#include <FS.h> // ---- esp board manager 2.4.2 --- iwip Variant V2 higher Bandwidth -- 160Mhz
#include <OneWire.h>
#include <EEPROM.h>
#include <ESP8266WiFi.h>
#define CUSTOMSUPLA_CPP
#include <CustomSupla.h>
#include <DNSServer.h>
#include <WiFiManager.h>
#include <ArduinoJson.h> //--------- https://github.com/bblanchon/ArduinoJson/tree/v5.13.2 ------
#include <Ticker.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#include <ESP8266HTTPUpdateServer.h>
#include <Button3.h>
extern "C"
#include "user_interface.h"
//#define D0 16 //no internal pullup resistor
//#define D1 5
//#define D2 4
//#define D3 0 //must not be pulled low during power on/reset, toggles value during boot
//#define D4 2 //must not be pulled low during power on/reset, toggles value during boot
//#define D5 14
//#define D6 12
//#define D7 13
//#define D8 15 //must not be pulled high during power on/reset
//#include "SSD1306Wire.h" //----- 0.96 Oled --- https://github.com/ThingPulse/esp8266-oled-ssd1306
//SSD1306Wire display(0x3c, 0, 2); // D3-SDA D4-SCL ----- 0.96 Oled ---
#include "SH1106Wire.h" //----- 1.3 Oled ---
SH1106Wire display(0x3c, 0, 2); // D3-SDA D4-SCL ----- 1.3 Oled ---
#define button_PIN 12
#define button2_PIN 14 // D5
#define TRIGGER_PIN 12 // D6
#define relay1 13 // D7
#define relay2 101 //
#define relay3 15 // D8
#define sensor1 5 // D1
#define sensor2 4 // D2
#define ONE_WIRE_BUS 3 // RX
OneWire oneWire(ONE_WIRE_BUS);
DeviceAddress Thermometer_1, Thermometer_2;
int resolution = 12;
WiFiClient client;
WiFiManager wifiManager;
ESP8266WebServer httpServer(81);
ESP8266HTTPUpdateServer httpUpdater;
Button3 button = Button3(button_PIN);
Button3 button2 = Button3(button2_PIN);
const char* host = "supla12bar";
Ticker btn_loop;
unsigned long wifi_checkDelay = 30000;
unsigned long wifimilis;
int C_W_state = HIGH;
int last_C_W_state = HIGH;
unsigned long time_last_C_W_change = 0;
long C_W_delay = 10000; // config delay 10 seconds
int MPX_mtbs = 5000; // mean time between MPX update
int mpx_zeroCal ;
unsigned long MPX_lasttime;
double MPX_Value = 0;
double MPV_Send = -1;
double temp_1;
double temp_2;
int Term_Tipo ;
int MPX_zero_offset = 0;
int mpx_Compensation =0;
int s;
int timeout = 120;
char Supla_server[40];
char Location_id[15];
char Location_Pass[34];
char MPX_Compensation[5];
char Supla_name[51];
char update_path[21] = "/update";
char update_username[21];
char update_password[21];
char termtipo[5];
byte mac[6];
bool pr_wifi = true;
bool pr_supla = true;
bool initialConfig = false;
bool manual = false;
bool dimm = false;
unsigned long dimm_milis ;
WiFiManagerParameter custom_field;
const uint8_t logo32_glcd_bmp[] PROGMEM = //logo supla 32
0x00,0x00,0x00,0x00,0xC0,0x1F,0x00,0x00,0xE0,0x7F,0x00,0x00,
0xF0,0x70,0x00,0x00,0x30,0xE0,0x00,0x00,0x38,0xC0,0x00,0x00,
0x18,0xC0,0x01,0x00,0x18,0xC0,0x01,0x00,0x38,0xC0,0x00,0x00,
0x38,0xE0,0x01,0x00,0x70,0xF0,0x07,0x00,0xE0,0x7F,0x0E,0x00,
0xC0,0x3F,0x38,0x00,0x00,0x1F,0xE0,0x0F,0x00,0x18,0xC0,0x1F,
0x00,0x18,0xC0,0x30,0x00,0x18,0xC0,0x30,0x00,0x30,0xC0,0x30,
0x00,0x30,0x80,0x1F,0x00,0x30,0xC0,0x0F,0x00,0x20,0x60,0x00,
0x00,0x60,0x20,0x00,0x00,0x60,0x30,0x00,0x00,0x40,0x18,0x00,
