i cant work it
odin56
hi. i was trying test supla and doing exatly same like manual but still not work... i have a rasperry pi 3b and android phone. Look a pictures:
have any ideas? what i was doing wrong?
Hi. Current sd card image doesn't support raspberry pi 3. You have to install supla software manually. Please type few commands at console:
cd
git clone https://github.com/SUPLA/raspberry
rm raspberry/ext01/boot/config.txt
sudo cp -r raspberry/ext01/* /
sudo update-rc.d supla-dev defaults
sudo nano /boot/location.txt
sudo /etc/init.d/supla-dev start
odin56
I installed noobs linux and open console and adding lines and it download supla directorys. So what i need to do next?
Yes, you should use dedicated image of SD Card contained Linux. Then you can install supla software manually.
odin56
Command line say "supla start ok" but still my phone does not regonize it... so could you please do manual for noobs or video.
Please check last state
cat /boot/last_state.txt
odin56
it say "registered and ready"
It looks like the device is connected to the server.
Please login at cloud.supla.org and check if devices status is "CONNECTED".
Probably you should select channel functions at cloud.supla.org.
odin56
Yes. Now i got it online, Thanks man. 8-)
Your welcome
Return to “Help”
