FQBN: esp32:esp32:XIAO_ESP32C6:PartitionScheme=zigbee_zczr,EraseFlash=all,ZigbeeMode=zczr
Using board 'XIAO_ESP32C6' from platform in folder: C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7
Using core 'esp32' from platform in folder: C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7
cmd /c if exist "C:\\Users\\Jacek\\Documents\\Arduino\\Bramka Zigbee\\Zigbee_Gateway_2\\partitions.csv" COPY /y "C:\\Users\\Jacek\\Documents\\Arduino\\Bramka Zigbee\\Zigbee_Gateway_2\\partitions.csv" "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1\\partitions.csv"
cmd /c if not exist "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1\\partitions.csv" if exist "C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.7\\variants\\XIAO_ESP32C6\\partitions.csv" COPY "C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.7\\variants\\XIAO_ESP32C6\\partitions.csv" "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1\\partitions.csv"
cmd /c if not exist "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1\\partitions.csv" COPY "C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.7\\tools\\partitions\\zigbee_zczr.csv" "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1\\partitions.csv"
1 file(s) copied.
cmd /c IF EXIST "C:\\Users\\Jacek\\Documents\\Arduino\\Bramka Zigbee\\Zigbee_Gateway_2\\bootloader.bin" ( COPY /y "C:\\Users\\Jacek\\Documents\\Arduino\\Bramka Zigbee\\Zigbee_Gateway_2\\bootloader.bin" "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1\\Zigbee_Gateway_2.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.7\\variants\\XIAO_ESP32C6\\bootloader.bin" ( COPY "C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.7\\variants\\XIAO_ESP32C6\\bootloader.bin" "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1\\Zigbee_Gateway_2.ino.bootloader.bin" ) ELSE ( "C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.6\\esptool.exe" --chip esp32c6 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1\\Zigbee_Gateway_2.ino.bootloader.bin" "C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-632e0c2a\\esp32c6\\bin\\bootloader_qio_80m.elf" ) )
esptool.py v4.6
Creating esp32c6 image...
Merged 2 ELF sections
Successfully created esp32c6 image.
cmd /c if exist "C:\\Users\\Jacek\\Documents\\Arduino\\Bramka Zigbee\\Zigbee_Gateway_2\\build_opt.h" COPY /y "C:\\Users\\Jacek\\Documents\\Arduino\\Bramka Zigbee\\Zigbee_Gateway_2\\build_opt.h" "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1\\build_opt.h"
cmd /c if not exist "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1\\build_opt.h" type nul > "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1\\build_opt.h"
cmd /c type nul > "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1/file_opts"
cmd /c COPY /y "C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-632e0c2a\\esp32c6\\sdkconfig" "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1\\sdkconfig"
1 file(s) copied.
Detecting libraries used...
C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302/bin/riscv32-esp-elf-g++ -c @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=160000000L -DARDUINO=10607 -DARDUINO_XIAO_ESP32C6 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="XIAO_ESP32C6" -DARDUINO_VARIANT="XIAO_ESP32C6" -DARDUINO_PARTITION_zigbee_zczr -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:XIAO_ESP32C6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=zigbee_zczr,DebugLevel=none,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=zczr" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 -DZIGBEE_MODE_ZCZR @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/defines -IC:\Users\Jacek\Documents\Arduino\Bramka Zigbee\Zigbee_Gateway_2 -iprefix C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/include/ @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/includes -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/qio_qspi/include -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\cores\esp32 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\variants\XIAO_ESP32C6 @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/build_opt.h @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/file_opts C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1\sketch\Zigbee_Gateway_2.ino.cpp -o nul
Alternatives for ZigbeeGateway.h: [[email protected]]
ResolveLibrary(ZigbeeGateway.h)
-> candidates: [[email protected]]
C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302/bin/riscv32-esp-elf-g++ -c @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=160000000L -DARDUINO=10607 -DARDUINO_XIAO_ESP32C6 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="XIAO_ESP32C6" -DARDUINO_VARIANT="XIAO_ESP32C6" -DARDUINO_PARTITION_zigbee_zczr -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:XIAO_ESP32C6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=zigbee_zczr,DebugLevel=none,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=zczr" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 -DZIGBEE_MODE_ZCZR @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/defines -IC:\Users\Jacek\Documents\Arduino\Bramka Zigbee\Zigbee_Gateway_2 -iprefix C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/include/ @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/includes -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/qio_qspi/include -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\cores\esp32 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\variants\XIAO_ESP32C6 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee\src @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/build_opt.h @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/file_opts C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1\sketch\Zigbee_Gateway_2.ino.cpp -o nul
C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302/bin/riscv32-esp-elf-g++ -c @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=160000000L -DARDUINO=10607 -DARDUINO_XIAO_ESP32C6 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="XIAO_ESP32C6" -DARDUINO_VARIANT="XIAO_ESP32C6" -DARDUINO_PARTITION_zigbee_zczr -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:XIAO_ESP32C6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=zigbee_zczr,DebugLevel=none,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=zczr" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 -DZIGBEE_MODE_ZCZR @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/defines -IC:\Users\Jacek\Documents\Arduino\Bramka Zigbee\Zigbee_Gateway_2 -iprefix C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/include/ @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/includes -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/qio_qspi/include -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\cores\esp32 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\variants\XIAO_ESP32C6 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee\src @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/build_opt.h @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/file_opts C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee\src\ZigbeeCore.cpp -o nul
