices_table.cpp:3447] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
17:43:57.691 -> [208545][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
17:43:57.691 -> [208545][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x1031) callback
17:43:57.691 -> [208546][V][ZigbeeHandlers.cpp:435] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x3fb7) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x1), extended status (0x0), zone id (0x0), delay (0x0)
17:43:57.691 -> [208547][I][z2s_devices_table.cpp:3149] Z2S_onIASzoneStatusChangeNotification(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, cluster 0x500, zone status 0x1
17:43:57.691 -> [208548][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x3e8
17:43:57.691 -> [208549][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x3e8
17:43:57.691 -> [208549][I][z2s_devices_table.cpp:3202] Z2S_onIASzoneStatusChangeNotification(): IASZONE - IAS_ZONE_ALARM_2_SID: channel:0, status: 1
17:43:57.691 -> [208550][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x3e8
17:43:57.691 -> [208551][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x3e8
17:43:57.926 -> [208788][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
17:43:57.926 -> [208788][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
17:43:57.926 ->
APSDE INDICATION - src_addr_mode: 183, cluster_id: 0xef00, asdu_length: 13
17:43:57.926 ->
17:43:57.926 ->
17:43:57.926 -> [208790][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0xef00, command id: 2
17:43:57.926 -> [208790][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
17:43:57.926 -> [208791][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 0, disable_default_response 0, is_manuf_specific 0
17:43:57.926 -> [208791][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
17:43:57.926 -> [208792][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 3 size: 10
17:43:57.926 -> [208792][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:43:57.926 -> [208792][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x03
17:43:57.926 -> [208793][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x6A
17:43:57.926 -> [208793][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x02
17:43:57.926 -> [208793][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:43:57.926 -> [208794][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x04
17:43:57.926 -> [208794][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:43:57.926 -> [208795][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:43:57.926 -> [208795][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x5C
17:43:57.926 -> [208795][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x3fb7, 0x3fb7, 0x0, 0x0
17:43:57.926 -> [208796][I][z2s_devices_table.cpp:3437] Z2S_onCustomCmdReceive(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, cluster 0xef00, cmd id 0x2
17:43:57.926 -> [208797][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:43:57.926 -> [208797][I][z2s_devices_table.cpp:3447] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
17:43:57.926 -> [208798][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
17:43:57.926 -> [208798][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x1040) callback
17:43:57.926 -> [208799][I][ZigbeeHandlers.cpp:484] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x3fb7
17:43:57.926 -> [208800][I][ZigbeeHandlers.cpp:485] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
17:43:57.926 -> [208800][I][ZigbeeHandlers.cpp:486] zb_cmd_custom_cluster_req_handler(): Payload size: 10
17:43:57.926 -> [208801][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
17:43:57.926 -> [208801][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x3
17:43:57.926 -> [208802][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x6a
17:43:57.926 -> [208802][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
17:43:57.926 -> [208802][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
17:43:57.926 -> [208803][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
17:43:57.926 -> [208803][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
17:43:57.926 -> [208804][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
17:43:57.926 -> [208804][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
17:43:57.926 -> [208805][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x5c
17:43:57.926 -> [208805][I][z2s_device_tuya_custom_cluster.cpp:2010] processTuyaCustomCluster(): processing Tuya custom cluster 0xEF00, command id 0x2
17:43:57.926 -> [208807][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:43:57.926 -> [208808][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x3e8
17:43:57.926 -> [208808][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:43:57.926 -> [208809][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:43:57.926 -> [208810][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xbde
17:43:57.926 -> [208810][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:43:57.926 -> [208811][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xb54
17:43:57.926 -> [208812][I][z2s_general_purpose_measurement.cpp:152] msgZ2SDeviceGeneralPurposeMeasurement(): channel(2), value: 92.000000
17:43:58.488 -> [209354][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
17:43:58.488 -> [209354][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
17:43:58.488 ->
APSDE INDICATION - src_addr_mode: 183, cluster_id: 0x0400, asdu_length: 8
17:43:58.488 ->
17:43:58.488 ->
APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 153, rx_time: 0
17:43:58.488 -> [209356][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x400, command id: 10
17:43:58.488 -> [209356][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
17:43:58.488 -> [209357][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
17:43:58.488 -> [209358][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
17:43:58.488 -> [209358][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 22 size: 5
17:43:58.488 -> [209358][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:43:58.488 -> [209359][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:43:58.488 -> [209359][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x21
17:43:58.488 -> [209359][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0xB3
17:43:58.488 -> [209360][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x4C
17:43:58.488 -> [209360][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x3fb7, 0x3fb7, 0x0, 0x0
17:43:58.488 -> [209361][I][z2s_devices_table.cpp:3437] Z2S_onCustomCmdReceive(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, cluster 0x400, cmd id 0xa
17:43:58.488 -> [209361][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:43:58.488 -> [209362][I][z2s_devices_table.cpp:3447] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
17:43:58.488 -> [209362][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
17:43:58.488 -> [209363][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x2000) callback
17:43:58.488 -> [209364][V][ZigbeeHandlers.cpp:234] zb_attribute_reporting_handler(): Received report from address(0x3fb7) src endpoint(1) to dst endpoint(1) cluster(0x400)
17:43:58.488 -> [209365][I][ZigbeeGateway.cpp:1008] zbAttributeReporting(): illuminance measurement 0x4cb3
17:43:58.488 -> [209365][I][z2s_devices_table.cpp:1810] Z2S_onIlluminanceReceive(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, illuminance 19635
17:43:58.488 -> [209366][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:43:58.488 -> [209366][I][z2s_general_purpose_measurement.cpp:152] msgZ2SDeviceGeneralPurposeMeasurement(): channel(2), value: 1963.000000
17:43:59.707 -> Channel(2) value changed to 1963.00
17:43:59.707 -> Send: [53 55 50 4C 41 17 28 00 00 00 67 00 00 00 0E 00 00 00 02 00 00 00 00 00 00 00 00 00 00 AC 9E 40 ]
17:43:59.707 -> Send: [53 55 50 4C 41 ]
17:44:08.472 -> [219344][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
17:44:08.472 -> [219345][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
17:44:08.472 ->
17:44:08.472 ->
17:44:08.472 ->
APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 132, rx_time: 0
17:44:08.472 -> [219347][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0xef00, command id: 2
17:44:08.472 -> [219348][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
17:44:08.472 -> [219348][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 0, disable_default_response 0, is_manuf_specific 0
17:44:08.472 -> [219348][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
17:44:08.472 -> [219349][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 14 size: 10
17:44:08.472 -> [219349][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:08.472 -> [219350][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x05
17:44:08.472 -> [219350][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x6F
17:44:08.472 -> [219350][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x02
17:44:08.472 -> [219350][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:08.472 -> [219351][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x04
17:44:08.472 -> [219351][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:08.472 -> [219352][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:08.472 -> [219352][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0xDD
17:44:08.472 -> [219352][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x3fb7, 0x3fb7, 0x0, 0x0
17:44:08.472 -> [219353][I][z2s_devices_table.cpp:3437] Z2S_onCustomCmdReceive(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, cluster 0xef00, cmd id 0x2
17:44:08.472 -> [219354][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:44:08.472 -> [219354][I][z2s_devices_table.cpp:3447] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
17:44:08.472 -> [219355][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
17:44:08.472 -> [219355][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x1040) callback
17:44:08.472 -> [219356][I][ZigbeeHandlers.cpp:484] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x3fb7
17:44:08.472 -> [219356][I][ZigbeeHandlers.cpp:485] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
17:44:08.472 -> [219357][I][ZigbeeHandlers.cpp:486] zb_cmd_custom_cluster_req_handler(): Payload size: 10
17:44:08.472 -> [219357][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
17:44:08.472 -> [219358][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x5
17:44:08.472 -> [219358][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x6f
17:44:08.472 -> [219358][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
17:44:08.472 -> [219359][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
17:44:08.472 -> [219359][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
17:44:08.472 -> [219360][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
17:44:08.472 -> [219360][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
17:44:08.472 -> [219361][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
