Nadal mój ESP zachowuje się dziwnie.
Nadal nie reaguje na zmianę ustawień dla I2C które zmieniłem z GPIO 1 i 3 (TX i RX) na GPIO, które robiły za wejścia (przyciski) GPIO 5 i 9 z nich wywaliłem kondensatory filtrujące drganie styków pozostały tylko rezystory ale z tego co pamiętam to powinny one zostać jako podciągające SDA i SCL do VCC
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 3584, room 16
tail 0
chksum 0xb0
csum 0xb0
v2843a5ac
~ld
Creating OneWire bus for pin: 2
Initializing OneWire bus at pin 2
OneWire(pin 2) Parasite power is OFF
OneWire(pin 2) Found 1 devices:
Device address not provided. Using device from index 0
Supla - starting initialization
Storage initialization
readStorage: 8; Read: [53 55 50 4C 41 1 0 1 ]
Storage: Number of sections 1
Reading section: 0
readStorage: 7; Read: [3 50 0 0 0 0 0 ]
Section type: 3; size: 80
Validating storage state section with current device configuration
Storage state section validation completed. Loading elements state...
readStorage: 4; Read: [0 0 0 0 ]
Relay[0]: restored durationMs: 0
readStorage: 1; Read: [1 ]
Relay[0]: restored relay state: ON
Relay[1]: restored durationMs: 0
Relay[1]: restored relay state: ON
Relay[2]: restored durationMs: 0
Relay[2]: restored relay state: ON
Relay[3]: restored durationMs: 0
Relay[3]: restored relay state: ON
Relay[4]: restored durationMs: 0
Relay[4]: restored relay state: ON
Relay[5]: restored durationMs: 0
Relay[5]: restored relay state: ON
Relay[6]: restored durationMs: 0
Relay[6]: restored relay state: ON
Relay[7]: restored durationMs: 0
Relay[7]: restored relay state: ON
Relay[8]: restored durationMs: 0
Relay[8]: restored relay state: ON
Relay[9]: restored durationMs: 0
Relay[9]: restored relay state: ON
Relay[10]: restored durationMs: 0
Relay[10]: restored relay state: ON
Relay[11]: restored durationMs: 0
Relay[11]: restored relay state: ON
Relay[12]: restored durationMs: 0
Relay[12]: restored relay state: ON
Relay[13]: restored durationMs: 0
Relay[13]: restored relay state: ON
Relay[14]: restored durationMs: 0
Relay[14]: restored relay state: ON
Relay[15]: restored durationMs: 0
Relay[15]: restored relay state: ON
**** Digital write[0], pin: 108; value: 0
Channel(0) value changed to 1
**** Digital write[1], pin: 100; value: 0
Channel(1) value changed to 1
**** Digital write[2], pin: 109; value: 0
Channel(2) value changed to 1
**** Digital write[3], pin: 101; value: 0
Channel(3) value changed to 1
**** Digital write[4], pin: 110; value: 0
Channel(4) value changed to 1
**** Digital write[5], pin: 102; value: 0
Channel(5) value changed to 1
**** Digital write[6], pin: 111; value: 0
Channel(6) value changed to 1
**** Digital write[7], pin: 103; value: 0
Channel(7) value changed to 1
**** Digital write[8], pin: 112; value: 0
Channel(8) value changed to 1
**** Digital write[9], pin: 104; value: 0
Channel(9) value changed to 1
**** Digital write[10], pin: 113; value: 0
Channel(10) value changed to 1
**** Digital write[11], pin: 105; value: 0
Channel(11) value changed to 1
**** Digital write[12], pin: 114; value: 0
Channel(12) value changed to 1
**** Digital write[13], pin: 106; value: 0
Channel(13) value changed to 1
**** Digital write[14], pin: 115; value: 0
Channel(14) value changed to 1
**** Digital write[15], pin: 107; value: 0
Channel(15) value changed to 1
Channel(16) value changed to 26.75
Initializing network layer
WiFi: establishing connection with SSID: "xxxxxxxxxxxxxxxxxxxxx"
Using Supla protocol version 12
Key=0 value=▒l▒!▒▒%,▒▒▒j
Key=1 value=▒▒nV\QU▒/#▒9