0x00,0xC0,0x0D,0x00,0x00,0xC0,0x07,0x00,0x00,0x60,0x04,0x00,
0x00,0x20,0x0C,0x00,0x00,0x20,0x0C,0x00,0x00,0x60,0x06,0x00,
0x00,0xC0,0x03,0x00,0x00,0x00,0x00,0x00
const uint8_t logo16_wifi_bmp[] PROGMEM = //logo wifi 16
0x00,0x00,0x00,0x00,0xE0,0x07,0x38,0x1C,0xC4,0x23,0x72,0x4E,
0x08,0x10,0xE4,0x27,0x10,0x0C,0x90,0x09,0x40,0x02,0x60,0x06,
0x40,0x02,0x80,0x01,0x00,0x00,0x00,0x00
const uint8_t logo16_supla_bmp[] PROGMEM = //logo supla 16
0x30,0x00,0x7C,0x00,0xC4,0x00,0x86,0x00,0x84,0x00,0xDC,0x03,
0x78,0x36,0x60,0x78,0x40,0x48,0x40,0x38,0x40,0x04,0x80,0x06,
0x80,0x03,0x40,0x02,0xC0,0x03,0x00,0x01
const uint8_t logosupla24[] PROGMEM = //logo supla 24
0x00,0x00,0x00,0xF0,0x03,0x00,0xF8,0x07,0x00,0x1C,0x0C,0x00,
0x0C,0x0C,0x00,0x0C,0x0C,0x00,0x0C,0x0C,0x00,0x1C,0x1E,0x00,
0xF8,0x7F,0x00,0xF0,0xC3,0x01,0x00,0x03,0x1F,0x00,0x02,0x36,
0x00,0x02,0x22,0x00,0x02,0x36,0x00,0x06,0x1E,0x00,0x04,0x01,
0x00,0x84,0x00,0x00,0x4C,0x00,0x00,0x7C,0x00,0x00,0x3C,0x00,
0x00,0x66,0x00,0x00,0x66,0x00,0x00,0x3C,0x00,0x00,0x18,0x00
void get_MPX(){
int val = 0;
for(int i = 0; i < 10; i++) {
val += analogRead(A0);
delay(1);
val = val / 10;
MPX_Value = map(val,MPX_zero_offset,(mpx_Compensation+MPX_zero_offset),0,1000) / 83.3;
yield();
Serial.print("bar: ");
Serial.println(MPX_Value,2);
if (MPX_Value != MPV_Send){
MPV_Send = MPX_Value;
TH_Overlay();
void Btn_loop(){
button.loop();
button2.loop();
CustomSupla.iterateOfline();
void saveConfigCallback () {
shouldSaveConfig = true;
display.clear();
display.setContrast(100, 241, 64);
display.setTextAlignment(TEXT_ALIGN_CENTER);
display.setFont(ArialMT_Plain_10);
display.drawString(64, 16, "wifi config connect");
display.drawString(64, 28, "to wifi hotspot");
display.setFont(ArialMT_Plain_16);
display.drawString(64, 44, "Supla_12Bar");
display.display();
btn_loop.detach();
WiFiManagerParameter custom_Supla_server("server", "Supla server", Supla_server, 40);
WiFiManagerParameter custom_Location_id("ID", "Location_id", Location_id, 15);
WiFiManagerParameter custom_Location_Pass("Password", "Location_Pass", Location_Pass, 34 );
WiFiManagerParameter custom_MPX_Compensation("Compensation", "Compensation 500-1000", MPX_Compensation, 5,"required");
WiFiManagerParameter custom_Supla_name("name", "Supla Device Name", Supla_name, 51,"required");
WiFiManagerParameter custom_update_username("updateUsername", "update username", update_username, 21,"required");
WiFiManagerParameter custom_update_password("updatePassword", "update password", update_password, 21,"required");
const char* custom_radio_str = "<br><div style='text-align:center; width:100%; padding:0;'><label for='customfieldid'>DS18B20 </label><input type='radio' name='customfieldid' value='0' checked> 1 - 2<input type='radio' name='customfieldid' value='1'> 2 - 1</div>";
new (&custom_field) WiFiManagerParameter(custom_radio_str); // custom html input
wifiManager.setBreakAfterConfig(true);
wifiManager.setSaveParamsCallback(saveParamCallback);
wifiManager.addParameter(&custom_Location_id);
wifiManager.addParameter(&custom_Location_Pass);
wifiManager.addParameter(&custom_MPX_Compensation);
wifiManager.addParameter(&custom_Supla_name);