17:44:08.472 -> [219361][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0xdd
17:44:08.472 -> [219361][I][z2s_device_tuya_custom_cluster.cpp:2010] processTuyaCustomCluster(): processing Tuya custom cluster 0xEF00, command id 0x2
17:44:08.472 -> [219362][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:44:08.472 -> [219363][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x3e8
17:44:08.472 -> [219363][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:44:08.472 -> [219364][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:44:08.472 -> [219364][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xbde
17:44:08.472 -> [219365][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:44:08.472 -> [219366][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xb54
17:44:08.801 -> [219670][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
17:44:08.801 -> [219670][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
17:44:08.801 ->
17:44:08.801 ->
17:44:08.801 ->
APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 137, rx_time: 0
17:44:08.801 -> [219672][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0xef00, command id: 2
17:44:08.801 -> [219672][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
17:44:08.801 -> [219673][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 0, disable_default_response 0, is_manuf_specific 0
17:44:08.801 -> [219673][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
17:44:08.801 -> [219674][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 17 size: 10
17:44:08.801 -> [219674][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:08.801 -> [219674][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x06
17:44:08.801 -> [219675][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x65
17:44:08.801 -> [219675][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x02
17:44:08.801 -> [219675][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:08.801 -> [219676][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x04
17:44:08.801 -> [219676][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:08.801 -> [219677][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:08.801 -> [219677][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x38
17:44:08.801 -> [219677][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x3fb7, 0x3fb7, 0x0, 0x0
17:44:08.801 -> [219678][I][z2s_devices_table.cpp:3437] Z2S_onCustomCmdReceive(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, cluster 0xef00, cmd id 0x2
17:44:08.801 -> [219679][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:44:08.801 -> [219679][I][z2s_devices_table.cpp:3447] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
17:44:08.801 -> [219680][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
17:44:08.801 -> [219681][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x1040) callback
17:44:08.801 -> [219681][I][ZigbeeHandlers.cpp:484] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x3fb7
17:44:08.801 -> [219682][I][ZigbeeHandlers.cpp:485] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
17:44:08.801 -> [219682][I][ZigbeeHandlers.cpp:486] zb_cmd_custom_cluster_req_handler(): Payload size: 10
17:44:08.801 -> [219682][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
17:44:08.801 -> [219683][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x6
17:44:08.801 -> [219683][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x65
17:44:08.801 -> [219684][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
17:44:08.801 -> [219684][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
17:44:08.801 -> [219685][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
17:44:08.801 -> [219685][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
17:44:08.801 -> [219686][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
17:44:08.801 -> [219686][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
17:44:08.801 -> [219686][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x38
17:44:08.801 -> [219687][I][z2s_device_tuya_custom_cluster.cpp:2010] processTuyaCustomCluster(): processing Tuya custom cluster 0xEF00, command id 0x2
17:44:08.801 -> [219688][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:44:08.801 -> [219688][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x3e8
17:44:08.801 -> [219689][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:44:08.801 -> [219690][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xbde
17:44:08.801 -> [219691][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:44:08.801 -> [219691][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xb54
17:44:08.801 -> [219692][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xb54
17:44:09.129 -> Channel(1) value changed to temp(22.10), humi(56.00)
17:44:09.129 -> Send: [53 55 50 4C 41 17 29 00 00 00 67 00 00 00 0E 00 00 00 01 00 00 00 00 00 54 56 00 00 C0 DA 00 00 ]
17:44:09.176 -> Send: [53 55 50 4C 41 ]
17:44:09.176 -> [220052][I][Z2S_Gateway.ino:860] loop(): Memory information: Flash chip real size:4194304 B, Free Sketch Space:2621440 B, Free Heap:118784, Minimal Free Heap:102228 B, HeapSize:358476 B, MaxAllocHeap:102388 B, Supla uptime:220 s
17:44:09.363 -> [220229][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
17:44:09.363 -> [220230][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
17:44:09.363 ->
APSDE INDICATION - src_addr_mode: 183, cluster_id: 0x0402, asdu_length: 8
17:44:09.363 ->
17:44:09.363 ->
APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 127, rx_time: 0
17:44:09.363 -> [220232][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x402, command id: 10
17:44:09.363 -> [220232][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
17:44:09.363 -> [220233][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
17:44:09.363 -> [220233][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
17:44:09.363 -> [220234][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 2 size: 5
17:44:09.363 -> [220234][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:09.363 -> [220235][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x29
17:44:09.363 -> [220235][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0xA2
17:44:09.363 -> [220235][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x08
17:44:09.363 -> [220236][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x3fb7, 0x3fb7, 0x0, 0x0
17:44:09.363 -> [220236][I][z2s_devices_table.cpp:3437] Z2S_onCustomCmdReceive(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, cluster 0x402, cmd id 0xa
17:44:09.363 -> [220237][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:44:09.363 -> [220237][I][z2s_devices_table.cpp:3447] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
17:44:09.363 -> [220238][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
17:44:09.363 -> [220239][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x2000) callback
17:44:09.363 -> [220239][V][ZigbeeHandlers.cpp:234] zb_attribute_reporting_handler(): Received report from address(0x3fb7) src endpoint(1) to dst endpoint(1) cluster(0x402)
17:44:09.363 -> [220240][I][ZigbeeGateway.cpp:963] zbAttributeReporting(): temperature measurement 22.100000
17:44:09.363 -> [220241][I][z2s_devices_table.cpp:1751] Z2S_onTemperatureReceive(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, temperature 22.100000
17:44:09.363 -> [220241][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xbde
17:44:19.160 -> [230055][I][Z2S_Gateway.ino:860] loop(): Memory information: Flash chip real size:4194304 B, Free Sketch Space:2621440 B, Free Heap:122520, Minimal Free Heap:102228 B, HeapSize:358476 B, MaxAllocHeap:102388 B, Supla uptime:230 s
17:44:20.801 -> Send: [53 55 50 4C 41 17 2A 00 00 00 28 00 00 00 10 00 00 00 74 C6 F7 68 00 00 00 00 19 E3 0A 00 00 00 00 00 ]
17:44:20.801 -> Send: [53 55 50 4C 41 ]
17:44:21.270 -> Recv: [53 55 50 4C 41 17 22 00 00 00 32 00 00 00 10 00 00 00 55 AA F7 68 00 00 00 00 1E 49 06 00 00 00 00 00 53 55 50 4C 41 ]
17:44:29.145 -> [240023][I][Z2S_Gateway.ino:715] loop(): New UTC time 814383869, new local time 814383869
17:44:29.145 -> [240024][I][Z2S_Gateway.ino:761] loop():
17:44:29.145 ->
Local Time Cluster Time status attribute 2
17:44:29.145 ->
UTC time attribute 814383869
17:44:29.145 ->
local time attribute 814383869
17:44:29.145 -> [240026][I][z2s_web_gui.cpp:751] fillMemoryUptimeInformation(): Memory & uptime information <b><i>Flash chip real size:</b></i> 4194304 B <b>| <i>Free Sketch Space:</b></i> 2621440 B<br><b><i>HeapSize:</b></i> 358476 B <b>| <i>FreeHeap:</b></i> 122584 B <b>| <i>MinimalFreeHeap:</b></i> 102228 B <b>| <i>MaxAllocHeap:</b></i> 102388 B<br><b><i>uxTaskGetStackHighWaterMark:</b></i> 3128 B <br><b><i>Total PSRAM:</b></i> 0 B <b>| <i>Free PSRAM:</b></i> 0 B<br><br><b><i>Local time:</i></b> Tue Oct 21 17:44:29 2025
17:44:29.145 -> <b><i>Supla uptime:</i></b> 240 s
17:44:33.176 -> [244053][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
17:44:33.176 -> [244054][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
17:44:33.176 ->
17:44:33.176 ->
17:44:33.176 ->
APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 142, rx_time: 0
17:44:33.176 -> [244055][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0xef00, command id: 2
17:44:33.176 -> [244056][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
17:44:33.176 -> [244056][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 0, disable_default_response 0, is_manuf_specific 0
17:44:33.176 -> [244057][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
17:44:33.176 -> [244057][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 15 size: 7
17:44:33.176 -> [244058][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:33.176 -> [244058][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x09
17:44:33.176 -> [244058][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x01
17:44:33.176 -> [244059][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x04
17:44:33.176 -> [244059][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:33.176 -> [244059][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x01
17:44:33.176 -> [244060][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x3fb7, 0x3fb7, 0x0, 0x0
17:44:33.176 -> [244060][I][z2s_devices_table.cpp:3437] Z2S_onCustomCmdReceive(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, cluster 0xef00, cmd id 0x2
17:44:33.176 -> [244061][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:44:33.176 -> [244062][I][z2s_devices_table.cpp:3447] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
17:44:33.176 -> [244062][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
17:44:33.176 -> [244063][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x1040) callback
17:44:33.176 -> [244063][I][ZigbeeHandlers.cpp:484] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x3fb7
17:44:33.176 -> [244064][I][ZigbeeHandlers.cpp:485] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
