Generalnie tymi plikami, które są w moim GitHubie w katalogu lib, musisz nadpisać odpowiadające im pliki w katologu Zigbee/src. Niestety póki co to jedyne rozwiązanie.lukasz06 wrote: Mon Jan 06, 2025 7:57 pm Ściągnąłem najnowszy kod z githuba i wywala błądCode: Select all
FQBN: esp32:esp32:XIAO_ESP32C6:PartitionScheme=zigbee_zczr,EraseFlash=all,ZigbeeMode=zczr Using board 'XIAO_ESP32C6' from platform in folder: C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7 Using core 'esp32' from platform in folder: C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7 cmd /c if exist "C:\\Users\\Jacek\\Documents\\Arduino\\Bramka Zigbee\\Zigbee_Gateway_2\\partitions.csv" COPY /y "C:\\Users\\Jacek\\Documents\\Arduino\\Bramka Zigbee\\Zigbee_Gateway_2\\partitions.csv" "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1\\partitions.csv" cmd /c if not exist "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1\\partitions.csv" if exist "C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.7\\variants\\XIAO_ESP32C6\\partitions.csv" COPY "C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.7\\variants\\XIAO_ESP32C6\\partitions.csv" "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1\\partitions.csv" cmd /c if not exist "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1\\partitions.csv" COPY "C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.7\\tools\\partitions\\zigbee_zczr.csv" "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1\\partitions.csv" 1 file(s) copied. cmd /c IF EXIST "C:\\Users\\Jacek\\Documents\\Arduino\\Bramka Zigbee\\Zigbee_Gateway_2\\bootloader.bin" ( COPY /y "C:\\Users\\Jacek\\Documents\\Arduino\\Bramka Zigbee\\Zigbee_Gateway_2\\bootloader.bin" "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1\\Zigbee_Gateway_2.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.7\\variants\\XIAO_ESP32C6\\bootloader.bin" ( COPY "C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.7\\variants\\XIAO_ESP32C6\\bootloader.bin" "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1\\Zigbee_Gateway_2.ino.bootloader.bin" ) ELSE ( "C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.6\\esptool.exe" --chip esp32c6 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1\\Zigbee_Gateway_2.ino.bootloader.bin" "C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-632e0c2a\\esp32c6\\bin\\bootloader_qio_80m.elf" ) ) esptool.py v4.6 Creating esp32c6 image... Merged 2 ELF sections Successfully created esp32c6 image. cmd /c if exist "C:\\Users\\Jacek\\Documents\\Arduino\\Bramka Zigbee\\Zigbee_Gateway_2\\build_opt.h" COPY /y "C:\\Users\\Jacek\\Documents\\Arduino\\Bramka Zigbee\\Zigbee_Gateway_2\\build_opt.h" "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1\\build_opt.h" cmd /c if not exist "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1\\build_opt.h" type nul > "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1\\build_opt.h" cmd /c type nul > "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1/file_opts" cmd /c COPY /y "C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-632e0c2a\\esp32c6\\sdkconfig" "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1\\sdkconfig" 1 file(s) copied. Detecting libraries used... C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302/bin/riscv32-esp-elf-g++ -c @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=160000000L -DARDUINO=10607 -DARDUINO_XIAO_ESP32C6 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="XIAO_ESP32C6" -DARDUINO_VARIANT="XIAO_ESP32C6" -DARDUINO_PARTITION_zigbee_zczr -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:XIAO_ESP32C6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=zigbee_zczr,DebugLevel=none,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=zczr" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 -DZIGBEE_MODE_ZCZR @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/defines -IC:\Users\Jacek\Documents\Arduino\Bramka Zigbee\Zigbee_Gateway_2 -iprefix C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/include/ @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/includes -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/qio_qspi/include -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\cores\esp32 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\variants\XIAO_ESP32C6 @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/build_opt.h @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/file_opts C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1\sketch\Zigbee_Gateway_2.ino.cpp -o nul Alternatives for ZigbeeGateway.h: [[email protected]] ResolveLibrary(ZigbeeGateway.h) -> candidates: [[email protected]] C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302/bin/riscv32-esp-elf-g++ -c @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=160000000L -DARDUINO=10607 -DARDUINO_XIAO_ESP32C6 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="XIAO_ESP32C6" -DARDUINO_VARIANT="XIAO_ESP32C6" -DARDUINO_PARTITION_zigbee_zczr -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:XIAO_ESP32C6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=zigbee_zczr,DebugLevel=none,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=zczr" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 -DZIGBEE_MODE_ZCZR @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/defines -IC:\Users\Jacek\Documents\Arduino\Bramka Zigbee\Zigbee_Gateway_2 -iprefix C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/include/ @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/includes -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/qio_qspi/include -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\cores\esp32 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\variants\XIAO_ESP32C6 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee\src @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/build_opt.h @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/file_opts C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1\sketch\Zigbee_Gateway_2.ino.cpp -o nul C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302/bin/riscv32-esp-elf-g++ -c @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=160000000L -DARDUINO=10607 -DARDUINO_XIAO_ESP32C6 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="XIAO_ESP32C6" -DARDUINO_VARIANT="XIAO_ESP32C6" -DARDUINO_PARTITION_zigbee_zczr -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:XIAO_ESP32C6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=zigbee_zczr,DebugLevel=none,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=zczr" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 -DZIGBEE_MODE_ZCZR @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/defines -IC:\Users\Jacek\Documents\Arduino\Bramka Zigbee\Zigbee_Gateway_2 -iprefix C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/include/ @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/includes -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/qio_qspi/include -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\cores\esp32 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\variants\XIAO_ESP32C6 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee\src @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/build_opt.h @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/file_opts C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee\src\ZigbeeCore.cpp -o nul C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302/bin/riscv32-esp-elf-g++ -c @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=160000000L -DARDUINO=10607 -DARDUINO_XIAO_ESP32C6 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="XIAO_ESP32C6" -DARDUINO_VARIANT="XIAO_ESP32C6" -DARDUINO_PARTITION_zigbee_zczr -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:XIAO_ESP32C6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=zigbee_zczr,DebugLevel=none,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=zczr" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 -DZIGBEE_MODE_ZCZR @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/defines -IC:\Users\Jacek\Documents\Arduino\Bramka Zigbee\Zigbee_Gateway_2 -iprefix C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/include/ @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/includes -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/qio_qspi/include -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\cores\esp32 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\variants\XIAO_ESP32C6 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee\src @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/build_opt.h @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/file_opts C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee\src\ZigbeeEP.cpp -o nul C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302/bin/riscv32-esp-elf-g++ -c @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=160000000L -DARDUINO=10607 -DARDUINO_XIAO_ESP32C6 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="XIAO_ESP32C6" -DARDUINO_VARIANT="XIAO_ESP32C6" -DARDUINO_PARTITION_zigbee_zczr -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:XIAO_ESP32C6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=zigbee_zczr,DebugLevel=none,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=zczr" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 -DZIGBEE_MODE_ZCZR @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/defines -IC:\Users\Jacek\Documents\Arduino\Bramka Zigbee\Zigbee_Gateway_2 -iprefix C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/include/ @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/includes -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/qio_qspi/include -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\cores\esp32 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\variants\XIAO_ESP32C6 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee\src @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/build_opt.h @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/file_opts C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee\src\ZigbeeGateway.cpp -o nul C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302/bin/riscv32-esp-elf-g++ -c @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=160000000L -DARDUINO=10607 -DARDUINO_XIAO_ESP32C6 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="XIAO_ESP32C6" -DARDUINO_VARIANT="XIAO_ESP32C6" -DARDUINO_PARTITION_zigbee_zczr -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:XIAO_ESP32C6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=zigbee_zczr,DebugLevel=none,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=zczr" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 -DZIGBEE_MODE_ZCZR @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/defines -IC:\Users\Jacek\Documents\Arduino\Bramka Zigbee\Zigbee_Gateway_2 -iprefix C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/include/ @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/includes -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/qio_qspi/include -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\cores\esp32 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\variants\XIAO_ESP32C6 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee\src @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/build_opt.h @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/file_opts C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee\src\ZigbeeHandlers.cpp -o nul C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302/bin/riscv32-esp-elf-g++ -c @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=160000000L -DARDUINO=10607 -DARDUINO_XIAO_ESP32C6 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="XIAO_ESP32C6" -DARDUINO_VARIANT="XIAO_ESP32C6" -DARDUINO_PARTITION_zigbee_zczr -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:XIAO_ESP32C6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=zigbee_zczr,DebugLevel=none,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=zczr" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 -DZIGBEE_MODE_ZCZR @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/defines -IC:\Users\Jacek\Documents\Arduino\Bramka Zigbee\Zigbee_Gateway_2 -iprefix C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/include/ @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/includes -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/qio_qspi/include -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\cores\esp32 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\variants\XIAO_ESP32C6 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee\src @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/build_opt.h @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/file_opts C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee\src\ZigbeeIASZone.cpp -o nul C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302/bin/riscv32-esp-elf-g++ -c @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=160000000L -DARDUINO=10607 -DARDUINO_XIAO_ESP32C6 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="XIAO_ESP32C6" -DARDUINO_VARIANT="XIAO_ESP32C6" -DARDUINO_PARTITION_zigbee_zczr -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:XIAO_ESP32C6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=zigbee_zczr,DebugLevel=none,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=zczr" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 -DZIGBEE_MODE_ZCZR @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/defines -IC:\Users\Jacek\Documents\Arduino\Bramka Zigbee\Zigbee_Gateway_2 -iprefix C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/include/ @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/includes -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/qio_qspi/include -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\cores\esp32 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\variants\XIAO_ESP32C6 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee\src @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/build_opt.h @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/file_opts C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee\src\ZigbeeITempMeas.cpp -o nul Generating function prototypes... C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302/bin/riscv32-esp-elf-g++ -c @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=160000000L -DARDUINO=10607 -DARDUINO_XIAO_ESP32C6 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="XIAO_ESP32C6" -DARDUINO_VARIANT="XIAO_ESP32C6" -DARDUINO_PARTITION_zigbee_zczr -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:XIAO_ESP32C6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=zigbee_zczr,DebugLevel=none,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=zczr" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 -DZIGBEE_MODE_ZCZR @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/defines -IC:\Users\Jacek\Documents\Arduino\Bramka Zigbee\Zigbee_Gateway_2 -iprefix C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/include/ @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/includes -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/qio_qspi/include -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\cores\esp32 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\variants\XIAO_ESP32C6 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee\src @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/build_opt.h @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/file_opts C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1\sketch\Zigbee_Gateway_2.ino.cpp -o C:\Users\Jacek\AppData\Local\Temp\1625517203\sketch_merged.cpp C:\Users\Jacek\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\Jacek\AppData\Local\Temp\1625517203\sketch_merged.cpp Kompilowanie szkicu... "C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-rv32\\2302/bin/riscv32-esp-elf-g++" -MMD -c "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-632e0c2a\\esp32c6/flags/cpp_flags" -Os -Werror=return-type -DF_CPU=160000000L -DARDUINO=10607 -DARDUINO_XIAO_ESP32C6 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"XIAO_ESP32C6\"" "-DARDUINO_VARIANT=\"XIAO_ESP32C6\"" -DARDUINO_PARTITION_zigbee_zczr "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:XIAO_ESP32C6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=zigbee_zczr,DebugLevel=none,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=zczr\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 -DZIGBEE_MODE_ZCZR "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-632e0c2a\\esp32c6/flags/defines" "-IC:\\Users\\Jacek\\Documents\\Arduino\\Bramka Zigbee\\Zigbee_Gateway_2" -iprefix "C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-632e0c2a\\esp32c6/include/" "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-632e0c2a\\esp32c6/flags/includes" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-632e0c2a\\esp32c6/qio_qspi/include" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.7\\cores\\esp32" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.7\\variants\\XIAO_ESP32C6" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.7\\libraries\\Zigbee\\src" "@C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1/build_opt.h" "@C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1/file_opts" "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1\\sketch\\Zigbee_Gateway_2.ino.cpp" -o "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1\\sketch\\Zigbee_Gateway_2.ino.cpp.o" C:\Users\Jacek\Documents\Arduino\Bramka Zigbee\Zigbee_Gateway_2\Zigbee_Gateway_2.ino:1:9: warning: #pragma once in main file 1 | #pragma once | ^~~~ In file included from C:\Users\Jacek\Documents\Arduino\Bramka Zigbee\Zigbee_Gateway_2\Zigbee_Gateway_2.ino:5: C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee\src/ZigbeeGateway.h:102:8: error: 'void ZigbeeGateway::zbAttributeRead(uint16_t, const esp_zb_zcl_attribute_t*)' marked 'override', but does not override 102 | void zbAttributeRead(uint16_t cluster_id, const esp_zb_zcl_attribute_t *attribute) override; | ^~~~~~~~~~~~~~~ Użycie biblioteki Zigbee w wersji 3.0.7 z folderu: C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee exit status 1 Compilation error: exit status 1
- Has thanked: 291 times
- Been thanked: 161 times
@Zibi_007 Wrzuciłem wersję, która listuje wszystkie endpointy i ich klastry na danym urządzeniu. Możesz wypróbować ją na tym gniazdku i przycisku x4?
U mie kompiluje się bez problemu.lukasz06 wrote: Mon Jan 06, 2025 7:57 pm Ściągnąłem najnowszy kod z githuba i wywala błądCode: Select all
Załączam gotowy .bin (wgranie jak zwykle od 0x0).
Rzeczywiście, pokazuje temperaturę i wilgotność. Kolejny krok do przodu, gratulacje!vajera wrote: Mon Jan 06, 2025 7:18 pm [...]
Wrzuciłem kilka poprawek - wyciąga więcej danych oraz raportuje temperaturę i wilgotność.
23:51:57.923 -> [ 21565][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
23:51:57.923 -> [ 21566][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0xb1e7) src endpoint(1) to dst endpoint(1) cluster(0x402)
23:51:57.923 -> [ 21566][I][ZigbeeGateway.cpp:173] zbAttributeRead(): zbAttributeRead from 45543, endpoint 1, cluster 1026, attribute 0
23:51:57.923 -> [ 21567][I][ZigbeeGateway.cpp:178] zbAttributeRead(): zbAttributeRead temperature measurement 29.430000
23:51:58.052 -> [ 21689][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
23:51:58.052 -> [ 21689][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0xb1e7) src endpoint(1) to dst endpoint(1) cluster(0x405)
23:51:58.052 -> [ 21690][I][ZigbeeGateway.cpp:173] zbAttributeRead(): zbAttributeRead from 45543, endpoint 1, cluster 1029, attribute 0
23:51:58.052 -> [ 21691][I][ZigbeeGateway.cpp:185] zbAttributeRead(): data type 33
23:51:58.052 -> [ 21691][I][ZigbeeGateway.cpp:186] zbAttributeRead(): zbAttributeRead humidity measurement 44.160000Code: Select all
00:05:44.509> [ 610][D][ZigbeeCore.cpp:124] zigbeeInit(): Initialize Zigbee stack
00:05:44.509>
00:05:44.509> [ 704][D][ZigbeeCore.cpp:131] zigbeeInit(): Register all Zigbee EPs in list
00:05:44.509>
00:05:44.509> [ 706][I][ZigbeeCore.cpp:139] zigbeeInit(): List of registered Zigbee EPs:
00:05:44.509>
00:05:44.509> [ 707][I][ZigbeeCore.cpp:141] zigbeeInit(): Device type: Home Gateway, Endpoint: 1, Device ID: 0x0050
00:05:44.509>
00:05:44.509> [ 710][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: ZDO Config Ready (0x17), status: ESP_FAIL
00:05:44.509>
00:05:44.509> [ 711][I][ZigbeeCore.cpp:220] esp_zb_app_signal_handler(): Zigbee stack initialized
00:05:44.509>
00:05:44.509> [ 713][I][ZigbeeCore.cpp:226] esp_zb_app_signal_handler(): Device started up in factory-reset mode
00:05:44.509>
00:05:44.509> [ 713][I][ZigbeeCore.cpp:230] esp_zb_app_signal_handler(): Start network formation
00:05:44.509>
00:05:44.509> [ 3081][I][ZigbeeCore.cpp:329] esp_zb_app_signal_handler(): Network(0x9e41) closed, devices joining not allowed.
