Mysql database access
psp50
I have installed supla on my own server using docker.
https://github.com/SUPLA/supla-docker
I have tried to access the database but I am unable to access the MySQL database.
can anybody guide me to access the database?
Are you using a docker installation?
psp50
yes, I have installed using docker.
Connect to the container and just run the mysql command.
psp50
pzygmunt wrote: Wed Nov 10, 2021 6:15 pm Connect to the container and just run the mysql command.
Thank you so much for your responce.
Can you please explain in little detail?
because I want to access user interfaces for databases like PHPMyAdmin or MySQL workbench software.
Is it possible to do that?
Yes. It is possible. Connect to the container. Run the mysql command. Add a user. Open port 3306 to connect outside the container and you can connect with a remote client.
psp50
i unable to do that when i try to do that i got this error in the commend line.
Command 'mysql' not found, but can be installed with:
apt install mysql-client-core-5.7
apt install mariadb-client-core-10.1
Are you sure you connected to the container where MySQL / MariaDB server is running?
psp50
Yes i got same error.
Is it possible to host own supla cloud on cpanel?
Like, Copy all supla cloud content to the cpanel and connect external database to that.
I’m beginner if it is possible then i will able to understand supla easily.
Sorry but I don't understand what you want to do.
Return to “General discussion”