17:44:33.176 -> [244064][I][ZigbeeHandlers.cpp:486] zb_cmd_custom_cluster_req_handler(): Payload size: 7
17:44:33.176 -> [244065][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
17:44:33.176 -> [244065][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x9
17:44:33.176 -> [244066][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x1
17:44:33.176 -> [244066][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x4
17:44:33.176 -> [244066][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
17:44:33.176 -> [244067][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
17:44:33.176 -> [244067][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
17:44:33.176 -> [244068][I][z2s_device_tuya_custom_cluster.cpp:2010] processTuyaCustomCluster(): processing Tuya custom cluster 0xEF00, command id 0x2
17:44:33.176 -> [244068][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:44:33.176 -> [244069][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x3e8
17:44:33.176 -> [244070][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:44:33.176 -> [244071][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xbde
17:44:33.176 -> [244072][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:44:33.176 -> [244072][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xb54
17:44:33.176 -> [244073][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xb54
17:44:33.270 -> Channel(0) value changed to 0
17:44:33.270 -> Send: [53 55 50 4C 41 17 2B 00 00 00 67 00 00 00 0E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
17:44:33.270 -> Send: [53 55 50 4C 41 ]
17:44:33.738 -> [244613][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
17:44:33.738 -> [244613][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
17:44:33.738 ->
17:44:33.738 ->
17:44:33.738 ->
17:44:33.738 -> [244615][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x500, command id: 0
17:44:33.738 -> [244615][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
17:44:33.738 -> [244616][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 0, disable_default_response 1, is_manuf_specific 0
17:44:33.738 -> [244616][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
17:44:33.738 -> [244617][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 26 size: 6
17:44:33.738 -> [244617][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:33.738 -> [244618][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:33.738 -> [244619][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:33.738 -> [244619][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x3fb7, 0x3fb7, 0x0, 0x0
17:44:33.738 -> [244619][I][z2s_devices_table.cpp:3437] Z2S_onCustomCmdReceive(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, cluster 0x500, cmd id 0x0
17:44:33.738 -> [244620][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:44:33.738 -> [244621][I][z2s_devices_table.cpp:3447] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
17:44:33.738 -> [244621][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
17:44:33.738 -> [244622][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x1031) callback
17:44:33.738 -> [244622][V][ZigbeeHandlers.cpp:435] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0x3fb7) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x0), extended status (0x0), zone id (0x0), delay (0x0)
17:44:33.738 -> [244623][I][z2s_devices_table.cpp:3149] Z2S_onIASzoneStatusChangeNotification(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, cluster 0x500, zone status 0x0
17:44:33.738 -> [244624][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x3e8
17:44:33.738 -> [244625][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x3e8
17:44:33.738 -> [244626][I][z2s_devices_table.cpp:3202] Z2S_onIASzoneStatusChangeNotification(): IASZONE - IAS_ZONE_ALARM_2_SID: channel:0, status: 0
17:44:33.738 -> [244627][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x3e8
17:44:33.785 -> Channel(0) value changed to 1
17:44:33.785 -> Send: [53 55 50 4C 41 17 2C 00 00 00 67 00 00 00 0E 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 ]
17:44:33.785 -> Send: [53 55 50 4C 41 ]
17:44:35.519 -> [246394][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
17:44:35.519 -> [246395][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
17:44:35.519 ->
17:44:35.519 ->
17:44:35.519 ->
17:44:35.519 -> [246397][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0xef00, command id: 2
17:44:35.519 -> [246397][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
17:44:35.519 -> [246398][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 0, disable_default_response 0, is_manuf_specific 0
17:44:35.519 -> [246398][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
17:44:35.519 -> [246398][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 5 size: 10
17:44:35.519 -> [246399][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:35.519 -> [246399][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x0B
17:44:35.519 -> [246399][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x6A
17:44:35.519 -> [246400][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x02
17:44:35.519 -> [246400][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:35.519 -> [246400][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x04
17:44:35.519 -> [246401][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:35.519 -> [246402][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x53