00:05:44.509>
00:05:44.509> [ 3082][I][ZigbeeCore.cpp:261] esp_zb_app_signal_handler(): Formed network successfully (Extended PAN ID: f0:f5:bd:ff:fe:03:07:18
00:05:44.509> , PAN ID: 0x9e41, Channel:22, Short Address: 0x0000)
00:05:44.509>
00:05:44.509> [ 3551][I][ZigbeeCore.cpp:327] esp_zb_app_signal_handler(): Network(0x9e41) is open for 180 seconds
00:05:44.509>
00:05:44.509> [ 3552][I][ZigbeeCore.cpp:276] esp_zb_app_signal_handler(): Network steering started
00:05:44.509>
00:06:02.294> [ 21552][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
00:06:02.294>
00:06:02.294> [ 21554][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
00:06:02.294>
00:06:02.817> [ 22074][I][ZigbeeCore.cpp:299] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x613b)
00:06:02.817>
00:06:02.817> [ 22075][V][ZigbeeCore.cpp:303] esp_zb_app_signal_handler(): Device capabilities: 0x80
00:06:02.817>
00:06:02.937> [ 22191][I][ZigbeeGateway.cpp:91] find_Cb(): Found sensor
00:06:02.937>
00:06:02.937> [ 22191][D][ZigbeeGateway.cpp:100] find_Cb(): Sensor found: short address(0x613b), endpoint(1)
00:06:02.937>
00:06:02.937> [ 22203][I][ZigbeeGateway.cpp:163] printJoinedDevices(): joined devices:
00:06:02.937>
00:06:02.937> [ 22203][I][ZigbeeGateway.cpp:166] printJoinedDevices(): Device on endpoint 1, short address: 0x613b
00:06:02.937>
00:06:02.937> [ 22204][D][Zigbee_Gateway_2.ino:161] loop(): getJoinedDEvices 1 0 357913941 before
00:06:02.937>
00:06:02.937> [ 22204][D][Zigbee_Gateway_2.ino:164] loop(): getJoinedDEvices 1 0 357913941 after
00:06:02.937>
00:06:02.937> [ 22205][I][ZigbeeGateway.cpp:163] printJoinedDevices(): joined devices:
00:06:02.937>
00:06:03.315> [ 22307][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x1000) callback
00:06:03.315>
00:06:03.315> [ 22308][V][ZigbeeHandlers.cpp:87] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x613b) src endpoint(1)
00:06:03.315> to dst endpoint(1) cluster(0x0)
00:06:03.315>
00:06:03.315> [ 22308][V][ZigbeeHandlers.cpp:96] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x
00:06:03.315> 4), type(0x42), value(16)
00:06:03.315>
00:06:03.315> [ 22309][I][ZigbeeEP.cpp:223] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_fllyghyj"
00:06:03.315>
00:06:03.315> [ 22205][I][Zigbee_Gateway_2.ino:167] loop(): manufacturer _TZ3000_fllyghyj
00:06:03.315>
00:06:03.315> [ 22426][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x1000) callback
00:06:03.315>
00:06:03.315> [ 22427][V][ZigbeeHandlers.cpp:87] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x613b) src endpoint(1)
00:06:03.315>
00:06:03.315> [ 22427][V][ZigbeeHandlers.cpp:96] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x
00:06:03.315> 5), type(0x42), value(6)
00:06:03.315>
00:06:03.315> [ 22428][I][ZigbeeEP.cpp:232] zbReadBasicCluster(): Peer Model is "TS0201"
00:06:03.315>
00:06:03.315> [ 22429][I][Zigbee_Gateway_2.ino:169] loop(): model TS0201
00:06:03.315>
00:06:03.315> [ 22430][D][ZigbeeGateway.cpp:112] bindDeviceCluster(): Request sensor to bind us
00:06:03.315>
00:06:03.315> [ 22433][V][ZigbeeGateway.cpp:73] bindCb(): Binding success (ZC side)
00:06:03.315>
00:06:03.315> [ 22557][V][ZigbeeGateway.cpp:75] bindCb(): Binding success (ED side
00:06:03.315>
00:06:04.347> [ 23496][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
00:06:04.347>
00:06:04.347> [ 23577][I][ZigbeeCore.cpp:327] esp_zb_app_signal_handler(): Network(0x9e41) is open for 180 seconds
00:06:04.347>
00:06:09.371> [ 28636][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
00:06:09.371>
00:06:09.371> [ 28637][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x613b) src endpoint(1) to dst e
00:06:09.371> ndpoint(1) cluster(0x402)
00:06:09.371>
00:06:09.371> [ 28637][I][ZigbeeGateway.cpp:173] zbAttributeRead(): zbAttributeRead from 24891, endpoint 1, cluster 1026, attribute 0
00:06:09.371>
00:06:09.371> [ 28638][I][ZigbeeGateway.cpp:178] zbAttributeRead(): zbAttributeRead temperature measurement 31.920000
00:06:09.371>
00:06:09.661> [ 28761][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
00:06:09.661>
00:06:09.661> [ 28761][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x613b) src endpoint(1) to dst e
00:06:09.661> ndpoint(1) cluster(0x405)
00:06:09.661>
00:06:09.661> [ 28762][I][ZigbeeGateway.cpp:173] zbAttributeRead(): zbAttributeRead from 24891, endpoint 1, cluster 1029, attribute 0
00:06:09.661>
00:06:09.661> [ 28762][I][ZigbeeGateway.cpp:185] zbAttributeRead(): data type 33
00:06:09.661>
00:06:09.661> [ 28763][I][ZigbeeGateway.cpp:186] zbAttributeRead(): zbAttributeRead humidity measurement 49.369999
Nie jestem pewno, o co dokładnie pytasz, ale czujnik wysyła pomiar temperatury jako atrybut Zigbee:[email protected] wrote: Mon Jan 06, 2025 7:26 pmTwój ostatni commit jest odpowiedzią że dobrze kombinuje ale ..vajera wrote: Mon Jan 06, 2025 7:18 pma rozwiń pytanie?[email protected] wrote: Mon Jan 06, 2025 5:45 pm @vajera a w jaki sposób wyciągałeś wartość przesłaną z urządzenia? kombinuje i nie wiem w sumie na co patrzę :/
BTW moje kombinacje tutaj:
https://github.com/rkalwak/Zigbee2SuplaArduinoIDE
Pytanie jest takie :
Liczba jako int16 którą dostaje z czujnika temp to są miliony i zastanawiam się jak z tego ma wyjść temperatura pokojowa bo nawet jak podzielę przez 100 żeby zrobić float to i tak nie pasuje
Np 1082241337 ale chyba zaczynam rozumieć że tu chodzi o indianess i pewnie to jest normalna liczba - nie sprawdzałem w sumie
attribute->id == ESP_ZB_ZCL_ATTR_TEMP_MEASUREMENT_VALUE_ID
a temperatura jest w strukturze:
typedef struct esp_zb_zcl_attribute_data_s {
esp_zb_zcl_attr_type_t type; /*!< The type of attribute, which can refer to esp_zb_zcl_attr_type_t */
uint16_t size; /*!< The value size of attribute */
void *value; /*!< The value of attribute, Note that if the type is string/array, the first byte of value indicates the string length */
} ESP_ZB_PACKED_STRUCT esp_zb_zcl_attribute_data_t;
int16_t example = 15;
int16_t *example_ptr = &example;
print(example_ptr) - błąd, drukujesz wartość wskaźnika czyli adres w pamięci, który aktualnie wskazuje na położenie zmiennej example
print(*example_ptr) - teraz wyjdzie "15";
Szybciej dodajesz te wersje, niż ja zdążę pobrać i skompilować. Zaraz działamvajera wrote: Mon Jan 06, 2025 11:06 pm @Zibi_007 Wrzuciłem wersję, która listuje wszystkie endpointy i ich klastry na danym urządzeniu. Możesz wypróbować ją na tym gniazdku i przycisku x4?
