hello!
how can i change the statut of the relay on supla when i use push button?
controle realy using supla app and button
caps_t
Card esp8266
software arduino
this is my code every thing is working except when i use the push button there is no update on supla app ( imean when i on the relay using the push button it geos on but on supla app it still have the off icone)
software arduino
#include <WiFiManager.h>
#include <SuplaDevice.h>
#include <supla/sensor/DHT.h>
#include <supla/condition.h>
// Choose proper network interface for your card:
#ifdef ARDUINO_ARCH_AVR
// Arduino Mega with EthernetShield W5100:
#include <supla/network/ethernet_shield.h>
// Ethernet MAC address
uint8_t mac[6] = {0x00, 0x01, 0x02, 0x03, 0x04, 0x05};
Supla::EthernetShield ethernet(mac);
// Supla::ENC28J60 ethernet(mac);
#elif defined(ARDUINO_ARCH_ESP8266) || defined(ARDUINO_ARCH_ESP32)
// ESP8266 and ESP32 based board:
Supla::ESPWifi wifi("", "");
#endif
#define DHT1PIN 5
#define DHT1TYPE DHT11
/*#define DHT2PIN 25
#define DHT2TYPE DHT22*/
void setup() {
pinMode(14,OUTPUT); // led pin as output
pinMode(4,INPUT_PULLUP); // d2 as input with internai pullup enabled
Serial.begin(115200);
WiFiManager wm;
wm.resetSettings();
bool res;
res = wm.autoConnect("ESP8266","xxxx");
if(!res) {
Serial.println("Failed to connect :(");
else {
Serial.println("connected... :)");
char GUID[SUPLA_GUID_SIZE] ={xxxx};
char AUTHKEY[SUPLA_AUTHKEY_SIZE] = {xxxx};
// CHANNEL0 - DHT22 Sensor
new Supla::Sensor::DHT(DHT1PIN, DHT1TYPE);
new Supla::Control::Relay(14,0);
new Supla::Control::Relay(12,0);
"xxxx.supla.org", // SUPLA server address
"[email protected]", // Email address used to login to Supla Cloud
AUTHKEY); // Authorization key
int buttonstate1, relaysatate1, buttonstate2, relaysatate2;
void loop() {
SuplaDevice.iterate();
buttonstate1 = digitalRead(4);
relaysatate1 = digitalRead(14);
buttonstate2 = digitalRead(0);
relaysatate2 = digitalRead(12);
if(buttonstate1 == LOW) // if pressed
delay(500);
if (relaysatate1 == LOW)
digitalWrite(14,HIGH);
else
digitalWrite(14,LOW);
if(buttonstate2 == LOW) // if pressed
delay(500);
if (relaysatate2 == LOW)
digitalWrite(12,HIGH);
else
digitalWrite(12,LOW);
- Has thanked: 134 times
The easiest way is to use components provided by SuplaDevice library. Beside of Relay, SuplaDevice also have Button class. You can also manage Wi-Fi and Supla server settings via web interface that is available.caps_t wrote: Mon Dec 12, 2022 7:26 pm Card esp8266
software arduino
Please take a look at WebInterface example. It also contain some RollerShutter related config, but it should be ease to remove them.
https://github.com/SUPLA/supla-device/b ... erface.ino
caps_t
thank you for your reply i tried to change your code and it didnt work
actually i want to do like this project
https://www.youtube.com/watch?v=4ywi2-nQy2o
What is not working?caps_t wrote: Tue Dec 13, 2022 12:03 am thank you for your reply i tried to change your code and it didnt work
BTW. if you'll reply to my message with a quote, then I'll be notified and I'll reply quicker
caps_t
klew wrote: Tue Dec 13, 2022 12:31 amWhat is not working?caps_t wrote: Tue Dec 13, 2022 12:03 am thank you for your reply i tried to change your code and it didnt work
BTW. if you'll reply to my message with a quote, then I'll be notified and I'll reply quicker![]()
i tried to modify your code but the relay goes on and off quicly.. and there areno change on supla app.
