Has thanked: 291 times
Pietras81 wrote: Tue Jul 01, 2025 5:07 pm O to chodzi
[ 35118][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x1bdc)
[ 35118][V][ZigbeeCore.cpp:359] esp_zb_app_signal_handler(): Device capabilities: 0x80
[ 35119][D][ZigbeeGateway.cpp:518] zbDeviceAnnce(): zbDeviceAnnce short address (0x1bdc), ieee_addr (0xa4):(0xc1):(0x38):(0xdb):(0xd2):(0xf6):(0x88):(0x89)
[ 35119][D][ZigbeeGateway.cpp:521] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x1bdc), ieee_addr (0xa4):(0xc1):(0x38):(0xdb):(0xd2):(0xf6):(0x88):(0x89)
[ 35120][I][ZigbeeGateway.cpp:545] zbDeviceAnnce(): Tuya magic last hope
[ 35324][I][ZigbeeGateway.cpp:588] printJoinedDevices(): joined devices:
[ 35324][I][ZigbeeGateway.cpp:591] printJoinedDevices(): Device on endpoint 1, short address: 0x1bdc
[ 35325][V][esp32-hal-rmt.c:305] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[ 35326][V][esp32-hal-rmt.c:306] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Asked to Loop: NO, LoopCancel: NO
[ 35327][I][ZigbeeGateway.cpp:349] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[ 35704][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 35704][V][ZigbeeHandlers.cpp:155] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x1bdc) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 35705][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(7)
[ 35705][I][ZigbeeGateway.cpp:382] zbReadBasicCluster(): Peer Manufacturer is "HOBEIAN"
[ 35706][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(3)
[ 35706][I][ZigbeeGateway.cpp:402] zbReadBasicCluster(): ZCL version id is "3"
[ 35707][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x1), type(0x20), value(147)
[ 35708][I][ZigbeeGateway.cpp:408] zbReadBasicCluster(): ZCL application version id is "147"
[ 35708][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(7)
[ 35709][I][ZigbeeGateway.cpp:389] zbReadBasicCluster(): Peer Model is "ZG-227Z"
[ 35709][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x7), type(0x30), value(3)
[ 35710][I][ZigbeeGateway.cpp:414] zbReadBasicCluster(): ZCL power source id is "3"
[ 35710][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(134), cluster(0x0), attribute(0xfffe), type(0x0), value(0)
[ 35714][I][ZigbeeHandlers.cpp:62] zb_raw_cmd_handler(): cluster id: 0x0, command id: 1
[ 35715][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 35715][I][ZigbeeHandlers.cpp:64] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 35716][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): manuf_specific 0x0
[ 35716][I][ZigbeeHandlers.cpp:67] zb_raw_cmd_handler(): RAW bufid: 21 size: 17
Si, exactamente 😉
+BWNU (0.8.48) - mniej więcej za 20 minut
kris.gie wrote: Mon Jun 30, 2025 7:14 pm Można prosić o dodanie:
https://www.aqara.com/en/product/valve- ... -t1-specs/
Peer Model is "lumi.valve.agl001"
Peer Manufacturer is "Aqara"
+BWNU 0.8.49 - proszę o feedback.
Pietras81
vajera wrote: Tue Jul 01, 2025 5:48 pm
Si, exactamente 😉
Dziękuję. Działa od strzała.
Jedyne ale to pokazuje 40% baterii ale czy ona z Chin przyjechała nowa tego nie wiem.
https://pietras-81.aqi.eco/
Pietras81 wrote: Tue Jul 01, 2025 9:15 pm Dziękuję. Działa od strzała.