Szukasz nowego GG? Jest tutaj: https://forum.supla.org/viewtopic.php?t=18036OK, gniazdko:vajera wrote: Mon Jan 06, 2025 11:06 pm @Zibi_007 Wrzuciłem wersję, która listuje wszystkie endpointy i ich klastry na danym urządzeniu. Możesz wypróbować ją na tym gniazdku i przycisku x4?
00:30:35.961>
00:30:35.961> [ 2052][D][ZigbeeCore.cpp:124] zigbeeInit(): Initialize Zigbee stack
00:30:35.961>
00:30:35.961> [ 2112][D][ZigbeeCore.cpp:131] zigbeeInit(): Register all Zigbee EPs in list
00:30:35.961>
00:30:35.961> [ 2114][I][ZigbeeCore.cpp:139] zigbeeInit(): List of registered Zigbee EPs:
00:30:35.961>
00:30:35.961> [ 2115][I][ZigbeeCore.cpp:141] zigbeeInit(): Device type: Home Gateway, Endpoint: 1, Device ID: 0x0050
00:30:35.961>
00:30:39.901> [ 2179][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: ZDO Config Ready (0x17), status: ESP_FAIL
00:30:39.902>
00:30:39.902> [ 2180][I][ZigbeeCore.cpp:220] esp_zb_app_signal_handler(): Zigbee stack initialized
00:30:39.902>
00:30:39.902> [ 2182][I][ZigbeeCore.cpp:226] esp_zb_app_signal_handler(): Device started up in factory-reset mode
00:30:39.902>
00:30:39.902> [ 2183][I][ZigbeeCore.cpp:230] esp_zb_app_signal_handler(): Start network formation
00:30:39.902>
00:30:39.902> [ 4550][I][ZigbeeCore.cpp:329] esp_zb_app_signal_handler(): Network(0x60c0) closed, devices joining not allowed.
00:30:39.902>
00:30:39.902> [ 4552][I][ZigbeeCore.cpp:261] esp_zb_app_signal_handler(): Formed network successfully (Extended PAN ID: f0:f5:bd:ff:fe:03:07:18
00:30:39.902> , PAN ID: 0x60c0, Channel:26, Short Address: 0x0000)
00:30:39.902>
00:30:39.902> [ 5020][I][ZigbeeCore.cpp:327] esp_zb_app_signal_handler(): Network(0x60c0) is open for 180 seconds
00:30:39.902>
00:30:39.902> [ 5021][I][ZigbeeCore.cpp:276] esp_zb_app_signal_handler(): Network steering started
00:30:39.903>
00:31:29.796> [ 55998][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
00:31:29.798>
00:31:29.798> [ 56000][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
00:31:29.798>
00:31:30.146> [ 56076][I][ZigbeeCore.cpp:299] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x91f9)
00:31:30.146>
00:31:30.146> [ 56077][V][ZigbeeCore.cpp:303] esp_zb_app_signal_handler(): Device capabilities: 0x8e
00:31:30.146>
00:31:30.146> [ 56082][I][ZigbeeCore.cpp:299] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x91f9)
00:31:30.146>
00:31:30.146> [ 56083][V][ZigbeeCore.cpp:303] esp_zb_app_signal_handler(): Device capabilities: 0x8e
00:31:30.146>
00:31:30.146> [ 56171][I][ZigbeeGateway.cpp:91] find_Cb(): Found sensor
00:31:30.146>
00:31:30.146> [ 56171][D][ZigbeeGateway.cpp:100] find_Cb(): Sensor found: short address(0x91f9), endpoint(1)
00:31:30.146>
00:31:30.146> [ 56190][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
00:31:30.146>
00:31:30.146> [ 56197][I][ZigbeeGateway.cpp:91] find_Cb(): Found sensor
00:31:30.146>
00:31:30.146> [ 56197][D][ZigbeeGateway.cpp:100] find_Cb(): Sensor found: short address(0x91f9), endpoint(1)
00:31:30.146>
00:31:30.146> [ 56252][I][ZigbeeGateway.cpp:163] printJoinedDevices(): joined devices:
00:31:30.146>
00:31:30.146> [ 56252][I][ZigbeeGateway.cpp:166] printJoinedDevices(): Device on endpoint 1, short address: 0x91f9
00:31:30.146>
00:31:30.146> [ 56253][I][ZigbeeGateway.cpp:166] printJoinedDevices(): Device on endpoint 1, short address: 0x91f9
00:31:30.147>
00:31:30.147> [ 56253][D][Zigbee_Gateway_2.ino:202] loop(): getJoinedDEvices 0 1 357913941 before
00:31:30.147>
00:31:30.147> [ 56254][D][Zigbee_Gateway_2.ino:205] loop(): getJoinedDEvices 0 1 357913941 after
00:31:30.147>
00:31:30.147> [ 56255][I][ZigbeeGateway.cpp:163] printJoinedDevices(): joined devices:
00:31:30.147>
00:31:30.147> [ 56255][I][ZigbeeGateway.cpp:166] printJoinedDevices(): Device on endpoint 1, short address: 0x91f9
00:31:30.147>
00:31:30.147> [ 56294][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x1000) callback
00:31:30.147>
00:31:30.147> [ 56294][V][ZigbeeHandlers.cpp:87] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x91f9) src endpoint(1)
00:31:30.147> to dst endpoint(1) cluster(0x0)
00:31:30.147>
00:31:30.147> [ 56295][V][ZigbeeHandlers.cpp:96] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x
00:31:30.147> 4), type(0x42), value(16)
00:31:30.147>
00:31:30.147> [ 56296][I][ZigbeeEP.cpp:223] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_5f43h46b"
00:31:30.147>
00:31:30.147> [ 56256][I][Zigbee_Gateway_2.ino:208] loop(): manufacturer _TZ3000_5f43h46b
00:31:30.147>
00:31:30.147> [ 56346][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x1000) callback
00:31:30.147>
00:31:30.147> [ 56346][V][ZigbeeHandlers.cpp:87] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x91f9) src endpoint(1)
00:31:30.147>
00:31:30.147> [ 56347][V][ZigbeeHandlers.cpp:96] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x
00:31:30.147> 5), type(0x42), value(6)
00:31:30.147>
00:31:30.148> [ 56348][I][ZigbeeEP.cpp:232] zbReadBasicCluster(): Peer Model is "TS011F"
00:31:30.148>
00:31:30.148> [ 56349][I][Zigbee_Gateway_2.ino:210] loop(): model TS011F
00:31:30.148>
00:31:30.148> [ 56350][D][ZigbeeGateway.cpp:112] bindDeviceCluster(): Request sensor to bind us
00:31:30.148>
00:31:30.148>
00:31:30.148> [ 56351][D][ZigbeeGateway.cpp:112] bindDeviceCluster(): Request sensor to bind us
00:31:30.148>
00:31:34.907> [ 56360][V][ZigbeeGateway.cpp:73] bindCb(): Binding success (ZC side)
00:31:34.907>
00:31:34.907> [ 56361][V][ZigbeeGateway.cpp:73] bindCb(): Binding success (ZC side)
00:31:34.907>
00:31:34.907>
00:31:34.907> [ 56362][D][Zigbee_Gateway_2.ino:202] loop(): getJoinedDEvices 1 0 357913941 before
00:31:34.907>
00:31:34.907> [ 56362][D][Zigbee_Gateway_2.ino:205] loop(): getJoinedDEvices 1 0 357913941 after
00:31:34.907>
00:31:34.907> [ 56363][I][ZigbeeGateway.cpp:163] printJoinedDevices(): joined devices:
00:31:34.907>
00:31:34.907> [ 56482][V][ZigbeeGateway.cpp:75] bindCb(): Binding success (ED side
00:31:34.907>
00:31:34.907> [ 56501][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
