[GG] Błąd generowania ESP+DHT11
klimasstudio
Dzisiaj chciałem zaktualizować firmware do ESP8266 + DHT11 i mam oto taki błąd podczas generowania:
Błąd generowania
/root/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.4-gcc10.3-1757bed/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: /tmp/arduino-sketch-B930872D266E0FE070994EE97BCF867C/libraries/SuplaDevice/supla/sensor/MAXThermocouple.cpp.o: in function `_ZN5Supla6Sensor15MAXThermocouple6onInitEv':
/var/www/html/code/lib/SuplaDevice/src/supla/sensor/MAXThermocouple.cpp:65: multiple definition of `_ZN5Supla6Sensor15MAXThermocouple6onInitEv'; /tmp/arduino-sketch-B930872D266E0FE070994EE97BCF867C/libraries/SuplaDeviceExtensions/supla/sensor/MAXThermocouple.cpp.o:/var/www/html/code/lib/SuplaDeviceExtensions/src/supla/sensor/MAXThermocouple.cpp:64: first defined here
/root/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.4-gcc10.3-1757bed/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: /tmp/arduino-sketch-B930872D266E0FE070994EE97BCF867C/libraries/SuplaDevice/supla/sensor/MAXThermocouple.cpp.o: in function `_ZN5Supla6Sensor15MAXThermocoupleC2Ehhh':
/var/www/html/code/lib/SuplaDevice/src/supla/sensor/MAXThermocouple.cpp:22: multiple definition of `_ZN5Supla6Sensor15MAXThermocoupleC2Ehhh'; /tmp/arduino-sketch-B930872D266E0FE070994EE97BCF867C/libraries/SuplaDeviceExtensions/supla/sensor/MAXThermocouple.cpp.o:/var/www/html/code/lib/SuplaDeviceExtensions/src/supla/sensor/MAXThermocouple.cpp:21: first defined here
/var/www/html/code/lib/SuplaDevice/src/supla/sensor/MAXThermocouple.cpp:22: multiple definition of `_ZN5Supla6Sensor15MAXThermocoupleC1Ehhh'; /tmp/arduino-sketch-B930872D266E0FE070994EE97BCF867C/libraries/SuplaDeviceExtensions/supla/sensor/MAXThermocouple.cpp.o:/var/www/html/code/lib/SuplaDeviceExtensions/src/supla/sensor/MAXThermocouple.cpp:21: first defined here
/root/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.4-gcc10.3-1757bed/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: /tmp/arduino-sketch-B930872D266E0FE070994EE97BCF867C/libraries/SuplaDevice/supla/sensor/MAXThermocouple.cpp.o: in function `_ZN5Supla6Sensor15MAXThermocouple7spiReadEv':
/var/www/html/code/lib/SuplaDevice/src/supla/sensor/MAXThermocouple.cpp:75: multiple definition of `_ZN5Supla6Sensor15MAXThermocouple7spiReadEv'; /tmp/arduino-sketch-B930872D266E0FE070994EE97BCF867C/libraries/SuplaDeviceExtensions/supla/sensor/MAXThermocouple.cpp.o:/var/www/html/code/lib/SuplaDeviceExtensions/src/supla/sensor/MAXThermocouple.cpp:74: first defined here
/root/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/3.0.4-gcc10.3-1757bed/bin/../lib/gcc/xtensa-lx106-elf/10.3.0/../../../../xtensa-lx106-elf/bin/ld: /tmp/arduino-sketch-B930872D266E0FE070994EE97BCF867C/libraries/SuplaDevice/supla/sensor/MAXThermocouple.cpp.o: in function `_ZN5Supla6Sensor15MAXThermocouple8getValueEv':
/var/www/html/code/lib/SuplaDevice/src/supla/sensor/MAXThermocouple.cpp:26: multiple definition of `_ZN5Supla6Sensor15MAXThermocouple8getValueEv'; /tmp/arduino-sketch-B930872D266E0FE070994EE97BCF867C/libraries/SuplaDeviceExtensions/supla/sensor/MAXThermocouple.cpp.o:/var/www/html/code/lib/SuplaDeviceExtensions/src/supla/sensor/MAXThermocouple.cpp:25: first defined here
collect2: error: ld returned 1 exit status
xxxxxxxxxxxxxxxxxx
BOARD esp8266:esp8266:generic:eesz=1M64,xtal=160
BOARD_NAME
TEMPLATE_BOARD
TEMPLATE_JSON
JSON_DEFINITION
OPTIONS -DATOMIC_FS_UPDATE -DBEARSSL_SSL_BASIC -DSUPLA_CONFIG -DSUPLA_DHT11 -DSUPLA_ENABLE_GUI -DSUPLA_OTA
local
Jednak nie działa.
Been thanked: 5 times
Mam już poprawkę, ale czekam na zaktualizowanie buildera do nowych płytek :)
klimasstudio
local wrote: Sun Mar 13, 2022 6:46 pm Jednak nie działa.
No właśnie że niestety też nie... próbowałem też inne warianty i też nie.
Chciałem update zrobić bo mam w jednej lokalizacji stare wersje nie odporne na "Advenced IP scanera" a chciałem poszukać na jakich IP są moduły i skończyło się tym że wszystkie suple odciałem :D musiałem APka restartować aby zatrybiły.
Zostaje poczekać albo poprosić kogoś ktoposiada na dtysku wygenerowaną binarke pod EP8266 + DHT11 :mrgreen:
wygeneruj sobie soft który posiada już builder np. Sensor DHT11 + Sensor DHT22.
DanteX
Ja też miałem dziś problem z wygenerowaniem pliku dla DHT 11, OLED 1,3, Wemos.
Skorzystałem z https://gui-generic-builder.supla.io/test.php i udało się wygenerować.
DanteX wrote: Sun Mar 13, 2022 7:27 pm Ja też miałem dziś problem z wygenerowaniem pliku dla DHT 11, OLED 1,3, Wemos.
tam jest wersja z przed kilku miesięcy.
klimasstudio
Tak tak też to sprawdzałem ale się zczaiłem że tam też wersja podatna na "Advenced IP scanera" :D
Goral64
Has thanked: 2 times
krycha88 wrote: Sun Mar 13, 2022 6:48 pm Mam już poprawkę, ale czekam na zaktualizowanie buildera do nowych płytek :)
Niestety, będzie obsuwa w temacie :(
Return to “GUI Generic”