wifiManager.addParameter(&custom_update_username);
wifiManager.addParameter(&custom_update_password);
wifiManager.addParameter(&custom_field);
wifiManager.setCustomHeadElement("<style>html{ background-color: #01DF3A;}</style><div class='s'><svg version='1.1' id='l' x='0' y='0' viewBox='0 0 200 200' xml:space='preserve'><path d='M59.3,2.5c18.1,0.6,31.8,8,40.2,23.5c3.1,5.7,4.3,11.9,4.1,18.3c-0.1,3.6-0.7,7.1-1.9,10.6c-0.2,0.7-0.1,1.1,0.6,1.5c12.8,7.7,25.5,15.4,38.3,23c2.9,1.7,5.8,3.4,8.7,5.3c1,0.6,1.6,0.6,2.5-0.1c4.5-3.6,9.8-5.3,15.7-5.4c12.5-0.1,22.9,7.9,25.2,19c1.9,9.2-2.9,19.2-11.8,23.9c-8.4,4.5-16.9,4.5-25.5,0.2c-0.7-0.3-1-0.2-1.5,0.3c-4.8,4.9-9.7,9.8-14.5,14.6c-5.3,5.3-10.6,10.7-15.9,16c-1.8,1.8-3.6,3.7-5.4,5.4c-0.7,0.6-0.6,1,0,1.6c3.6,3.4,5.8,7.5,6.2,12.2c0.7,7.7-2.2,14-8.8,18.5c-12.3,8.6-30.3,3.5-35-10.4c-2.8-8.4,0.6-17.7,8.6-22.8c0.9-0.6,1.1-1,0.8-2c-2-6.2-4.4-12.4-6.6-18.6c-6.3-17.6-12.7-35.1-19-52.7c-0.2-0.7-0.5-1-1.4-0.9c-12.5,0.7-23.6-2.6-33-10.4c-8-6.6-12.9-15-14.2-25c-1.5-11.5,1.7-21.9,9.6-30.7C32.5,8.9,42.2,4.2,53.7,2.7c0.7-0.1,1.5-0.2,2.2-0.2C57,2.4,58.2,2.5,59.3,2.5z M76.5,81c0,0.1,0.1,0.3,0.1,0.6c1.6,6.3,3.2,12.6,4.7,18.9c4.5,17.7,8.9,35.5,13.3,53.2c0.2,0.9,0.6,1.1,1.6,0.9c5.4-1.2,10.7-0.8,15.7,1.6c0.8,0.4,1.2,0.3,1.7-0.4c11.2-12.9,22.5-25.7,33.4-38.7c0.5-0.6,0.4-1,0-1.6c-5.6-7.9-6.1-16.1-1.3-24.5c0.5-0.8,0.3-1.1-0.5-1.6c-9.1-4.7-18.1-9.3-27.2-14c-6.8-3.5-13.5-7-20.3-10.5c-0.7-0.4-1.1-0.3-1.6,0.4c-1.3,1.8-2.7,3.5-4.3,5.1c-4.2,4.2-9.1,7.4-14.7,9.7C76.9,80.3,76.4,80.3,76.5,81z M89,42.6c0.1-2.5-0.4-5.4-1.5-8.1C83,23.1,74.2,16.9,61.7,15.8c-10-0.9-18.6,2.4-25.3,9.7c-8.4,9-9.3,22.4-2.2,32.4c6.8,9.6,19.1,14.2,31.4,11.9C79.2,67.1,89,55.9,89,42.6z M102.1,188.6c0.6,0.1,1.5-0.1,2.4-0.2c9.5-1.4,15.3-10.9,11.6-19.2c-2.6-5.9-9.4-9.6-16.8-8.6c-8.3,1.2-14.1,8.9-12.4,16.6C88.2,183.9,94.4,188.6,102.1,188.6z M167.7,88.5c-1,0-2.1,0.1-3.1,0.3c-9,1.7-14.2,10.6-10.8,18.6c2.9,6.8,11.4,10.3,19,7.8c7.1-2.3,11.1-9.1,9.6-15.9C180.9,93,174.8,88.5,167.7,88.5z'/></svg>");
wifiManager.setMinimumSignalQuality();
wifiManager.setConfigPortalTimeout(timeout);
if (!wifiManager.startConfigPortal("Supla_12Bar")) { // ----wifi configuration ap name---
Serial.println("Not connected to WiFi but continuing anyway.");
} else {
Serial.println("connected...yeey :)"); //if you get here you have connected to the WiFi
strcpy(Location_id, custom_Location_id.getValue());
strcpy(Location_Pass, custom_Location_Pass.getValue());
strcpy(MPX_Compensation, custom_MPX_Compensation.getValue());
strcpy(Supla_name, custom_Supla_name.getValue());
strcpy(update_username, custom_update_username.getValue());
strcpy(update_password, custom_update_password.getValue());
String getParam(String name){
String value;
if(wifiManager.server->hasArg(name)) {
value = wifiManager.server->arg(name);
if (value == "1"){ Term_Tipo = 1;} else { Term_Tipo = 0;}
return value;
void saveParamCallback(){
Serial.println("[CALLBACK] saveParamCallback fired");
Serial.println("PARAM customfieldid = " + getParam("customfieldid"));
itoa(Term_Tipo ,termtipo ,10) ;
void TH_Overlay() {
display.clear();
display.setFont(Dialog_plain_36);
display.setTextAlignment(TEXT_ALIGN_RIGHT);