C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302/bin/riscv32-esp-elf-g++ -c @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=160000000L -DARDUINO=10607 -DARDUINO_XIAO_ESP32C6 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="XIAO_ESP32C6" -DARDUINO_VARIANT="XIAO_ESP32C6" -DARDUINO_PARTITION_zigbee_zczr -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:XIAO_ESP32C6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=zigbee_zczr,DebugLevel=none,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=zczr" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 -DZIGBEE_MODE_ZCZR @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/defines -IC:\Users\Jacek\Documents\Arduino\Bramka Zigbee\Zigbee_Gateway_2 -iprefix C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/include/ @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/includes -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/qio_qspi/include -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\cores\esp32 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\variants\XIAO_ESP32C6 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee\src @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/build_opt.h @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/file_opts C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee\src\ZigbeeEP.cpp -o nul
C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302/bin/riscv32-esp-elf-g++ -c @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=160000000L -DARDUINO=10607 -DARDUINO_XIAO_ESP32C6 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="XIAO_ESP32C6" -DARDUINO_VARIANT="XIAO_ESP32C6" -DARDUINO_PARTITION_zigbee_zczr -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:XIAO_ESP32C6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=zigbee_zczr,DebugLevel=none,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=zczr" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 -DZIGBEE_MODE_ZCZR @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/defines -IC:\Users\Jacek\Documents\Arduino\Bramka Zigbee\Zigbee_Gateway_2 -iprefix C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/include/ @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/includes -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/qio_qspi/include -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\cores\esp32 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\variants\XIAO_ESP32C6 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee\src @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/build_opt.h @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/file_opts C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee\src\ZigbeeGateway.cpp -o nul
C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302/bin/riscv32-esp-elf-g++ -c @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=160000000L -DARDUINO=10607 -DARDUINO_XIAO_ESP32C6 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="XIAO_ESP32C6" -DARDUINO_VARIANT="XIAO_ESP32C6" -DARDUINO_PARTITION_zigbee_zczr -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:XIAO_ESP32C6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=zigbee_zczr,DebugLevel=none,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=zczr" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 -DZIGBEE_MODE_ZCZR @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/defines -IC:\Users\Jacek\Documents\Arduino\Bramka Zigbee\Zigbee_Gateway_2 -iprefix C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/include/ @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/includes -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/qio_qspi/include -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\cores\esp32 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\variants\XIAO_ESP32C6 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee\src @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/build_opt.h @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/file_opts C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee\src\ZigbeeHandlers.cpp -o nul
C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302/bin/riscv32-esp-elf-g++ -c @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=160000000L -DARDUINO=10607 -DARDUINO_XIAO_ESP32C6 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="XIAO_ESP32C6" -DARDUINO_VARIANT="XIAO_ESP32C6" -DARDUINO_PARTITION_zigbee_zczr -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:XIAO_ESP32C6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=zigbee_zczr,DebugLevel=none,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=zczr" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 -DZIGBEE_MODE_ZCZR @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/defines -IC:\Users\Jacek\Documents\Arduino\Bramka Zigbee\Zigbee_Gateway_2 -iprefix C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/include/ @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/includes -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/qio_qspi/include -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\cores\esp32 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\variants\XIAO_ESP32C6 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee\src @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/build_opt.h @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/file_opts C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee\src\ZigbeeIASZone.cpp -o nul
C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302/bin/riscv32-esp-elf-g++ -c @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=160000000L -DARDUINO=10607 -DARDUINO_XIAO_ESP32C6 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="XIAO_ESP32C6" -DARDUINO_VARIANT="XIAO_ESP32C6" -DARDUINO_PARTITION_zigbee_zczr -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:XIAO_ESP32C6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=zigbee_zczr,DebugLevel=none,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=zczr" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 -DZIGBEE_MODE_ZCZR @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/defines -IC:\Users\Jacek\Documents\Arduino\Bramka Zigbee\Zigbee_Gateway_2 -iprefix C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/include/ @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/includes -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/qio_qspi/include -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\cores\esp32 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\variants\XIAO_ESP32C6 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee\src @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/build_opt.h @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/file_opts C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee\src\ZigbeeITempMeas.cpp -o nul
Generating function prototypes...