Zdarza się, że te czujniki leżą w magazynie wiele miesięcy 😉 Jak chcesz to mogę zrobić tak, żeby pokazywało 100% 🤣
Pietras81
vajera wrote: Tue Jul 01, 2025 9:22 pm
Jak kiedyś wymiennie baterie na nową to poproszę, puki co może leżała długo i tego się trzymajmy :)
cinas wrote: Mon Jun 30, 2025 4:17 pm Proszę o dodanie licznika energii 1-f dwukierunkowy
Peer Manufacturer is "_TZE284_iwn0gpzz"
Peer Model is "TS0601"
Licznik identyczny z wcześniej dodawanym tylko poparzeni był 3-faz
Licznik 3-faz któy działa poprawnie
Peer Manufacturer is "_TZE284_dikb3dp6"
W miarę możliwości poproszę o logi z parowania - może uda mi się rozgryźć kwestię tej częstotliwości raportowania danych.
lukasz06
Has thanked: 46 times
Been thanked: 21 times
Ta żarówka jest już od dawna (0.7.12) w bazie ;)
Niewiedziałem :) Powiem tak, żyje swoim życiem, nie reaguje w ogóle na zmianę kolorów rgb, świeci tylko kolor biały zimny i ciepły, przyciemnianie robię np 80%, w apce, za chwilę samo sie zmienia na np 30%
Edit1. Czujnik Temp Sonoff
Manufacturer - Sonoff
Model - SNZB-02LD
+BWNU (jako T/H póki co)
A czego się jeszcze można spodziewać?
W apce Ewelinka jest możliwość min kalibracji temp i możliwość ustawienia czasu raportowania przesyłania temp
Edit2. Smart Knob
Peer Manufacturer is "_TZ3000_qja6nq5z"
Peer Model is "TS004F"
Ten jest w bramce bodajże od lutego ;)
Czas leci...;)
Ogólnie działa z opóźnieniem, może przez to, że mam już ok 20 kanałów. Nie działał mi przycisk hold, jak długo go trzeba przytrzymać?
Jednak dla mnie ten Knob jako przekażnik odpada, myślałem bardziej, że będzie on służył np jako dimmer, lub jako wyzwalacz akcji.
Been thanked: 32 times
I jeszcze to: Peer Model is "ZG-227Z" - ewentualnie można (nie trzeba) to https://www.zigbee2mqtt.io/devices/ZG-227Z.html
Pisałem Ci wcześniej, co wystarczy odczytać z logów i nie trzeba ich wtedy przesyłać...
Teraz wystarczy już tylko poczekać na @vajerę i jego +BWNU :)
lukasz06 wrote: Tue Jul 01, 2025 10:16 pm Niewiedziałem :) Powiem tak, żyje swoim życiem, nie reaguje w ogóle na zmianę kolorów rgb, świeci tylko kolor biały zimny i ciepły, przyciemnianie robię np 80%, w apce, za chwilę samo sie zmienia na np 30%
Z tego posta:
viewtopic.php?p=202380#p202380
wynikało, że działa prawidłowo, więc musiałbyś wrzucić jakieś logi.
Miałem na myśli fakt, że tam jest tylko czujnik temperatury, więc może w końcu zrobię sam termometr Zigbee, ale chwilowo dałem gotowy komponent T/H.
Te dodatkowe parametry są jak najbardziej do ustawienia (telnet, docelowo GUI).
Edit2. Smart Knob
Logi....
3 sekundy?
jak dla mnie ten Knob jako przekażnik odpada, myślałem bardziej, że będzie on służył np jako dimmer, lub jako wyzwalacz akcji.
Tak właśnie się dodaje - wygląda jak przekaźnik, ale działa w jedną stronę - możesz na nim ustawić reakcje, w tym ściemnianie i rozjaśnianie.
Nie używałeś do tej pory smart buttons?
kris.gie
vajera wrote: Tue Jul 01, 2025 6:41 pm
Działa aż miło. Zawór dodał się do bramki, zgłosił jak należy. Otwieranie i zamykanie manualne działa, po sparowaniu z Ikeowskim czujnikiem reaguje po wykryciu zalania, następnie przy próbie otwarcia zaworu z Supli wyskakuje ostrzeżenie. Rewelacja!!! Wielkie dzięki :D
