Supla-Cloud-Server
bouali
thank you very much pzygmunt for your help i have solved the problem
emiliakowalski
THIS IS THE REASON MY APP IS NOT CONNECTING WITH THE SERVER PLEASE HELP ME OUT
bouali
emiliakowalski
why there is ssl 3 error i have tried to compile with new openssl version but failed give error no function of ssl3 method defined
- Been thanked: 59 times
cd /usr/src
sudo mkdir openssl
sudo wget https://www.openssl.org/source/openssl-1.0.1t.tar.gz
sudo tar zxvf openssl-1.0.1t.tar.gz
cd openssl-1.0.1t
sudo ./config --prefix=/usr/src/openssl shared
*edit Makefile and remove no-ssl2 flags
sudo make depend
sudo make install
sudo cp /usr/src/openssl/lib/*.so /usr/lib/supla-server/
sudo rm -rf cp /usr/src/openssl
emiliakowalski
i used this command to create schema in supla database
$ php app/console doctrine:schema:create
used latest version supla 2.0
but app giving error of " BAD CREDENTIALS"
so i checked supla-server, error is there is no no such table in database do i need to create new tables manually.
There is no such table in database --------------supla.supla_v_device_accessid-------------