display.drawString(75, 10, String(MPX_Value, 1));
display.setFont(ArialMT_Plain_24);
display.drawString(114, 22, "bar");
display.drawString(64, 48, String(temp_1, 1) + "ºC " + " " + String(temp_2, 1) + "ºC");
if (pr_wifi == false){
display.drawString(42, 0, "Rssi " + String(WiFi.RSSI()) + " db");
if (s == 17){
display.drawXbm(85, 0, 24, 24, logosupla24);// ------------------------------------------------ oled supla ok --------
}else{
display.drawString(110, 0, "E" + String(s));
display.display();
double t = -275;
switch(channelNumber)
case 0:
return MPV_Send;
break;
case 1:
if (Term_Tipo){
t = sensors.getTempCByIndex(1);
} else {
t = sensors.getTempCByIndex(0);
temp_1 = t;
Serial.print("DS18B20 1 Temp: ");
Serial.println(t);
break;
case 2:
if (Term_Tipo){
} else {
temp_2 = t;
Serial.print("DS18B20 2 Temp: ");
Serial.println(t);
sensors.requestTemperatures();
break;
return t;
int supla_DigitalRead(int channelNumber, uint8_t pin) {
if (channelNumber == 4){
manual = digitalRead(relay1);
return manual;
}else{
return digitalRead(pin);
void suplaDigitalWrite(int channelNumber, uint8_t pin, uint8_t val) {
if ( channelNumber == 4 ) {
digitalWrite(relay1, val);
manual = val;
TH_Overlay();
return;
if ( channelNumber == 3 ) {
if (manual == false){
return;
}else {
digitalWrite(pin, val);
TH_Overlay();
return;
return;
void status_func(int status, const char *msg) {
if (s != status){
s=status;
Serial.print("status: ");
Serial.println(s);
void printAddress(DeviceAddress deviceAddress)
for (uint8_t i = 0; i < 8; i++)
if (deviceAddress[i] < 16) Serial.print("0");
Serial.print(deviceAddress[i], HEX);
Serial.println("");
void setup() { // ------------------------ Setup --------------------------
wifi_set_sleep_type(NONE_SLEEP_T);
Serial.begin(115200, SERIAL_8N1, SERIAL_TX_ONLY, 1);
delay(1000);
EEPROM.begin(128);
pinMode(TRIGGER_PIN, INPUT_PULLUP);
if (WiFi.SSID()==""){
initialConfig = true;
display.init();
display.flipScreenVertically();
display.clear();
display.drawString(33, 40, "SUPLA");
display.drawXbm(0, 16, 32, 32,logo32_glcd_bmp );
display.display();
delay(2000);
button.setClickHandler(click);
button.setLongClickHandler(longClick);
button.setQuintleClickHandler(quintleClick);
button2.setClickHandler(click2);
button2.setLongClickHandler(longClick2);
display.clear();
display.drawString(64, 0, "mounting FS...");
display.display();
if (SPIFFS.begin()) {
Serial.println("mounted file system");
if (SPIFFS.exists("/config.json")) {
Serial.println("reading config file");
File configFile = SPIFFS.open("/config.json", "r");
if (configFile) {
Serial.println("opened config file");
DynamicJsonBuffer jsonBuffer;
Serial.println(jsonBuffer.size());
//json.printTo(Serial);
if (json.success()) {
Serial.println("\nparsed json");
if (json.containsKey("Supla_server")) strcpy(Supla_server, json["Supla_server"]);
if (json.containsKey("Location_id")) strcpy(Location_id, json["Location_id"]);
if (json.containsKey("Location_Pass")) strcpy(Location_Pass, json["Location_Pass"]);
if (json.containsKey("MPX_Compensation")) strcpy(MPX_Compensation, json["MPX_Compensation"]);
if (json.containsKey("Supla_name")) strcpy(Supla_name, json["Supla_name"]);