Please share your modified code herecaps_t wrote: Tue Dec 13, 2022 2:44 am
caps_t
this is my first code it work perfectly but there no change on the icone on supla app when i push botton (for exemple when i turn on the relay using the button the relay goes on but on supla app the icone show that relay is off)
#endif
#define DHT1PIN 5
void setup() {
WiFiManager wm;
wm.resetSettings();
bool res;
if(!res) {
else {
char GUID[SUPLA_GUID_SIZE] ={deleted };
char AUTHKEY[SUPLA_AUTHKEY_SIZE] = {deleted };
"xxxxx.supla.org", // SUPLA server address
void loop() {
else
else
}Code: Select all
#include <supla/control/action_trigger.h>
#include <supla/device/status_led.h>
#include <supla/storage/littlefs_config.h>
#include <supla/network/esp_web_server.h>
#include <supla/network/html/device_info.h>
#include <supla/network/html/protocol_parameters.h>
#include <supla/network/html/status_led_parameters.h>
#include <supla/network/html/wifi_parameters.h>
#include <supla/device/supla_ca_cert.h>
#include <supla/events.h>
uint8_t mac[6] = { 0x00, 0x01, 0x02, 0x03, 0x04, 0x05 };
#endif
#define DHT1PIN 5
Supla::Device::StatusLed statusLed(14, true); // inverted state
Supla::EspWebServer suplaServer;
// HTML www component (they appear in sections according to creation
// sequence)
Supla::Html::DeviceInfo htmlDeviceInfo(&SuplaDevice);
Supla::Html::WifiParameters htmlWifi;
Supla::Html::ProtocolParameters htmlProto;
Supla::Html::StatusLedParameters htmlStatusLed;
void setup() {
pinMode(14, OUTPUT); // led pin as output
pinMode(4, INPUT_PULLUP); // d2 as input with internai pullup enabled
WiFiManager wm;
wm.resetSettings();
bool res;
res = wm.autoConnect("ESP8266", "xxxx");
if (!res) {
} else {
char GUID[SUPLA_GUID_SIZE] = { deleted };
char AUTHKEY[SUPLA_AUTHKEY_SIZE] = { deleted };
new Supla::Control::Relay(14, 0);
new Supla::Control::Relay(12, 0);
// CH 0 - Roller shutter
auto rs1 = new Supla::Control::RollerShutter(14, 14, true);
auto rs2 = new Supla::Control::RollerShutter(12, 12, true);
// CH 1 - Relay
auto r1 = new Supla::Control::Relay(14);
// CH 2 - Relay
auto r2 = new Supla::Control::Relay(12);
// CH 3 - Action trigger
auto at1 = new Supla::Control::ActionTrigger();
// CH 4 - Action trigger
auto at2 = new Supla::Control::ActionTrigger();
// CH 5 - Action trigger
auto at3 = new Supla::Control::ActionTrigger();
// CH 6 - Action trigger
auto at4 = new Supla::Control::ActionTrigger();
// CH 7 - Action trigger
auto at5 = new Supla::Control::ActionTrigger();
// CH 8 - Action trigger
auto at6 = new Supla::Control::ActionTrigger();
// Buttons configuration
auto button1Open = new Supla::Control::Button(4, true, true);
auto button1Close = new Supla::Control::Button(4, true, true);
auto button2Open = new Supla::Control::Button(0, true, true);
auto button2Close = new Supla::Control::Button(0, true, true);
auto buttonCfgRelay1 = new Supla::Control::Button(14, true, true);
auto buttonCfgRelay2 = new Supla::Control::Button(12, true, true);
button1Open->addAction(Supla::OPEN_OR_STOP, *rs1, Supla::ON_PRESS);
button1Open->setHoldTime(100);
button1Open->setMulticlickTime(300);
button1Close->addAction(Supla::CLOSE_OR_STOP, *rs1, Supla::ON_PRESS);
button1Close->setHoldTime(100);
button1Close->setMulticlickTime(300);
button2Open->addAction(Supla::OPEN_OR_STOP, *rs2, Supla::ON_PRESS);
button2Open->setHoldTime(100);
button2Open->setMulticlickTime(300);
button2Close->addAction(Supla::CLOSE_OR_STOP, *rs2, Supla::ON_PRESS);
button2Close->setHoldTime(100);
button2Close->setMulticlickTime(300);
buttonCfgRelay1->configureAsConfigButton(&SuplaDevice);
buttonCfgRelay1->addAction(Supla::TOGGLE, r1, Supla::ON_CLICK_1);
buttonCfgRelay2->configureAsConfigButton(&SuplaDevice);
buttonCfgRelay2->addAction(Supla::TOGGLE, r2, Supla::ON_CLICK_1);
// Action trigger configuration
at1->setRelatedChannel(rs1);
at1->attach(button1Open);
at2->setRelatedChannel(rs1);
at2->attach(button1Close);
at3->setRelatedChannel(r1);
at3->attach(buttonCfgRelay1);
at4->setRelatedChannel(rs2);
at4->attach(button2Open);
at5->setRelatedChannel(rs2);
at5->attach(button2Close);
at6->setRelatedChannel(r2);
at6->attach(buttonCfgRelay2);
// configure defualt Supla CA certificate
SuplaDevice.setSuplaCACert(suplaCACert);
SuplaDevice.setSupla3rdPartyCACert(supla3rdCACert);
SuplaDevice.begin();
void loop() {
Don't add anything from your previous code.caps_t wrote: Tue Dec 13, 2022 1:40 pm i tried to add your code and this is the result ( i'm new on iot)
Just start with this example and remove items you don't need (like roller shutter).
Handling of WiFi SSID setting, Supla server setting is already part of this example.
Also handling of input/button is also already included.