00:31:34.907>
00:31:34.907> [ 56506][V][ZigbeeGateway.cpp:75] bindCb(): Binding success (ED side
00:31:34.907>
00:31:34.907> [ 56523][V][ZigbeeGateway.cpp:75] bindCb(): Binding success (ED side
00:31:34.907>
00:31:34.907> [ 56581][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
00:31:34.907>
00:31:34.907> [ 56649][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x1000) callback
00:31:34.907>
00:31:34.907> [ 56649][V][ZigbeeHandlers.cpp:87] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x91f9) src endpoint(1)
00:31:34.907> to dst endpoint(1) cluster(0x0)
00:31:34.907>
00:31:34.907> [ 56650][V][ZigbeeHandlers.cpp:96] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x
00:31:34.908> 4), type(0x42), value(16)
00:31:34.908>
00:31:34.908> [ 56651][I][ZigbeeEP.cpp:223] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_5f43h46b"
00:31:34.908>
00:31:34.908> [ 56365][I][Zigbee_Gateway_2.ino:208] loop(): manufacturer _TZ3000_5f43h46b
00:31:34.908>
00:31:34.908> [ 56694][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x1000) callback
00:31:34.908>
00:31:34.908> [ 56695][V][ZigbeeHandlers.cpp:87] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x91f9) src endpoint(1)
00:31:34.908> to dst endpoint(1) cluster(0x0)
00:31:34.908>
00:31:34.908> [ 56696][V][ZigbeeHandlers.cpp:96] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x
00:31:34.908> 5), type(0x42), value(6)
00:31:34.908>
00:31:34.908> [ 56696][I][ZigbeeEP.cpp:232] zbReadBasicCluster(): Peer Model is "TS011F"
00:31:34.908>
00:31:34.908> [ 56698][I][Zigbee_Gateway_2.ino:210] loop(): model TS011F
00:31:34.908>
00:31:34.908> [ 56698][D][ZigbeeGateway.cpp:112] bindDeviceCluster(): Request sensor to bind us
00:31:34.908>
00:31:34.908> [ 56699][D][ZigbeeGateway.cpp:112] bindDeviceCluster(): Request sensor to bind us
00:31:34.908>
00:31:34.908>
00:31:34.908> [ 56709][V][ZigbeeGateway.cpp:73] bindCb(): Binding success (ZC side)
00:31:34.908>
00:31:34.908>
00:31:34.908> [ 56710][V][ZigbeeGateway.cpp:73] bindCb(): Binding success (ZC side)
00:31:34.908>
00:31:34.908> [ 56711][I][ZigbeeGateway.cpp:154] printGatewayDevices(): gateway devices:
00:31:34.908>
00:31:34.909> [ 56711][I][ZigbeeGateway.cpp:157] printGatewayDevices(): Device on endpoint 1, short address: 0x91f9
00:31:34.909>
00:31:34.909> [ 56712][I][ZigbeeGateway.cpp:157] printGatewayDevices(): Device on endpoint 1, short address: 0x91f9
00:31:34.909>
00:31:34.909> [ 56713][I][ZigbeeGateway.cpp:157] printGatewayDevices(): Device on endpoint 1, short address: 0x91f9
00:31:34.909>
00:31:34.909> [ 56714][I][ZigbeeGateway.cpp:157] printGatewayDevices(): Device on endpoint 1, short address: 0x91f9
00:31:34.909>
00:31:34.909> [ 56715][I][ZigbeeGateway.cpp:157] printGatewayDevices(): Device on endpoint 1, short address: 0x91f9
00:31:34.909>
00:31:34.909>
00:31:34.909> [ 56716][I][ZigbeeGateway.cpp:163] printJoinedDevices(): joined devices:
00:31:34.909>
00:31:34.909> [ 56795][V][ZigbeeGateway.cpp:75] bindCb(): Binding success (ED side
00:31:34.909>
00:31:34.909> [ 56824][V][ZigbeeGateway.cpp:75] bindCb(): Binding success (ED side
00:31:34.909>
00:31:34.909> [ 56853][V][ZigbeeGateway.cpp:75] bindCb(): Binding success (ED side
00:31:34.909>
00:31:34.909> [ 56867][I][Zigbee_Gateway_2.ino:120] Z2S_active_ep_req(): Z2S active_ep_req: device address 37369, endpoints count 1
00:31:34.909>
00:31:34.909> [ 56868][I][Zigbee_Gateway_2.ino:123] Z2S_active_ep_req(): Endpont # 1, id 1
00:31:34.909>
00:31:34.909> [ 59661][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
00:31:34.909>
00:31:34.909> [ 59731][I][ZigbeeCore.cpp:327] esp_zb_app_signal_handler(): Network(0x60c0) is open for 180 seconds
00:31:34.909>
00:31:41.842> [ 61869][I][Zigbee_Gateway_2.ino:147] Z2S_simple_desc_req(): Z2S simple desc failed
00:31:41.842>
00:31:41.842> [ 65632][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
00:31:41.842>
00:31:41.842> [ 65632][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x91f9) src endpoint(1) to dst e
00:31:41.842> ndpoint(1) cluster(0x6)
00:31:41.843>
00:31:41.843> [ 65633][I][ZigbeeGateway.cpp:173] zbAttributeRead(): zbAttributeRead from 37369, endpoint 1, cluster 6, attribute 0
00:31:41.843>
00:31:41.843> [ 65639][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
00:31:41.843>
00:31:41.843> [ 65639][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x91f9) src endpoint(1) to dst e
00:31:41.844> ndpoint(1) cluster(0xe001)
00:31:41.844>
00:31:41.845> [ 65640][I][ZigbeeGateway.cpp:173] zbAttributeRead(): zbAttributeRead from 37369, endpoint 1, cluster 57345, attribute 53264
00:31:41.845>
00:31:41.845> [ 65646][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
00:31:41.845>
00:31:41.846> [ 65647][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x91f9) src endpoint(1) to dst e
00:31:41.846> ndpoint(1) cluster(0xe001)
00:31:41.846>
00:31:41.846> [ 65647][I][ZigbeeGateway.cpp:173] zbAttributeRead(): zbAttributeRead from 37369, endpoint 1, cluster 57345, attribute 53296
00:31:41.846>
00:31:41.847> [ 66173][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
00:31:41.847>
00:32:12.469> -----------------------------------------
00:32:12.469> Monitoring stopped (07.01.2025 00:32:12).
00:35:43.186 -> [ 1117][D][ZigbeeCore.cpp:124] zigbeeInit(): Initialize Zigbee stack
00:35:43.251 -> [ 1175][D][ZigbeeCore.cpp:131] zigbeeInit(): Register all Zigbee EPs in list
00:35:43.251 -> [ 1177][I][ZigbeeCore.cpp:139] zigbeeInit(): List of registered Zigbee EPs:
00:35:43.251 -> [ 1177][I][ZigbeeCore.cpp:141] zigbeeInit(): Device type: Home Gateway, Endpoint: 1, Device ID: 0x0050
00:35:43.251 -> [ 1186][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: ZDO Config Ready (0x17), status: ESP_FAIL
00:35:43.251 -> [ 1186][I][ZigbeeCore.cpp:220] esp_zb_app_signal_handler(): Zigbee stack initialized
00:35:43.251 -> [ 1191][I][ZigbeeCore.cpp:329] esp_zb_app_signal_handler(): Network(0x60c0) closed, devices joining not allowed.
