gui generique builder 4.6.14
hixam
Hello everyone I hope you are doing well. I encountered a problem with the new version I generated a flash which does not work on my esp8266 nodemcu, the same flash which I had generated with version 4.6.13 which works well. i just want to add buttons and roller shutters
hixam
the problem is that after configuring the esp in the android application everything goes well but the esp is not visible in the cloud I repeat the configuration but it does not work. I did the same thing with the program generated with the old version and it worked fine
I chose the relay option and the first 4 (frequency, config, update, gui) 1mo
Goral64
- Has thanked: 2 times
- Been thanked: 1 time
If you have changed options, added any, or added fewer than before, there may be a channel conflict.
When you enter CONFIG page, does some recent status show you?
hixam
Last state : no connection to the network
Goral64
LAST STATE "Brak połączenia z siecią" means No network connection.
This means that you have something misconfigured to connect to your WiFi network.
BTW. You can generate the firmware in another available language, e.g. English ou en français
Goral64
Changing the Builder language also changes the language in GUI-Generic
The translation may contain errors, for which we apologize.
hixam
i tried 2 different esp01 and they cant connect to wifi