Key=2 value=xxxxxxxxxxxxxxxxxxxxxx
Key=3 value=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Key=4 value=admin
Key=5 value=password
Key=6 value=4_relay+OLED+BME280+DS18B20
Key=7 value=svrXX.supla.org
Key=8 [email protected]
Key=9 value=16
Key=10 value=16
Key=11 value=0
Key=12 value=1
Key=13 value=1
Key=14 value=1
Key=15 value=0
Key=16 value=0
Key=17 value=10
Key=18 value=0
Key=19 value=2,0,0,,2,1,,,,,,
Key=20 value=0
Key=21 value=1
Key=22 value=
Key=23 value=
Key=24 value=,,0,0,2,0,0,1,2,1,,,,,,,0,,,,,,,
Key=25 value=0,0,0,0,2,0,0,,4,1,,,,,,,0,,,,,,
Key=26 value=1,6,0,0,2,0,0,,6,1,,,,,,,0,,,,,,
Key=27 value=0,0,0,0,2,0,0,,8,1,,,,,,,0,,,,,,
Key=28 value=0,0,0,0,2,0,0,,10,1,,,,,,,0,,,,,
Key=29 value=0,0,0,0,2,0,0,,12,1,,,,,,,0,,,,,
Key=30 value=,,0,0,2,0,0,,14,1,,,,,,,0,,,,,,,
Key=31 value=,,0,0,2,0,0,,16,1,,,,,,,0,,,,,,,
Key=32 value=,,0,0,2,0,0,,1,1,,,,,,,0,,,,,,,,
Key=33 value=,,0,0,2,0,0,,3,1,,,,,,,0,,,,,,,,
Key=34 value=0,0,0,0,2,0,0,,5,1,,,,,,,0,,,,,,
Key=35 value=,,0,0,2,0,0,,7,1,,,,,,,0,,,,,,,,
Key=36 value=,,0,0,2,0,0,,9,1,,,,,,,0,,,,,,,,
Key=37 value=,,0,0,2,0,0,,11,1,,,,,,,0,,,,,,,
Key=38 value=,,0,0,2,0,0,,13,1,,,,,,,0,,,,,,,
Key=39 value=,,0,0,2,0,0,,15,1,,,,,,,0,,,,,,,
Key=40 value=1,4,0,0,0,0,0,,,,,,,,,,0,,,,,,,,
Key=41 value=0,0,0,,2,,,0,,,,,,,,,,,,,,,,,,,,
Key=42 value=0
Key=43 value=
Key=44 value=
Key=45 value=0
Key=46 value=
Key=47 value=0
Key=48 value=0
Key=49 value=
Key=50 value=
Key=51 value=
Key=52 value=
Key=53 value=
Key=54 value=
Key=55 value=
Key=56 value=
local IP: 192.168.1.149
subnetMask: 255.255.255.0
gatewayIP: 192.168.1.1
Signal strength (RSSI): -53 dBm
Establishing unsecured connection with: svrXX.supla.org (port: 2015)
Connected to Supla Server
Device registered (activity timeout 120 s, server version: 14, server min version: 1)
Changing activity timeout to 30
Activity timeout set to 30 s
Channel(16) value changed to 26.68
Channel(16) value changed to 26.81
1.4.1 z załaczonym I2C (GPIO 5 i 9) ale na wyświetlaczu nic nie wyświetla i się ciągle restartuje
Signal strength (RSSI): -56 dBm
5▒ZM|Creating OneWire bus for pin: 2▒G,▒▒vAm1ס▒~A▒▒▒▒n▒*E"H▒▒▒A,pJ
MCP23017 1 not found!
MCP23017 2 not found!
MCP23017 3 not found!
MCP23017 4 not found!
Reading section: 0
Channel(16) value changed to 28.37
Channel(18) value changed to -1.0
Channel(17) value changed to temp(-275.000000), humi(-1.000000)
WiFi: establishing connection with SSID: "xxxxxxxxxxxxxxxxxxxx"
Key=3 value=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Key=4 value=admin
Key=9 value=16
Key=10 value=16
Key=11 value=0
Key=12 value=1
Key=13 value=1
Key=14 value=1
Key=15 value=0
Key=16 value=0
Key=17 value=10
Key=18 value=0
Key=20 value=0
Key=21 value=1
Key=22 value=
Key=23 value=
Key=29 value=1,10,0,0,2,0,0,,12,1,,,,,,,0,,,,
Key=33 value=1,9,0,0,2,0,0,,3,1,,,,,,,0,,,,,,
Key=42 value=0
Key=43 value=2
Key=44 value=5
Key=45 value=0
Key=46 value=
Key=47 value=0
Key=48 value=0
Key=49 value=
Key=50 value=
Key=51 value=
Key=52 value=
Key=53 value=
Key=54 value=
Key=55 value=
Key=56 value=
Signal strength (RSSI): -55 dBm
W,▒d!ZM|Creating OneWire bus for pin: 2,▒▒vAm▒▒!▒~A▒▒▒▒n▒*E"Hh▒▒A,pZ
Reading section: 0
Channel(16) value changed to 28.50
Key=4 value=admin
Key=9 value=16
Key=10 value=16
Key=11 value=0
Key=12 value=1
Key=13 value=1
Key=14 value=1
Key=15 value=0
Key=16 value=0
Key=17 value=10
Key=18 value=0
Key=20 value=0
Key=21 value=1
Key=22 value=
Key=23 value=
Key=42 value=0
Key=43 value=2
Key=44 value=5
Key=45 value=0
Key=46 value=
Key=47 value=0
Key=48 value=0
Key=49 value=
Key=50 value=
Key=51 value=