if (json.containsKey("update_username")) strcpy(update_username, json["update_username"]);
if (json.containsKey("update_password")) strcpy(update_password, json["update_password"]);
mpx_Compensation = String(MPX_Compensation).toInt();
if (json.containsKey("termtipo")) strcpy(termtipo, json["termtipo"]);
Term_Tipo = (String(termtipo).toInt());
Serial.print("Compensation: ");
Serial.println(mpx_Compensation);
} else {
Serial.println("failed to load json config");
} else {
Serial.println("failed to mount FS");
MPX_zero_offset = EEPROM.read(1);
Serial.print("Read zero offset: ");
Serial.println(MPX_zero_offset);
sensors.begin();
Serial.println(".");
sensors.begin();
Serial.print("Locating devices...");
Serial.print("Found ");
Serial.print(sensors.getDeviceCount(), DEC);
Serial.println(" devices.");
oneWire.reset_search();
if (!oneWire.search(Thermometer_1)) Serial.println("Unable to find address for Thermometer 1"); else printAddress(Thermometer_1);
if (!oneWire.search(Thermometer_2)) Serial.println("Unable to find address for Thermometer 2"); else printAddress(Thermometer_2);
sensors.setResolution(Thermometer_1, resolution);
sensors.setResolution(Thermometer_2, resolution);
sensors.setWaitForConversion(false);
uint8_t mac[WL_MAC_ADDR_LENGTH];
WiFi.macAddress(mac);
char GUID[SUPLA_GUID_SIZE] = {mac[WL_MAC_ADDR_LENGTH - 6], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 3],
mac[WL_MAC_ADDR_LENGTH - 2], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 1], mac[WL_MAC_ADDR_LENGTH - 2],
mac[WL_MAC_ADDR_LENGTH - 3], mac[WL_MAC_ADDR_LENGTH - 4], mac[WL_MAC_ADDR_LENGTH - 5], mac[WL_MAC_ADDR_LENGTH - 6]};
CustomSupla.addDS18B20Thermometer();
CustomSupla.addRelay(relay1, false);
CustomSupla.addRelay(relay2, false);
CustomSupla.addRelay(relay3, false);
CustomSupla.addSensorNO(sensor1, true);
CustomSupla.addSensorNO(sensor2, true);
CustomSupla.setStatusFuncImpl(&status_func); // ----------------------------- Status -----------------------------
CustomSupla.setDigitalReadFuncImpl(&supla_DigitalRead); // ------Send Value to server -------
CustomSupla.setDigitalWriteFuncImpl(&suplaDigitalWrite); // ------- Read Value from server -------
CustomSupla.setName(Supla_name); // Supla device name
wifi_station_set_hostname(Supla_name);
int LocationID = atoi(Location_id);
CustomSupla.begin(GUID, // Global Unique Identifier
mac, // Ethernet MAC address
Supla_server, // SUPLA server address
LocationID, // Location ID
Location_Pass); // Location Password
WiFi.mode(WIFI_STA);
//btn_loop.attach_ms(40, Btn_loop);
dimm_milis = millis() + 15000;
void loop() {
if (WiFi.status() == WL_CONNECTED)
httpServer.handleClient();
if (s == 17){
button.loop();
button2.loop();
if (pr_supla == true){
btn_loop.detach();
pr_supla = false;
Serial.println("Supla connected");
}else{
delay(25);
if (pr_supla == false){
pr_supla = true;
Serial.println("Not connected");
btn_loop.attach_ms(80, Btn_loop);
if (millis() > MPX_lasttime + MPX_mtbs) { //--------------MPX callback--------------------
get_MPX();
MPX_lasttime = millis();
int C_W_read = digitalRead(TRIGGER_PIN);{
if (C_W_read != last_C_W_state) {
time_last_C_W_change = millis();
if ((millis() - time_last_C_W_change) > C_W_delay) {