00:35:43.251 -> [ 1192][I][ZigbeeCore.cpp:226] esp_zb_app_signal_handler(): Device started up in non factory-reset mode
00:35:43.251 -> [ 1193][I][ZigbeeCore.cpp:239] esp_zb_app_signal_handler(): Device rebooted
00:35:43.251 -> [ 1193][I][ZigbeeCore.cpp:243] esp_zb_app_signal_handler(): Opening network for joining for 180 seconds
00:35:43.251 -> [ 1194][D][ZigbeeCore.cpp:467] searchBindings(): Requesting binding table for address 0x0000
00:35:43.251 -> [ 1195][D][ZigbeeCore.cpp:407] bindingTableCb(): Binding table callback for address 0x0000 with status 0
00:35:43.251 -> [ 1196][D][ZigbeeCore.cpp:410] bindingTableCb(): Binding table info: total 3, index 0, count 3
00:35:43.251 -> [ 1196][D][ZigbeeCore.cpp:420] bindingTableCb(): Binding table record: src_endp 1, dst_endp 1, cluster_id 0x0006, dst_addr_mode 3
00:35:43.251 -> [ 1197][D][ZigbeeCore.cpp:437] bindingTableCb(): Device bound to EP 1 -> device endpoint: 1, short addr: 0x91f9, ieee addr: 70:B3:D5:2B:60:0F:4F:A8
00:35:43.251 -> [ 1198][D][ZigbeeCore.cpp:420] bindingTableCb(): Binding table record: src_endp 1, dst_endp 1, cluster_id 0x0702, dst_addr_mode 3
00:35:43.251 -> [ 1198][D][ZigbeeCore.cpp:437] bindingTableCb(): Device bound to EP 1 -> device endpoint: 1, short addr: 0x91f9, ieee addr: 70:B3:D5:2B:60:0F:4F:A8
00:35:43.251 -> [ 1199][D][ZigbeeCore.cpp:420] bindingTableCb(): Binding table record: src_endp 1, dst_endp 1, cluster_id 0x0b04, dst_addr_mode 3
00:35:43.251 -> [ 1200][D][ZigbeeCore.cpp:437] bindingTableCb(): Device bound to EP 1 -> device endpoint: 1, short addr: 0x91f9, ieee addr: 70:B3:D5:2B:60:0F:4F:A8
00:35:43.251 -> [ 1200][D][ZigbeeCore.cpp:458] bindingTableCb(): Filling bounded devices finished
00:35:43.381 -> [ 1301][I][ZigbeeCore.cpp:327] esp_zb_app_signal_handler(): Network(0x60c0) is open for 180 seconds
00:35:43.382 -> [ 1303][I][ZigbeeGateway.cpp:154] printGatewayDevices(): gateway devices:
00:35:43.382 -> [ 1303][I][ZigbeeGateway.cpp:157] printGatewayDevices(): Device on endpoint 1, short address: 0x91f9
00:35:43.382 -> [ 1304][I][ZigbeeGateway.cpp:157] printGatewayDevices(): Device on endpoint 1, short address: 0x91f9
00:35:43.382 -> [ 1305][I][ZigbeeGateway.cpp:163] printJoinedDevices(): joined devices:
00:35:43.447 -> [ 1394][I][Zigbee_Gateway_2.ino:120] Z2S_active_ep_req(): Z2S active_ep_req: device address 37369, endpoints count 1
00:35:43.447 -> [ 1394][I][Zigbee_Gateway_2.ino:123] Z2S_active_ep_req(): Endpont # 1, id 1
00:35:48.455 -> [ 6395][I][Zigbee_Gateway_2.ino:147] Z2S_simple_desc_req(): Z2S simple desc failed
00:36:08.029 -> [ 25980][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
00:36:08.029 -> [ 25980][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x91f9) src endpoint(1) to dst endpoint(1) cluster(0x6)
00:36:08.029 -> [ 25981][I][ZigbeeGateway.cpp:173] zbAttributeRead(): zbAttributeRead from 37369, endpoint 1, cluster 6, attribute 0
00:36:09.299 -> [ 27245][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
00:36:09.299 -> [ 27245][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x91f9) src endpoint(1) to dst endpoint(1) cluster(0x6)
00:36:09.299 -> [ 27246][I][ZigbeeGateway.cpp:173] zbAttributeRead(): zbAttributeRead from 37369, endpoint 1, cluster 6, attribute 0
00:36:58.232 -> [ 76160][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
00:36:58.232 -> [ 76160][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x91f9) src endpoint(1) to dst endpoint(1) cluster(0x0)
00:36:58.232 -> [ 76161][I][ZigbeeGateway.cpp:173] zbAttributeRead(): zbAttributeRead from 37369, endpoint 1, cluster 0, attribute 1 Teraz przycisk x4:
00:41:25.905>
00:41:31.778> [ 13558][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
00:41:31.778>
00:41:37.751> [ 19526][V][ZigbeeCore.cpp:200] openNetwork(): Opening network for joining for 180 seconds
00:41:37.751>
00:41:37.859> [ 19638][I][ZigbeeCore.cpp:327] esp_zb_app_signal_handler(): Network(0x60c0) is open for 180 seconds
00:41:37.859>
00:41:42.779> [ 24566][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
00:41:42.779>
00:41:50.845> [ 32636][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
00:41:50.846>
00:42:01.828> [ 43613][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
00:42:01.828>
00:42:04.531> [ 46316][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
00:42:04.531>
00:42:04.532> [ 46317][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x91f9) src endpoint(1) to dst e
00:42:04.533> ndpoint(1) cluster(0x0)
00:42:04.533>
00:42:04.533> [ 46317][I][ZigbeeGateway.cpp:173] zbAttributeRead(): zbAttributeRead from 37369, endpoint 1, cluster 0, attribute 1
00:42:04.533>
00:42:06.513> [ 48300][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
00:42:06.513>
00:42:10.326> [ 52103][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
00:42:10.327>
00:42:10.327> [ 52105][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
00:42:10.327>
00:42:10.841> [ 52623][I][ZigbeeCore.cpp:299] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x9b60)
00:42:10.841>
00:42:10.841> [ 52624][V][ZigbeeCore.cpp:303] esp_zb_app_signal_handler(): Device capabilities: 0x80
00:42:10.841>
00:42:11.343> [ 53129][I][ZigbeeGateway.cpp:91] find_Cb(): Found sensor
00:42:11.343>
00:42:11.344> [ 53129][D][ZigbeeGateway.cpp:100] find_Cb(): Sensor found: short address(0x9b60), endpoint(1)
00:42:11.344>
00:42:11.478> [ 53212][I][ZigbeeGateway.cpp:163] printJoinedDevices(): joined devices:
00:42:11.478>
00:42:11.478> [ 53212][I][ZigbeeGateway.cpp:166] printJoinedDevices(): Device on endpoint 1, short address: 0x9b60
00:42:11.478>
00:42:11.478> [ 53213][D][Zigbee_Gateway_2.ino:202] loop(): getJoinedDEvices 1 0 357913941 before
00:42:11.478>
00:42:11.478> [ 53213][D][Zigbee_Gateway_2.ino:205] loop(): getJoinedDEvices 1 0 357913941 after
00:42:11.478>
00:42:11.478> [ 53214][I][ZigbeeGateway.cpp:163] printJoinedDevices(): joined devices:
00:42:11.478>
00:42:11.845> [ 53631][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x1000) callback
00:42:11.845>
00:42:11.845> [ 53631][V][ZigbeeHandlers.cpp:87] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x9b60) src endpoint(1)
00:42:11.845> to dst endpoint(1) cluster(0x0)
00:42:11.845>
00:42:11.845> [ 53632][V][ZigbeeHandlers.cpp:96] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x
00:42:11.845> 4), type(0x42), value(16)
00:42:11.845>
00:42:11.845> [ 53632][I][ZigbeeEP.cpp:223] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_wkai4ga5"
00:42:11.845>
00:42:11.845> [ 53214][I][Zigbee_Gateway_2.ino:208] loop(): manufacturer _TZ3000_wkai4ga5
00:42:11.845>
00:42:12.356> [ 54136][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x1000) callback
00:42:12.356>
00:42:12.356> [ 54136][V][ZigbeeHandlers.cpp:87] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x9b60) src endpoint(1)
00:42:12.357> to dst endpoint(1) cluster(0x0)
00:42:12.357>
00:42:12.357> [ 54137][V][ZigbeeHandlers.cpp:96] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x
00:42:12.357> 5), type(0x42), value(6)
00:42:12.358>
00:42:12.358> [ 54138][I][ZigbeeEP.cpp:232] zbReadBasicCluster(): Peer Model is "TS0044"
00:42:12.358>
00:42:12.358> [ 54140][I][Zigbee_Gateway_2.ino:210] loop(): model TS0044
00:42:12.358>