C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302/bin/riscv32-esp-elf-g++ -c @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=160000000L -DARDUINO=10607 -DARDUINO_XIAO_ESP32C6 -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="XIAO_ESP32C6" -DARDUINO_VARIANT="XIAO_ESP32C6" -DARDUINO_PARTITION_zigbee_zczr -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:XIAO_ESP32C6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=zigbee_zczr,DebugLevel=none,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=zczr" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 -DZIGBEE_MODE_ZCZR @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/defines -IC:\Users\Jacek\Documents\Arduino\Bramka Zigbee\Zigbee_Gateway_2 -iprefix C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/include/ @C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/flags/includes -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-632e0c2a\esp32c6/qio_qspi/include -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\cores\esp32 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\variants\XIAO_ESP32C6 -IC:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee\src @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/build_opt.h @C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1/file_opts C:\Users\Jacek\AppData\Local\arduino\sketches\02AAF47D8C4FC725A2CFE26366C169A1\sketch\Zigbee_Gateway_2.ino.cpp -o C:\Users\Jacek\AppData\Local\Temp\1625517203\sketch_merged.cpp
C:\Users\Jacek\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\Jacek\AppData\Local\Temp\1625517203\sketch_merged.cpp
Kompilowanie szkicu...
"C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-rv32\\2302/bin/riscv32-esp-elf-g++" -MMD -c "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-632e0c2a\\esp32c6/flags/cpp_flags" -Os -Werror=return-type -DF_CPU=160000000L -DARDUINO=10607 -DARDUINO_XIAO_ESP32C6 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"XIAO_ESP32C6\"" "-DARDUINO_VARIANT=\"XIAO_ESP32C6\"" -DARDUINO_PARTITION_zigbee_zczr "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:XIAO_ESP32C6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=zigbee_zczr,DebugLevel=none,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=zczr\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 -DZIGBEE_MODE_ZCZR "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-632e0c2a\\esp32c6/flags/defines" "-IC:\\Users\\Jacek\\Documents\\Arduino\\Bramka Zigbee\\Zigbee_Gateway_2" -iprefix "C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-632e0c2a\\esp32c6/include/" "@C:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-632e0c2a\\esp32c6/flags/includes" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-632e0c2a\\esp32c6/qio_qspi/include" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.7\\cores\\esp32" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.7\\variants\\XIAO_ESP32C6" "-IC:\\Users\\Jacek\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.7\\libraries\\Zigbee\\src" "@C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1/build_opt.h" "@C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1/file_opts" "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1\\sketch\\Zigbee_Gateway_2.ino.cpp" -o "C:\\Users\\Jacek\\AppData\\Local\\arduino\\sketches\\02AAF47D8C4FC725A2CFE26366C169A1\\sketch\\Zigbee_Gateway_2.ino.cpp.o"
C:\Users\Jacek\Documents\Arduino\Bramka Zigbee\Zigbee_Gateway_2\Zigbee_Gateway_2.ino:1:9: warning: #pragma once in main file
1 | #pragma once
In file included from C:\Users\Jacek\Documents\Arduino\Bramka Zigbee\Zigbee_Gateway_2\Zigbee_Gateway_2.ino:5:
C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee\src/ZigbeeGateway.h:102:8: error: 'void ZigbeeGateway::zbAttributeRead(uint16_t, const esp_zb_zcl_attribute_t*)' marked 'override', but does not override
102 | void zbAttributeRead(uint16_t cluster_id, const esp_zb_zcl_attribute_t *attribute) override;
Użycie biblioteki Zigbee w wersji 3.0.7 z folderu: C:\Users\Jacek\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\libraries\Zigbee
exit status 1
Compilation error: exit status 1
