unable to connect dev and client to supla 2.0
emiliakowalski
hello i have installed supla2.0 cloud but unable to connect my devices client and dev to supla2.0 below is my configuration and sample parameter file, ports are open, firewall disables and listen 2015 & 2016, port let me know what can be the issue. accessing locally and there is one more error looks like in supla-dev.
Last edited by emiliakowalski on Tue Jul 11, 2017 3:14 pm, edited 4 times in total.
emiliakowalski
HI can anyone solve this issue
emiliakowalski
hi can you please help pzygmunt
emiliakowalski
supla-dev error
emiliakowalski
any solution please
Send to me ssh access on private.
emiliakowalski
hi thankyou,
i wanted to do it on my own but at the very last point, i m am failed in networking or connection. :( though It was very good journey because of supla i learned,
linux,
symfony
doctrine
lamp
nodejs
about composer etc....
Thanks to Supla project and to pzygmunt and supla team.
will share with you my ssh credentials. before that i would like to give my last try through one polish post that was for run.sh
emiliakowalski
Hello pzygmunt found the reason i think because of unknown version my app is not connecting pls help me out
emiliakowalski
cd /usr/src
sudo mkdir openssl
sudo wget https://www.openssl.org/source/openssl-1.0.1t.tar.gz
sudo tar zxvf openssl-1.0.1t.tar.gz
cd openssl-1.0.1t
sudo ./config --prefix=/usr/src/openssl shared
*edit Makefile and remove no-ssl2 flags
sudo make depend
sudo make install
sudo cp /usr/src/openssl/lib/*.so /usr/lib/supla-server/
sudo rm -rf cp /usr/src/openssl
Return to “Help”