17:44:35.519 -> [246402][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x3fb7, 0x3fb7, 0x0, 0x0
17:44:35.519 -> [246402][I][z2s_devices_table.cpp:3437] Z2S_onCustomCmdReceive(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, cluster 0xef00, cmd id 0x2
17:44:35.519 -> [246403][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:44:35.519 -> [246404][I][z2s_devices_table.cpp:3447] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
17:44:35.519 -> [246404][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
17:44:35.519 -> [246405][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x1040) callback
17:44:35.519 -> [246405][I][ZigbeeHandlers.cpp:484] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x3fb7
17:44:35.519 -> [246406][I][ZigbeeHandlers.cpp:485] zb_cmd_custom_cluster_req_handler(): Frame control 0x0
17:44:35.519 -> [246406][I][ZigbeeHandlers.cpp:486] zb_cmd_custom_cluster_req_handler(): Payload size: 10
17:44:35.519 -> [246407][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
17:44:35.519 -> [246407][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0xb
17:44:35.519 -> [246408][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x6a
17:44:35.519 -> [246408][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
17:44:35.519 -> [246409][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
17:44:35.519 -> [246409][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
17:44:35.519 -> [246409][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
17:44:35.519 -> [246410][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
17:44:35.519 -> [246410][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
17:44:35.519 -> [246411][I][ZigbeeHandlers.cpp:488] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x53
17:44:35.519 -> [246411][I][z2s_device_tuya_custom_cluster.cpp:2010] processTuyaCustomCluster(): processing Tuya custom cluster 0xEF00, command id 0x2
17:44:35.519 -> [246412][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:44:35.519 -> [246412][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x3e8
17:44:35.519 -> [246413][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:44:35.519 -> [246414][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:44:35.519 -> [246414][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xbde
17:44:35.519 -> [246415][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:44:35.519 -> [246415][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xb54
17:44:35.519 -> [246416][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xb54
17:44:35.519 -> [246417][I][z2s_general_purpose_measurement.cpp:152] msgZ2SDeviceGeneralPurposeMeasurement(): channel(2), value: 83.000000
17:44:36.082 -> [246945][D][ZigbeeCore.cpp:479] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
17:44:36.082 -> [246946][D][ZigbeeCore.cpp:480] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
17:44:36.082 ->
17:44:36.082 ->
17:44:36.082 ->
17:44:36.082 -> [246948][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x400, command id: 10
17:44:36.082 -> [246948][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
17:44:36.082 -> [246948][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
17:44:36.082 -> [246949][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
17:44:36.082 -> [246949][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 6 size: 5
17:44:36.082 -> [246950][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
17:44:36.082 -> [246950][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x21
17:44:36.082 -> [246951][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0xF3
17:44:36.082 -> [246951][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x4A
17:44:36.082 -> [246951][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x3fb7, 0x3fb7, 0x0, 0x0
17:44:36.082 -> [246952][I][z2s_devices_table.cpp:3437] Z2S_onCustomCmdReceive(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, cluster 0x400, cmd id 0xa
17:44:36.082 -> [246953][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0xffffffff
17:44:36.082 -> [246953][I][z2s_devices_table.cpp:3447] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x0
17:44:36.082 -> [246954][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
17:44:36.082 -> [246955][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x2000) callback
17:44:36.082 -> [246955][V][ZigbeeHandlers.cpp:234] zb_attribute_reporting_handler(): Received report from address(0x3fb7) src endpoint(1) to dst endpoint(1) cluster(0x400)
17:44:36.082 -> [246956][I][ZigbeeGateway.cpp:1008] zbAttributeReporting(): illuminance measurement 0x4af3
17:44:36.082 -> [246956][I][z2s_devices_table.cpp:1810] Z2S_onIlluminanceReceive(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, illuminance 19187
17:44:36.082 -> [246957][I][z2s_devices_table.cpp:156] Z2S_findChannelNumberSlot(): A4:C1:38:5A:D1:74:D8:D4, endpoint 0x1, channel type 0x2328
17:44:36.082 -> [246957][I][z2s_general_purpose_measurement.cpp:152] msgZ2SDeviceGeneralPurposeMeasurement(): channel(2), value: 1918.000000
17:44:39.176 -> [250059][I][Z2S_Gateway.ino:860] loop(): Memory information: Flash chip real size:4194304 B, Free Sketch Space:2621440 B, Free Heap:122520, Minimal Free Heap:102228 B, HeapSize:358476 B, MaxAllocHeap:102388 B, Supla uptime:250 s
17:44:39.691 -> Channel(2) value changed to 1918.00
17:44:39.691 -> Send: [53 55 50 4C 41 17 2D 00 00 00 67 00 00 00 0E 00 00 00 02 00 00 00 00 00 00 00 00 00 00 F8 9D 40 ]
17:44:39.691 -> Send: [53 55 50 4C 41 ]