00:42:12.360> [ 54141][D][ZigbeeGateway.cpp:112] bindDeviceCluster(): Request sensor to bind us
00:42:12.360>
00:42:12.360> [ 54144][V][ZigbeeGateway.cpp:73] bindCb(): Binding success (ZC side)
00:42:12.360>
00:42:12.360> [ 54145][I][ZigbeeGateway.cpp:154] printGatewayDevices(): gateway devices:
00:42:12.360>
00:42:12.361> [ 54146][I][ZigbeeGateway.cpp:157] printGatewayDevices(): Device on endpoint 1, short address: 0x91f9
00:42:12.361>
00:42:12.361>
00:42:13.025> [ 54147][I][ZigbeeGateway.cpp:157] printGatewayDevices(): Device on endpoint 1, short address: 0x91f9
00:42:13.025>
00:42:13.025> [ 54149][I][ZigbeeGateway.cpp:157] printGatewayDevices(): Device on endpoint 1, short address: 0x9b60
00:42:13.025>
00:42:13.025> [ 54150][I][ZigbeeGateway.cpp:163] printJoinedDevices(): joined devices:
00:42:13.025>
00:42:13.025> [ 54231][V][ZigbeeGateway.cpp:75] bindCb(): Binding success (ED side
00:42:13.025>
00:42:13.025> [ 54245][I][Zigbee_Gateway_2.ino:120] Z2S_active_ep_req(): Z2S active_ep_req: device address 39776, endpoints count 4
00:42:13.025>
00:42:13.025> [ 54246][I][Zigbee_Gateway_2.ino:123] Z2S_active_ep_req(): Endpont # 1, id 1
00:42:13.025>
00:42:13.025> [ 54246][I][Zigbee_Gateway_2.ino:123] Z2S_active_ep_req(): Endpont # 2, id 2
00:42:13.025>
00:42:13.025> [ 54247][I][Zigbee_Gateway_2.ino:123] Z2S_active_ep_req(): Endpont # 3, id 3
00:42:13.025>
00:42:13.025> [ 54247][I][Zigbee_Gateway_2.ino:123] Z2S_active_ep_req(): Endpont # 4, id 4
00:42:13.025>
00:42:13.025> [ 54279][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
00:42:13.025>
00:42:13.025> [ 54311][I][Zigbee_Gateway_2.ino:137] Z2S_simple_desc_req(): Z2S simple_desc_req: device address 0, endpoint # 1
00:42:13.025>
00:42:13.025> [ 54311][I][Zigbee_Gateway_2.ino:138] Z2S_simple_desc_req(): Z2S simple_desc_req: in clusters # 3, out clusters # 2
00:42:13.025>
00:42:13.025> [ 54312][I][Zigbee_Gateway_2.ino:141] Z2S_simple_desc_req(): In cluster # 1, id 0
00:42:13.025>
00:42:13.025> [ 54312][I][Zigbee_Gateway_2.ino:141] Z2S_simple_desc_req(): In cluster # 2, id 1
00:42:13.025>
00:42:13.025> [ 54312][I][Zigbee_Gateway_2.ino:141] Z2S_simple_desc_req(): In cluster # 3, id 6
00:42:13.025>
00:42:13.025> [ 54313][I][Zigbee_Gateway_2.ino:144] Z2S_simple_desc_req(): Out cluster # 1, id 10
00:42:13.025>
00:42:13.025> [ 54313][I][Zigbee_Gateway_2.ino:144] Z2S_simple_desc_req(): Out cluster # 2, id 25
00:42:13.025>
00:42:13.025> [ 54327][I][Zigbee_Gateway_2.ino:137] Z2S_simple_desc_req(): Z2S simple_desc_req: device address 0, endpoint # 2
00:42:13.025>
00:42:13.025> [ 54328][I][Zigbee_Gateway_2.ino:138] Z2S_simple_desc_req(): Z2S simple_desc_req: in clusters # 2, out clusters # 0
00:42:13.025>
00:42:13.025> [ 54328][I][Zigbee_Gateway_2.ino:141] Z2S_simple_desc_req(): In cluster # 1, id 1
00:42:13.025>
00:42:13.025> [ 54329][I][Zigbee_Gateway_2.ino:141] Z2S_simple_desc_req(): In cluster # 2, id 6
00:42:13.025>
00:42:13.025> [ 54343][I][Zigbee_Gateway_2.ino:137] Z2S_simple_desc_req(): Z2S simple_desc_req: device address 0, endpoint # 3
00:42:13.025>
00:42:13.025> [ 54344][I][Zigbee_Gateway_2.ino:138] Z2S_simple_desc_req(): Z2S simple_desc_req: in clusters # 2, out clusters # 0
00:42:13.025>
00:42:13.025> [ 54344][I][Zigbee_Gateway_2.ino:141] Z2S_simple_desc_req(): In cluster # 1, id 1
00:42:13.025>
00:42:13.025> [ 54344][I][Zigbee_Gateway_2.ino:141] Z2S_simple_desc_req(): In cluster # 2, id 6
00:42:13.025>
00:42:13.025> [ 54358][I][Zigbee_Gateway_2.ino:137] Z2S_simple_desc_req(): Z2S simple_desc_req: device address 0, endpoint # 4
00:42:13.025>
00:42:13.025> [ 54359][I][Zigbee_Gateway_2.ino:138] Z2S_simple_desc_req(): Z2S simple_desc_req: in clusters # 2, out clusters # 0
00:42:13.025>
00:42:13.025> [ 54360][I][Zigbee_Gateway_2.ino:141] Z2S_simple_desc_req(): In cluster # 1, id 1
00:42:13.025>
00:42:13.025> [ 54360][I][Zigbee_Gateway_2.ino:141] Z2S_simple_desc_req(): In cluster # 2, id 6
00:42:13.025>
00:42:13.025> [ 54558][I][ZigbeeCore.cpp:327] esp_zb_app_signal_handler(): Network(0x60c0) is open for 180 seconds
00:42:13.026>
00:42:20.986> [ 62766][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
00:42:20.986>
00:42:20.987> [ 62766][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x9b60) src endpoint(1) to dst e
00:42:20.987> ndpoint(1) cluster(0x1)
00:42:20.987>
00:42:20.987> [ 62767][I][ZigbeeGateway.cpp:173] zbAttributeRead(): zbAttributeRead from 39776, endpoint 1, cluster 1, attribute 33
00:42:20.987>
00:42:20.988> [ 62767][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
00:42:20.988>
00:42:20.988> [ 62768][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x9b60) src endpoint(1) to dst e
00:42:20.988> ndpoint(1) cluster(0x1)
00:42:20.989>
00:42:20.989> [ 62768][I][ZigbeeGateway.cpp:173] zbAttributeRead(): zbAttributeRead from 39776, endpoint 1, cluster 1, attribute 32
00:42:20.989>
00:42:31.013> [ 72796][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
00:42:31.013>
00:42:31.013> [ 72797][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x9b60) src endpoint(1) to dst e
00:42:31.013> ndpoint(1) cluster(0x1)
00:42:31.014>
00:42:31.014> [ 72798][I][ZigbeeGateway.cpp:173] zbAttributeRead(): zbAttributeRead from 39776, endpoint 1, cluster 1, attribute 33
00:42:31.014>
00:42:31.014> [ 72798][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
00:42:31.014>
00:42:31.014> [ 72799][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x9b60) src endpoint(1) to dst e
00:42:31.014> ndpoint(1) cluster(0x1)
00:42:31.015>
00:42:31.015> [ 72799][I][ZigbeeGateway.cpp:173] zbAttributeRead(): zbAttributeRead from 39776, endpoint 1, cluster 1, attribute 32
00:42:31.015>
00:42:41.424> [ 83211][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
00:42:41.424>
00:42:41.425> [ 83212][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x9b60) src endpoint(1) to dst e
00:42:41.425> ndpoint(1) cluster(0x1)
00:42:41.425>
00:42:41.425> [ 83212][I][ZigbeeGateway.cpp:173] zbAttributeRead(): zbAttributeRead from 39776, endpoint 1, cluster 1, attribute 33
00:42:41.425>
00:42:41.426> [ 83213][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
00:42:41.426>
00:42:41.426> [ 83213][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x9b60) src endpoint(1) to dst e
00:42:41.426> ndpoint(1) cluster(0x1)
00:42:41.427>
00:42:41.427> [ 83214][I][ZigbeeGateway.cpp:173] zbAttributeRead(): zbAttributeRead from 39776, endpoint 1, cluster 1, attribute 32
00:42:41.427>
00:46:03.324 -> zbInit
00:46:03.324 -> [ 1206][D][ZigbeeCore.cpp:124] zigbeeInit(): Initialize Zigbee stack
00:46:03.359 -> [ 1249][D][ZigbeeCore.cpp:131] zigbeeInit(): Register all Zigbee EPs in list
00:46:03.359 -> [ 1251][I][ZigbeeCore.cpp:139] zigbeeInit(): List of registered Zigbee EPs:
00:46:03.359 -> [ 1251][I][ZigbeeCore.cpp:141] zigbeeInit(): Device type: Home Gateway, Endpoint: 1, Device ID: 0x0050
00:46:03.361 -> [ 1263][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: ZDO Config Ready (0x17), status: ESP_FAIL
00:46:03.361 -> [ 1264][I][ZigbeeCore.cpp:220] esp_zb_app_signal_handler(): Zigbee stack initialized
00:46:03.361 -> [ 1269][I][ZigbeeCore.cpp:329] esp_zb_app_signal_handler(): Network(0x60c0) closed, devices joining not allowed.