if (C_W_read != C_W_state) {
Serial.println("Triger sate changed");
C_W_state = C_W_read;
if (C_W_state == LOW) {
ondemandwifiCallback () ;
last_C_W_state = C_W_read;
if (initialConfig) {
if (shouldSaveConfig) {
Serial.println("saving config");
json["Location_id"] = Location_id;
json["Location_Pass"] = Location_Pass;
json["MPX_Compensation"] = MPX_Compensation;
json["Supla_name"] = Supla_name;
json["update_username"] = update_username;
json["update_password"] = update_password;
json["termtipo"] = termtipo;
File configFile = SPIFFS.open("/config.json", "w");
if (!configFile) {
Serial.println("failed to open config file for writing");
json.prettyPrintTo(Serial);
json.printTo(configFile);
configFile.close();
display.clear();
display.drawString(64, 0, "config saved");
display.display();
ESP.restart();
delay(5000);
if ((WiFi.status() != WL_CONNECTED) && ( pr_wifi == false)) {
WiFi_up();
pr_wifi = true;
else if ((WiFi.status() == WL_CONNECTED) && (pr_wifi)){
Serial.println("");
Serial.println("CONNECTED");
Serial.print("local IP: ");
Serial.print("subnetMask: ");
Serial.print("gatewayIP: ");
long rssi = WiFi.RSSI();
Serial.print("Signal Strength (RSSI): ");
Serial.print(rssi);
Serial.println(" dBm");
pr_wifi = false;
MDNS.begin(host);
httpUpdater.setup(&httpServer,update_path, update_username, update_password);
httpServer.begin();
MDNS.addService("http", "tcp", 81);
Serial.printf("HTTPUpdateServer ready! Open http://%s.local:81%s in your browser and login with username '%s' and password '%s'\n", host, update_path, update_username, update_password);
CustomSupla.iterate();
delay(25);
if (millis() > dimm_milis){
if (dimm == false){
display.setContrast(50, 50, 30);
display.display();
dimm = true ;
dimm_milis = millis() + 15000 ;
// Supla.org ethernet layer
if ( size > 0 ) {
return -1;
return client.connected();
client.stop();
CustomSuplaCallbacks supla_arduino_get_callbacks(void) {
CustomSuplaCallbacks cb;
cb.get_temperature = &get_temperature;
return cb;
void click(Button3& btn) {
display.setContrast(100, 230, 60);
dimm = false;
TH_Overlay();
void longClick(Button3& btn) {
if (dimm == true){
dimm = false;
TH_Overlay();
if (digitalRead(relay3) == 1 ) {
CustomSupla.relayOff(5);
Serial.println("BTN Switsh off relay 2");
} else {
CustomSupla.relayOn(5, 0);
Serial.println("BTN Switsh on relay 2");
void quintleClick(Button3& btn) {
int val = 0;
delay(1);
val = val / 10;
MPX_zero_offset = val;
display.clear();
display.drawString(64, 20, "MPX Call..");
display.display();
dimm = false;
Serial.print("Write zero offset: ");
EEPROM.write(1, MPX_zero_offset);
EEPROM.commit();
delay (3000);
TH_Overlay();
void longClick2(Button3& btn) {
CustomSupla.relayOn(3, 1000);
Serial.println("BTN Switsh on 1 second");
void click2(Button3& btn) {
if (dimm == true){
dimm = false;
TH_Overlay();
if (digitalRead(relay1) == 1 ) {
CustomSupla.relayOff(4);
Serial.println("BTN Switsh off relay");
} else {
CustomSupla.relayOn(4, 0);
Serial.println("BTN Switsh on relay");
void WiFi_up(){ // conect to wifi
if (millis() > wifimilis) {
WiFi.begin();
Serial.println("CONNECTING WIFI");
wifimilis = (millis() + wifi_checkDelay) ;