00:46:03.392 -> [ 1270][I][ZigbeeCore.cpp:226] esp_zb_app_signal_handler(): Device started up in non factory-reset mode
00:46:03.392 -> [ 1271][I][ZigbeeCore.cpp:239] esp_zb_app_signal_handler(): Device rebooted
00:46:03.392 -> [ 1271][I][ZigbeeCore.cpp:243] esp_zb_app_signal_handler(): Opening network for joining for 180 seconds
00:46:03.392 -> [ 1272][D][ZigbeeCore.cpp:467] searchBindings(): Requesting binding table for address 0x0000
00:46:03.392 -> [ 1273][D][ZigbeeCore.cpp:407] bindingTableCb(): Binding table callback for address 0x0000 with status 0
00:46:03.392 -> [ 1274][D][ZigbeeCore.cpp:410] bindingTableCb(): Binding table info: total 4, index 0, count 3
00:46:03.392 -> [ 1274][D][ZigbeeCore.cpp:420] bindingTableCb(): Binding table record: src_endp 1, dst_endp 1, cluster_id 0x0006, dst_addr_mode 3
00:46:03.392 -> [ 1275][D][ZigbeeCore.cpp:437] bindingTableCb(): Device bound to EP 1 -> device endpoint: 1, short addr: 0x91f9, ieee addr: 70:B3:D5:2B:60:0F:4F:A8
00:46:03.392 -> [ 1276][D][ZigbeeCore.cpp:420] bindingTableCb(): Binding table record: src_endp 1, dst_endp 1, cluster_id 0x0702, dst_addr_mode 3
00:46:03.392 -> [ 1276][D][ZigbeeCore.cpp:437] bindingTableCb(): Device bound to EP 1 -> device endpoint: 1, short addr: 0x91f9, ieee addr: 70:B3:D5:2B:60:0F:4F:A8
00:46:03.392 -> [ 1277][D][ZigbeeCore.cpp:420] bindingTableCb(): Binding table record: src_endp 1, dst_endp 1, cluster_id 0x0b04, dst_addr_mode 3
00:46:03.392 -> [ 1278][D][ZigbeeCore.cpp:437] bindingTableCb(): Device bound to EP 1 -> device endpoint: 1, short addr: 0x91f9, ieee addr: 70:B3:D5:2B:60:0F:4F:A8
00:46:03.392 -> [ 1279][D][ZigbeeCore.cpp:407] bindingTableCb(): Binding table callback for address 0x0000 with status 0
00:46:03.392 -> [ 1279][D][ZigbeeCore.cpp:410] bindingTableCb(): Binding table info: total 4, index 3, count 1
00:46:03.392 -> [ 1280][D][ZigbeeCore.cpp:420] bindingTableCb(): Binding table record: src_endp 1, dst_endp 1, cluster_id 0x0006, dst_addr_mode 3
00:46:03.392 -> [ 1280][D][ZigbeeCore.cpp:437] bindingTableCb(): Device bound to EP 1 -> device endpoint: 1, short addr: 0x9b60, ieee addr: A4:C1:38:91:94:BB:9C:13
00:46:03.392 -> [ 1281][D][ZigbeeCore.cpp:458] bindingTableCb(): Filling bounded devices finished
00:46:03.453 -> [ 1350][I][ZigbeeCore.cpp:327] esp_zb_app_signal_handler(): Network(0x60c0) is open for 180 seconds
00:46:03.486 -> [ 1382][I][ZigbeeGateway.cpp:154] printGatewayDevices(): gateway devices:
00:46:03.486 -> [ 1382][I][ZigbeeGateway.cpp:157] printGatewayDevices(): Device on endpoint 1, short address: 0x91f9
00:46:03.486 -> [ 1383][I][ZigbeeGateway.cpp:157] printGatewayDevices(): Device on endpoint 1, short address: 0x91f9
00:46:03.486 -> [ 1384][I][ZigbeeGateway.cpp:157] printGatewayDevices(): Device on endpoint 1, short address: 0x9b60
00:46:03.486 -> [ 1385][I][ZigbeeGateway.cpp:163] printJoinedDevices(): joined devices:
00:46:08.499 -> [ 6386][I][Zigbee_Gateway_2.ino:129] Z2S_active_ep_req(): Z2S active_ep_req failed
00:46:11.165 -> [ 9067][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
[email protected]
- Has thanked: 18 times
- Been thanked: 27 times
Obiekt skumałem , zapomniałem że tam jest wskaźnik a nie wartość i to co wypisywałem to był adres .... Dzięki , w takim razie rzeźbie czesc wystawiajaca do Supli
EDIT:
udało się to uruchomić pod Platform.io
https://github.com/rkalwak/ZigbeeToSupla
veeroos
- Has thanked: 1 time
- Been thanked: 9 times
hej. ja na czystej instalce windowsa, na nowo zainstalowanym Arduino z podmienioną biblioteką Zigbee nadal mam problem z kompilacją. Będę jednak tylko obserwatorem, owszem Zibi wrzuca Binarki ale tak za każdym razem po każdej aktualizacji prosić o binarkę, to tak słabo. Nie wiem co macie więcej zainstalowanego, ale to u mnie nie chce chodzić.
https://github.com/v33r005
[email protected]
Ja sobie wrzuciłem wszystko do jednego katalogu, zobacz zipa i tam jest obrazek jak ustawic Arduino IDE. No i z Platforn.io tez mozesz zobaczyc
Widzę nie jestem samveeroos wrote: Tue Jan 07, 2025 8:47 am hej. ja na czystej instalce windowsa, na nowo zainstalowanym Arduino z podmienioną biblioteką Zigbee nadal mam problem z kompilacją. Będę jednak tylko obserwatorem, owszem Zibi wrzuca Binarki ale tak za każdym razem po każdej aktualizacji prosić o binarkę, to tak słabo. Nie wiem co macie więcej zainstalowanego, ale to u mnie nie chce chodzić.
A jaki masz Windows, bo ja 10
